ELBG250ELL722AK55S
ELBG250ELL722AK55S
    NCC(贵弥功)
    插件
    7200 µF 25 V 铝电解电容器 径向,Can 105°C 时为 5000 小时
ELBG250ELL722AK55S 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS LBG For airbag module, 105℃ Series ・For airbag application ・High capacitance, low impedance, and good low temperature behavior ・Endurance with ripple current : 5,000 hours at 105℃ ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. LBV Downsized LBG ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Range Capacitance Tolerance Leakage Current -55 to +105℃ 25 & 35Vdc 1,000 to 11,000µF 0 to +30% (A) I=0.01CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 25V 35V tanδ (Max.) 0.20 0.16 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. Rated voltage (Vdc) 25V 35V Z(-55℃)/Z(+20℃) 3 3 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Code : E φD' φd Sleeve (PET : Dark blue) F±0.5 ●Terminal L' Vent 15min. 4min. 18 φD 12.5 14.5 16 φd 0.6 0.8 0.8 0.8 F 5.0 7.5 7.5 7.5 φD' φD+0.5max. L' L+1.5max. Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E L BG AAA E AA AAA A AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 1,000µF:102, 11,000µF:113) Lead forming·taping code Terminal code Voltage code (ex. 16V:160, 35V:350) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS For airbag module, 105℃ LBGSeries ◆STANDARD RATINGS Cap (µF) Case size φD×L(mm) tanδ 1,700 2,400 2,400 2,800 3,000 3,400 3,500 4,200 4,200 4,500 4,600 5,400 5,600 6,000 6,400 6,600 7,800 7,900 9,200 11,000 1,000 1,400 1,400 1,600 1,800 2,000 2,100 2,500 2,500 2,700 2,800 3,200 3,400 3,600 3,800 4,000 4,700 4,800 5,600 6,700 12.5 × 20 12.5 × 25 14.5 × 20 12.5 × 30 16 × 20 14.5 × 25 12.5 × 35 16 × 25 18 × 20 12.5 × 40 14.5 × 31.5 14.5 × 35.5 16 × 31.5 18 × 25 14.5 × 40 16 × 35.5 16 × 40 18 × 31.5 18 × 35.5 18 × 40 12.5 × 20 12.5 × 25 14.5 × 20 12.5 × 30 16 × 20 14.5 × 25 12.5 × 35 16 × 25 18 × 20 12.5 × 40 14.5 × 31.5 14.5 × 35.5 16 × 31.5 18 × 25 14.5 × 40 16 × 35.5 16 × 40 18 × 31.5 18 × 35.5 18 × 40 0.20 0.22 0.22 0.22 0.24 0.24 0.24 0.26 0.26 0.26 0.26 0.28 0.28 0.30 0.30 0.30 0.32 0.32 0.36 0.40 0.16 0.16 0.16 0.16 0.16 0.18 0.18 0.18 0.18 0.18 0.18 0.20 0.20 0.20 0.20 0.22 0.22 0.22 0.24 0.26 WV (Vdc) 25 35 Impedance (Ω max./100kHz) 20℃ -40℃ Rated ripple current (mArms/105℃, 100kHz) Part No. 0.057 0.045 0.051 0.039 0.044 0.041 0.033 0.033 0.042 0.027 0.032 0.028 0.026 0.030 0.025 0.023 0.021 0.024 0.022 0.020 0.057 0.045 0.051 0.039 0.044 0.041 0.033 0.033 0.042 0.027 0.032 0.028 0.026 0.030 0.025 0.023 0.021 0.024 0.022 0.020 0.29 0.23 0.26 0.20 0.22 0.21 0.17 0.17 0.21 0.14 0.16 0.14 0.13 0.15 0.13 0.12 0.11 0.12 0.11 0.10 0.29 0.23 0.26 0.20 0.22 0.21 0.17 0.17 0.21 0.14 0.16 0.14 0.13 0.15 0.13 0.12 0.11 0.12 0.11 0.10 1,700 2,000 2,000 2,300 2,250 2,400 2,700 2,600 2,500 3,100 2,700 3,100 3,200 2,800 3,400 3,500 3,800 3,500 3,700 4,000 1,700 2,000 2,000 2,300 2,250 2,400 2,700 2,600 2,500 3,100 2,700 3,100 3,200 2,800 3,400 3,500 3,800 3,500 3,700 4,000 ELBG250E □□ 172AK20S ELBG250E □□ 242AK25S ELBG250E □□ 242AU20S ELBG250E □□ 282AK30S ELBG250E □□ 302AL20S ELBG250E □□ 342AU25S ELBG250E □□ 352AK35S ELBG250E □□ 422AL25S ELBG250E □□ 422AM20S ELBG250E □□ 452AK40S ELBG250E □□ 462AUN3S ELBG250E □□ 542AUP1S ELBG250E □□ 562ALN3S ELBG250E □□ 602AM25S ELBG250E □□ 642AU40S ELBG250E □□ 662ALP1S ELBG250E □□ 782AL40S ELBG250E □□ 792AMN3S ELBG250E □□ 922AMP1S ELBG250E □□ 113AM40S ELBG350E □□ 102AK20S ELBG350E □□ 142AK25S ELBG350E □□ 142AU20S ELBG350E □□ 162AK30S ELBG350E □□ 182AL20S ELBG350E □□ 202AU25S ELBG350E □□ 212AK35S ELBG350E □□ 252AL25S ELBG350E □□ 252AM20S ELBG350E □□ 272AK40S ELBG350E □□ 282AUN3S ELBG350E □□ 322AUP1S ELBG350E □□ 342ALN3S ELBG350E □□ 362AM25S ELBG350E □□ 382AU40S ELBG350E □□ 402ALP1S ELBG350E □□ 472AL40S ELBG350E □□ 482AMN3S ELBG350E □□ 562AMP1S ELBG350E □□ 672AM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 1,000 to 2,000 2,100 to 3,800 4,000 to 11,000 120 0.60 0.75 0.85 1k 0.87 0.90 0.95 10k 0.95 0.95 0.98 100k 1.00 1.00 1.00 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
ELBG250ELL722AK55S 价格&库存
很抱歉,暂时无法提供与“ELBG250ELL722AK55S”相匹配的价格&库存,您可以联系我们找货
