DIPPED RADIAL LEAD MULTILAYER CERAMIC CAPACITORS
NTD
Series
RoHS2
RoHS
Compliant
◆FEATURES
1. Small in size and wide capacitance range.
Max. 470µF is available.
2. Temperature characteristic is X7R in EIA code.
3. Superior humidity characteristic and long life.
4. Excellent high frequency characteristic due to low ESR.
5. High rated ripple current.
6. 500Vdc items are available.
7. Resin(UL94 V-0) used for coating.
8. Pb-free design(also ceramic dielectric)
◆APPLICATIONS
1. Smoothing circuit of switching mode AC-DC or DC-DC converter.
2. Noise suppressor for various kinds of equipments.
3. By-pass or decoupling circuits.
4. Automotive equipments.
◆CONSTRUCTION
Coating Resin
Ceramic
Dielectric
Termination
Solder (Pb-free)
Internal Electrode
Lead Wire
◆RATINGS
1.
2.
3.
4.
5.
6.
Category Temperature Range
Rated Voltage Range
Rated Capacitance Range
Rated Capacitance Tolerance
Temperature Characteristics
Rated Ripple Current
-55 to +125℃
25, 35, 50, 100, 250, 500Vdc
0.1 to 470µF
M(±20%), K(±10%)
X7R
See No.5 on the following table
◆SPECIFICATIONS
No.
1
Items
Withstand
Voltage
Between
Terminals
Specification
No abnormality.
Terminals to
Coating Resin
Test Condition
Rated voltage
Withstand voltage
Less than 250V
250% of rated voltage
More than 250V
Less than 500V
100V +
150% of rated voltage
More than 500V
130% of rated voltage
Shall be applied for 5 seconds.
2
Insulation Resistance
100/CR(MΩ) or 4000(MΩ)
whichever is less.
3
Rated Capacitance
Within specified tolerance.
Rated voltage shall be applied for 60±5 seconds at
temperature 25±2℃.
CR>10µF
CR≦10µF
Temperature
4
Dissipation Factor
5.0% maximum.
25±2℃
Frequency
1±0.1kHz
120±12Hz
Voltage
1±0.2Vrms
0.5±0.2Vrms
As customer requirement, Chemi-Con has submits the test results according to AEC-Q200 for Multilayer ceramic
capacitors. Please contact us for more information.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
28
CAT. No. E1002C 2023
NTD
Series
◆SPECIFICATIONS
No.
Items
Specification
Test Condition
5
See STANDARD RATINGS
10kHz to 1MHz (sine curve)
Ripple voltage Vp shall be less than the rated voltage.
6
Robustness Tension
of
Terminations
No visible damage.
The force applied shall be :
Bending
Lead φ (mm)
0.5 max.
0.6 min.
Tensile(N)
5
10
Lead φ (mm)
Bending(N)
0.5 max.
0.6 min.
(sec.)
10±1
10±1
(kg)
2.5
5
0.25
0.51
Time : 2times.
7
Vibration
Appearance : No abnormality.
Capacitance : To meet the initial
specification.
D.F. : To meet the initial specification.
8
Solderability
Min. 75% of surface of the termination
shall be covered with new solder.
9
Resistance to Soldering Heat
10
Temperature Cycle
11
Humidity Load Life
ΔC/C :±20%
D.F. : 10% maximum
I.R. : 25/CR(MΩ) or 1000(MΩ)
whichever is less.
Temperature : 40±2℃
Humidity
: 90 to 95%RH
Voltage
: Rated voltage
Time
: 500± 24
hours
Endurance
ΔC/C :±20%
D.F. : 10% maximum
I.R. : 50/CR(MΩ) or 1000(MΩ)
whichever is less.
Temperature : 125±3℃
Voltage
: Rated voltage
Time
: 1000± 48
0 hours
Amplitude
: 1.5mm
Frequency range
: 10-55-10Hz (1 min)
Direction and time :
2 hours each to X, Y, Z axis. Total 6 hours.
Solder
Solder Temperature
Dipping Time
Pb Free
245±5℃
2±0.5sec.
ΔC/C :±15%
I.R. : To meet the initial specification.
Solder Temperature : 350±10℃
Dipping Time
: 3±0.5 sec.
Depth
: 1.5 to 2mm
ΔC/C :±15%
Temperature (℃)
Step
Min. Category temperature ±3
1
Room temperature
2
3
Max. Category temperature ±3
4
Room temperature
For 5 cycles for above temperature cycle.
