88970052
    CROUZET(高诺斯)
    Module
    控制器 - 可编程逻辑(PLC) 底座安装,DIN 轨道 24VDC
88970052 数据手册
Logic controllers Concentrated performance Smart & Essential www.automation.crouzet.com Content 2 Presentation P. 3 Millenium 3 P. 4 The range P. 5 Communication solutions P. 6 M3 Soft software P. 8 Accessories P. 9 Applications P. 10 Selection guide P. 12 Technical data P. 14 Millenium 3 Smart Millenium 3 Essential Extensions Input/Output Connection Diagrams Bare Board and Resin Board Versions General characteristics Power supplies and converters Accessories p. 15 p. 21 p. 23 p. 30 p. 35 p. 39 p. 44 p. 47 Glossary of function blocks P. 68 Selection process P. 70 Part numbers index P. 72 www.crouzet-automation.com Presentation Crouzet Automation, Supported by an experienced technical team, Crouzet Automation is a pioneer in the simplification of programming. The brand offers the easiest-touse and most adaptable alternative automation solution for specialized and demanding needs. These products are specifically suited for integration in a wide range of applications such as waste and water treatment, access control, renewable energies, building equipment, industrial machines and transportation. InnoVista Sensors™: your trusted partner of choice to face industrial challenges of today and tomorrow. InnoVista Sensors™ is a worldwide industrial specialist of sensors, controllers and actuators for automated systems. Through its brands, Crouzet Aerospace, Crouzet Automation, Crouzet Control, Crouzet Motors, Crouzet Switches and Systron Donner Inertial, InnoVista Sensors™ offers a wide range of reliable, efficient and customizable components dedicated to the Aerospace & Defence, Transportation and Industrial market and segments. Thanks to the recognized expertise of its teams and a strong innovation policy, InnoVista Sensors™ brings performance enhancing solutions to its customers worldwide. www.innovistasensors.com Crouzet Automation presence worldwide Production Sales subsidiaries www.crouzet-automation.com 3 Millenium 3 Crouzet Automation Logic Controllers Millenium 3, concentrated performance The Millenium 3 Smart is a programmable logic controller which enables the control and monitoring of machines or automation installations with up to 50 I/O. + Timers + Control relays + Counters + more Temperature controllers Power supply terminals Input terminals Blue screen with 4 lines of 18 characters Programming port 6 programmable buttons Output terminals Timers Calculation of level of liquid in a tank External preset Up/Down counter Digital or adaptive tune PID regulation Sunrise Sunset Time To tackle simpler applications that still require a powerful logic controller, Crouzet Automation offers the Millenium 3 “Essential” range. The 12 VDC or 24 VDC Millenium 3 Essential range includes a variety of versions and is compatible with a large range of accessories. It is the right solution for simple needs. 4 The range Crouzet Automation Logic Controllers The Millenium 3 Smart range • Multiple configuration options derived from an extensive product range with numerous accessories • Simplified connectivity making integration of communication systems easy • Easy implementation supported by free, user-friendly programming software (M3 Soft) • Application-specific solutions thanks to dedicated and easy to use specific function blocks • Enhanced visibility on the display with high contrast, blue back lit LCD screen Expandable versions XD26 XB26 XD10 XB10 Expandable kit Compact versions CD20 www.crouzet-automation.com CB20 CD12 CB12 Compact kit 5 Communication solution Crouzet Automation Logic Controllers Extensive Connectivity Options Solutions with close proximity to your installation Millenium 3 Virtual Display - Bluetooth® or USB Your requirements Our solution Main functions • Remote viewing of the Millenium 3 display unit - on an Android smartphone via Bluetooth® - on a PC via Bluetooth® or USB • Display/modificatio of program setpoints • Access to a virtual panel (Millenium 3 without display unit) • Viewing setpoints on a panel less than 10 m away • Changing and modifying setpoints • Locating the Millenium 3 display unit remotely In summary • Reading counters in the vicinity • Bluetooth® interface (10 m): Millenium 3 accessory • Two versions: Lite (ESC/ENTER buttons disabled) & Standard See also page 48 MTP programmable touch panels - RS232 cable Your requirements Our solution Main functions • Displaying data on a graphic panel • Modifying setpoints from the touch panel • Taking control of the remote panel from a distance VNC link (1) • Supervision of your installation • Use of Millenium 3 internal data, processing alarms and recipes • Display of text, data, graphics, animations • Archiving of data • Customization of interfaces (picture library) • Remote control of panel In summary • Storage: 128 MB flash memory, SD card and USB key • Direct communication using