ELXG161VSN472MA80S
ELXG161VSN472MA80S
    NCC(贵弥功)
    插件
    4700 µF 160 V 铝电解电容器 径向,Can - 卡入式 105°C 时为 5000 小时
ELXG161VSN472MA80S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS LXG Long life snap-ins, 105℃ LXG Series ・Endurance with ripple current : 5,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Longer life KMQ ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 10 to 100Vdc (at 20℃, 120Hz) ±20% (M) I=0.02CV or 3mA, whichever is smaller. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 5 minutes) Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 80 & 100V tanδ (Max.) 0.60 0.45 0.30 0.25 0.20 0.15 0.15 (at 20℃, 120Hz) Capacitance change : Capacitance at the lowest operating temperature shall not be less than 70% of the 20℃ value. Rated voltage (Vdc) 10V 16V 25V 35V 50V 63V 80 & 100V Z(-25℃)/Z(+20℃) 4 4 3 3 2 2 2 Z(-40℃)/Z(+20℃) 15 15 10 8 6 6 5 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃. Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦250% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] Code : VS (φ22 to φ35) : Standard Negative mark φD+1max. 10 L±2 Vent Sleeve (PET : Brown) Negative mark PC board pin-out (View from Solder side) 2-1.2×6 2-φ2 *4.0±0.5 Code : LI (φ35) 4.2±0.5 Sleeve (PET : Brown) ●Terminal PC board pin-out (View from Solder side) φD+1max. ●Terminal Vent 5±0.5 L±2 4.5±1 14.2±1 *φD=35mm : 3.5±0.5mm The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E L XG AAA VS N AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 390µF:391, 3,300µF:332) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 10V:100, 100V:101) Series code Category Please refer to "Product code guide (snap-in type)" ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 10 to 50Vdc 63 to 100Vdc 50 0.95 0.92 120 1.00 1.00 300 1.03 1.07 1k 1.05 1.13 10k 1.08 1.19 50k 1.08 1.20 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ LXGSeries ◆STANDARD RATINGS WV (Vdc) 10 16 25 35 Cap (µF) 6,800 10,000 10,000 12,000 12,000 12,000 15,000 15,000 18,000 18,000 18,000 18,000 22,000 22,000 27,000 27,000 33,000 39,000 39,000 47,000 5,600 6,800 6,800 8,200 10,000 10,000 10,000 12,000 12,000 12,000 15,000 15,000 18,000 18,000 18,000 22,000 22,000 27,000 27,000 39,000 3,900 4,700 4,700 5,600 6,800 6,800 6,800 8,200 8,200 8,200 10,000 10,000 12,000 12,000 12,000 15,000 15,000 18,000 18,000 27,000 2,200 3,300 3,300 3,900 3,900 4,700 4,700 Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 × 25 22 × 30 25.4× 25 22 ×35 25.4×30 30 ×25 22 ×40 25.4×35 22 ×50 25.4×40 30 ×30 35 ×25 30× 35 35× 30 25.4× 50 30 × 40 35 × 35 30 × 50 35 ×40 35 ×50 22 ×25 22 ×30 25.4×25 22 ×35 22 ×40 25.4×30 30 ×25 25.4×35 30×30 35×25 22×50 25.4×40 25.4×50 30×35 35×30 30×40 35×35 30×50 35×40 35×50 22 ×25 22 ×30 25.4×25 22 ×35 22×40 25.4×30 30×25 25.4×35 30×30 35 ×25 22 ×50 25.4×40 25.4×50 30 ×35 35 ×30 30 ×40 35 ×35 30 ×50 35 ×40 35× 50 22 × 25 22 × 30 25.4× 25 22 × 35 25.4× 30 22 × 40 30 × 25 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.60 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.45 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.25 0.25 