MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
SMQ
Series
Downsized, 85℃
SMQ
・Downsized from current standard SMG series
・Endurance : 2,000 hours at 85℃
・Non solvent resistant type
・RoHS2 Compliant
Downsized
SMG
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +85℃(6.3 to 400Vdc) -25 to +85℃(450Vdc)
6.3 to 450Vdc
±20% (M)
6.3 to 100Vdc
I=0.03CV or 4µA, whichever is greater.
(at 20℃, 120Hz)
160 to 450Vdc
CV≦1,000
I=0.1CV+40 max.
CV>1,000
I=0.04CV+100 max.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 1 minute)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 315 to 400V 450V
tanδ(Max.)
0.28 0.24 0.20 0.16 0.14 0.12 0.09 0.08
0.20
0.24
0.24
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 200V 250V 350V 400V 450V
5
4
3
2
2
2
2
2
3
3
4
4
6
≦φ8
Z(-25℃)/Z(+20℃)
5
4
3
2
2
2
2
2
3
3
4
4
6
≧φ10
12
10
8
5
4
3
3
3
8
10
8
8
≦φ8
Z(-40℃)/Z(+20℃)
(at 120Hz)
10
8
5
4
3
3
3
4
4
6
6
≧φ10 12
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours
at 85℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Rated voltage
6.3 to 100Vdc
160 to 450Vdc
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φD'
φd
Sleeve (PET : Black)
F±0.5
Code : E
F±0.5
● Terminal
15min.
L'
Vent
(except φ5)
4min.
(φ5 to φ10)
(φ12.5 to φ18)
φD
φd
F
φD'
L'
5
0.5
2.0
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
18
0.8
7.5
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E S MQ A A A E A A A A A M A A A N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,50V:500,100V:101)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001V 2021
Downsized, 85℃
SMQSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
50
63
Cap
(µF)
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
100
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
47
68
100
220
330
470
1,000
2,200
3,300
4,700
6,800
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
470
1,000
2,200
3,300
22
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
85℃, 120Hz)
8 ×11.5
10 ×16
10 ×20
12.5× 20
12.5× 25
16 ×25
16 ×31.5
18 ×35.5
5 ×11
6.3×11
6.3×11
10 ×12.5
10 ×16
12.5× 20
12.5× 25
16 ×25
16 ×31.5
16 ×35.5
18 ×40
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×20
12.5× 25
16 ×25
16 ×25
16 ×35.5
18 ×40
5 ×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 25
16 ×25
16 ×25
16 ×35.5
18 ×40
5 ×11
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 20
16 ×25
16 ×31.5
16 ×35.5
18 ×40
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
10 ×20
12.5× 25
16 ×31.5
18 ×35.5
5 ×11
0.28
0.30
0.32
0.34
0.38
0.46
0.56
0.70
0.24
0.24
0.24
0.24
0.26
0.28
0.30
0.34
0.42
0.52
0.66
0.20
0.20
0.20
0.20
0.22
0.24
0.26
0.30
0.38
0.48
0.16
0.16
0.16
0.16
0.16
0.18
0.20
0.22
0.26
0.34
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.16
0.18
0.20
0.24
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.14
0.16
0.09
540
890
1,190
1,550
1,920
2,350
2,550
3,200
240
290
350
650
990
1,450
1,800
2,250
2,550
2,880
3,400
260
320
440
700
1,000
1,700
2,100
2,250
2,710
3,100
180
280
440
550
860
1,550
1,980
2,200
2,600
2,800
130
160
210
385
490
650
1,150
1,800
2,100
2,500
2,800
17
28
35
41
60
95
125
155
210
260
430
590
760
1,350
1,980
2,500
100
Part No.
