EKMQ451VSD331MA35S
EKMQ451VSD331MA35S
    NCC(贵弥功)
    插件
    330 µF 450 V 铝电解电容器 径向,Can - 卡入式 105°C 时为 2000 小时
EKMQ451VSD331MA35S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Standard snap-ins, 105℃ KMQ KMR Series Downsized ・Endurance with ripple current : 2,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant KMQ ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ (35&50Vdc), -25 to +105℃ (160 to 450Vdc) 35&50Vdc, 160 to 450Vdc (at 20℃, 120Hz) ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 5 minutes) Rated voltage (Vdc) 35V 50V 160 to 250V 315 to 400V 420 & 450V Nominal capacitance (µF) 10,000>C C≧10,000 10,000>C C≧10,000 (at 20℃, 120Hz) tanδ(Max.) 0.30 0.35 0.25 0.30 0.15 0.15 0.20 Rated voltage (Vdc) 35&50V 160 to 250V 315 to 450V Z(-25℃)/Z(+20℃) 4 4 8 Z(-40℃)/Z(+20℃) 10 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D.F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] Negative mark φD+1max. 10 2-φ2 4.0±0.5 L±2 Vent Code : LI (φ35) Sleeve (PET : Brown) Negative mark Vent PC board pin-out (View from Solder side) 2-1.2×6 φD+1max. Sleeve (PET : Brown) ●Terminal PC board pin-out (View from Solder side) 4.2±0.5 Code : VS (φ22 to φ35) : Standard ●Terminal 5±0.5 L±2 4.5±1 14.2±1 The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KMQ A A A V S N A A A M A A A S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 68µF:680, 3,300µF:332) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161, 315V:3B1, 450V:451) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Standard snap-ins, 105℃ KMQSeries ◆STANDARD RATINGS WV (Vdc) 35 50 160 Cap (µF) 4,700 5,600 5,600 6,800 6,800 8,200 8,200 8,200 10,000 10,000 10,000 12,000 12,000 12,000 12,000 15,000 15,000 15,000 18,000 18,000 18,000 22,000 22,000 27,000 33,000 2,700 3,300 3,300 3,900 3,900 4,700 4,700 4,700 5,600 5,600 5,600 6,800 6,800 6,800 6,800 8,200 8,200 8,200 10,000 10,000 10,000 12,000 12,000 15,000 18,000 470 560 680 680 820 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 22 ×25 22 × 25 25.4× 25 22 × 30 25.4× 25 22 ×35 25.4 ×30 30 ×25 22 ×40 25.4 ×35 30 ×25 22 ×50 25.4 ×35 30 ×30 35 ×25 25.4 ×40 30 ×35 35 ×25 25.4 ×50 30 ×40 35 ×30 30 ×50 35 ×35 35 ×40 35 ×50 22 ×25 22×30 25.4×25 22×30 25.4×25 22 ×35 25.4 ×30 30×25 22 ×40 25.4×35 30 ×25 22×50 25.4×40 30×30 35 ×25 25.4×45 30 ×35 35 ×30 25.4×50 30 ×40 35×30 30×50 35×35 35×40 35×50 22 ×25 22 ×30 22 ×30 25.4×25 22 × 35 25.4× 30 30 × 25 22 × 40 25.4× 35 30× 25 25.4× 