(min.)
30±3
3 max.
30±3
3 max.
*CR : Rated Capacitance(µF)
29
NTD
Series
◆STANDARD RATINGS
Rated
voltage
(Vdc)
25
35
50
100
Rated
Capacitance
(μF)
3.3
4.7
6.8
10
15
15
22
33
47
68
100
150
220
330
470
3.3
4.7
6.8
10
15
22
33
47
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
68
100
150
220
0.33
0.47
0.68
1.0
1.5
2.2
1.5
2.2
3.3
4.7
3.3
4.7
6.8
6.8
10
15
22
33
47
68
100
Electrostatic
Capacitance
Temperature
Characteristics
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
L max.
W max.
T max.
F±0.8
φd±0.05
Maximum ripple
current
(Arms)
5.0
5.0
6.5
6.5
6.5
7.5
7.5
7.5
10.0
13.5
13.5
22.5
22.5
28.5
28.5
5.0
5.0
6.5
6.5
7.5
7.5
10.0
10.0
5.0
5.0
5.0
5.0
6.5
6.5
7.5
7.5
10.0
13.5
22.5
22.5
22.5
28.5
28.5
5.0
5.0
5.0
5.0
5.0
5.0
6.5
6.5
6.5
6.5
7.5
7.5
7.5
10.0
13.5
13.5
22.5
22.5
28.5
28.5
28.5
6.0
6.0
6.5
6.5
6.5
9.0
9.0
9.0
11.5
15.0
15.0
20.0
20.0
20.0
20.0
6.0
6.0
6.5
6.5
9.0
9.0
11.5
11.5
6.0
6.0
6.0
6.0
6.5
6.5
9.0
9.0
11.5
15.0
20.0
20.0
20.0
20.0
20.0
6.0
6.0
6.0
6.0
6.0
6.0
6.5
6.5
6.5
6.5
9.0
9.0
9.0
11.5
15.0
15.0
20.0
20.0
20.0
20.0
20.0
3.5
3.5
4.0
4.0
4.0
4.5
4.5
4.5
5.5
6.0
8.0
6.0
8.0
8.0
11.5
3.5
3.5
4.0
4.0
4.5
4.5
5.0
5.5
3.5
3.5
3.5
3.5
4.0
4.0
4.5
4.5
5.0
5.5
6.0
6.0
6.0
7.5
10.0
3.5
3.5
3.5
3.5
3.5
3.5
4.0
4.0
4.0
4.0
4.5
4.5
4.7
5.0
5.0
6.0
6.0
6.0
7.5
7.5
9.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
10.0
10.0
20.0
20.0
25.0
25.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
10.0
20.0
20.0
20.0
25.0
25.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
10.0
10.0
20.0
20.0
25.0
25.0
25.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.6
0.6
0.8
0.8
0.8
0.8
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.6
0.8
0.8
0.8
0.8
0.8
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.6
0.6
0.8
0.8
0.8
0.8
0.8
0.3
0.3
0.8
0.8
0.8
1.0
1.0
1.0
1.5
2.0
2.0
3.0
3.0
4.0
4.0
0.3
0.3
0.8
0.8
1.0
1.0
1.5
1.5
0.3
0.3
0.3
0.3
0.8
0.8
1.0
1.0
1.5
2.0
3.0
3.0
3.0
4.0
4.0
0.3
0.3
0.3
0.3
0.3
0.3
0.8
0.8
0.8
0.8
1.0
1.0
1.0
1.5
2.0
2.0
3.0
3.0
4.0
4.0
4.0
Dimensions(mm)
Part Number
KTD250B335□32A0T00
KTD250B475□32A0T00
KTD250B685□43A0T00
KTD250B106□43A0T00
KTD250B156□43A0T00
KTD250B156□55A0T00
KTD250B226□55A0T00
KTD250B336□55A0T00
KTD250B476□76A0T00
KTD250B686M80A0B00
KTD250B107M80A0B00
KTD250B157M90A0B00
KTD250B227M90A0B00
KTD250B337M99A0B00
KTD250B477M99A0B00
KTD350B335□32A0T00
KTD350B475□32A0T00
KTD350B685□43A0T00
KTD350B106□43A0T00
KTD350B156□55A0T00
KTD350B226□55A0T00
KTD350B336□76A0T00
KTD350B476□76A0T00
KTD500B105□32A0T00
KTD500B155□32A0T00
KTD500B225□32A0T00
KTD500B335□32A0T00
KTD500B475□43A0T00
KTD500B685□43A0T00
KTD500B106□55A0T00
KTD500B156□55A0T00
KTD500B226□76A0T00
KTD500B336M80A0B00
KTD500B476M90A0B00
KTD500B686M90A0B00
KTD500B107M90A0B00
KTD500B157M99A0B00
KTD500B227M99A0B00
KTD101B334□32A0T00
KTD101B474□32A0T00
KTD101B684□32A0T00
KTD101B105□32A0T00
KTD101B155□32A0T00
KTD101B225□32A0T00
