EKRG350ETC101MH09D
EKRG350ETC101MH09D
    NCC(贵弥功)
    插件
    100 µF 35 V 铝电解电容器 径向,Can 105°C 时为 1000 小时
EKRG350ETC101MH09D 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low profile, 105℃ KRG Series ・Low profile :φ10×12.5mm toφ18×25mm ・Endurance : 1,000 hours at 105℃ ・Solvent resistant type (see PRECAUTIONS AND GUIDELINES) ・RoHS2 Compliant ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ 6.3 to 50Vdc (at 20℃, 120Hz) ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃ after 2 minutes) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V tanδ (Max.) 0.28 0.24 0.20 0.16 0.14 0.12 When nominal capacitance exceeds 1,000µF, add 0.03 to the value above for each 1,000µF increase. (at 20℃, 120Hz) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V Z(-25℃)/Z(+20℃) 5 4 3 2 2 2 Z(-40℃)/Z(+20℃) 10 8 6 4 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 1,000 hours at 105℃. Rated voltage 6.3 to 16Vdc 25 to 50Vdc Capacitance change ≦±25% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Rated voltage 6.3 to 16Vdc 25 to 50Vdc Capacitance change ≦±25% of the initial value ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value ≦200% of the initial specified value Leakage current ≦The initial specified value ≦The initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] F±0.5 Code : E φD' φd Sleeve (PET : Brown) F±0.5 ●Terminal L' 15min. 4min. Vent φD φd F φD ' L' (φ12.5 to φ18) (φ10) Gas escape end seal 10 & 12.5 16 & 18 0.6 0.8 5.0 7.5 φD+0.5max. L+1.5max. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KRG AAA E AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 220µF:221, 1,000µF:102) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3, 35V:350, 50V:500) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low profile, 105℃ KRGSeries ◆STANDARD RATINGS WV (Vdc) 6.3 10 16 Cap (µF) Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 4,700 16 × 15 6,800 18 × 15 10,000 18 ×20 1,000 10 × 12.5 2,200 12.5× 15 3,300 16 × 15 4,700 18 × 15 6,800 18 × 20 10,000 18 × 25 1,000 12.5× 13 2,200 16 × 15 3,300 18× 15 4,700 18× 20 6,800 18× 25 0.37 0.43 0.55 0.24 0.27 0.30 0.33 0.39 0.51 0.20 0.23 0.26 0.29 0.35 1,010 1,190 1,440 445 690 940 1,120 1,330 1,700 515 830 1,050 1,260 1,560 Part No. EKRG6R3E□□472ML15S EKRG6R3E□□682MM15S EKRG6R3E□□103MM20S EKRG100E□□102MJC5S EKRG100E□□222MK15S EKRG100E□□332ML15S EKRG100E□□472MM15S EKRG100E□□682MM20S EKRG100E□□103MM25S EKRG160E□□102MK13S EKRG160E□□222ML15S EKRG160E□□332MM15S EKRG160E□□472MM20S EKRG160E□□682MM25S WV (Vdc) 25 35 50 Cap (µF) 470 1,000 2,200 3,300 4,700 330 470 1,000 2,200 220 330 470 1,000 Rated ripple current Case size tanδ (mArms/ φD×L(mm) 105℃, 120Hz) 10 × 12.5 12.5 × 15 18 × 15 18 × 20 18 × 25 10 × 12.5 12.5 × 13 16 × 15 18 × 20 10 × 12.5 12.5 × 13 16 × 15 18 × 20 0.16 0.16 0.19 0.22 0.25 0.14 0.14 0.14 0.17 0.12 0.12 0.12 0.12 370 590 970 1,220 1,470 340 415 720 1,110 290 370 535 830 Part No. EKRG250E□□471MJC5S EKRG250E□□102MK15S EKRG250E□□222MM15S EKRG250E□□332MM20S EKRG250E□□472MM25S EKRG350E□□331MJC5S EKRG350E□□471MK13S EKRG350E□□102ML15S EKRG350E□□222MM20S EKRG500E□□221MJC5S EKRG500E□□331MK13S EKRG500E□□471ML15S EKRG500E□□102MM20S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 220 to 1,000 2,200 to 50 0.80 0.85 120 1.00 1.00 300 1.15 1.03 1k 1.30 1.05 10k 1.40 1.08 100k 1.50 1.08 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
EKRG350ETC101MH09D 价格&库存
很抱歉,暂时无法提供与“EKRG350ETC101MH09D”相匹配的价格&库存,您可以联系我们找货