40 30 ×30 35 ×25 25.4 ×45 30 ×35 35 ×30 25.4×50 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.35 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.30 0.30 0.30 0.30 0.30 0.30 0.30 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.87 2.04 2.00 2.36 2.21 2.65 2.49 2.62 3.00 2.88 2.90 3.47 3.15 3.25 3.20 3.61 3.78 3.60 4.14 4.30 4.10 5.00 4.64 5.37 6.00 1.65 1.92 1.76 2.08 2.04 2.43 2.50 2.29 2.63 2.61 2.80 3.05 2.94 3.30 2.77 3.60 3.60 3.60 4.00 4.00 4.00 4.29 4.37 4.50 5.30 1.40 1.50 1.70 1.70 2.00 2.00 2.00 2.20 2.20 2.20 2.30 2.30 2.30 2.50 2.50 2.50 2.70 Part No. EKMQ350VSN472MP25S EKMQ350VSN562MP25S EKMQ350VSN562MQ25S EKMQ350VSN682MP30S EKMQ350VSN682MQ25S EKMQ350VSN822MP35S EKMQ350VSN822MQ30S EKMQ350VSN822MR25S EKMQ350VSN103MP40S EKMQ350VSN103MQ35S EKMQ350VSN103MR25S EKMQ350VSN123MP50S EKMQ350VSN123MQ35S EKMQ350VSN123MR30S EKMQ350VSN123MA25S EKMQ350VSN153MQ40S EKMQ350VSN153MR35S EKMQ350VSN153MA25S EKMQ350VSN183MQ50S EKMQ350VSN183MR40S EKMQ350VSN183MA30S EKMQ350VSN223MR50S EKMQ350VSN223MA35S EKMQ350VSN273MA40S EKMQ350VSN333MA50S EKMQ500VSN272MP25S EKMQ500VSN332MP30S EKMQ500VSN332MQ25S EKMQ500VSN392MP30S EKMQ500VSN392MQ25S EKMQ500VSN472MP35S EKMQ500VSN472MQ30S EKMQ500VSN472MR25S EKMQ500VSN562MP40S EKMQ500VSN562MQ35S EKMQ500VSN562MR25S EKMQ500VSN682MP50S EKMQ500VSN682MQ40S EKMQ500VSN682MR30S EKMQ500VSN682MA25S EKMQ500VSN822MQ45S EKMQ500VSN822MR35S EKMQ500VSN822MA30S EKMQ500VSN103MQ50S EKMQ500VSN103MR40S EKMQ500VSN103MA30S EKMQ500VSN123MR50S EKMQ500VSN123MA35S EKMQ500VSN153MA40S EKMQ500VSN183MA50S EKMQ161VSN471MP25S EKMQ161VSN561MP30S EKMQ161VSN681MP30S EKMQ161VSN681MQ25S EKMQ161VSN821MP35S EKMQ161VSN821MQ30S EKMQ161VSN821MR25S EKMQ161VSN102MP40S EKMQ161VSN102MQ35S EKMQ161VSN102MR25S EKMQ161VSN122MQ40S EKMQ161VSN122MR30S EKMQ161VSN122MA25S EKMQ161VSN152MQ45S EKMQ161VSN152MR35S EKMQ161VSN152MA30S EKMQ161VSN182MQ50S WV (Vdc) 160 180 200 250 Cap (µF) 1,800 1,800 2,200 2,200 2,700 2,700 3,300 390 470 560 560 680 680 820 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,700 390 470 560 560 680 680 820 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,800 1,800 2,200 220 270 330 330 390 390 470 470 470 560 560 560 680 680 680 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 50 22 × 25 22 × 30 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 50 22 × 25 22 × 30 22 × 30 25.4× 25 22 × 40 25.4 × 30 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 45 30 × 30 35 × 25 25.4 × 50 30 × 35 35 × 30 30 × 40 35 × 30 30 × 45 35 × 40 35 × 45 22 × 25 22 × 25 22 × 30 25.4 × 25 22 × 35 25.4 × 25 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 25 22 × 50 25.4 × 40 30 × 30 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 2.70 2.70 2.90 2.90 3.10 3.10 3.30 1.30 1.40 1.50 1.50 1.70 1.70 2.00 2.00 2.00 2.20 2.20 2.20 2.20 2.30 2.30 2.30 2.50 2.50 2.50 2.70 2.70 2.90 2.90 3.10 1.31 1.45 1.67 1.67 1.75 1.75 2.04 2.04 2.04 2.30 2.30 2.30 2.30 2.65 2.65 2.65 2.80 2.80 3.08 3.08 3.48 1.00 1.10 1.20 1.20 1.30 1.30 1.40 1.40 1.40 1.50 1.50 1.50 1.70 1.70 1.70 Part No. EKMQ161VSN182MR40S EKMQ161VSN182MA30S EKMQ161VSN222MR45S EKMQ161VSN222MA35S EKMQ161VSN272MR50S EKMQ161VSN272MA40S EKMQ161VSN332MA50S EKMQ181VSN391MP25S EKMQ181VSN471MP30S EKMQ181VSN561MP30S EKMQ181VSN561MQ25S EKMQ181VSN681MP35S EKMQ181VSN681MQ30S EKMQ181VSN821MP40S EKMQ181VSN821MQ30S EKMQ181VSN821MR25S EKMQ181VSN102MP45S EKMQ181VSN102MQ40S EKMQ181VSN102MR30S EKMQ181VSN102MA25S EKMQ181VSN122MQ45S EKMQ181VSN122MR35S EKMQ181VSN122MA30S EKMQ181VSN152MQ50S EKMQ181VSN152MR40S EKMQ181VSN152MA30S EKMQ181VSN182MR45S EKMQ181VSN182MA35S EKMQ181VSN222MR50S EKMQ181VSN222MA40S EKMQ181VSN272MA50S EKMQ201VSN391MP25S EKMQ201VSN471MP30S EKMQ201VSN561MP30S EKMQ201VSN561MQ25S EKMQ201VSN681MP40S EKMQ201VSN681MQ30S EKMQ201VSN821MP45S EKMQ201VSN821MQ35S EKMQ201VSN821MR25S EKMQ201VSN102MP50S EKMQ201VSN102MQ45S EKMQ201VSN102MR30S EKMQ201VSN102MA25S EKMQ201VSN122MQ50S EKMQ201VSN122MR35S EKMQ201VSN122MA30S EKMQ201VSN152MR40S EKMQ201VSN152MA30S EKMQ201VSN182MR45S EKMQ201VSN182MA40S EKMQ201VSN222MA45S EKMQ251VSN221MP25S EKMQ251VSN271MP25S EKMQ251VSN331MP30S EKMQ251VSN331MQ25S EKMQ251VSN391MP35S EKMQ251VSN391MQ25S EKMQ251VSN471MP40S EKMQ251VSN471MQ30S EKMQ251VSN471MR25S EKMQ251VSN561MP45S EKMQ251VSN561MQ35S EKMQ251VSN561MR25S EKMQ251VSN681MP50S EKMQ251VSN681MQ40S EKMQ251VSN681MR30S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Standard snap-ins, 105℃ KMQSeries ◆STANDARD RATINGS WV (Vdc) 250 315 350 400 Cap (µF) 680 820 820 820 1,000 1,000 1,200 1,200 1,500 1,800 150 180 220 220 270 270 330 330 330 390 390 390 390 470 470 470 560 560 560 680 680 820 820 1,000 120 150 180 180 220 220 270 270 270 330 330 330 390 390 470 470 470 560 560 680 680 820 100 120 150 150 180 180 220 220 220 270 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 35 ×25 25.4 ×45 30 ×35 35× 30 30× 40 35× 30 30× 45 35× 35 35× 45 35× 50 22× 25 22 × 30 22 × 30 25.4× 25 22 ×35 25.4×30 22 ×45 25.4×35 30 ×25 22 ×45 25.4 ×40 30 ×30 35× 25 25.4× 45 30 × 35 35 × 25 25.4×50 30×40 35×30 30×45 35×35 30×50 35×40 35×45 22 ×25 22 ×30 22 ×30 25.4 ×25 22 ×35 25.4 ×30 22 ×40 25.4 ×30 30 ×25 22 ×45 25.4 ×40 30 ×30 25.4 ×45 30 ×35 25.4 ×50 30 ×35 35 ×30 30 ×45 35 ×35 30 ×50 35 × 40 35 ×45 22 ×25 22 ×30 22× 30 25.4× 25 22 × 35 25.4× 30 22 ×45 25.4×35 30 ×25 22 ×50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.70 2.00 2.00 2.00 2.20 2.20 2.30 2.30 2.50 2.70 0.82 0.90 1.00 1.00 1.10 1.10 1.20 1.20 1.20 1.30 1.30 1.30 1.30 1.40 1.40 1.40 1.50 1.50 1.50 1.70 1.70 2.00 2.00 2.30 0.75 0.82 0.90 0.90 1.00 1.00 1.10 1.10 1.10 1.20 1.20 1.20 1.30 1.30 1.40 1.40 1.40 1.50 1.50 1.70 1.70 1.90 0.70 0.75 0.88 0.88 0.95 0.95 1.10 1.10 1.10 1.22 Part No. EKMQ251VSN681MA25S EKMQ251VSN821MQ45S EKMQ251VSN821MR35S EKMQ251VSN821MA30S EKMQ251VSN102MR40S EKMQ251VSN102MA30S EKMQ251VSN122MR45S EKMQ251VSN122MA35S EKMQ251VSN152MA45S EKMQ251VSN182MA50S EKMQ3B1VSN151MP25S EKMQ3B1VSN181MP30S EKMQ3B1VSN221MP30S EKMQ3B1VSN221MQ25S EKMQ3B1VSN271MP35S EKMQ3B1VSN271MQ30S EKMQ3B1VSN331MP45S EKMQ3B1VSN331MQ35S EKMQ3B1VSN331MR25S EKMQ3B1VSN391MP45S EKMQ3B1VSN391MQ40S EKMQ3B1VSN391MR30S EKMQ3B1VSN391MA25S EKMQ3B1VSN471MQ45S EKMQ3B1VSN471MR35S EKMQ3B1VSN471MA25S EKMQ3B1VSN561MQ50S EKMQ3B1VSN561MR40S EKMQ3B1VSN561MA30S EKMQ3B1VSN681MR45S EKMQ3B1VSN681MA35S EKMQ3B1VSN821MR50S EKMQ3B1VSN821MA40S EKMQ3B1VSN102MA45S EKMQ351VSN121MP25S EKMQ351VSN151MP30S EKMQ351VSN181MP30S EKMQ351VSN181MQ25S EKMQ351VSN221MP35S EKMQ351VSN221MQ30S EKMQ351VSN271MP40S EKMQ351VSN271MQ30S EKMQ351VSN271MR25S EKMQ351VSN331MP45S EKMQ351VSN331MQ40S EKMQ351VSN331MR30S EKMQ351VSN391MQ45S EKMQ351VSN391MR35S EKMQ351VSN471MQ50S EKMQ351VSN471MR35S EKMQ351VSN471MA30S EKMQ351VSN561MR45S EKMQ351VSN561MA35S EKMQ351VSN681MR50S EKMQ351VSN681MA40S EKMQ351VSN821MA45S EKMQ401VSN101MP25S EKMQ401VSN121MP30S EKMQ401VSN151MP30S EKMQ401VSN151MQ25S EKMQ401VSN181MP35S EKMQ401VSN181MQ30S EKMQ401VSN221MP45S EKMQ401VSN221MQ35S EKMQ401VSN221MR25S EKMQ401VSN271MP50S WV (Vdc) 400 420 450 Cap (µF) 270 270 270 330 330 330 390 390 390 470 470 560 560 680 82 100 100 120 120 150 150 150 180 180 180 220 220 220 220 270 270 270 330 330 330 390 390 470 470 560 680 68 82 100 100 120 120 150 150 150 180 180 180 220 220 220 270 270 270 330 330 390 390 470 560 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 105℃, 120Hz) 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 22 × 25 