MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
Downsized, 105℃
KMQ
Series
・Downsized from current standard KMG series
・Solvent resistant type except 160 to 450Vdc
(see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +105℃(6.3 to 100Vdc) -40 to +105℃(160 to 400Vdc) -25 to +105℃(450Vdc)
6.3 to 450Vdc
±20% (M)
6.3 to 100Vdc
I=0.03CV or 4µA, whichever is greater.
(at 20℃, 120Hz)
160 to 450Vdc
CV≦1,000
I=0.1CV+40 max.
CV>1,000
I=0.04CV+100 max.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 1 minute)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V
tanδ(Max.)
0.28 0.24 0.20 0.16 0.14 0.12 0.10 0.08
0.20
0.24
0.24
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63 to 100V 160 to 200V 250V 350V 400V 450V
5
4
3
2
2
2
2
3
3
4
4
6
≦φ8
Z(-25℃)/Z(+20℃)
5
4
3
2
2
2
2
3
3
4
4
6
≧φ10
10
8
6
4
3
3
3
8
10
8
8
≦φ8
Z(-40℃)/Z(+20℃)
(at 120Hz)
8
6
4
3
3
3
4
4
6
6
≧φ10 10
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 1,000 hours (2,000 hours forφ10 and more) at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Rated voltage
6.3 to 100Vdc
160 to 450Vdc
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φD'
φd
Sleeve (PET : Brown)
F±0.5
Code : E
F±0.5
● Terminal
15min.
L'
Vent
(except φ5)
4min.
(φ5 to φ10)
(φ12.5 to φ18)
Gas escape end seal
φD
5
φd 0.5
F
2.0
φD'
L'
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
18
0.8
7.5
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KMQ A A A E A A A A A M A A A N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,35V:350,100V:101)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001X 2023
Downsized, 105℃
KMQSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
50
Cap
(µF)
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
100
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
47
68
100
220
330
470
1,000
2,200
3,300
4,700
6,800
1.0
2.2
3.3
4.7
10
22
33
47
68
100
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
8 ×11.5
10 ×16
10 ×20
12.5× 20
12.5× 25
16 ×25
16 ×31.5
18 ×35.5
5 ×11
6.3×11
6.3×11
10 ×12.5
10 ×16
12.5× 20
12.5× 25
16 ×25
16 ×31.5
16 ×35.5
18 ×40
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×20
12.5× 25
16 ×25
16 ×25
16 ×35.5
18 ×40
5 ×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 25
16 ×25
16 ×25
16 ×35.5
18 ×40
5 ×11
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 20
16 ×25
16 ×31.5
16 ×35.5
18 ×40
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
6.3×11
6.3×11
8 ×11.5
0.28
0.30
0.32
0.34
0.38
0.46
0.56
0.70
0.24
0.24
0.24
0.24
0.26
0.28
0.30
0.34
0.42
0.52
0.66
0.20
0.20
0.20
0.20
0.22
0.24
0.26
0.30
0.38
0.48
0.16
0.16
0.16
0.16
0.16
0.18
0.20
0.22
0.26
0.34
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.16
0.18
0.20
0.24
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
390
635
840
1,090
1,350
1,650
1,820
2,280
155
210
250
460
705
1,000
1,260
1,570
1,820
2,050
2,420
190
225
315
500
710
1,170
1,500
1,600
1,930
2,210
125
200
310
380
610
1,090
1,400
1,570
1,850
2,000
93
110
150
270
350
460
810
1,260
1,500
1,780
2,000
13
30
46
68
90
115
150
190
Part No.
EKMQ6R3E□□102MHB5D
EKMQ6R3E□□222MJ16S
EKMQ6R3E□□332MJ20S
EKMQ6R3E□□472MK20S
EKMQ6R3E□□682MK25S
EKMQ6R3E□□103ML25S
EKMQ6R3E□□153MLN3S
EKMQ6R3E□□223MMP1S
EKMQ100E□□221ME11D
EKMQ100E□□331MF11D
EKMQ100E□□471MF11D
EKMQ100E□□102MJC5S
EKMQ100E□□222MJ16S
EKMQ100E□□332MK20S
EKMQ100E□□472MK25S
EKMQ100E□□682ML25S
EKMQ100E□□103MLN3S
EKMQ100E□□153MLP1S
EKMQ100E□□223MM40S
EKMQ160E□□221MF11D
EKMQ160E□□331MF11D
EKMQ160E□□471MHB5D
EKMQ160E□□102MJC5S
EKMQ160E□□222MJ20S
EKMQ160E□□332MK25S
EKMQ160E□□472ML25S
EKMQ160E□□682ML25S
EKMQ160E□□103MLP1S
EKMQ160E□□153MM40S
EKMQ250E□□101ME11D
EKMQ250E□□221MF11D
EKMQ250E□□331MHB5D
EKMQ250E□□471MJC5S
EKMQ250E□□102MJ16S
EKMQ250E□□222MK25S
EKMQ250E□□332ML25S
EKMQ250E□□472ML25S