the Millenium 3 programming port • Programmable with EB software (compatible with Windows 2000/XP/Vista/7) • Extensive connectivity Option See also page 49 (1) VNC: Virtual Network Computing. Allows a device to be controlled remotely. Local Area Network (LAN) solutions Programmable touch panels and communication extensions – Modbus networks Your requirements Our solution Main functions • See MTP programmable touch panels solution • Management and centralizing of data in a single place • Display of Millenium 3 program values • Remote setpoint modificatio • Managing a group of machines or an installation on a local area network • Centralizing data • Displaying data on a graphic panel • Modifying setpoints from the panel • Accessing the system locally in real time In summary Modbus • MTP panel Modbus master • XN05 extension: Modbus Ethernet TCP/IP • XN06 extension: Modbus RS485 RTU See also page 23 and 49 6 www.crouzet-automation.com ons Wide Area Network (WAN) solutions M3MOD - GSM modem communication interface Your requirements Our solution Main functions • Automatic notificatio of alarms via SMS • Input and output states, as well as all program values, can be polled and controlled remotely • Reports can be produced using the available variables • Management of telephone contacts • Receiving remote early warning of an event • Consulting a value or an internal state • Occasionally modifying setpoints In summary GSM • Reliable plug & play solution that is simple to install • Solution managed using M3 Soft software • Option to send SMS messages via a telecom operator service See also page 55 Remote management solutions with Your requirements • Supervising and monitoring installations with up to 50 remote I/O (2) - Cloud Our solution Millenium 3 Netbiter EC220 Main functions Millenium 3 Netbiter EC150 • Managing an installed base of machines • Accessing your data remotely, 24/7 Modbus Internet (via router or ADSL box) GPRS • Optimizing your maintenance operations Internet • Remote control of an automated application • Display of Millenium 3 program parameters and values via the internet • Remote setpoint modificatio • Data logging • Management of events sent via emails or SMS In summary • Direct communication between Netbiter and Millenium 3 via the SLin/SLout protocol or via Modbus • GPRS: SIM card procured via HMS • Cloud solution: secure remote server • Easy to set up and use • Several Millenium 3 can be connected via Modbus (2) Partnership solutions with the HMS company, validated by Crouzet Automation and HMS. Information relating to the products has been provided by the supplier of each product respectively, and they are wholly responsible for its accuracy in addition to supplying and providing backup for their products. Communication extensions - Modbus RS485 or Modbus Ethernet TCP/IP Your requirements Our solution Main functions • Can be combined with distributed automation • Management and centralizing of data in a single place • Display of Millenium 3 program values • Remote setpoint modificatio • Managing a group of machines or an installation on a local area network • Centralizing data • Accessing the system locally in real time In summary Modbus • Uses Modbus protocol • XN05 extension: Modbus Ethernet TCP/IP • XN06 extension: Modbus RS485 RTU • Compatible with standard supervisors See also page 23 www.crouzet-automation.com 7 M3 Soft software Crouzet Automation Logic Controllers Millenium 3 and M3 Soft The M3 Soft is a high-performance software platform used to program the Millenium 3 logic controller and optimize design times. Free The Millenium 3 programming software (M3 Soft) can be downloaded free of charge from the Crouzet website at www.crouzet.com Blocks can be wired in wiring mode or text mode Move one or more blocks without disconnecting the wires Choice of programming language Clear work area Customized password protection Simple User-friendly and ergonomic • Quick, simple and intuitive programming requires no specialist knowledge • Software available in 5 languages: English, French, Italian, German and Spanish • Self-teaching made easier thanks to a user-friendly online help guide and programming examples • Function block programming is fun and very visual • A simulation mode that consistently represents controller operation Powerful • A complete range of basic functions: counting, timing, comparison, display, logic, gain, sin/cos, etc are also available • A wide range of dedicated functions: pump rotation, PID regulation, movement, pressure, level, water ratio, solar tracking, and flow • Blocks simply organized by function for quick access • Help associated with each function block accessible at the click of a button • Programming langages: FBD (Function Bloc Diagram) and SFC (Sequential Function Chart/Grafcet) or LD (Ladder Diagram) User-definable and effective • Possibility of creating and saving custom macros