LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS
KMM
LXS
Series
LXQ
Longer life
Longer life
・Longer life from KMQ series
・Endurance with ripple current : 2,000 to 3,000 hours at 105℃
・Non solvent resistant type
・RoHS2 Compliant
Long life snap-ins, 105℃
KMM
KMS
Downsized
Longer life
KMQ
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-25 to +105℃
160 to 450Vdc
±20% (M)
I≦3 CV
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
160 to 400V
420 & 450V
tanδ(Max.)
0.15
0.20
Rated voltage (Vdc)
160 to 400V
420 & 450V
Z(-25℃)/Z(+20℃)
4
8
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 5 minutes)
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage)for 3,000 hours at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
≦±15% of the initial value
D.F. (tanδ)
≦150% of the initial specified value
Leakage current
Endurance
Shelf Life
◆DIMENSIONS [mm]
●Terminal
Sleeve (PET : Brown)
Negative mark
PC board pin-out
(View from Solder side)
φD+1max.
10
Vent
2-φ2
4.0±0.5
L±2
Code : LI (φ35)
Negative mark
PC board pin-out
2-1.2×6
4.2±0.5
Code : VS (φ22 toφ35) : Standard
φD+1max.
●Terminal
Vent
5±0.5
L±2
4.5±1
14.2±1
*φD=35mm : 3.5±0.5mm
The standard design has no plastic disc.
◆PART NUMBERING SYSTEM
1
2
3
4
E K MM
5
6
7
8
9
10
VS N
11
12
13
14
M
15
16
17
18
S
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 120µF:121, 1,000µF:102)
Dummy terminal code
Terminal code (VS, LI)
Voltage code (ex. 160V:161, 250V:251, 315V:3B1)
Series code
Category
Please refer to "Product code guide (snap-in type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001X 2023
KMMSeries
◆STANDARD RATINGS
WV
(Vdc)
160
180
Cap
(µF)
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
220
270
330
330
390
390
390
470
470
470
560
560
560
560
680
680
680
680
820
820
820
820
1,000
1,000
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,500
1,800
1,800
2,200
2,200
2,700
3,300
180
220
270
270
330
330
330
390
390
390
470
470
470
470
560
560
560
560
680
680
680
680
820
820
820
820
1,000
1,000
1,000
22 ×20
25.4×20
22 ×25
25.4 ×20
22 ×25
25.4 ×25
30× 20
22× 30
25.4× 25
30 × 20
22 × 35
25.4× 30
30 ×25
35 ×20
22 ×40
25.4×30
30 ×25
35 ×20
22× 45
25.4× 35
30 × 30
35 × 25
22 × 50
25.4× 40
30 × 30
35 × 25
25.4 × 45
30 × 35
35 × 30
25.4 × 60
30 × 40
35 × 30
30 × 45
35 × 35
30 × 60
35 × 45
35 × 50
35 × 60
22 × 20
25.4 × 20
22 × 25
25.4 × 20
22 × 25
25.4 × 25
30 × 20
22 × 30
25.4 × 25
30 × 20
22 × 35
25.4 × 30
30 × 25
35 × 20
22 × 40
25.4 × 30
30 × 25
35 ×20
22 ×45
25.4 ×35
30× 30
35 × 25
22 ×50
25.4×40
30 ×30
35 ×25
25.4 ×45
30× 35
35 × 30
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.81
0.98
1.20
1.02
1.30
1.26
1.25
1.55
1.55
1.30
1.67
1.67
1.67
1.46
1.82
1.82
1.82
1.51
2.04
2.04
2.04
2.04
2.25
2.25
2.25
2.25
2.49
2.49
2.49
2.97
2.84
2.84
3.32
3.00
3.86
3.50
4.00
4.63
0.80
0.90
1.00
0.95
1.20
1.16
1.15
1.35
1.35
1.20
1.50
1.50
1.50
1.36
1.67
1.67
1.67
1.43
1.78
1.78
1.78
1.83
2.04
2.04
2.04
2.04
2.30
2.30
2.30
Part No.
