EKMQ250ELL153MP50S
EKMQ250ELL153MP50S
    NCC(贵弥功)
    插件
    15000 µF 25 V 铝电解电容器 径向,Can 105°C 时为 2000 小时
EKMQ250ELL153MP50S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105℃ KMQ Series ・Downsized from current standard KMG series ・Solvent resistant type except 160 to 450Vdc (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃(6.3 to 100Vdc) -40 to +105℃(160 to 400Vdc) -25 to +105℃(450Vdc) 6.3 to 450Vdc ±20% (M) 6.3 to 100Vdc I=0.03CV or 4µA, whichever is greater. (at 20℃, 120Hz) 160 to 450Vdc CV≦1,000 I=0.1CV+40 max. CV>1,000 I=0.04CV+100 max. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 1 minute) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V tanδ(Max.) 0.28 0.24 0.20 0.16 0.14 0.12 0.10 0.08 0.20 0.24 0.24 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63 to 100V 160 to 200V 250V 350V 400V 450V 5 4 3 2 2 2 2 3 3 4 4 6 ≦φ8 Z(-25℃)/Z(+20℃) 5 4 3 2 2 2 2 3 3 4 4 6 ≧φ10 10 8 6 4 3 3 3 8 10 8 8 ≦φ8 Z(-40℃)/Z(+20℃) (at 120Hz) 8 6 4 3 3 3 4 4 6 6 ≧φ10 10 The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 1,000 hours (2,000 hours forφ10 and more) at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3 to 100Vdc 160 to 450Vdc Capacitance change ≦±20% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] φD' φd Sleeve (PET : Brown) F±0.5 Code : E F±0.5 ● Terminal 15min. L' Vent (except φ5) 4min. (φ5 to φ10) (φ12.5 to φ18) Gas escape end seal φD 5 φd 0.5 F 2.0 φD' L' 6.3 0.5 2.5 10 12.5 8 0.6 0.6 0.6 3.5 5.0 5.0 φD+0.5max. L+1.5max. 16 0.8 7.5 18 0.8 7.5 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KMQ A A A E A A A A A M A A A N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3,35V:350,100V:101) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105℃ KMQSeries ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 25 35 50 Cap (µF) 1,000 2,200 3,300 4,700 6,800 10,000 15,000 22,000 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 22,000 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 15,000 100 220 330 470 1,000 2,200 3,300 4,700 6,800 10,000 47 68 100 220 330 470 1,000 2,200 3,300 4,700 6,800 1.0 2.2 3.3 4.7 10 22 33 47 68 100 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 8 ×11.5 10 ×16 10 ×20 12.5× 20 12.5× 25 16 ×25 16 ×31.5 18 ×35.5 5 ×11 6.3×11 6.3×11 10 ×12.5 10 ×16 12.5× 20 12.5× 25 16 ×25 16 ×31.5 16 ×35.5 18 ×40 6.3×11 6.3×11 8 ×11.5 10 ×12.5 10 ×20 12.5× 25 16 ×25 16 ×25 16 ×35.5 18 ×40 5 ×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 12.5× 25 16 ×25 16 ×25 16 ×35.5 18 ×40 5 ×11 6.3×11 6.3×11 8 ×11.5 10 ×12.5 10 ×16 12.5× 20 16 ×25 16 ×31.5 16 ×35.5 18 ×40 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 5 ×11 6.3×11 6.3×11 8 ×11.5 0.28 0.30 0.32 0.34 0.38 0.46 0.56 0.70 0.24 0.24 0.24 0.24 0.26 0.28 0.30 0.34 0.42 0.52 0.66 0.20 0.20 0.20 0.20 0.22 0.24 0.26 0.30 0.38 0.48 0.16 0.16 0.16 0.16 0.16 0.18 0.20 0.22 0.26 0.34 0.14 0.14 0.14 0.14 0.14 0.14 0.14 0.16 0.18 0.20 0.24 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 390 635 840 1,090 1,350 1,650 1,820 2,280 155 210 250 460 705 1,000 1,260 1,570 1,820 2,050 2,420 190 225 315 500 710 1,170 1,500 1,600 1,930 2,210 125 200 310 380 610 1,090 1,400 1,570 1,850 2,000 93 110 150 270 350 460 810 1,260 1,500 1,780 2,000 13 20 25 30 46 68 90 115 150 190 Part No. EKMQ6R3E□□102MHB5D EKMQ6R3E□□222MJ16S EKMQ6R3E□□332MJ20S EKMQ6R3E□□472MK20S EKMQ6R3E□□682MK25S EKMQ6R3E□□103ML25S EKMQ6R3E□□153MLN3S EKMQ6R3E□□223MMP1S EKMQ100E□□221ME11D EKMQ100E□□331MF11D EKMQ100E□□471MF11D EKMQ100E□□102MJC5S EKMQ100E□□222MJ16S EKMQ100E□□332MK20S EKMQ100E□□472MK25S EKMQ100E□□682ML25S EKMQ100E□□103MLN3S EKMQ100E□□153MLP1S EKMQ100E□□223MM40S EKMQ160E□□221MF11D EKMQ160E□□331MF11D EKMQ160E□□471MHB5D EKMQ160E□□102MJC5S EKMQ160E□□222MJ20S EKMQ160E□□332MK25S EKMQ160E□□472ML25S