ERWF401LGN272MD80M
ERWF401LGN272MD80M
    NCC(贵弥功)
    插件
    2700 µF 400 V 铝电解电容器 径向,Can - 螺丝端子 85°C 时为 5000 小时
ERWF401LGN272MD80M 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminal, 85℃ RWF Series ・High ripple capability ・Endurance with ripple current : 5,000 hours at 85℃ ・Wide range of case sizes fromφ50 toφ100 ・RoHS2 Compliant RWF RWE RWH Downsized Higher ripple current Longer life ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +85℃ 350 to 450Vdc ±20% (M) I=0.02CV or 5mA, whichever is smaller. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Dissipation Factor (tanδ) Low Temperature Characteristics Insulation Resistance (at 20℃, 120Hz) (at 20℃ after 5 minutes) 0.25 max. (at 20℃, 120Hz) Capacitance change C(-25℃)/C(+20℃)≧0.7 (at 120Hz) When measured between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case by using an insulation resistance meter of 500Vdc, the insulation resistance shall not be less than 100MΩ. When a voltage of 2,000Vac is applied for 1 minute between the terminals that are connected to each other and to the mounting clamp on the insulating sleeve covering the case, there shall not be electrical damage. The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 85℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 85℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Insulation Withstanding Voltage Endurance Shelf Life ◆DIMENSIONS (Screw-Mount) [mm] ● Mounting Clamp Code : B ● Mounting 4.5 B±1 F±1 φD+1.8max. Sleeve (PVC : Black) 6 30°±5° Vent 45°±5° 8 J G±1 L+4max. Plastic disk φD 50 63.5 76.2 φ50 &φ63.5 : G=6 φ76.2 &φ89 : G=5 φ100 : G=10 toφ89 Plus hexagon-headed screw :M5×0.8×10 Clamp Code : C 360° 3 A±1 W±1 F W B A 78.0 64.0 68.0 22.4 90.0 76.0 80.0 28.0 104.5 90.0 93.5 31.5 φD 50 63.5 76.2 89 100 E 32.5 38.1 44.5 50.8 56.5 M Code : LG K±1 E±1 ● Terminal K 37.0 43.5 50.0 56.5 63.4 M 4.5 4.5 4.5 4.5 5.5 F 22.4 28.0 31.5 31.5 41.5 J 14.0 14.0 14.0 16.0 18.0 Cross-recessed head (phillips) screw : M8×1.25×16 Spring washer,Washer Maximum screw tightening torque :6.31Nm * The screw and the mounting clamp are separately supplied and not attached to the product. Maximum screw tightening torque :3.23Nm φ100 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E RW F A A A L G N A A A M A A A U Supplement code Size code Capacitance tolerance code Capacitance code (ex. 6,800µ F:682, 12,000µ F:123) Mounting clamp code (N, B, C) Terminal code Voltage code (ex. 350V:351, 400V:401) Series code Category Please refer to "Product code guide (screw-mount terminal type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Inverter-use screw terminal, 85℃ RWFSeries ◆STANDARD RATINGS WV (Vdc) 350 400 Cap (µF) 1,200 1,800 2,200 2,200 2,700 3,300 3,900 4,700 5,600 5,600 6,800 6,800 8,200 10,000 12,000 15,000 18,000 22,000 1,000 1,500 1,800 1,800 2,200 2,700 3,300 3,900 4,700 4,700 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 50 × 60 50 × 75 50 × 85 50 × 96 50 × 115 50 × 130 63.5 × 115 63.5 × 130 63.5 × 155 76.2 × 115 63.5 × 190 76.2 × 130 76.2 × 155 76.2 × 170 89 × 155 89 × 190 100 × 190 100 × 250 50 × 60 50 × 75 50 × 85 50 × 96 50 × 105 50 × 130 63.5 × 115 63.5 × 130 63.5 × 155 76.2 × 115 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 4.90 6.50 7.50 7.70 9.30 10.8 12.1 14.0 16.6 16.1 20.0 18.6 22.2 25.2 29.1 35.7 36.9 46.1 4.40 5.90 6.80 7.00 8.00 9.80 11.1 12.7 15.2 14.7 Part No. ERWF351LGC122MC60U ERWF351LGC182MC75U ERWF351LGC222MC85U ERWF351LGC222MC96U ERWF351LGC272MCB5U ERWF351LGC332MCD0U ERWF351LGC392MDB5U ERWF351LGC472MDD0U ERWF351LGC562MDF5U ERWF351LGC562MEB5U ERWF351LGC682MDK0U ERWF351LGC682MED0U ERWF351LGC822MEF5U ERWF351LGC103MEH0U ERWF351LGC123MFF5U ERWF351LGC153MFK0U ERWF351LGC183MGK0U ERWF351LGC223MGR0U ERWF401LGC102MC60U ERWF401LGC152MC75U ERWF401LGC182MC85U ERWF401LGC182MC96U ERWF401LGC222MCA5U ERWF401LGC272MCD0U ERWF401LGC332MDB5U ERWF401LGC392MDD0U ERWF401LGC472MDF5U ERWF401LGC472MEB5U WV (Vdc) 400 450 Cap (µF) 5,600 5,600 6,800 8,200 10,000 12,000 15,000 18,000 820 1,000 1,200 1,200 1,500 1,800 2,200 2,700 3,300 3,900 3,900 4,700 4,700 5,600 6,800 8,200 10,000 12,000 15,000 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 63.5 × 190 76.2 × 130 76.2 × 155 76.2 × 170 89 × 155 89 × 170 100 × 190 100 × 220 50 × 60 50 × 75 50 × 85 50 × 96 50 × 96 50 × 115 50 × 130 63.5 × 115 63.5 × 130 63.5 × 155 76.2 × 115 63.5 × 190 76.2 × 130 76.2 × 155 76.2 × 170 89 × 155 89 × 170 100 × 190 100 × 250 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 18.2 16.9 20.2 22.8 26.6 30.0 33.7 37.4 4.00 4.80 5.60 5.70 6.30 7.60 8.80 10.1 11.7 13.8 13.4 16.7 15.5 18.3 20.7 24.1 27.8 29.3 37.0 Part No. ERWF401LGC562MDK0U ERWF401LGC562MED0U ERWF401LGC682MEF5U ERWF401LGC822MEH0U ERWF401LGC103MFF5U ERWF401LGC123MFH0U ERWF401LGC153MGK0U ERWF401LGC183MGN0U ERWF451LGC821MC60U ERWF451LGC102MC75U ERWF451LGC122MC85U ERWF451LGC122MC96U ERWF451LGC152MC96U ERWF451LGC182MCB5U ERWF451LGC222MCD0U ERWF451LGC272MDB5U ERWF451LGC332MDD0U ERWF451LGC392MDF5U ERWF451LGC392MEB5U ERWF451LGC472MDK0U ERWF451LGC472MED0U ERWF451LGC562MEF5U ERWF451LGC682MEH0U ERWF451LGC822MFF5U ERWF451LGC103MFH0U ERWF451LGC123MGK0U ERWF451LGC153MGR0U ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency (Hz) Coefficient 50 0.8 120 1.0 300 1.1 1k 1.3 3k 1.4 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Also, for the RWF series capacitors, using them at operating voltage less than their rated voltage can extend their lifetime. For details, please contact a representative of Nippon Chemi-Con. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
ERWF401LGN272MD80M 价格&库存
很抱歉,暂时无法提供与“ERWF401LGN272MD80M”相匹配的价格&库存,您可以联系我们找货
