ACB80DHLD
ACB80DHLD
    SULLINS
    插件,P=1.27mm
    CONN EDGE DUAL FMALE 160POS .050
ACB80DHLD 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 1012 ORIGINAL RELEASE 04/28/06 HT B 1743 VJ C 2562 UPDATE DWG FORMAT TABULATE MATERIAL 9/12/2008 INCORPORATING "E" & "H" TO CODING CHART UPDATE RECOMMENDED PCB HOLE TO .030 (WAS .040), STANDOFF ON DWG VIEW, REMOVE 'E' & 'H' 3/14/2012 MTL OPTION F JH E E .050 1.27 2X .096 2.44 FOR (R) MTG D .250 6.35 E D B A FIRST POSITION INDICATOR .030 0.76 MIN A F D .075 1.91 SEE NOTE 13 .050 1.27 2X 2X .125 3.18 FOR (D) OR (T) MTGS. D PCB LAYOUT, CONNECTOR SIDE +.005 +0.13 .370 9.40 - .015 - 0.38 .125 3.18 C .030 0.76 A .300 7.62 INSERTION DEPTH C .610 15.49 C .250 6.35 .018[0.46] X .012[0.30] .060 1.52 A .250 6.35 _ _ B _ _ DHLD .160±.025 4.06±0.64 TAIL LENGTH SECTION A-A B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 300 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 1 AMP PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 8 7 6 5 CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 04/28/2006 HT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C CAGE CODE 54453 SCALE: 2:1 3 2 A EDGECARD, .050 CC, HP _ _ B _ _ DHL _ DWG. NO. C10709 SHEET 1 OF 3 1 REV C FILE NAME: C10709, _ _B_ _DHL_ 8 7 4 5 6 1 2 3 F F C E E .134 3.40 .025 0.64 .110 2.79 F _ _ B _ _ DHLN _ _ B _ _ DHLR D D 2X #4-40 THREADED INSERTS D C C _ _ B _ _ DHLT B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 04/28/2006 HT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C CAGE CODE 54453 SCALE: 2:1 3 2 A EDGECARD, .050 CC, HP _ _ B _ _ DHL _ DWG. NO. C10709 SHEET 2 OF 3 1 REV C FILE NAME: C10709, _ _B_ _DHL_ 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 04/28/2006 HT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C CAGE CODE 54453 SCALE: 2:1 3 2 A EDGECARD, .050 CC, HP _ _ B _ _ DHL _ DWG. NO. C10709 SHEET 3 OF 3 1 REV C FILE NAME: C10709, _ _B_ _DHL_
ACB80DHLD 价格&库存
很抱歉,暂时无法提供与“ACB80DHLD”相匹配的价格&库存,您可以联系我们找货