in the macro tab allowing the user to simplify programs and utilize their expertise • Possibility of protecting macros by locking them with a password for greater security 8 www.crouzet-automation.com Accessories Crouzet Automation Logic Controllers Accessories Sensors, power supplies, converters, remote screens and communication accessories offer solutions to control your automation systems with the greatest ease of use. S s en o rs I Ventilation duct temperature sensor Ac ce NTC temperature probes ss o ri es Potentiometer Memory cartridge I Ambient temperature sensor P o w e r s u p pli e s I Co Power supplies from 7.5 to 240 W 5, 12 or 24 V m m u ni c a ti s ol u ti on rs te er nv Co Programmable touchpanels s I Remote screens I www.crouzet-automation.com STN and GSM modems Temperature and current/voltage converters on I Bluetooth® interface 9 Applications Crouzet Automation Logic Controllers Where are they found? Buidling Equipment Access Control Opening control for doors Control opening and closing of doors and other associated security devices for restricting access; synchronization between the various doors BOOLEAN OR LOGIC Create logic equations between the connected inputs Automatic barriers Control barriers with automatic detection of vehicles. Function for selecting opening times / days. UP/DOWN COUNTER Up/Down counter with external preset HVAC Heat pump Management of various parameters such as heating, cooling, fluid temperatures, operation, calendar-based function, frost protection mode, alarm management, etc WATER RATIO Water temperature control CLOCK Weekly and yearly time programmer Air treatment plant Maintaining forced air at the correct temperature NTC1 Temperature measurement REGULATION Analog PID regulation GAIN Conversion of an analog value by changing the scale and datum point Building Automation Solar water heating Automation of operation and heating regulation, remote management of the installation TEMPERATURE CONTROL (pressure or other) 10 Illuminated signs Managing flashing on illuminated signs WEEKLY TIME PROGRAMMER Programming of time slots during which it will be possible to execute actions LUX-I Measurement of the light level TWILIGHT Calculation of the sunrise and sunset times Infrastructure and Energy Fluid management Swimming pools, fountains, spas Managing circulation pumps, monitoring levels, temperature and conductivity of the water filtration Filtration duration settings depending on the water temperature Irrigation/Sprinklers Irrigation control based on temperature, humidity, and day/night cycle PUMP MANAGEMENT Pump rotation function Water treatment Reverse osmosis Circulation pumps management, supervision of flow pressure and temperature of osmosis processed water FLOW Calculation of the flow of a liquid in a pipe CTN Temperature measurement (-35 to +120 °C) Pump management Circulation pumps management, supervision of levels and pressure GAIN Conversion of an analog value by changing the scale and datum point LEVEL Calculation of the level of liquid in a tank Industrial OEMs Packing machines Stretch wrapping machines Controlling the motor that unrolls the packing film. Controls cutting of the film after heat sealing and monitors the duration of the motor cycles GRAFCET SFC FUNCTIONS For sequential automation systems (Sequential Function Chart) TIMERS (TEMPORISATEURS) A/C function - BW function B/H function - Li/L function Packaging Controlling heat sealing times on blister packs, packaging bags, etc HIGH SPEED COUNT Counting of pulses AND Logical AND with 2 inputs Other typical applications: Medical, Solar, Agricultural Equipment, Transportation, Hoisting, Handling… www.crouzet-automation.com 11 Selection guide Millenium 3 range Type Part number M3 Smart kits Supply Inputs Outputs Available with Available in / Solid State Output compatible with the Page 12 V c 24 V a 0.5 A/PWM Essential version ** Available in Kit 12 Smart* 88 974 080 24 V c 8 (4 configurable as analog) 4 relays 8 A 14 Kit 12 Smart* 88 974 081 100 C 240 V a 8 4 relays 8 A 14 Kit 20 Smart* 88 974 082 24 V c 12 (6 configurable as analog) 8 relays 8 A 14 Kit 20 Smart* 88 974 083 100 C 240 V a 12 8 relays 8 A 14 Kit 26 Smart* 88 974 084 24 V c 16 (6 configurable as analog) 8 relays 8 A and 2 relays 5 A 14 Kit 26 Smart* 88 974 085 100 C 240 V a 16 8 relays 8 A and 2 relays 5 A 14 CD12 Smart* 88 974 041 24 V c 8 (4 configurable as analog) 4 relays 8 A CD12 Smart* 88 974 043 100 C 240 V a 8 4 relays 8 A CD20 Smart* 88 974 051 24 V c 12 (6 configurable as analog) 8 relays 8 A CD20 Smart* 88 974 053 100 C 240 V a 12 8 relays 8 A CB12 Smart* 88 974 021 24 V c 8 (4 configurable as analog) 4 relays 8 A CB12 Smart* 88 974 023 100 C 240 V a 8 4 relays 8 A CB20 Smart* 88 974 031 24 V c 12 (6 configurable as analog) 8 relays 8 A CB20 Smart* 88 974 033 100 C 240 V a 12 8 relays 8 A XD10 Smart* 88 974 141 24 V c 6 (4 configurable as analog) 4 