ABB80DHFR
ABB80DHFR
    SULLINS
    SMD
    CONN EDGE DUAL FMALE 160POS .050
ABB80DHFR 数据手册
8 7 4 5 6 REVISIONS _ _ B _ _ DHF _ -S_ _ _ _ F MATERIALS (INSULATOR / CONTACT) MODIFICATION R = BLACK PPS/PHOSPHOR BRONZE OMIT = WITHOUT MOLDED KEY, EX: 'RBB15DHFD' OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECS S# FOR MOLDED KEY (SEE DWG C13556 FOR S#, 'G' & 'H' DIMENSIONS) G = BLACK PA9T/PHOSPHOR BRONZE MOUNTING STYLE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECS D = FLUSH MOUNTING (PAGE 1) NUMBER OF POSITIONS (CONTACTS PER ROW) A = BLACK PPS/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECS 1 2 3 PART NUMBER CODING REV. ECO. NO C 2098 DATE BY 1/5/2010 JH 2919 DESCRIPTION REMOVED "-S621" FROM P/N CODING, PCB LAYOUT DIM .185" MAX (WAS .185" MIN), .315" MIN (WAS .315" MAX), CORRECT NOTES 8 & 9. ADD CONTACT GAP DIM, TOL TO INSULATOR WIDTH, UPDATE DWG FORMAT D 2/13/2014 NC E 4412 ADD MOLDED KEY OPTIONS 8/6/2021 PL N = NO MOUNTING EARS T = FLUSH MOUNTING WITH #4-40 THREADED INSERT R = BOARD LOCK PLATING ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE CONTACT SURFACE TERMINATION B = .000010" GOLD .000100" PURE TIN, MATTE C = .000030" GOLD .000100" PURE TIN, MATTE J = BLACK PA9T/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECS (CONSULT FACTORY FOR OTHER MATERIALS) E D E E B A FIRST POSITION INDICATOR 2X .075 1.91 SEE NOTE 13 .125 3.18 .050 1.27 D F C D .030 0.76 .370 A +.005 +0.13 9.40 - .015 - 0.38 .300 7.62 INSERTION DEPTH .250 6.35 .610 15.49 .010 A .018 0.46 X 0.12[0.30] .060 1.52 .100±.025 2.54±0.64 TAIL LENGTH C _ _B_ _DHFD SECTION A-A .040 1.02 .050 1.27 C .185 4.70 MAX 2X .125 3.18 FOR (D) AND (T) MTG'S B A NOTES: 2X .096 2.44 1. INSULATOR MATERIAL: SEE PART NUMBER CODING FOR (R) MTG 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 300 VAC 8. CURRENT RATING: 1 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03 15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 16. MODIFICATION: SEE PART NUMBER CODING 8 7 6 5 B A F D .315 8.00 MIN RECOMMENDED PCB LAYOUT CUSTOMER COPY Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 4/28/2006 HT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 3 2 _ _B_ _DHF_-S_ _ _ _ CAGE CODE 54453 SCALE: 2:1 4 A EDGECARD, .050 CC, HP DWG. NO. C10708 REV E SHEET 1 OF 3 1 FILE NAME: C10708, _ _B_ _DHF_-OMIT, S_ _ _ _ STD KEY IN POSITION, KEY BETWEEN POSITIONS 8 7 4 5 6 D 1 2 3 2X #4-40 THREADED INSERTS F F .134±.015 3.40±0.38 .110 2.79 C E E F (BOARD LOCK) _ _B_ _DHFT _ _B_ _DHFN .026±.002 0.66±0.05 MOLDED KEY IN POSITION D .024±.002 0.61±0.05 MOLDED KEY BETWEEN POSITIONS G C .025 0.64 _ _B_ _DHFR D H C B B MOLDED KEY BETWEEN POSITIONS SCALE 4:1 ('D' MOUNTING AS SHOWN FOR EXAMPLE) MOLDED KEY IN POSITION SCALE 4:1 ('D' MOUNTING AS SHOWN FOR EXAMPLE) CUSTOMER COPY Pb A RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 4/28/2006 HT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 7 6 5 4 3 2 _ _B_ _DHF_-S_ _ _ _ CAGE CODE 54453 SCALE: 2:1 8 A EDGECARD, .050 CC, HP DWG. NO. C10708 REV E SHEET 2 OF 3 1 FILE NAME: C10708, _ _B_ _DHF_-OMIT, S_ _ _ _ STD KEY IN POSITION, KEY BETWEEN POSITIONS 8 PART NUMBER F E D C _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _B05DHF_ _B06DHF_ _B07DHF_ _B08DHF_ _B09DHF_ _B10DHF_ _B11DHF_ _B12DHF_ _B13DHF_ _B14DHF_ _B15DHF_ _B16DHF_ _B17DHF_ _B18DHF_ _B19DHF_ _B20DHF_ _B21DHF_ _B22DHF_ _B23DHF_ _B24DHF_ _B25DHF_ _B26DHF_ _B27DHF_ _B28DHF_ _B29DHF_ _B30DHF_ _B31DHF_ _B32DHF_ _B33DHF_ _B34DHF_ _B35DHF_ _B36DHF_ _B37DHF_ _B38DHF_ _B39DHF_ _B40DHF_ _B41DHF_ _B42DHF_ _B43DHF_ _B44DHF_ _B45DHF_ _B46DHF_ _B47DHF_ _B48DHF_ _B49DHF_ _B50DHF_ _B51DHF_ _B52DHF_ _B53DHF_ _B54DHF_ _B55DHF_ _B56DHF_ _B57DHF_ _B58DHF_ _B59DHF_ _B60DHF_ _B61DHF_ _B62DHF_ _B63DHF_ 7 NO OF POS. 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 A±.005[0.13] IN MM 0.200 5.08 0.250 6.35 0.300 7.62 0.350 8.89 0.400 10.16 0.450 11.43 0.500 12.70 0.550 13.97 0.600 15.24 0.650 16.51 0.700 17.78 0.750 19.05 0.800 20.32 0.850 21.59 0.900 22.86 0.950 24.13 1.000 25.40 1.050 26.67 1.100 27.94 1.150 29.21 1.200 30.48 1.250 31.75 1.300 33.02 1.350 34.29 1.400 35.56 1.450 36.83 1.500 38.10 1.550 39.37 1.600 40.64 1.650 41.91 1.700 43.18 1.750 44.45 1.800 45.72 1.850 46.99 1.900 48.26 1.950 49.53 2.000 50.80 2.050 52.07 2.100 53.34 2.150 54.61 2.200 55.88 2.250 57.15 2.300 58.42 2.350 59.69 2.400 60.96 2.450 62.23 2.500 63.50 2.550 64.77 2.600 66.04 2.650 67.31 2.700 68.58 2.750 69.85 2.800 71.12 2.850 72.39 2.900 73.66 2.950 74.93 3.000 76.20 3.050 77.47 3.100 78.74 B±.005[0.13] IN MM 0.300 7.62 0.350 8.89 0.400 10.16 0.450 11.43 0.500 12.70 0.550 13.97 0.600 15.24 0.650 16.51 0.700 17.78 0.750 19.05 0.800 20.32 0.850 21.59 0.900 22.86 0.950 24.13 1.000 25.40 1.050 26.67 1.100 27.94 1.150 29.21 1.200 30.48 1.250 31.75 1.300 33.02 1.350 34.29 1.400 35.56 1.450 36.83 1.500 38.10 1.550 39.37 1.600 40.64 1.650 41.91 1.700 43.18 1.750 44.45 1.800 45.72 1.850 46.99 1.900 48.26 1.950 49.53 2.000 50.80 2.050 52.07 2.100 53.34 2.150 54.61 2.200 55.88 2.250 57.15 2.300 58.42 2.350 59.69 2.400 60.96 2.450 62.23 2.500 63.50 2.550 64.77 2.600 66.04 2.650 67.31 2.700 68.58 2.750 69.85 2.800 71.12 2.850 72.39 2.900 73.66 2.950 74.93 3.000 76.20 3.050 77.47 3.100 78.74 3.150 80.01 3.200 81.28 WITHOUT MOLDED KEY B 4 5 6 C±.015[0.38] IN MM 0.490 12.45 0.540 13.72 0.590 14.99 0.640 16.26 0.690 17.53 0.740 18.80 0.790 20.07 0.840 21.34 0.890 22.61 0.940 23.88 0.990 25.15 1.040 26.42 1.090 27.69 1.140 28.96 1.190 30.23 1.240 31.50 