3563TR
3563TR
    KEYSTONE
    SMD
    保险丝 夹 15 A 500V 1 电路 刀片 表面贴装型
3563TR 数据手册
“MINI” AUTOMOTIVE FUSE CLIPS & HOLDERS ® For .110 (2.8) × .032 (.80) MINI BLADE FUSES For Littelfuse Mini 297 or 997 series/Bussmann ATM series or equivalent VERTICAL FUSE ENTRY Thru Hole Mount Surface Mount AVAILABLE ON TAPE AND REEL MATERIAL: .016 (.41) Brass, Matte Tin Plate UL Current Rating: 15 Amps @ 500V AC .236 [6.0] .079 [2.00] • Low Profile .250 [6.4] • Low Profile .079 [2.00] ® .125 [3.2] .197 [5.0] .125 [3.2] Mounting Detail For Two Clips .091 [2.30] Pad Layout For Two Clips .244 [6.2] .236 [6.0] .091 [2.30] (2) PLS .400 [10.2] CAT. NO. 3563 (Bulk) .320 [8.2] “AUTO” FUSE CLIPS & HOLDERS .320 [8.2] .094 [2.4] DIA. (4) PLS .270 [6.9] .120 [3.1] DIA. (2) PLS CAT. NO. 3564 .091 [2.30] MIN. TYP. CAT. NO. 3563TR (Tape & Reel) .400 [10.2] MIN. Tape & Reel Spec’s: 24mm wide; 12mm pitch; 13 inch reel (1500 pieces per reel) .125 [3.2] .120 [3.1] DIA. SPECIFICATIONS Material: .012 (.30) Brass Insulator: Nylon, UL Rated 94V-0 UL Temperature Rating: -58°F to+292°F (-50°C to+145°C) .156 [4.0] .578 [14.7] .196 [5.0] .138 [3.5] .187 [4.8] .440 [11.2] .340 [8.7] .062 [1.55] .125 [3.2] .125 [3.2] Mounting Detail For Two Clips .086 [2.20] .144 [3.7] .100 [2.6] .176 [4.5] .144 [3.7] .075 [1.90] .144 [3.7] .065 [1.65] DIA. (4) PLS CAT. NO. 3544 Tin-Nickel Plate UL Current Rating: 30 Amps @ 500V AC LOW PROFILE MINI FUSE HOLDER UL Current Rating: 20 Amps @ 500V AC CAT. NO. 3544-2 Tin Plate MINI FUSE HOLDER • Low insertion force • Thru hole PC mountable, maintains position during wave soldering • Fuse holder fully insulates clips to protect fuse from shorting • Holder assures proper spacing and reduces assembly time For Littelfuse Low Profile Mini 897 series or equivalent For Littelfuse Mini 297 or 997 series/Bussmann ATM or equivalents SPECIFICATIONS Contacts: .016 (.41) Brass, Tin-Nickel Plate Insulator: Nylon 4/6, UL Rated 94V-0 UL Current Rating: 30 Amps @ 500V AC UL Temperature Rating: -58°F to+292°F (-50°C to+145°C) .265 [6.8] .780 [19.8] .290 [7.4] .265 [6.73] .630 [16.00] .290 [7.37] .110 [2.8] .530 [13.5] .062 [1.57] (2) PLS .134 [3.4] .110 [2.79] .390 [9.9] .062 [1.57] TYP Mounting Detail Mounting Detail .390 [9.9] .530 [13.5] Refer to page 41 for Cat. No. 3557 Clip details .134 [3.4] CAT. NO. 3557-2 .134 [3.41] .063 [1.60] DIA. (4) PLS .134 [3.40] .063 [1.60] DIA. (4) PLS CAT. NO. 3568 HORIZONTAL FUSE ENTRY ® For Littelfuse Mini 297 or 997 series/Bussmann ATM series or equivalent SPECIFICATIONS Contacts: .012 (.30) Brass Insulator: Nylon 6/6, UL Rated 94V-0 UL Temperature Rating: -58°F to+292°F (-50°C to+145°C) .062 [1.55] .280 [7.1] .156 [4.0] .075 [1.90] Mounting Detail For Two Clips .212 [5.4] .295 [7.5] .040 [1.00] .100 [2.6] .400 [10.2] .070 [1.80] .145 [3.7] .400 [10.2] .070 [1.8] (2) PLS CAT. NO. 3549 Nickel Plate UL Current Rating: 30 Amps @ 500V AC Tel (718) 956-8900 • Fax (718) 956-9040 (800) 221-5510 • kec@keyelco.com .700 [17.8] .228 [5.8] .046 [1.17] DIA. (2) PLS .076 [1.93] DIA. (2) PLS 42 .394 [10.0] .295 [7.5] .406 [10.3] .040 [1.0] (2) PLS UL Current Rating: 20 Amps @ 500V AC CAT. NO. 3549-2 Tin Plate ® RoHS COMPLIANT ~ ISO 9001 CERTIFIED www.keyelco.com 31-07 20th Road – Astoria, NY 11105-2017
3563TR 价格&库存
很抱歉,暂时无法提供与“3563TR”相匹配的价格&库存,您可以联系我们找货
3563TR
    库存:40500
    3563TR
      3563TR
      • 1+9.861591+1.27040
      • 10+7.4531110+0.96013
      • 25+6.6684425+0.85905
      • 100+5.66345100+0.72959
      • 500+4.71270500+0.60711
      库存:1674
      3563TR
        • 1+8.574371+1.10458
        • 10+6.4807810+0.83488
        • 25+5.7986625+0.74700
        • 100+4.92474100+0.63442
        • 500+4.09800500+0.52792
        库存:1674