relays 8 A XD10 Smart* 88 974 143 100 C 240 V a 6 4 relays 8 A XD26 Smart* 88 974 161 24 V c 16 (6 configurable as analog) 8 relays 8 A and 2 relays 5 A XD26 Smart* 88 974 163 100 C 240 V a 16 8 relays 8 A and 2 relays 5 A XB10 Smart* 88 974 131 XB10 Smart* 88 974 133 XB26 Smart* 88 974 151 24 V c 16 (6 configurable as analog) 8 relays 8 A and 2 relays 5 A XB26 Smart* 88 974 153 100 C 240 V a 16 8 relays 8 A and 2 relays 5 A Compact versions With display Without display • • • • • • • 15 15 • 15 15 • • • 16 16 • • 16 16 Expandable versions With display Without display • • • • • • • 17 17 • 17 17 18 18 • • • • 18 18 With Removable Terminal Blocks CD12 RBT Smart* 88 974 441 24 V c 8 (4 configurable as analog) 4 relays 8 A 19 XD26 RBT Smart* 88 974 561 24 V c 16 (6 configurable as analog) 8 relays 8 A and 2 relays 5 A 19 Sandwich extensions XN05 Modbus TCP/IP 88 970 270 24 V c • 23 Communication XN06 Modbus RS485 88 972 250 24 V c • 23 XN07 Master RS485 88 974 250 24 V c XE10 88 970 321 24 V c 6 4 relays 5 A XE10 88 970 323 100 C 240 V a 6 4 relays 5 A XR06 88 970 211 24 V c 4 2 relays 8 A XR06 88 970 213 100 C 240 V a 4 2 relays 8 A XR10 88 970 221 24 V c 6 4 relays 8 A XR10 88 970 223 100 C 240 V a 6 4 relays 8 A XR14 88 970 231 24 V c 8 4 relays 8 A and 2 relays 5 A XR14 88 970 233 100 C 240 V a 8 4 relays 8 A and 2 relays 5 A XA03 3xPt100 88 970 800 24 V c 3 analog (Pt100) 24 V c 2 analog 0-10V/0-20mA (1 Pt100) 24 • 26 • • 26 • 26 • • 26 • 26 • 26 • 26 • 26 Digital Termination Extensions Digital Analog XA04 2AI/2AO 88 970 241 • • • • • 27 • 2 analog 0-10V/PWM 28 Bare board and resin board versions Bare board Resin board • NB12 88 970 001 24 V c 8 (4 configurable as analog) 4 relays 8 A NB12 88 970 003 100 C 240 V a 8 4 relays 8 A NB20 88 970 011 24 V c 12 (6 configurable as analog) 8 relays 8 A NB20 88 970 013 NBR12 88 973 001 24 V c 8 (4 configurable as analog) 4 relays 8 A • • 36 NBR26 88 973 061 24 V c 16 (6 configurable as analog) 10 relays 8 A • • 36 NBR32 88 973 211 24 V c 20 (6 configurable as analog) 12 relays 8 A • 36 NBR40 88 973 231 24 V c 24 (6 configurable as analog) 16 relays 8 A • 36 35 35 35 35 * Millenium 3 Smart: backlit blue LCD display. Extended operating temperature range and function block library **Millenium 3 Essential (p. 21): Logic Controller with green screen and industrial temperature range 12 www.crouzet-automation.com Millenium 3 accessories Power supplies and DC/DC converters in modular casings Part number Input voltage Output voltage 88 950 303 100 C 240 V a 24 V c 88 950 304 100 C 240 V a 24 V c 88 950 307 100 C 240 V a 24 V c 88 950 302 100 C 240 V a 24 V c 88 950 305 100 C 240 V a 5Vc 88 950 306 100 C 240 V a 12 V c 88 950 320 9.2 C 18 V c 12 V c 88 950 321 9.2 C 36 V c 24 V c Nominal power Output current Page 44 46 Connection accessories, tools and programming software Part number Name 88 970 111 M3 Soft: Millenium 3 programming software (CD-ROM) 88 970 108 Memory cartridge for transfer and saving of programms 88 970 102 3 m serial programming cable: PC DB9 F C Millenium 3 88 970 104 Millenium 3 C Bluetooth® interface (class A 10 m) 88 970 109 3 m USB programming cable: PC C Millenium 3 88 970 110 Bluetooth® adaptor C USB (class A 10 m) 88 970 123 1.80 m serial link cable: DB9 M/DB9 F 88 970 510 0.5 m serial programming cable: Millenium 3 C DB9 M Ready to use Millenium 3 Smart democase including: - a CD12 Smart, a CTN probe, a LDR probe, an I/O simulator - a 3 m USB programming cable: PC C Millenium 3, a M3 Soft CD - a power supply 110 V-230 V a 88 974 106 Name Page 47 14 Page Millenium 3 Virtual Display Android smartphone and tablet as well as Windows XP/7 PC application 48 TFT-LCD compact 4.3" and 7" resistive touch panels - MTP6/50, MTP8/50 & MTP8/70 49 Plug & Play remote LCD displays/keypads 52 Remote LED display - Input 0-10 V 54 Man/Machine interface Remote control communication solutions Modem communication solutions M3MOD, GSM Modem and STN Modem 55 Temperature probes and light sensors NTC Temperature probes 57 LDR Light sensors 59 0-10 V Temperature sensors 60 Temperature probes Pt100 & Thermocouple 62 Temperature and signal converters Thermocouple Pt100/Pt1000 C 0-10 V 64 PWM to 0-10 V/4-20 mA to 0-10 V 65 Other accessories and kits Standard Smart and Essential product kits 14 Removable connectors 47 Potentiometer ø 22 mm 66 Faceplates 67 www.crouzet-automation.com 13 100-102-UK_Millenium 3 Smart.fm Page 14 Jeudi, 5. décembre 2013 11:47 11 Millenium 3 ➜ Smart range starter kits ■ Each standard kit includes: - 1 Millenium 3 Smart (CD12, CD20 or XD26) - 1 USB programming cable: PC ➞ Millenium 3 - 1 interactive CD ROM including the software workshop, application library and technical brochures, the library of specific functions Part numbers Type Kit 12 Kit 20 Kit 26 Input 8 digital (including 4 analog) 8 digital 12 digital (including 6 analog) 12 digital 16 digital (including 6 analog) 16 