0.25 0.25 0.25 0.25 0.25 1.30 1.65 1.64 1.85 1.85 1.89 2.12 2.16 2.45 2.43 2.37 2.42 2.73 2.79 3.11 3.13 3.49 3.99 3.96 4.62 1.44 1.66 1.66 1.87 2.12 2.07 2.11 2.37 2.37 2.42 2.74 2.71 3.11 3.02 3.09 3.46 3.49 4.07 4.04 5.16 1.31 1.51 1.51 1.70 1.92 1.87 1.90 2.14 2.15 2.19 2.45 2.43 2.78 2.70 2.76 3.13 3.16 3.64 3.61 4.70 1.10 1.42 1.41 1.58 1.58 1.78 1.77 Part No. ELXG100VSN682MP25S ELXG100VSN103MP30S ELXG100VSN103MQ25S ELXG100VSN123MP35S ELXG100VSN123MQ30S ELXG100VSN123MR25S ELXG100VSN153MP40S ELXG100VSN153MQ35S ELXG100VSN183MP50S ELXG100VSN183MQ40S ELXG100VSN183MR30S ELXG100VSN183MA25S ELXG100VSN223MR35S ELXG100VSN223MA30S ELXG100VSN273MQ50S ELXG100VSN273MR40S ELXG100VSN333MA35S ELXG100VSN393MR50S ELXG100VSN393MA40S ELXG100VSN473MA50S ELXG160VSN562MP25S ELXG160VSN682MP30S ELXG160VSN682MQ25S ELXG160VSN822MP35S ELXG160VSN103MP40S ELXG160VSN103MQ30S ELXG160VSN103MR25S ELXG160VSN123MQ35S ELXG160VSN123MR30S ELXG160VSN123MA25S ELXG160VSN153MP50S ELXG160VSN153MQ40S ELXG160VSN183MQ50S ELXG160VSN183MR35S ELXG160VSN183MA30S ELXG160VSN223MR40S ELXG160VSN223MA35S ELXG160VSN273MR50S ELXG160VSN273MA40S ELXG160VSN393MA50S ELXG250VSN392MP25S ELXG250VSN472MP30S ELXG250VSN472MQ25S ELXG250VSN562MP35S ELXG250VSN682MP40S ELXG250VSN682MQ30S ELXG250VSN682MR25S ELXG250VSN822MQ35S ELXG250VSN822MR30S ELXG250VSN822MA25S ELXG250VSN103MP50S ELXG250VSN103MQ40S ELXG250VSN123MQ50S ELXG250VSN123MR35S ELXG250VSN123MA30S ELXG250VSN153MR40S ELXG250VSN153MA35S ELXG250VSN183MR50S ELXG250VSN183MA40S ELXG250VSN273MA50S ELXG350VSN222MP25S ELXG350VSN332MP30S ELXG350VSN332MQ25S ELXG350VSN392MP35S ELXG350VSN392MQ30S ELXG350VSN472MP40S ELXG350VSN472MR25S WV (Vdc) 35 50 63 80 Cap (µF) 5,600 5,600 5,600 6,800 6,800 8,200 8,200 8,200 10,000 10,000 12,000 12,000 18,000 1,500 1,800 1,800 2,200 2,700 2,700 2,700 3,300 3,300 3,300 3,900 3,900 4,700 4,700 5,600 5,600 5,600 6,800 6,800 10,000 1,000 1,200 1,200 1,500 1,800 1,800 1,800 2,200 2,200 2,200 2,700 2,700 2,700 3,300 3,300 3,900 3,900 4,700 4,700 6,800 680 820 1,000 1,000 1,200 1,200 1,200 1,500 1,800 1,800 1,800 1,800 2,200 2,200 Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 25.4 × 35 30 × 30 35 × 25 22 × 50 25.4 × 40 25.4 × 50 30 × 35 35 × 30 30 × 40 35 × 35 30 × 50 35 × 40 35 × 50 22 × 25 22 × 30 25.4× 25 22 × 35 22 × 40 25.4 × 30 30 × 25 25.4 × 35 30 × 30 35 × 25 22 × 50 25.4 × 40 30 × 35 35 × 30 25.4 × 50 30 × 40 35 × 35 30 × 50 35 × 40 35 × 50 22 × 25 22 × 30 25.4 × 25 22 × 35 22 × 40 25.4 × 30 30 × 25 25.4 × 35 30 × 30 35 × 25 22 × 50 25.4 × 40 30 × 35 25.4 × 50 35 × 30 30 × 40 35 × 35 30 × 50 35 × 40 35 × 50 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 30 × 25 25.4 × 35 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 50 30 × 35 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.98 1.98 2.03 2.26 2.24 2.57 2.50 2.55 2.86 2.88 3.32 3.30 4.29 1.02 1.17 1.17 1.33 1.51 1.47 1.50 1.70 1.70 1.74 1.91 1.89 2.11 2.16 2.38 2.39 2.41 2.79 2.78 3.57 1.00 1.15 1.15 1.32 1.49 1.45 1.48 1.67 1.68 1.71 1.92 1.90 1.93 2.20 2.18 2.41 2.43 2.80 2.78 3.55 0.97 1.12 1.27 1.23 1.42 1.39 1.41 1.62 1.84 1.82 1.78 1.82 2.11 2.05 Part