EKMQ250E□□682MLP1S
EKMQ250E□□103MM40S
EKMQ350E□□470ME11D
EKMQ350E□□680MF11D
EKMQ350E□□101MF11D
EKMQ350E□□221MHB5D
EKMQ350E□□331MJC5S
EKMQ350E□□471MJ16S
EKMQ350E□□102MK20S
EKMQ350E□□222ML25S
EKMQ350E□□332MLN3S
EKMQ350E□□472MLP1S
EKMQ350E□□682MM40S
EKMQ500E□□1R0ME11D
EKMQ500E□□2R2ME11D
EKMQ500E□□3R3ME11D
EKMQ500E□□4R7ME11D
EKMQ500E□□100ME11D
EKMQ500E□□220ME11D
EKMQ500E□□330ME11D
EKMQ500E□□470MF11D
EKMQ500E□□680MF11D
EKMQ500E□□101MHB5D
WV
(Vdc)
50
63
100
*1
160
*1
200
*1
250
*1
350
*1
400
*1
450
Cap
(µF)
220
330
470
1,000
2,200
3,300
22
33
47
68
100
220
330
470
1,000
2,200
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
470
1,000
68
100
220
330
470
47
68
100
220
330
47
68
100
220
22
33
47
68
100
22
33
47
68
100
22
33
47
68
100
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
10 × 12.5
10 × 16
10 × 20
12.5 × 25
16 × 31.5
18 × 35.5
5 × 11
6.3 × 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 16
10 × 20
12.5 × 20
16 × 25
18 × 35.5
5 × 11
5 × 11
5 × 11
5 × 11
5 × 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
10 × 16
12.5 × 20
12.5 × 25
16 × 25
18 × 35.5
12.5 × 20
12.5 × 25
16 × 31.5
18 × 35.5
18 × 40
12.5 × 20
12.5 × 25
16 × 25
16 × 35.5
18 × 40
12.5 × 20
16 × 25
16 × 25
18 × 35.5
12.5 × 20
12.5 × 25
16 × 25
16 × 25
18 × 31.5
12.5 × 25
16 × 25
16 × 25
16 × 31.5
18 × 35.5
12.5 × 25
16 × 25
16 × 31.5
18 × 35.5
18 × 40
0.12
0.12
0.12
0.12
0.14
0.16
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.12
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
300
410
540
950
1,410
1,770
71
100
120
155
200
335
510
640
930
1,650
15
21
29
32
50
93
130
140
190
240
390
540
715
960
250
310
540
705
855
195
250
335
500
675
190
270
310
485
130
170
230
285
375
145
195
200
240
310
100
125
155
185
200
Part No.
EKMQ500E□□221MJC5S
EKMQ500E□□331MJ16S
EKMQ500E□□471MJ20S
EKMQ500E□□102MK25S
EKMQ500E□□222MLN3S
EKMQ500E□□332MMP1S
EKMQ630E□□220ME11D
EKMQ630E□□330MF11D
EKMQ630E□□470MF11D
EKMQ630E□□680MHB5D
EKMQ630E□□101MHB5D
EKMQ630E□□221MJ16S
EKMQ630E□□331MJ20S
EKMQ630E□□471MK20S
EKMQ630E□□102ML25S
EKMQ630E□□222MMP1S
EKMQ101E□□1R0ME11D
EKMQ101E□□2R2ME11D
EKMQ101E□□3R3ME11D
EKMQ101E□□4R7ME11D
EKMQ101E□□100ME11D
EKMQ101E□□220MF11D
EKMQ101E□□330MHB5D
EKMQ101E□□470MHB5D
EKMQ101E□□680MJC5S
EKMQ101E□□101MJ16S
EKMQ101E□□221MK20S
EKMQ101E□□331MK25S
EKMQ101E□□471ML25S
EKMQ101E□□102MMP1S
EKMQ161E□□680MK20S
EKMQ161E□□101MK25S
EKMQ161E□□221MLN3S
EKMQ161E□□331MMP1S
EKMQ161E□□471MM40S
EKMQ201E□□470MK20S
EKMQ201E□□680MK25S
EKMQ201E□□101ML25S
EKMQ201E□□221MLP1S
EKMQ201E□□331MM40S
EKMQ251E□□470MK20S
EKMQ251E□□680ML25S
EKMQ251E□□101ML25S
EKMQ251E□□221MMP1S
EKMQ351E□□220MK20S
EKMQ351E□□330MK25S
EKMQ351E□□470ML25S
EKMQ351E□□680ML25S
EKMQ351E□□101MMN3S
EKMQ401E□□220MK25S
EKMQ401E□□330ML25S
EKMQ401E□□470ML25S
EKMQ401E□□680MLN3S
EKMQ401E□□101MMP1S
EKMQ451E□□220MK25S
EKMQ451E□□330ML25S
EKMQ451E□□470MLN3S
EKMQ451E□□680MMP1S
EKMQ451E□□101MM40S
□□ : Enter the appropriate lead forming or taping code.
is scheduled to be discontinued.
Production of the products shown in
*1: Assembly boards with the designated products attached cannot be cleaned.
Downsized, 105℃
KMQSeries
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
1.0
10
100
2,200
Frequency(Hz)
to 4.7
to 68
to 1,000
to
50
0.65
0.75
0.80
0.85
120
1.00
1.00
1.00
1.00
300
1.35
1.25
1.15
1.03
1k
1.75
1.50
1.30
1.05
10k
2.30
1.75
1.40
1.08
100k
2.50
1.80
1.50
1.08
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming
goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Part Numbering System
Part Numbering System (Appendix)
Standardization
Available Items by Manufacturing Locations
Environmental Measures
Technical Note
Precautions and Guidelines
Recommended Soldering Conditions
Taping, Lead-preforming and Packaging
Available Terminals for Snap-in and Screw Mount Type