digital Output 4 relays 8 A 4 relays 8 A 8 relays 8 A 8 relays 8 A 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 relays (8 x 8 A relay and 2 x 5 A relay) Supply 24 V c 100 ➞ 240 V a 24 V c 100 ➞ 240 V a 24 V c 100 ➞ 240 V a Code 88974080 88974081 88974082 88974083 88974084 88974085 ➜ Standard Smart and Essential product kits Part numbers Type Kit 16 Kit 20 Kit 26 Kit 32 Description XD10 Essential - 24 V c (Ref. 88970141) + XN05 (Ref. 88970270) + 1 Power supply PS24-30 W (Ref. 88950307) CD20 Essential - 24 V c (Ref. 88970051) + 1 Power supply PS24-60 W (Ref. 88950302) XD26 Smart - 24 V c (Ref. 88974161) + M3 Soft (Ref. 88970111) + Power supply PS24-30W (Ref. 88950307) + USB programming cable (Ref. 88970109) XD26 Essential - 24 V c (Ref. 88970161) + XR06 (Ref. 88970211) + 1 Power supply PS24-60 W (Ref. 88950302) Code 88970825 88970808 88970094 88970813 ➜ Democase Millenium 3 Smart ■ ■ ■ ■ Quickly demonstrates the strengths of Millenium 3 Smart Rapid Start Up of the Millenium 3 Useful for training and demonstrations Shipped with a demonstration program installed Part numbers Type DEMO Description Democase Millenium 3 Smart Comments The democase consists of: - 88974042: CD12 Smart: 8xDI (incl. 4xAI) 4xDO 0.5A 24 V c (incl. 1 PWM) - 89750180 NTC1 probe: 10 KOhm @ 25°C, -25 ➞ +85 °C (FB: CTN1) - 89750183: LDR1 probe: 10 ➞ 3000 Lux - 88970109: USB 3 m cable - 88970111: M3 Soft (CD-ROM) - Input Output Simulator (Switches, Potentiometer, LED) - Power supply 110V -230 V a with Europe & US adaptor - Demonstration program factory installed 14 Code 88974106 103-UK_Millenium 3 Smart_Smart Compact range with display_7650.fm Page 15 Jeudi, 5. décembre 2013 11:59 11 Millenium 3 Smart ➜ Smart "Compact" range with display ■ Highly visible blue LCD with 4 lines of 18 characters and configurable backlighting ■ Allow the use of the entire library of specific functions blocs of the software workshop ■ Extended temperature range (-20 °C ➞ +70 °C) ■ Analog inputs 0-10 VDC, Potentiometer, NTC, LDR (0-20 mA/Pt100 with converters) ■ Selective parameter setting: you can choose the CD20 CD12 parameters that can be adjusted on the front panel Part numbers Type CD12 Smart Input 8 digital (including 4 analog) 8 digital (including 4 analog) 8 digital 8 digital 8 digital (including 4 analog) 8 digital (including 4 analog) 12 digital (including 6 analog) 12 digital (including 6 analog) 12 digital 12 digital 12 digital (including 6 analog) CD20 Smart Output 4 relays 8 A 4 solid state 0.5 A (including 1 PWM) 4 relays 8 A 4 relays 8 A 4 relays 8 A 4 solid state 0.5 A (including 1 PWM) 8 relays 8 A 8 solid state 0.5 A (including 4 PWM) 8 relays 8 A 8 relays 8 A 8 relays 8 A Supply 24 V c 24 V c 100 ➞ 240 V a 24 V a 12 V c 12 V c 24 V c 24 V c 100 ➞ 240 V a 24 V a 12 V c Code 88974041 88974042 88974043 88974044 88974045 88974046 88974051 88974052 88974053 88974054 88974055 Accessories Type M3 Soft PA PA PA PA Description Multilingual programming software containing specific library functions (CD-ROM) EEPROM memory cartridge 3 m serial programming cable: PC ➞ Millenium 3 USB programing cable 3 m: PC ➞ Millenium 3 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Code 88970111 88970108 88970102 88970109 88970104 Specific characteristics* Operating temperature Operating factor -20 ➞ +70 °C 100 % (6 A relays) 66 % (8 A relays) -40 ➞ +80 °C Display with 4 lines of 18 characters, white characters on a blue background Storage temperature LCD display Dimensions (mm) CD20 Smart CD12 Smart 124,6 113,3 71,2 1 ESC 2 1 2 – 1 + 2 1 2 A B ESC – + 90 OK 107,6 35 100 90 OK 27,5 B 27,5 A 107,6 35 100 27,5 27,5 59,9 58 68 58 68 *Also see Millenium 3 Smart and Essential General characteristics 15 104-UK_Millenium 3 Smart_Smart Compact range without display_7651.fm Page 16 Jeudi, 5. décembre 2013 12:02 12 Millenium 3 Smart ➜ Smart "Compact" range without display ■ Efficient and economical version, without display or keys setting ■ Allow the use of the entire library of specific functions blocs of the software workshop ■ Extended temperature range (-30 °C ➞ +70 °C) ■ Analog inputs 0-10 VDC, Potentiometer, NTC, LDR CB12 (0-20 mA/Pt100 with converters) CB20 Part numbers Type CB12 Smart Input 8 digital (including 4 analog) 8 digital 8 digital 8 digital (including 4 analog) 12 digital (including 6 analog) 12 digital 12 digital CB20 Smart Output 4 relays 8 A 4 relays 8 A 4 relays 8 A 4 solid state 0.5 A (including 1 PWM) 8 relays 8 A 8 relays 8 A 8 relays 8 A Supply 24 V c 100 ➞ 240 V a 24 V a 12 V c 24 V c 100 ➞ 240 V a 24 V a Code 88974021 88974023 88974024 88974026 88974031 88974033 88974034 Accessories Type M3 Soft PA PA PA PA Description Multilingual programming software containing specific library functions (CD-ROM) EEPROM memory cartridge 3 m serial programming cable: PC ➞ Millenium 3 USB programing cable 3 m: PC ➞ Millenium 3 Code 88970111 88970108 88970102 88970109 88970104 