KTD101B155□43A0T00
KTD101B225□43A0T00
KTD101B335□43A0T00
KTD101B475□43A0T00
KTD101B335□55A0T00
KTD101B475□55A0T00
KTD101B685□55A0T00
KTD101B685□76A0T00
KTD101B106M80A0B00
KTD101B156M80A0B00
KTD101B226M90A0B00
KTD101B336M90A0B00
KTD101B476M99A0B00
KTD101B686M99A0B00
KTD101B107M99A0B00
Taping
Quantity per reel
(pcs. / reel)
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
1,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,500
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,500
30
NTD
Series
◆STANDARD RATINGS
Rated
voltage
(Vdc)
Electrostatic
Capacitance
Temperature
Characteristics
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
X7R
Rated
Capacitance
(μF)
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
2.2
3.3
4.7
6.8
10
15
0.47
0.56
0.68
1.0
1.2
250
500
L max.
W max.
T max.
F±0.8
φd±0.05
Maximum ripple
current
(Arms)
5.0
5.0
5.0
5.0
6.5
6.5
7.5
7.5
10.0
13.5
22.5
22.5
28.5
28.5
28.5
7.5
7.5
10.0
10.0
10.0
6.0
6.0
6.0
6.0
6.5
6.5
9.0
9.0
11.5
15.0
20.0
20.0
20.0
20.0
20.0
9.0
9.0
11.5
11.5
11.5
3.5
3.5
3.5
3.5
4.0
4.0
4.5
4.5
6.0
5.0
6.0
6.0
7.5
7.5
7.5
3.5
3.5
3.4
3.8
4.2
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
5.0
10.0
20.0
20.0
25.0
25.0
25.0
5.0
5.0
5.0
5.0
5.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.6
0.8
0.8
0.8
0.8
0.8
0.5
0.5
0.5
0.5
0.5
0.3
0.3
0.3
0.3
0.8
0.8
1.0
1.0
1.5
2.0
3.0
3.0
4.0
4.0
4.0
0.8
0.8
1.0
1.0
1.0
Dimensions(mm)
Taping
Quantity per reel
(pcs. / reel)
Part Number
KTD251B104□32A0T00
KTD251B154□32A0T00
KTD251B224□32A0T00
KTD251B334□32A0T00
KTD251B474□43A0T00
KTD251B684□43A0T00
KTD251B105□55A0T00
KTD251B155□55A0T00
KTD251B225□76A0T00
KTD251B225M80A0B00
KTD251B335M90A0B00
KTD251B475M90A0B00
KTD251B685M99A0B00
KTD251B106M99A0B00
KTD251B156M99A0B00
KTD501B474□55A0T00
KTD501B564□55A0T00
KTD501B684□76A0T00
KTD501B105□76A0T00
KTD501B125□76A0T00
2,000
2,000
2,000
2,000
2,000
2,000
2,000
2,000
1,000
2,000
2,000
1,500
1,500
1,500
※ The square (□) in part numbers is replaced by a capacitance tolerance code: ‘K’ when ±10%, or ‘M’ when ±20%
※ Please consult with us when you consider the rating other than a standard table.
2
3
4
5
6
7
8
9
10
11
12
13
14
15
◆DIMENSIONS
16
Crimped lead
32 to 76 Size
17 18
K TD 5 0 0 B 1 0 6 M 5 5 A0 T 0 0
L
T
W
L
F
15min.
Supplement code
Taping code
Terminal code
Size code
Capacitance tolerance code
Nominal Capacitance code
Temperature characteristics code
Rated voltage code
Series code
Category
Straight lead
For all size
T
W
1
F
d
15min.
◆PART NUMBERING SYSTEM
d
Please refer to"Part Numbering System" of the beginning of a catalog for the details.
31
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods
delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Precautions and Guidelines・Recommended Soldering Conditions
List of Standardization and Obsoleted Products
TAPING SPECIFICATION
Characteristics Data
Minimum Packaging Quantity