ESMQ6R3E□□102MHB5D
ESMQ6R3E□□222MJ16S
ESMQ6R3E□□332MJ20S
ESMQ6R3E□□472MK20S
ESMQ6R3E□□682MK25S
ESMQ6R3E□□103ML25S
ESMQ6R3E□□153MLN3S
ESMQ6R3E□□223MMP1S
ESMQ100E□□221ME11D
ESMQ100E□□331MF11D
ESMQ100E□□471MF11D
ESMQ100E□□102MJC5S
ESMQ100E□□222MJ16S
ESMQ100E□□332MK20S
ESMQ100E□□472MK25S
ESMQ100E□□682ML25S
ESMQ100E□□103MLN3S
ESMQ100E□□153MLP1S
ESMQ100E□□223MM40S
ESMQ160E□□221MF11D
ESMQ160E□□331MF11D
ESMQ160E□□471MHB5D
ESMQ160E□□102MJC5S
ESMQ160E□□222MJ20S
ESMQ160E□□332MK25S
ESMQ160E□□472ML25S
ESMQ160E□□682ML25S
ESMQ160E□□103MLP1S
ESMQ160E□□153MM40S
ESMQ250E□□101ME11D
ESMQ250E□□221MF11D
ESMQ250E□□331MHB5D
ESMQ250E□□471MJC5S
ESMQ250E□□102MJ16S
ESMQ250E□□222MK25S
ESMQ250E□□332ML25S
ESMQ250E□□472ML25S
ESMQ250E□□682MLP1S
ESMQ250E□□103MM40S
ESMQ350E□□470ME11D
ESMQ350E□□680MF11D
ESMQ350E□□101MF11D
ESMQ350E□□221MHB5D
ESMQ350E□□331MJC5S
ESMQ350E□□471MJ16S
ESMQ350E□□102MK20S
ESMQ350E□□222ML25S
ESMQ350E□□332MLN3S
ESMQ350E□□472MLP1S
ESMQ350E□□682MM40S
ESMQ500E□□1R0ME11D
ESMQ500E□□2R2ME11D
ESMQ500E□□3R3ME11D
ESMQ500E□□4R7ME11D
ESMQ500E□□100ME11D
ESMQ500E□□220ME11D
ESMQ500E□□330ME11D
ESMQ500E□□470MF11D
ESMQ500E□□680MF11D
ESMQ500E□□101MHB5D
ESMQ500E□□221MJC5S
ESMQ500E□□331MJ16S
ESMQ500E□□471MJ20S
ESMQ500E□□102MK25S
ESMQ500E□□222MLN3S
ESMQ500E□□332MMP1S
ESMQ630E□□220ME11D
WV
(Vdc)
63
100
160
200
250
350
400
Cap
(µF)
33
47
68
100
220
330
470
1,000
2,200
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
470
1,000
10
22
33
47
68
100
220
330
470
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
3.3
4.7
10
22
33
47
68
100
220
2.2
3.3
4.7
10
22
33
47
68
100
1.0
2.2
3.3
4.7
10
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
85℃, 120Hz)
6.3 × 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 16
10 × 20
12.5 × 20
16 × 25
18 × 35.5
5 × 11
5 × 11
5 × 11
5 × 11
5 × 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
10 × 16
12.5 × 20
12.5 × 25
16 × 25
18 × 35.5
8 × 11.5
10 × 12.5
10 × 16
10 × 20
12.5 × 20
12.5 × 25
16 × 31.5
18 × 35.5
18 × 40
6.3 × 11
6.3 × 11
6.3 × 11
6.3 × 11
8 × 11.5
10 × 16
10 × 20
12.5 × 20
12.5 × 25
16 × 25
16 × 35.5
18 × 40
6.3 × 11
6.3 × 11
10 × 12.5
10 × 20
10 × 20
12.5 × 20
16 × 25
16 × 25
18 × 35.5
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
12.5 × 20
12.5 × 25
16 × 25
16 × 25
18 × 31.5
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
10 × 16
0.09
0.09
0.09
0.09
0.09
0.09
0.09
0.09
0.11
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
140
170
220
280
490
710
900
1,300
2,300
21
30
40
45
70
130
180
200
270
340
550
760
1,000
1,350
80
130
180
210
350
430
760
995
1,200
22
33
40
50
80
150
205
270
350
475
700
950
40
50
100
170
200
270
380
440
680
30
46
55
90
185
240
325
400
530
22
38
48
60
90
Part No.