EKMM161VSN221MP20S
EKMM161VSN271MQ20S
EKMM161VSN331MP25S
EKMM161VSN331MQ20S
EKMM161VSN391MP25S
EKMM161VSN391MQ25S
EKMM161VSN391MR20S
EKMM161VSN471MP30S
EKMM161VSN471MQ25S
EKMM161VSN471MR20S
EKMM161VSN561MP35S
EKMM161VSN561MQ30S
EKMM161VSN561MR25S
EKMM161VSN561MA20S
EKMM161VSN681MP40S
EKMM161VSN681MQ30S
EKMM161VSN681MR25S
EKMM161VSN681MA20S
EKMM161VSN821MP45S
EKMM161VSN821MQ35S
EKMM161VSN821MR30S
EKMM161VSN821MA25S
EKMM161VSN102MP50S
EKMM161VSN102MQ40S
EKMM161VSN102MR30S
EKMM161VSN102MA25S
EKMM161VSN122MQ45S
EKMM161VSN122MR35S
EKMM161VSN122MA30S
EKMM161VSN152MQ60S
EKMM161VSN152MR40S
EKMM161VSN152MA30S
EKMM161VSN182MR45S
EKMM161VSN182MA35S
EKMM161VSN222MR60S
EKMM161VSN222MA45S
EKMM161VSN272MA50S
EKMM161VSN332MA60S
EKMM181VSN181MP20S
EKMM181VSN221MQ20S
EKMM181VSN271MP25S
EKMM181VSN271MQ20S
EKMM181VSN331MP25S
EKMM181VSN331MQ25S
EKMM181VSN331MR20S
EKMM181VSN391MP30S
EKMM181VSN391MQ25S
EKMM181VSN391MR20S
EKMM181VSN471MP35S
EKMM181VSN471MQ30S
EKMM181VSN471MR25S
EKMM181VSN471MA20S
EKMM181VSN561MP40S
EKMM181VSN561MQ30S
EKMM181VSN561MR25S
EKMM181VSN561MA20S
EKMM181VSN681MP45S
EKMM181VSN681MQ35S
EKMM181VSN681MR30S
EKMM181VSN681MA25S
EKMM181VSN821MP50S
EKMM181VSN821MQ40S
EKMM181VSN821MR30S
EKMM181VSN821MA25S
EKMM181VSN102MQ45S
EKMM181VSN102MR35S
EKMM181VSN102MA30S
WV
(Vdc)
180
200
220
Cap
(µF)
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
1,200
1,200
1,200
1,500
1,500
1,800
1,800
2,200
2,700
150
180
220
270
270
330
330
330
390
390
390
470
470
470
470
560
560
560
680
680
680
680
820
820
820
1,000
1,000
1,000
1,200
1,200
1,200
1,500
1,500
1,800
1,800
2,200
150
180
220
220
270
270
270
330
330
330
390
390
390
390
470
470
470
560
560
560
560
680
25.4× 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 60
35 × 40
35 × 50
35 × 60
22 × 20
22 × 20
25.4 × 20
22 × 25
30 × 20
22 × 30
25.4 × 25
30 × 20
22 × 30
25.4 × 25
35 × 20
22 × 35
25.4 × 30
30 × 25
35 × 20
22 × 40
25.4 × 30
30 × 25
22 × 45
25.4 × 35
30 × 30
35 × 25
25.4 × 45
30 × 30
35 × 25
25.4 × 50
30 × 35
35 × 30
25.4 × 60
30 × 40
35 × 35
30 × 50
35 × 40
30 × 60
35 × 45
35 × 50
22 × 20
25.4 × 20
22 × 25
25.4 × 20
22 × 30
25.4 × 25
30 × 20
22 × 35
25.4 × 25
35 × 20
22 × 35
25.4 × 30
30 × 25
35 × 20
22 × 40
25.4 × 35
30 × 25
22 × 45
25.4 × 40
30 × 30
35 × 25
25.4 × 45
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
2.55
2.55
2.55
2.90
2.90
3.49
3.30
3.65
4.19
0.73
0.80
0.85
1.10
1.05
1.25
1.25
1.10
1.35
1.35
1.30
1.50
1.50
1.50
1.41
1.67
1.67
1.67
1.78
1.78
1.78
1.78
2.04
2.04
2.04
2.30
2.30
2.30
2.66
2.65
2.65
3.08
3.08
3.49
3.48
3.78
0.67
0.76
1.00
0.84
1.15
1.08
0.98
1.25
1.25
1.13
1.40
1.40
1.36
1.23
1.51
1.54
1.50
1.70
1.72
1.70
1.71
1.94
Part No.