EKMQ160E□□682ML25S EKMQ160E□□103MLP1S EKMQ160E□□153MM40S EKMQ250E□□101ME11D EKMQ250E□□221MF11D EKMQ250E□□331MHB5D EKMQ250E□□471MJC5S EKMQ250E□□102MJ16S EKMQ250E□□222MK25S EKMQ250E□□332ML25S EKMQ250E□□472ML25S EKMQ250E□□682MLP1S EKMQ250E□□103MM40S EKMQ350E□□470ME11D EKMQ350E□□680MF11D EKMQ350E□□101MF11D EKMQ350E□□221MHB5D EKMQ350E□□331MJC5S EKMQ350E□□471MJ16S EKMQ350E□□102MK20S EKMQ350E□□222ML25S EKMQ350E□□332MLN3S EKMQ350E□□472MLP1S EKMQ350E□□682MM40S EKMQ500E□□1R0ME11D EKMQ500E□□2R2ME11D EKMQ500E□□3R3ME11D EKMQ500E□□4R7ME11D EKMQ500E□□100ME11D EKMQ500E□□220ME11D EKMQ500E□□330ME11D EKMQ500E□□470MF11D EKMQ500E□□680MF11D EKMQ500E□□101MHB5D WV (Vdc) 50 63 100 *1 160 *1 200 *1 250 *1 350 *1 400 *1 450 Cap (µF) 220 330 470 1,000 2,200 3,300 22 33 47 68 100 220 330 470 1,000 2,200 1.0 2.2 3.3 4.7 10 22 33 47 68 100 220 330 470 1,000 68 100 220 330 470 47 68 100 220 330 47 68 100 220 22 33 47 68 100 22 33 47 68 100 22 33 47 68 100 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 10 × 12.5 10 × 16 10 × 20 12.5 × 25 16 × 31.5 18 × 35.5 5 × 11 6.3 × 11 6.3 × 11 8 × 11.5 8 × 11.5 10 × 16 10 × 20 12.5 × 20 16 × 25 18 × 35.5 5 × 11 5 × 11 5 × 11 5 × 11 5 × 11 6.3 × 11 8 × 11.5 8 × 11.5 10 × 12.5 10 × 16 12.5 × 20 12.5 × 25 16 × 25 18 × 35.5 12.5 × 20 12.5 × 25 16 × 31.5 18 × 35.5 18 × 40 12.5 × 20 12.5 × 25 16 × 25 16 × 35.5 18 × 40 12.5 × 20 16 × 25 16 × 25 18 × 35.5 12.5 × 20 12.5 × 25 16 × 25 16 × 25 18 × 31.5 12.5 × 25 16 × 25 16 × 25 16 × 31.5 18 × 35.5 12.5 × 25 16 × 25 16 × 31.5 18 × 35.5 18 × 40 0.12 0.12 0.12 0.12 0.14 0.16 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.10 0.12 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.08 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 300 410 540 950 1,410 1,770 71 100 120 155 200 335 510 640 930 1,650 15 21 29 32 50 93 130 140 190 240 390 540 715 960 250 310 540 705 855 195 250 335 500 675 190 270 310 485 130 170 230 285 375 145 195 200 240 310 100 125 155 185 200 Part No. EKMQ500E□□221MJC5S EKMQ500E□□331MJ16S EKMQ500E□□471MJ20S EKMQ500E□□102MK25S EKMQ500E□□222MLN3S EKMQ500E□□332MMP1S EKMQ630E□□220ME11D EKMQ630E□□330MF11D EKMQ630E□□470MF11D EKMQ630E□□680MHB5D EKMQ630E□□101MHB5D EKMQ630E□□221MJ16S EKMQ630E□□331MJ20S EKMQ630E□□471MK20S EKMQ630E□□102ML25S EKMQ630E□□222MMP1S EKMQ101E□□1R0ME11D EKMQ101E□□2R2ME11D EKMQ101E□□3R3ME11D EKMQ101E□□4R7ME11D EKMQ101E□□100ME11D EKMQ101E□□220MF11D EKMQ101E□□330MHB5D EKMQ101E□□470MHB5D EKMQ101E□□680MJC5S EKMQ101E□□101MJ16S EKMQ101E□□221MK20S EKMQ101E□□331MK25S EKMQ101E□□471ML25S EKMQ101E□□102MMP1S EKMQ161E□□680MK20S EKMQ161E□□101MK25S EKMQ161E□□221MLN3S EKMQ161E□□331MMP1S EKMQ161E□□471MM40S EKMQ201E□□470MK20S EKMQ201E□□680MK25S EKMQ201E□□101ML25S EKMQ201E□□221MLP1S EKMQ201E□□331MM40S EKMQ251E□□470MK20S EKMQ251E□□680ML25S EKMQ251E□□101ML25S EKMQ251E□□221MMP1S EKMQ351E□□220MK20S EKMQ351E□□330MK25S EKMQ351E□□470ML25S EKMQ351E□□680ML25S EKMQ351E□□101MMN3S EKMQ401E□□220MK25S EKMQ401E□□330ML25S EKMQ401E□□470ML25S EKMQ401E□□680MLN3S EKMQ401E□□101MMP1S EKMQ451E□□220MK25S EKMQ451E□□330ML25S EKMQ451E□□470MLN3S EKMQ451E□□680MMP1S EKMQ451E□□101MM40S □□ : Enter the appropriate lead forming or taping code. is scheduled to be discontinued. Production of the products shown in *1: Assembly boards with the designated products attached cannot be cleaned. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Downsized, 105℃ KMQSeries ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) 1.0 10 100 2,200 Frequency(Hz) to 4.7 to 68 to 1,000 to 50 0.65 0.75 0.80 0.85 120 1.00 1.00 1.00 1.00 300 1.35 1.25 1.15 1.03 1k 1.75 1.50 1.30 1.05 10k 2.30 1.75 1.40 1.08 100k 2.50 1.80 1.50 1.08 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EKMQ250ELL153MP50S 价格&库存
很抱歉,暂时无法提供与“EKMQ250ELL153MP50S”相匹配的价格&库存,您可以联系我们找货