ESMQ630E□□330MF11D
ESMQ630E□□470MF11D
ESMQ630E□□680MHB5D
ESMQ630E□□101MHB5D
ESMQ630E□□221MJ16S
ESMQ630E□□331MJ20S
ESMQ630E□□471MK20S
ESMQ630E□□102ML25S
ESMQ630E□□222MMP1S
ESMQ101E□□1R0ME11D
ESMQ101E□□2R2ME11D
ESMQ101E□□3R3ME11D
ESMQ101E□□4R7ME11D
ESMQ101E□□100ME11D
ESMQ101E□□220MF11D
ESMQ101E□□330MHB5D
ESMQ101E□□470MHB5D
ESMQ101E□□680MJC5S
ESMQ101E□□101MJ16S
ESMQ101E□□221MK20S
ESMQ101E□□331MK25S
ESMQ101E□□471ML25S
ESMQ101E□□102MMP1S
ESMQ161E□□100MHB5D
ESMQ161E□□220MJC5S
ESMQ161E□□330MJ16S
ESMQ161E□□470MJ20S
ESMQ161E□□680MK20S
ESMQ161E□□101MK25S
ESMQ161E□□221MLN3S
ESMQ161E□□331MMP1S
ESMQ161E□□471MM40S
ESMQ201E□□1R0MF11D
ESMQ201E□□2R2MF11D
ESMQ201E□□3R3MF11D
ESMQ201E□□4R7MF11D
ESMQ201E□□100MHB5D
ESMQ201E□□220MJ16S
ESMQ201E□□330MJ20S
ESMQ201E□□470MK20S
ESMQ201E□□680MK25S
ESMQ201E□□101ML25S
ESMQ201E□□221MLP1S
ESMQ201E□□331MM40S
ESMQ251E□□3R3MF11D
ESMQ251E□□4R7MF11D
ESMQ251E□□100MJC5S
ESMQ251E□□220MJ20S
ESMQ251E□□330MJ20S
ESMQ251E□□470MK20S
ESMQ251E□□680ML25S
ESMQ251E□□101ML25S
ESMQ251E□□221MMP1S
ESMQ351E□□2R2MF11D
ESMQ351E□□3R3MHB5D
ESMQ351E□□4R7MHB5D
ESMQ351E□□100MJC5S
ESMQ351E□□220MK20S
ESMQ351E□□330MK25S
ESMQ351E□□470ML25S
ESMQ351E□□680ML25S
ESMQ351E□□101MMN3S
ESMQ401E□□1R0MF11D
ESMQ401E□□2R2MHB5D
ESMQ401E□□3R3MHB5D
ESMQ401E□□4R7MJC5S
ESMQ401E□□100MJ16S
□□ : Enter the appropriate lead forming or taping code.
Downsized, 85℃
SMQSeries
◆STANDARD RATINGS
WV
(Vdc)
400
450
Cap
(µF)
22
33
47
68
100
2.2
3.3
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
85℃, 120Hz)
12.5× 25
16 × 25
16 × 25
16 ×31.5
18 ×35.5
8×11.5
10 ×12.5
0.24
0.24
0.24
0.24
0.24
0.24
0.24
205
275
280
340
440
28
40
Part No.
ESMQ401E□□220MK25S
ESMQ401E□□330ML25S
ESMQ401E□□470ML25S
ESMQ401E□□680MLN3S
ESMQ401E□□101MMP1S
ESMQ451E□□2R2MHB5D
ESMQ451E□□3R3MJC5S
WV
(Vdc)
Cap
(µF)
450
4.7
10
22
33
47
68
100
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
85℃, 120Hz)
10 × 12.5
10 × 20
12.5 × 25
16 × 25
16 × 31.5
18 × 35.5
18 × 40
0.24
0.24
0.24
0.24
0.24
0.24
0.24
46
80
140
180
220
260
280
Part No.
ESMQ451E□□4R7MJC5S
ESMQ451E□□100MJ20S
ESMQ451E□□220MK25S
ESMQ451E□□330ML25S
ESMQ451E□□470MLN3S
ESMQ451E□□680MMP1S
ESMQ451E□□101MM40S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
1.0
10
100
2,200
Frequency(Hz)
to 4.7
to 68
to 1,000
to
50
0.65
0.75
0.80
0.85
120
1.00
1.00
1.00
1.00
300
1.35
1.25
1.15
1.03
1k
1.75
1.50
1.30
1.05
10k
2.30
1.75
1.40
1.08
100k
2.50
1.80
1.50
1.08
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