EKMM181VSN122MQ50S
EKMM181VSN122MR40S
EKMM181VSN122MA30S
EKMM181VSN152MR45S
EKMM181VSN152MA35S
EKMM181VSN182MR60S
EKMM181VSN182MA40S
EKMM181VSN222MA50S
EKMM181VSN272MA60S
EKMM201VSN151MP20S
EKMM201VSN181MP20S
EKMM201VSN221MQ20S
EKMM201VSN271MP25S
EKMM201VSN271MR20S
EKMM201VSN331MP30S
EKMM201VSN331MQ25S
EKMM201VSN331MR20S
EKMM201VSN391MP30S
EKMM201VSN391MQ25S
EKMM201VSN391MA20S
EKMM201VSN471MP35S
EKMM201VSN471MQ30S
EKMM201VSN471MR25S
EKMM201VSN471MA20S
EKMM201VSN561MP40S
EKMM201VSN561MQ30S
EKMM201VSN561MR25S
EKMM201VSN681MP45S
EKMM201VSN681MQ35S
EKMM201VSN681MR30S
EKMM201VSN681MA25S
EKMM201VSN821MQ45S
EKMM201VSN821MR30S
EKMM201VSN821MA25S
EKMM201VSN102MQ50S
EKMM201VSN102MR35S
EKMM201VSN102MA30S
EKMM201VSN122MQ60S
EKMM201VSN122MR40S
EKMM201VSN122MA35S
EKMM201VSN152MR50S
EKMM201VSN152MA40S
EKMM201VSN182MR60S
EKMM201VSN182MA45S
EKMM201VSN222MA50S
EKMM221VSN151MP20S
EKMM221VSN181MQ20S
EKMM221VSN221MP25S
EKMM221VSN221MQ20S
EKMM221VSN271MP30S
EKMM221VSN271MQ25S
EKMM221VSN271MR20S
EKMM221VSN331MP35S
EKMM221VSN331MQ25S
EKMM221VSN331MA20S
EKMM221VSN391MP35S
EKMM221VSN391MQ30S
EKMM221VSN391MR25S
EKMM221VSN391MA20S
EKMM221VSN471MP40S
EKMM221VSN471MQ35S
EKMM221VSN471MR25S
EKMM221VSN561MP45S
EKMM221VSN561MQ40S
EKMM221VSN561MR30S
EKMM221VSN561MA25S
EKMM221VSN681MQ45S
KMMSeries
◆STANDARD RATINGS
WV
(Vdc)
220
250
315
Cap
(µF)
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
680
680
820
820
820
1,000
1,000
1,000
1,200
1,200
1,500
1,500
1,800
2,200
120
150
180
180
220
220
220
270
270
270
330
330
330
330
390
390
390
470
470
470
470
560
560
560
560
680
680
680
820
820
820
1,000
1,000
1,200
1,200
1,500
1,800
68
82
100
100
120
120
120
150
150
150
150
180
180
180
180
220
30 ×35
35 ×25
25.4 ×50
30 ×40
35× 30
25.4× 60
30× 45
35× 35
30× 50
35× 40
30× 60
35× 45
35× 50
35× 60
22× 20
25.4× 20
22 × 25
25.4× 20
22 × 25
25.4× 25
30 ×20
22 ×30
25.4×25
30 ×20
22 ×35
25.4× 30
30 ×25
35 ×20
22 ×40
25.4×35
30 ×25
22 ×45
25.4×35
30 ×30
35 ×25
22 ×50
25.4×40
30 ×30
35 ×25
25.4×50
30 ×35
35 ×30
25.4×60
30 ×40
35 ×35
30 ×50
35 ×40
30 ×60
35 ×45
35 ×50
35 ×60
22×20
22×20
22 ×25
25.4× 20
22 ×25
25.4×20
30 ×20
22× 30
25.4× 25
30 × 20
35 ×20
22 ×35
25.4 ×25
30 × 25
35 × 20
22 ×40
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
1.93
1.89
2.18
2.19
2.16
2.54
2.50
2.44
2.81
2.79
3.30
3.22
3.63
4.23
0.60
0.74
0.78
0.75
1.00
0.95
0.95
1.18
1.18
1.00
1.30
1.30
1.30
1.16
1.49
1.49
1.49
1.65
1.65
1.65
1.65
1.67
1.80
1.80
1.80
2.00
2.00
2.00
2.20
2.30
2.30
2.47
2.47
2.85
2.60
3.00
3.42
0.45
0.47
0.61
0.56
0.75
0.62
0.65
0.82
0.82
0.70
0.76
0.92
0.92
0.90
0.85
1.04
Part No.