22 × 25 25.4 × 25 22 × 30 25.4 × 25 22 × 35 25.4 × 30 30 × 25 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 35 × 25 25.4 × 40 30 × 30 35 × 25 25.4 × 50 30 × 35 35 × 30 30 × 40 35 × 35 30 × 45 35 × 40 35 × 45 35 × 50 22 × 25 22 × 30 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 40 30 × 30 25.4 × 45 30 × 30 35 × 25 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 40 35 × 45 35 × 50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.22 1.22 1.22 1.44 1.44 1.44 1.55 1.55 1.55 1.68 1.68 1.90 1.90 2.12 0.64 0.66 0.66 0.81 0.81 0.84 0.84 0.84 0.91 0.91 0.91 1.05 1.05 1.05 1.05 1.25 1.25 1.25 1.42 1.42 1.42 1.61 1.61 1.86 1.86 2.10 2.20 0.50 0.56 0.64 0.64 0.72 0.72 0.79 0.79 0.79 0.87 0.87 0.87 1.00 1.00 1.00 1.19 1.19 1.19 1.38 1.38 1.55 1.55 1.74 1.90 Part No. EKMQ401VSN271MQ40S EKMQ401VSN271MR30S EKMQ401VSN271MA25S EKMQ401VSN331MQ45S EKMQ401VSN331MR35S EKMQ401VSN331MA30S EKMQ401VSN391MQ50S EKMQ401VSN391MR40S EKMQ401VSN391MA30S EKMQ401VSN471MR45S EKMQ401VSN471MA35S EKMQ401VSN561MR50S EKMQ401VSN561MA40S EKMQ401VSN681MA45S EKMQ421VSN820MP25S EKMQ421VSN101MP25S EKMQ421VSN101MQ25S EKMQ421VSN121MP30S EKMQ421VSN121MQ25S EKMQ421VSN151MP35S EKMQ421VSN151MQ30S EKMQ421VSN151MR25S EKMQ421VSN181MP40S EKMQ421VSN181MQ30S EKMQ421VSN181MR25S EKMQ421VSN221MP45S EKMQ421VSN221MQ35S EKMQ421VSN221MR30S EKMQ421VSN221MA25S EKMQ421VSN271MQ40S EKMQ421VSN271MR30S EKMQ421VSN271MA25S EKMQ421VSN331MQ50S EKMQ421VSN331MR35S EKMQ421VSN331MA30S EKMQ421VSN391MR40S EKMQ421VSN391MA35S EKMQ421VSN471MR45S EKMQ421VSN471MA40S EKMQ421VSN561MA45S EKMQ421VSN681MA50S EKMQ451VSN680MP25S EKMQ451VSN820MP30S EKMQ451VSN101MP30S EKMQ451VSN101MQ25S EKMQ451VSN121MP35S EKMQ451VSN121MQ30S EKMQ451VSN151MP40S EKMQ451VSN151MQ30S EKMQ451VSN151MR25S EKMQ451VSN181MP45S EKMQ451VSN181MQ40S EKMQ451VSN181MR30S EKMQ451VSN221MQ45S EKMQ451VSN221MR30S EKMQ451VSN221MA25S EKMQ451VSN271MQ50S EKMQ451VSN271MR40S EKMQ451VSN271MA30S EKMQ451VSN331MR45S EKMQ451VSN331MA35S EKMQ451VSN391MR50S EKMQ451VSN391MA40S EKMQ451VSN471MA45S EKMQ451VSN561MA50S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Standard snap-ins, 105℃ KMQSeries ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 35, 50Vdc 160 to 250Vdc 315 to 450Vdc 50 0.95 0.81 0.77 120 1.00 1.00 1.00 300 1.03 1.17 1.16 1k 1.05 1.32 1.30 10k 1.08 1.45 1.41 50k 1.08 1.50 1.43 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EKMQ451VSD331MA35S 价格&库存
很抱歉,暂时无法提供与“EKMQ451VSD331MA35S”相匹配的价格&库存,您可以联系我们找货