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Specific characteristics* -30 ➞ +70 °C (c ); -20 ➞ +70 °C (a ) 100 % (6 A relays) 66 % (8 A relays) -40 ➞ +80 °C Operating temperature Operating factor Storage temperature Dimensions (mm) CB20 Smart CB12 Smart 124,6 113,3 71,2 2 1 2 1 2 1 2 57,5 67,5 *Also see Millenium 3 Smart and Essential General characteristics 16 90 57,5 67,5 107,6 35 27,5 100 90 27,5 1 107,6 35 100 27,5 27,5 59,9 105-UK_Millenium 3 Smart_Smart Expandable range with display_7653.fm Page 17 Jeudi, 5. décembre 2013 12:05 12 Millenium 3 Smart ➜ Smart "Expandable" range with display ■ Highly visible blue LCD with 4 lines of 18 characters and configurable backlighting ■ Allow the use of the entire library of specific functions blocs of the software workshop ■ Extended temperature range (-20 °C ➞ +70 °C) ■ Analog inputs 0-10 VDC, Potentiometer, NTC, LDR (0-20 mA/Pt100 with converters) ■ Open to XN network communication extensions, XD26 XD10 digital I/O, analog, Pt100 extensions Part numbers Type XD10 Smart Input 6 digital (including 4 analog) 6 digital (including 4 analog) 6 digital 6 digital 16 digital (including 6 analog) 16 digital (including 6 analog) 16 digital 16 digital 16 digital (including 6 analog) 16 digital (including 6 analog) XD26 Smart Output 4 relays 8 A 4 solid state 0.5 A (including 1 PWM) 4 relays 8 A 4 relays 8 A 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 solid state 0.5 A (including 4 PWM) 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 solid state 0.5 A (including 4 PWM) Supply 24 V c 24 V c 100 ➞ 240 V a 24 V a 24 V c 24 V c 100 ➞ 240 V a 24 V a 12 V c 12 V c Code 88974141 88974142 88974143 88974144 88974161 88974162 88974163 88974164 88974165 88974166 Accessories Type M3 Soft PA PA PA PA Description Multilingual programming software containing specific library functions (CD-ROM) EEPROM memory cartridge 3 m serial programming cable: PC ➞ Millenium 3 Serial programming cable 3 m: PC ➞ Millenium 3 Code 88970111 88970108 88970102 88970109 88970104 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Specific characteristics* Operating temperature Operating factor -20 ➞ +70 °C 100 % (6 A relays) 66 % (8 A relays) -40 ➞ +80 °C Display with 4 lines of 18 characters, white characters on a blue background Storage temperature LCD display Dimensions (mm) XD26 Smart XD10 Smart 124,6 113,3 71,2 1 ESC 2 1 2 1 + 2 1 2 90 35 100 90 OK A B ESC – + OK 107,6 – 27,5 B 27,5 A 107,6 35 100 27,5 27,5 59,9 58 68 58 68 *Also see Millenium 3 Smart and Essential General characteristics 17 106-UK_Millenium 3 Smart_Smart Expandable range without display_7652.fm Page 18 Jeudi, 5. décembre 2013 12:08 12 Millenium 3 Smart ➜ Smart "Expandable" range without display ■ Efficient and economical version, without display or keys setting ■ Allow the use of the entire library of specific functions blocs of the software workshop ■ Extended temperature range (-30 °C ➞ +70 °C) ■ Analog inputs 0-10 VDC, Potentiometer, NTC, LDR (0-20 mA/Pt100 with converters) ■ Open to XN network communication extensions, XB26 XB10 digital I/O, analog, Pt100 extensions Part numbers Type XB10 Smart Input 6 digital (including 4 analog) 6 digital (including 4 analog) 6 digital 6 digital 16 digital (including 6 analog) 16 digital (including 6 analog) 16 digital 16 digital 16 digital (including 6 analog) XB26 Smart Output 4 relays 8 A 4 solid state 0.5 A (including 1 PWM) 4 relays 8 A 4 relays 8 A 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 solid state 0.5 A (including 4 PWM) 10 relays (8 x 8 A relay and 2 x 5 A relay) Supply 24 V c 24 V c 10 relays (8 x 8 A relay and 2 x 5 A relay) 10 relays (8 x 8 A relay and 2 x 5 A relay) 24 V a 12 V c 100 ➞ 240 V a 24 V a 24 V c 24 V c 100 ➞ 240 V a Code 88974131 88974132 88974133 88974134 88974151 88974152 88974153 88974154 88974155 Accessories Type M3 Soft PA PA PA PA Description Multilingual programming software containing specific library functions (CD-ROM) EEPROM memory cartridge 3 m serial programming cable: PC ➞ Millenium 3 USB programing cable 3 m: PC ➞ Millenium 3 Code 88970111 88970108 88970102 88970109 88970104 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Specific characteristics* -30 ➞ +70 °C (c ); -20 ➞ +70 °C (a ) 100 % (6 A relays) 66 % (8 A relays) -40 ➞ +80 °C Operating temperature Operating factor Storage temperature Dimensions (mm) XB26 Smart XB10 Smart 124,6 113,3 71,2 2 1 2 1 2 1 2 57,5 67,5 *Also see Millenium 3 Smart and Essential General characteristics 18 90 57,5 67,5 107,6 35 27,5 100 90 27,5 1 107,6 35 100 27,5 27,5 59,9 107-UK_Millenium 3 Smart_Smart range with Removable Terminal blocks_9730.fm Page 19 Jeudi, 5. décembre 2013 12:11 12 Millenium 3 Smart ➜ Smart range with Removable Terminal blocks ■ Designed for industrial, commercial, medical and paramedical machines ■ Faster maintenance process which improves the machine availability rate ■ Easier for cabling, allows