EKMM221VSN681MR35S
EKMM221VSN681MA25S
EKMM221VSN821MQ50S
EKMM221VSN821MR40S
EKMM221VSN821MA30S
EKMM221VSN102MQ60S
EKMM221VSN102MR45S
EKMM221VSN102MA35S
EKMM221VSN122MR50S
EKMM221VSN122MA40S
EKMM221VSN152MR60S
EKMM221VSN152MA45S
EKMM221VSN182MA50S
EKMM221VSN222MA60S
EKMM251VSN121MP20S
EKMM251VSN151MQ20S
EKMM251VSN181MP25S
EKMM251VSN181MQ20S
EKMM251VSN221MP25S
EKMM251VSN221MQ25S
EKMM251VSN221MR20S
EKMM251VSN271MP30S
EKMM251VSN271MQ25S
EKMM251VSN271MR20S
EKMM251VSN331MP35S
EKMM251VSN331MQ30S
EKMM251VSN331MR25S
EKMM251VSN331MA20S
EKMM251VSN391MP40S
EKMM251VSN391MQ35S
EKMM251VSN391MR25S
EKMM251VSN471MP45S
EKMM251VSN471MQ35S
EKMM251VSN471MR30S
EKMM251VSN471MA25S
EKMM251VSN561MP50S
EKMM251VSN561MQ40S
EKMM251VSN561MR30S
EKMM251VSN561MA25S
EKMM251VSN681MQ50S
EKMM251VSN681MR35S
EKMM251VSN681MA30S
EKMM251VSN821MQ60S
EKMM251VSN821MR40S
EKMM251VSN821MA35S
EKMM251VSN102MR50S
EKMM251VSN102MA40S
EKMM251VSN122MR60S
EKMM251VSN122MA45S
EKMM251VSN152MA50S
EKMM251VSN182MA60S
EKMM3B1VSN680MP20S
EKMM3B1VSN820MP20S
EKMM3B1VSN101MP25S
EKMM3B1VSN101MQ20S
EKMM3B1VSN121MP25S
EKMM3B1VSN121MQ20S
EKMM3B1VSN121MR20S
EKMM3B1VSN151MP30S
EKMM3B1VSN151MQ25S
EKMM3B1VSN151MR20S
EKMM3B1VSN151MA20S
EKMM3B1VSN181MP35S
EKMM3B1VSN181MQ25S
EKMM3B1VSN181MR25S
EKMM3B1VSN181MA20S
EKMM3B1VSN221MP40S
WV
(Vdc)
315
350
400
Cap
(µF)
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
220
220
220
270
270
270
270
330
330
330
330
390
390
390
470
470
470
560
560
680
680
820
1,000
56
68
82
82
100
100
120
120
120
150
150
150
150
180
180
180
220
220
220
220
270
270
270
270
330
330
330
390
390
390
470
470
470
560
560
680
680
820
47
56
68
68
82
82
25.4× 30
30 × 25
35 × 20
22 × 45
25.4 × 35
30 × 25
35 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
30 × 35
35 × 30
25.4 × 50
30 × 40
35 × 30
30 × 45
35 × 35
30 × 50
35 × 40
35 × 45
35 × 60
22 × 20
25.4 × 20
22 × 25
25.4 × 20
22 × 25
30 × 20
22 × 30
25.4 × 25
30 × 20
22 × 35
25.4 × 30
30 × 25
35 × 20
22 × 40
25.4 × 30
30 × 25
22 × 45
25.4 × 35
30 × 30
35 × 25
22 × 50
25.4 × 40
30 × 30
35 × 25
25.4 × 45
30 × 35
35 × 30
25.4 × 50
30 × 40
35 × 35
25.4 × 60
30 × 45
35 × 35
30 × 50
35 × 40
30 × 60
35 × 50
35 × 60
22 × 20
25.4 × 20
22 × 25
25.4 × 20
22 × 25
30 × 20
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
1.04
1.04
0.90
1.16
1.16
1.16
1.15
1.33
1.33