No. ELXG350VSN562MQ35S ELXG350VSN562MR30S ELXG350VSN562MA25S ELXG350VSN682MP50S ELXG350VSN682MQ40S ELXG350VSN822MQ50S ELXG350VSN822MR35S ELXG350VSN822MA30S ELXG350VSN103MR40S ELXG350VSN103MA35S ELXG350VSN123MR50S ELXG350VSN123MA40S ELXG350VSN183MA50S ELXG500VSN152MP25S ELXG500VSN182MP30S ELXG500VSN182MQ25S ELXG500VSN222MP35S ELXG500VSN272MP40S ELXG500VSN272MQ30S ELXG500VSN272MR25S ELXG500VSN332MQ35S ELXG500VSN332MR30S ELXG500VSN332MA25S ELXG500VSN392MP50S ELXG500VSN392MQ40S ELXG500VSN472MR35S ELXG500VSN472MA30S ELXG500VSN562MQ50S ELXG500VSN562MR40S ELXG500VSN562MA35S ELXG500VSN682MR50S ELXG500VSN682MA40S ELXG500VSN103MA50S ELXG630VSN102MP25S ELXG630VSN122MP30S ELXG630VSN122MQ25S ELXG630VSN152MP35S ELXG630VSN182MP40S ELXG630VSN182MQ30S ELXG630VSN182MR25S ELXG630VSN222MQ35S ELXG630VSN222MR30S ELXG630VSN222MA25S ELXG630VSN272MP50S ELXG630VSN272MQ40S ELXG630VSN272MR35S ELXG630VSN332MQ50S ELXG630VSN332MA30S ELXG630VSN392MR40S ELXG630VSN392MA35S ELXG630VSN472MR50S ELXG630VSN472MA40S ELXG630VSN682MA50S ELXG800VSN681MP25S ELXG800VSN821MP30S ELXG800VSN102MP35S ELXG800VSN102MQ25S ELXG800VSN122MP40S ELXG800VSN122MQ30S ELXG800VSN122MR25S ELXG800VSN152MQ35S ELXG800VSN182MP50S ELXG800VSN182MQ40S ELXG800VSN182MR30S ELXG800VSN182MA25S ELXG800VSN222MQ50S ELXG800VSN222MR35S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Long life snap-ins, 105℃ LXGSeries ◆STANDARD RATINGS WV (Vdc) 80 100 Cap (µF) Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 2,200 2,700 2,700 3,300 3,300 4,700 390 560 560 680 820 820 820 35 ×30 30 ×40 35 ×35 30 ×50 35 ×40 35 ×50 22 ×25 22 ×30 25.4×25 22 ×35 22 ×40 25.4×30 30 ×25 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 2.09 2.35 2.37 2.75 2.73 3.46 0.78 0.99 0.98 1.12 1.26 1.23 1.25 Part No. ELXG800VSN222MA30S ELXG800VSN272MR40S ELXG800VSN272MA35S ELXG800VSN332MR50S ELXG800VSN332MA40S ELXG800VSN472MA50S ELXG101VSN391MP25S ELXG101VSN561MP30S ELXG101VSN561MQ25S ELXG101VSN681MP35S ELXG101VSN821MP40S ELXG101VSN821MQ30S ELXG101VSN821MR25S WV (Vdc) Cap (µF) Rated ripple Case size current tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 100 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 2,200 2,200 2,700 25.4 × 35 30 × 30 35 × 25 22 × 50 25.4 × 40 30 × 35 25.4 × 50 30 × 40 35 × 30 35 × 35 30 × 50 35 × 40 35 × 50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.41 1.42 1.45 1.60 1.59 1.61 1.86 1.87 1.85 2.07 2.40 2.39 2.81 Part No. ELXG101VSN102MQ35S ELXG101VSN102MR30S ELXG101VSN102MA25S ELXG101VSN122MP50S ELXG101VSN122MQ40S ELXG101VSN122MR35S ELXG101VSN152MQ50S ELXG101VSN152MR40S ELXG101VSN152MA30S ELXG101VSN182MA35S ELXG101VSN222MR50S ELXG101VSN222MA40S ELXG101VSN272MA50S ◆MAXIMUM IMPEDANCE [mΩ/20℃, 30kHz] Case size φD×L(mm) Vdc 22×25 22×30 22×35 22×40 22×50 25.4×25 25.4×30 25.4×35 25.4×40 25.4×50 30×25 30×30 30×35 30×40 30×50 35×25 35×30 35×35 35×40 35×50 10 to 63 120 100 80 70 50 90 70 60 50 40 70 50 40 35 25 65 45 38 30 23 80 100 150 120 95 80 60 110 85 70 60 45 80 60 50 40 30 70 50 40 30 25 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
ELXG161VSN472MA80S 价格&库存
很抱歉,暂时无法提供与“ELXG161VSN472MA80S”相匹配的价格&库存,您可以联系我们找货