1.290 32.77 1.340 34.04 1.390 35.31 1.440 36.58 1.490 37.85 1.540 39.12 1.590 40.39 1.640 41.66 1.690 42.93 1.740 44.20 1.790 45.47 1.840 46.74 1.890 48.01 1.940 49.28 1.990 50.55 2.040 51.82 2.090 53.09 2.140 54.36 2.190 55.63 2.240 56.90 2.290 58.17 2.340 59.44 2.390 60.71 2.440 61.98 2.490 63.25 2.540 64.52 2.590 65.79 2.640 67.06 2.690 68.33 2.740 69.60 2.790 70.87 2.840 72.14 2.890 73.41 2.940 74.68 2.990 75.95 3.040 77.22 3.090 78.49 3.140 79.76 3.190 81.03 3.240 82.30 3.290 83.57 3.340 84.84 3.390 86.11 D±.010[0.25] IN MM 0.776 19.71 0.826 20.98 0.876 22.25 0.926 23.52 0.976 24.79 1.026 26.06 1.076 27.33 1.126 28.60 1.176 29.87 1.226 31.14 1.276 32.41 1.326 33.68 1.376 34.95 1.426 36.22 1.476 37.49 1.526 38.76 1.576 40.03 1.626 41.30 1.676 42.57 1.726 43.84 1.776 45.11 1.826 46.38 1.876 47.65 1.926 48.92 1.976 50.19 2.026 51.46 2.076 52.73 2.126 54.00 2.176 55.27 2.226 56.54 2.276 57.81 2.326 59.08 2.376 60.35 2.426 61.62 2.476 62.89 2.526 64.16 2.576 65.43 2.626 66.70 2.676 67.97 2.726 69.24 2.776 70.51 2.826 71.78 2.876 73.05 2.926 74.32 2.976 75.59 3.026 76.86 3.076 78.13 3.126 79.40 3.176 80.67 3.226 81.94 3.276 83.21 3.326 84.48 3.376 85.75 3.426 87.02 3.476 88.29 3.526 89.56 3.576 90.83 3.626 92.10 3.676 93.37 E±.020[0.51] IN MM 1.090 27.69 1.140 28.96 1.190 30.23 1.240 31.50 1.290 32.77 1.340 34.04 1.390 35.31 1.440 36.58 1.490 37.85 1.540 39.12 1.590 40.39 1.640 41.66 1.690 42.93 1.740 44.20 1.790 45.47 1.840 46.74 1.890 48.01 1.940 49.28 1.990 50.55 2.040 51.82 2.090 53.09 2.140 54.36 2.190 55.63 2.240 56.90 2.290 58.17 2.340 59.44 2.390 60.71 2.440 61.98 2.490 63.25 2.540 64.52 2.590 65.79 2.640 67.06 2.690 68.33 2.740 69.60 2.790 70.87 2.840 72.14 2.890 73.41 2.940 74.68 2.990 75.95 3.040 77.22 3.090 78.49 3.140 79.76 3.190 81.03 3.240 82.30 3.290 83.57 3.340 84.84 3.390 86.11 3.440 87.38 3.490 88.65 3.540 89.92 3.590 91.19 3.640 92.46 3.690 93.73 3.740 95.00 3.790 96.27 3.840 97.54 3.890 98.81 3.940 100.08 3.990 101.35 F±.010[0.25] IN MM 0.350 8.89 0.400 10.16 0.450 11.43 0.500 12.70 0.550 13.97 0.600 15.24 0.650 16.51 0.700 17.78 0.750 19.05 0.800 20.32 0.850 21.59 0.900 22.86 0.950 24.13 1.000 25.40 1.050 26.67 1.100 27.94 1.150 29.21 1.200 30.48 1.250 31.75 1.300 33.02 1.350 34.29 1.400 35.56 1.450 36.83 1.500 38.10 1.550 39.37 1.600 40.64 1.650 41.91 1.700 43.18 1.750 44.45 1.800 45.72 1.850 46.99 1.900 48.26 1.950 49.53 2.000 50.80 2.050 52.07 2.100 53.34 2.150 54.61 2.200 55.88 2.250 57.15 2.300 58.42 2.350 59.69 2.400 60.96 2.450 62.23 2.500 63.50 2.550 64.77 2.600 66.04 2.650 67.31 2.700 68.58 2.750 69.85 2.800 71.12 2.850 72.39 2.900 73.66 2.950 74.93 3.000 76.20 3.050 77.47 3.100 78.74 3.150 80.01 3.200 81.28 3.250 82.55 PART NUMBER _ _B64DHF_ _ _B65DHF_ _ _B66DHF_ _ _B67DHF_ _ _B68DHF_ _ _B69DHF_ _ _B70DHF_ _ _B71DHF_ _ _B72DHF_ _ _B73DHF_ _ _B74DHF_ _ _B75DHF_ _ _B76DHF_ _ _B77DHF_ _ _B78DHF_ _ _B79DHF_ _ _B80DHF_ _ _B81DHF_ _ _B82DHF_ _ _B83DHF_ _ _B84DHF_ _ _B85DHF_ _ _B86DHF_ _ _B87DHF_ _ _B88DHF_ _ _B89DHF_ _ _B90DHF_ _ _B91DHF_ _ _B92DHF_ _ _B93DHF_ _ _B94DHF_ _ _B95DHF_ _ _B96DHF_ _ _B97DHF_ _ _B98DHF_ _ _B99DHF_ _ _B100DHF_ _ _B101DHF_ _ _B102DHF_ _ _B103DHF_ _ _B104DHF_ _ _B105DHF_ _ _B106DHF_ _ _B107DHF_ _ _B108DHF_ _ _B109DHF_ _ _B110DHF_ _ _B111DHF_ _ _B112DHF_ _ _B113DHF_ _ _B114DHF_ _ _B115DHF_ _ _B116DHF_ _ _B117DHF_ _ _B118DHF_ _ _B119DHF_ _ _B120DHF_ A±.005[0.13] IN MM 3.150 80.01 3.200 81.28 3.250 82.55 3.300 83.82 3.350 85.09 3.400 86.36 3.450 87.63 3.500 88.90 3.550 90.17 3.600 91.44 3.650 92.71 3.700 93.98 3.750 95.25 3.800 96.52 3.850 97.79 3.900 99.06 3.950 100.33 4.000 101.60 4.050 102.87 4.100 104.14 4.150 105.41 4.200 106.68 4.250 107.95 4.300 109.22 4.350 110.49 4.400 111.76 4.450 113.03 4.500 114.30 4.550 115.57 4.600 116.84 4.650 118.11 4.700 119.38 4.750 120.65 4.800 121.92 4.850 123.19 4.900 124.46 4.950 125.73 5.000 127.00 5.050 128.27 5.100 129.54 5.150 130.81 5.200 132.08 5.250 133.35 5.300 134.62 5.350 135.89 5.400 137.16 5.450 138.43 5.500 139.70 5.550 140.97 5.600 142.24 5.650 143.51 5.700 144.78 5.750 146.05 5.800 147.32 5.850 148.59 5.900 149.86 5.950 151.13 1 2 3 NO OF POS. 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 B±.005[0.13] IN MM 3.250 82.55 3.300 83.82 3.350 85.09 3.400 86.36 3.450 87.63 3.500 88.90 3.550 90.17 3.600 91.44 3.650 92.71 3.700 93.98 3.750 95.25 3.800 96.52 3.850 97.79 3.900 99.06 3.950 100.33 4.000 101.60 4.050 102.87 4.100 104.14 4.150 105.41 4.200 106.68 4.250 107.95 4.300 109.22 4.350 110.49 4.400 111.76 4.450 113.03 4.500 114.30 4.550 115.57 4.600 116.84 4.650 118.11 4.700 119.38 4.750 120.65 4.800 121.92 4.850 123.19 4.900 124.46 4.950 125.73 5.000 127.00 5.050 128.27 5.100 129.54 5.150 130.81 5.200 132.08 5.250 133.35 5.300 134.62 5.350 135.89 5.400 137.16 5.450 138.43 5.500 139.70 5.550 140.97 5.600 142.24 5.650 143.51 5.700 144.78 5.750 146.05 5.800 147.32 5.850 148.59 5.900 149.86 5.950 151.13 6.000 152.40 6.050 153.67 C±.015[0.38] IN MM 3.440 87.38 3.490 88.65 3.540 89.92 3.590 91.19 3.640 92.46 3.690 93.73 3.740 95.00 3.790 96.27 3.840 97.54 3.890 98.81 3.940 100.08 3.990 101.35 4.040 102.62 4.090 103.89 4.140 105.16 4.190 106.43 4.240 107.70 4.290 108.97 4.340 110.24 4.390 111.51 4.440 112.78 4.490 114.05 4.540 115.32 4.590 116.59 4.640 117.86 4.690 119.13 4.740 120.40 4.790 121.67 4.840 122.94 4.890 124.21 4.940 125.48 4.990 126.75 5.040 128.02 5.090 129.29 5.140 130.56 5.190 131.83 5.240 133.10 5.290 134.37 5.340 135.64 5.390 136.91 5.440 138.18 5.490 139.45 5.540 140.72 