1.33
1.33
1.47
1.47
1.47
1.70
1.70
1.70
2.05
2.05
2.17
2.17
2.20
2.55
0.41
0.46
0.55
0.51
0.69
0.60
0.75
0.75
0.65
0.82
0.83
0.82
0.76
0.92
0.92
0.90
1.05
1.04
1.02
1.04
1.16
1.18
1.17
1.20
1.29
1.34
1.22
1.51
1.51
1.47
1.66
1.65
1.69
1.85
1.90
2.15
1.99
2.31
0.37
0.42
0.50
0.46
0.64
0.55
Part No.
EKMM3B1VSN221MQ30S
EKMM3B1VSN221MR25S
EKMM3B1VSN221MA20S
EKMM3B1VSN271MP45S
EKMM3B1VSN271MQ35S
EKMM3B1VSN271MR25S
EKMM3B1VSN271MA25S
EKMM3B1VSN331MP50S
EKMM3B1VSN331MQ40S
EKMM3B1VSN331MR30S
EKMM3B1VSN331MA25S
EKMM3B1VSN391MQ45S
EKMM3B1VSN391MR35S
EKMM3B1VSN391MA30S
EKMM3B1VSN471MQ50S
EKMM3B1VSN471MR40S
EKMM3B1VSN471MA30S
EKMM3B1VSN561MR45S
EKMM3B1VSN561MA35S
EKMM3B1VSN681MR50S
EKMM3B1VSN681MA40S
EKMM3B1VSN821MA45S
EKMM3B1VSN102MA60S
EKMM351VSN560MP20S
EKMM351VSN680MQ20S
EKMM351VSN820MP25S
EKMM351VSN820MQ20S
EKMM351VSN101MP25S
EKMM351VSN101MR20S
EKMM351VSN121MP30S
EKMM351VSN121MQ25S
EKMM351VSN121MR20S
EKMM351VSN151MP35S
EKMM351VSN151MQ30S
EKMM351VSN151MR25S
EKMM351VSN151MA20S
EKMM351VSN181MP40S
EKMM351VSN181MQ30S
EKMM351VSN181MR25S
EKMM351VSN221MP45S
EKMM351VSN221MQ35S
EKMM351VSN221MR30S
EKMM351VSN221MA25S
EKMM351VSN271MP50S
EKMM351VSN271MQ40S
EKMM351VSN271MR30S
EKMM351VSN271MA25S
EKMM351VSN331MQ45S
EKMM351VSN331MR35S
EKMM351VSN331MA30S
EKMM351VSN391MQ50S
EKMM351VSN391MR40S
EKMM351VSN391MA35S
EKMM351VSN471MQ60S
EKMM351VSN471MR45S
EKMM351VSN471MA35S
EKMM351VSN561MR50S
EKMM351VSN561MA40S
EKMM351VSN681MR60S
EKMM351VSN681MA50S
EKMM351VSN821MA60S
EKMM401VSN470MP20S
EKMM401VSN560MQ20S
EKMM401VSN680MP25S
EKMM401VSN680MQ20S
EKMM401VSN820MP25S
EKMM401VSN820MR20S
KMMSeries
◆STANDARD RATINGS
WV
(Vdc)
400
420
Cap
(µF)
100
100
100
120
120
120
120
150
150
150
150
180
180
180
180
220
220
220
220
270
270
270
330
330
330
390
390
390
470
470
560
560
680
47
56
68
68
82
82
82
100
100
100
120
120
120
120
150
150
150
180
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
22 ×30
25.4×25
30 ×20
22 ×35
25.4 ×25
30× 25
35× 20
22 × 40
25.4× 30
30 × 25
35 ×20
22 ×45
25.4×35
30 ×30
35 ×25
22 ×50
25.4 ×40
30× 30
35 × 25
25.4× 45
30 × 35
35 ×30
25.4 ×50
30 ×40
35 × 30
25.4× 60
30 × 45
35 × 35
30 × 50
35 × 40
30 × 60
35 × 45
35 × 60
22 × 20
25.4× 20
22× 25
25.4 × 20
22 × 25
25.4× 25
30× 20
22× 30
25.4× 25
30× 20
22× 35
25.4× 30
30× 25
35× 20
22× 40
25.4× 35
30× 25
22× 45