pre-cabling of the installation ■ Simplifies the panel mounting ■ Spring cage connectors provide a solution suitable for CD12 RBT XD26 RBT mobile applications and applications that are subject to vibration ■ Compatible with standard 5.08 mm pitch spring cage or screw connectors (angled or straight) ■ Features identical to the Millenium 3 Smart range, compatible with any extensions and accessories Part numbers Type CD12 RBT Smart Designation Smart Compact with display and removable terminal blocks Smart Expandable with display and removable terminal blocks XD26 RBT Smart Input Output 8 digital (including 4 analog) 4 relays 8 A Supply 24 V c Code 88974441 16 digital (including 6 analog) 24 V c 88974561 10 relays (8 x 8 A relay and 2 x 5 A relay) Accessories Type M3 Soft PA PA PA PA MA MA Description Multilingual programming software containing specific library functions (CD-ROM) EEPROM memory cartridge 3 m serial programming cable: PC ➞ Millenium 3 USB programing cable 3 m: PC ➞ Millenium 3 Code 88970111 88970108 88970102 88970109 88970104 88970313 88970317 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Removable connector (spring cage) kit for NBR12, CD12 RBT Removable connector (spring cage) kit for XD26 RBT Dimensions (mm) XD26 RBT Smart CD12 RBT Smart 124,6 113,3 71,2 1 ESC 2 1 2 1 + 2 1 2 90 35 100 95 90 OK A B ESC – + OK 107,6 – 27,5 B 27,5 A 107,6 35 95 100 27,5 27,5 59,9 58 68 58 68 19 107-UK_Millenium 3 Smart_Smart range with Removable Terminal blocks_9730.fm Page 20 Jeudi, 5. décembre 2013 12:11 12 Connections References compatible connectors / Phoenix contact: www.phoenixcontact.com Connectors Vertical Connectors with screw connection Standard Connectors with screw connection Connectors with spring-cage connection Maximum current in contacts 10 A @ 70 °C 12 A @ 60 °C 9 A @ 70 °C 12 A @ 50 °C 12 A @ 70 °C CD12 RBT Smart Qty 1 2 pins MSTB 2.5 HC/2-ST-5.08 1 8 pins MSTB 2.5 HC/8-ST-5.08 1 11 pins MSTB 2.5 HC/11-ST-5.08 Qty 1 2 pins MVSTBR 2.5 HC/2-ST-5.08 1 8 pins MVSTBR 2.5 HC/8-ST-5.08 1 11 pins MVSTBR 2.5 HC/11-ST-5.08 Qty 1 1 1 Ref. Crouzet: 88 970 313 2 pins FKC 2.5/2-ST-5.08 8 pins FKC 2.5/8-ST-5.08 11 pins FKC 2.5/11-ST-5.08 XD26 RBT Smart Qty 1 1 3 1 Qty 1 1 3 1 Qty 1 1 3 1 Ref. Crouzet: 88 970 317 2 pins FKC 2.5/2-ST-5.08 17 pins FKC 2.5/17-ST-5.08 5 pins FKC 2.5/5-ST-5.08 7 pins FKC 2.5/7-ST-5.08 2 pins MSTB 2.5 HC/2-ST-5.08 17 pins MSTB 2.5 HC/17-ST-5.08 5 pins MSTB 2.5 HC/5-ST-5.08 7 pins MSTB 2.5 HC/7-ST-5.08 2 pins MVSTBR 2.5 HC/2-ST-5.08 17 pins MVSTBR 2.5 HC/17-ST-5.08 5 pins MVSTBR 2.5 HC/5-ST-5.08 7 pins MVSTBR 2.5 HC/7-ST-5.08 Product adaptations ■ ■ ■ ■ ■ 20 Blind versions Static outputs versions 12 V c , 24 V a power supply versions (not feasible in 110-230 V a for safety reasons) Termination extensions UL - cUL certification 108-111-UK_Millenium 3 Essential_ Compact range with display_5931.fm Page 21 Mardi, 17. décembre 2013 11:58 11 Millenium 3 Essential ➜ Essential range: powerful but cost effective ■ Industrial temperature range (-20 °C ➞ +55 °C) ■ Analog inputs 0-10 VDC, Potentiometer (0-20 mA/Pt100 with converters) ■ Display versions: - Green LCD with 4 lines of 18 characters and configurable backlighting - Selective parameter setting: you can choose the parameters that can be adjusted on the front panel ■ Expandable versions: open to XN network communication extensions and digital I/O or analog extensions CD12/XD10 CD20/XD26 CB12/XB10 CB20/XB26 Part numbers Essential "compact" range Type Input CD12 8 digital (including 4 analog) CD20 CB12 CB20 Output 4 relays 8 A Supply 24 V c Code 88970041 8 digital (including 4 analog) 4 solid state 0.5 A (including 1 PWM) 4 relays 8 A 24 V c 12 V c 88970042 8 digital (including 4 analog) 8 digital (including 4 analog) 4 solid state 0.5 A (including 1 PWM) 12 V c 88970865 12 digital (including 6 analog) 8 relays 8 A 88970051 12 digital (including 6 analog) 8 solid state 0.5 A (including 4 PWM) 24 V c 24 V c 12 digital (including 6 analog) 8 relays 8 A 88970055 8 digital (including 4 analog) 4 relays 8 A 12 V c 24 V c 8 digital (including 4 analog) 4 solid state 0.5 A (including 1 PWM) 88970840 12 digital (including 6 analog) 8 relays 8 A 12 digital (including 6 analog) 8 solid state 0.5 A (including 4 PWM) 12 V c 24 V c 24 V c Input 6 digital (including 4 analog) Output 4 relays 8 A Supply 24 V c Code 88970141 6 digital (including 4 analog) 4 solid state 0.5 A (including 1 PWM) 10 relays (8 x 8 A relay and 2 x 5 A relay) 24 V c 24 V c 88970142 16 digital (including 6 analog) 16 digital (including 6 analog) 10 solid state 0.5 A (including 4 PWM) 88970162 16 digital (including 6 analog) 10 relays (8 x 8 A relay and 2 x 5 A relay) 24 V c 12 V c 16 digital (including 6 analog) 10 solid state 0.5 A (including 4 PWM) 88970814 6 digital (including 4 analog) 4 relays 8 A 6 digital (including 4 analog) 4 solid state 0.5 A (including 1 PWM) 12 V c 24 V c 24 V c 