5.590 141.99 5.640 143.26 5.690 144.53 5.740 145.80 5.790 147.07 5.840 148.34 5.890 149.61 5.940 150.88 5.990 152.15 6.040 153.42 6.090 154.69 6.140 155.96 6.190 157.23 6.240 158.50 D±.010[0.25] E±.020[0.51] IN MM IN MM 3.726 94.64 4.040 102.62 3.776 95.91 4.090 103.89 3.826 97.18 4.140 105.16 3.876 98.45 4.190 106.43 3.926 99.72 4.240 107.70 3.976 100.99 4.290 108.97 4.026 102.26 4.340 110.24 4.076 103.53 4.390 111.51 4.126 104.80 4.440 112.78 4.176 106.07 4.490 114.05 4.226 107.34 4.540 115.32 4.276 108.61 4.590 116.59 4.326 109.88 4.640 117.86 4.376 111.15 4.690 119.13 4.426 112.42 4.740 120.40 4.476 113.69 4.790 121.67 4.526 114.96 4.840 122.94 4.576 116.23 4.890 124.21 4.626 117.50 4.940 125.48 4.676 118.77 4.990 126.75 4.726 120.04 5.040 128.02 4.776 121.31 5.090 129.29 4.826 122.58 5.140 130.56 4.876 123.85 5.190 131.83 4.926 125.12 5.240 133.10 4.976 126.39 5.290 134.37 5.026 127.66 5.340 135.64 5.076 128.93 5.390 136.91 5.126 130.20 5.440 138.18 5.176 131.47 5.490 139.45 5.226 132.74 5.540 140.72 5.276 134.01 5.590 141.99 5.326 135.28 5.640 143.26 5.376 136.55 5.690 144.53 5.426 137.82 5.740 145.80 5.476 139.09 5.790 147.07 5.526 140.36 5.840 148.34 5.576 141.63 5.890 149.61 5.626 142.90 5.940 150.88 5.676 144.17 5.990 152.15 5.726 145.44 6.040 153.42 5.776 146.71 6.090 154.69 5.826 147.98 6.140 155.96 5.876 149.25 6.190 157.23 5.926 150.52 6.240 158.50 5.976 151.79 6.290 159.77 6.026 153.06 6.340 161.04 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY 'N' OR 'R' MOUNTING ONLY F±.010[0.25] IN MM 3.300 83.82 3.350 85.09 3.400 86.36 3.450 87.63 3.500 88.90 3.550 90.17 3.600 91.44 3.650 92.71 3.700 93.98 3.750 95.25 3.800 96.52 3.850 97.79 3.900 99.06 3.950 100.33 4.000 101.60 4.050 102.87 4.100 104.14 4.150 105.41 4.200 106.68 4.250 107.95 4.300 109.22 4.350 110.49 4.400 111.76 4.450 113.03 4.500 114.30 4.550 115.57 4.600 116.84 4.650 118.11 4.700 119.38 4.750 120.65 4.800 121.92 4.850 123.19 4.900 124.46 4.950 125.73 5.000 127.00 5.050 128.27 5.100 129.54 5.150 130.81 5.200 132.08 5.250 133.35 5.300 134.62 5.350 135.89 5.400 137.16 5.450 138.43 5.500 139.70 5.550 140.97 5.600 142.24 5.650 143.51 5.700 144.78 5.750 146.05 5.800 147.32 5.850 148.59 5.900 149.86 5.950 151.13 6.000 152.40 6.050 153.67 6.100 154.94 WITH MOLDED KEY BETWEEN POSITIONS WITH MOLDED KEY IN POSITION F E D C B CUSTOMER COPY Pb A RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 4/28/2006 HT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 7 6 5 4 3 2 _ _B_ _DHF_-S_ _ _ _ CAGE CODE 54453 SCALE: 3:1 8 A EDGECARD, .050 CC, HP DWG. NO. C10708 REV E SHEET 3 OF 3 1 FILE NAME: C10708, _ _B_ _DHF_-OMIT, S_ _ _ _ STD KEY IN POSITION, KEY BETWEEN POSITIONS
ABB80DHFR 价格&库存
很抱歉,暂时无法提供与“ABB80DHFR”相匹配的价格&库存,您可以联系我们找货