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.70
0.70
0.60
0.75
0.75
0.73
0.75
0.88
0.88
0.88
0.80
0.98
0.98
0.98
0.98
1.10
1.10
1.10
1.10
1.22
1.22
1.22
1.44
1.44
1.44
1.51
1.60
1.60
1.90
1.90
2.10
2.12
2.27
0.37
0.42
0.50
0.46
0.64
0.58
0.53
0.70
0.70
0.59
0.75
0.75
0.73
0.67
0.88
0.88
0.88
0.95
Part No.
EKMM401VSN101MP30S
EKMM401VSN101MQ25S
EKMM401VSN101MR20S
EKMM401VSN121MP35S
EKMM401VSN121MQ25S
EKMM401VSN121MR25S
EKMM401VSN121MA20S
EKMM401VSN151MP40S
EKMM401VSN151MQ30S
EKMM401VSN151MR25S
EKMM401VSN151MA20S
EKMM401VSN181MP45S
EKMM401VSN181MQ35S
EKMM401VSN181MR30S
EKMM401VSN181MA25S
EKMM401VSN221MP50S
EKMM401VSN221MQ40S
EKMM401VSN221MR30S
EKMM401VSN221MA25S
EKMM401VSN271MQ45S
EKMM401VSN271MR35S
EKMM401VSN271MA30S
EKMM401VSN331MQ50S
EKMM401VSN331MR40S
EKMM401VSN331MA30S
EKMM401VSN391MQ60S
EKMM401VSN391MR45S
EKMM401VSN391MA35S
EKMM401VSN471MR50S
EKMM401VSN471MA40S
EKMM401VSN561MR60S
EKMM401VSN561MA45S
EKMM401VSN681MA60S
EKMM421VSN470MP20S
EKMM421VSN560MQ20S
EKMM421VSN680MP25S
EKMM421VSN680MQ20S
EKMM421VSN820MP25S
EKMM421VSN820MQ25S
EKMM421VSN820MR20S
EKMM421VSN101MP30S
EKMM421VSN101MQ25S
EKMM421VSN101MR20S
EKMM421VSN121MP35S
EKMM421VSN121MQ30S
EKMM421VSN121MR25S
EKMM421VSN121MA20S
EKMM421VSN151MP40S
EKMM421VSN151MQ35S
EKMM421VSN151MR25S
EKMM421VSN181MP45S
WV
(Vdc)
420
450
Cap
(µF)
180
180
180
220
220
220
220
270
270
270
330
330
330
390
390
470
470
560
680
56
68
68
82
82
100
100
100
120
120
120
120
150
150
150
150
180
180
180
220
220
220
270
270
270
330
330
390
390
470
560
Rated ripple
current
Case size
tanδ
(Arms/
φD×L(mm)
105℃, 120Hz)
25.4× 35
30 × 30
35 × 25
22 × 50
25.4 × 45
30 × 35
35 × 25
25.4 × 50
30 × 40
35 × 30
25.4 × 60
30 × 45
35 × 35
30 × 50
35 × 40
30 × 60
35 × 45
35 × 50
35 × 60
22 × 25
22 × 30
25.4 × 25
22 × 30
25.4 × 25
22 × 35
25.4 × 30
30 × 25
22 × 40
25.4 × 30
30 × 25
35 × 25
22 × 45
25.4 × 35
30 × 30
35 × 25
22 × 50
25.4 × 40
30 × 30
25.4 × 45
30 × 35
35 × 30
25.4 × 60
30 × 40
35 × 35
30 × 50
35 × 40
30 × 60
35 × 40
35 × 50
35 × 60
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.95
0.95
0.94
1.10
1.10
1.10
1.10
1.22
1.22
1.22
1.41
1.45
1.45
1.55
1.55
1.79
1.90
2.15
2.27
0.40
0.53
0.50
0.64
0.64
0.69
0.69
0.64
0.80
0.80
0.80
0.73
0.88
0.88
0.88
0.75
1.00
1.00
1.00
1.12
1.12
1.12
1.18
1.28
1.28
1.45
1.45
1.51
1.55
1.85
1.91
Part No.
EKMM421VSN181MQ35S
EKMM421VSN181MR30S
EKMM421VSN181MA25S
EKMM421VSN221MP50S
EKMM421VSN221MQ45S
EKMM421VSN221MR35S
EKMM421VSN221MA25S
EKMM421VSN271MQ50S
EKMM421VSN271MR40S
EKMM421VSN271MA30S
EKMM421VSN331MQ60S
EKMM421VSN331MR45S
EKMM421VSN331MA35S
EKMM421VSN391MR50S
EKMM421VSN391MA40S
EKMM421VSN471MR60S
EKMM421VSN471MA45S
EKMM421VSN561MA50S
EKMM421VSN681MA60S
EKMM451VSN560MP25S
EKMM451VSN680MP30S
EKMM451VSN680MQ25S
EKMM451VSN820MP30S
EKMM451VSN820MQ25S
EKMM451VSN101MP35S
EKMM451VSN101MQ30S
EKMM451VSN101MR25S
EKMM451VSN121MP40S
EKMM451VSN121MQ30S
EKMM451VSN121MR25S
EKMM451VSN121MA25S
EKMM451VSN151MP45S
EKMM451VSN151MQ35S
EKMM451VSN151MR30S
EKMM451VSN151MA25S
EKMM451VSN181MP50S
EKMM451VSN181MQ40S
EKMM451VSN181MR30S
EKMM451VSN221MQ45S
EKMM451VSN221MR35S
EKMM451VSN221MA30S
EKMM451VSN271MQ60S
EKMM451VSN271MR40S
EKMM451VSN271MA35S
EKMM451VSN331MR50S
EKMM451VSN331MA40S
EKMM451VSN391MR60S
EKMM451VSN391MA40S
EKMM451VSN471MA50S
EKMM451VSN561MA60S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
160 to 250Vdc
315 to 450Vdc
50
0.81
0.77
120
1.00
1.00
300
1.17
1.16
1k
1.32
1.30
10k
1.45
1.41
50k
1.50
1.43
The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer
to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note.
Product Guide
■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults
and accidents from occurring.
■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure
prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications.
■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for
use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or
property. In addition, our products are not intended to be used in specific applications that may cause a major social impact.
Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power
generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles,
trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized
information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose
applications.
■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations
and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment
systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You
should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and
determine whether or not our products suit your requirements according to the specifications of your equipment systems.
Therefore, you bear final responsibility regarding the use of our products.
Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention
measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction.
■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We
assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel
or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our
official sales channel.
■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this
catalog will be available in the future.
The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific
products
■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our
published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming
goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be
accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual
non-conforming product, or in other ways deemed necessary.
In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any
potential compensation.
Part Numbering System
Part Numbering System (Appendix)
Standardization
Available Items by Manufacturing Locations
Environmental Measures
Technical Note
Precautions and Guidelines
Recommended Soldering Conditions
Taping, Lead-preforming and Packaging
Available Terminals for Snap-in and Screw Mount Type