16 digital (including 6 analog) 10 relays (8 x 8 A relay and 2 x 5 A relay) 88970151 16 digital (including 6 analog) 10 solid state 0.5 A (including 4 PWM) 24 V c 24 V c 16 digital (including 6 analog) 10 relays (8 x 8 A relay and 2 x 5 A relay) 12 V c 88970155 88970045 88970052 88970021 88970031 88970806 Essential "expandable" range Type XD10 XD26 XB10 XB26 88970161 88970165 88970131 88970132 88970152 Accessories Type M3 Soft PA PA PA PA Description Multilingual programming software containing specific library functions (CD-ROM) EEPROM memory cartridge 3 m serial programming cable: PC ➞ Millenium 3 USB programing cable 3 m: PC ➞ Millenium 3 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Code 88970111 88970108 88970102 88970109 88970104 21 108-111-UK_Millenium 3 Essential_ Compact range with display_5931.fm Page 22 Jeudi, 5. décembre 2013 12:25 12 Dimensions (mm) CD12 CB12 2 1 2 – + 1 2 1 2 90 35 100 90 OK 1 2 1 2 1 2 1 2 58 68 57,5 67,5 CD20 CB20 124,6 113,3 57,5 67,5 XD10 XB10 1 2 1 OK 2 90 35 1 2 1 2 1 2 1 2 107,6 2 + 27,5 2 1 – 100 90 35 ESC 27,5 1 B 107,6 27,5 71,2 59,9 27,5 71,2 59,9 100 A 58 68 57,5 67,5 XD26 XB26 124,6 113,3 – + 27,5 35 100 90 OK 27,5 ESC 27,5 B 107,6 35 100 27,5 124,6 113,3 58 68 22 90 58 68 A 107,6 35 100 90 OK 90 + 107,6 – 27,5 ESC 27,5 B 107,6 35 100 27,5 27,5 124,6 113,3 A 107,6 ESC 27,5 1 B 27,5 A 107,6 35 100 27,5 71,2 59,9 27,5 71,2 59,9 57,5 67,5 112-UK_Millenium 3 Essential_Sandwich communication extensions_5955.fm Page 23 Jeudi, 5. décembre 2013 12:27 12 Millenium 3 Smart and Essential ➜ Sandwich communication extensions ■ Standard Modbus RS485 or TCP/IP protocol ■ Connects one or several Millenium 3 to a touch screen, a supervision PC or a network gateway ■ Exchange of the input/output state and/or of internal values ■ Updating date and time of a group of Millenium 3 ■ Power supply via the controller XN06 XN05 Part numbers Type XN06 XN05 Description Modbus RS-485 (slave) communication extension Ethernet protocol TCP/IP Modbus extension (Server) Supply Via the 24 V c controller Via the 24 V c controller Code 88972250 88970270 Specific characteristics* 88972250 88970270 Certifications Earthing UL, CSA Yes, refer to the quick reference guide supplied with the product -20 ➞ +55 °C (+40 °C in a non-ventilated enclosure) in accordance with IEC/EN 60068-2-1 and IEC/EN 60068-2-2 Maximum length of the network: 1000 m (9600 Baud maxi, AWG 26) UL, CSA Yes, refer to the quick reference guide supplied with the product 0 ➞ +55 °C (+40 °C in a non-ventilated enclosure) in accordance with IEC/EN 60068-2-1 and IEC/EN 60068-2-2 Maximum length between 2 controllers: 100 m Communication parameters 88972250 88970270 Type of link Transmission rate (Bauds) 2 or 4-wire; RTU or ASCII 1200, 2400, 4800, 9600, 19200, 28800, 38400, 57600 None; even; odd 1 ➞ 247 - Operating temperature Cable length Parity Addressing Characteristics of exchanges Static or dynamic (BootP server) 88972250 88970270 4 1 - 8 8 12 1 8 8 4 1 Ladder programming Image of smart relay I/O Status Function blocks programming Read-words Read/Write Clock words "Status" words Dimensions (mm) XN05 - XN06 35 90 108 35 27,5 100 27,5 10 67,5 57,5 52,5 25 15 44 *Also see Millenium 3 Smart and Essential General characteristics 23 113-UK_Millenium 3 Smart_Sandwich communication extensions_8350.fm Page 24 Jeudi, 5. décembre 2013 12:33 12 Millenium 3 Smart ➜ Sandwich communication extension ■ Allows the ability to create a Millenium 3 network ■ Ability to exchange 6 to 1 words with FBD programming ■ Only compatible with Millenium 3 Smart controllers ■ Periodic exchanges with max. 6 XN06 extensions ■ Automatic recognition of number of slaves XN07 Part numbers Type XN07 Description Master exchange unit for XN06 Supply Via the 24 V c controller Code 88974250 Accessories Designation RJ45 tee-joint with 20 cm cable EOL ferrules, RC 120  1 nF (pack of 2) RJ45 wiring kit (2 tees, 2 ferrules, 1 x 4-pair FTP cable, 3 m) Code 88970125 88970126 88970127 Specific characteristics* Earthing Operating temperature Cable length Pull-up and Pull-down resistance Internal link between electronic mass and equipment mass Refer to the quick reference guide supplied with the product -20 ➞ +55 °C (+40 °C in a non-ventilated enclosure) in accordance with to IEC/EN 60068-2-1 and IEC/EN 60068-2-2 Maximum network length: 1000 m (max. 9600 bauds, AWG 26) Polarised line with 470  resistance (included in product) Communication parameters Type of link Transmission rate (Bauds) Parity Addressing 2 or 4-wire; RTU or ASCII 1200, 2400, 4800, 9600, 19200, 28800, 38400, 57600 None; even; odd XN07: 7 ➞ 247 XN06: 1 ➞ 6 Characteristics of exchanges Function blocks programming Read-words 1 to 6, depending on the number of XN06 (1 XN06: 6 words, 2 XN06: 3 words, 3 XN06: 2 words, 4, 5 or 6 XN06: 1 word) Write-words 1 to 6, depending on the number of XN06 (1 XN06: 6 words, 2 XN06: 3 words, 3 XN06: 2 words, 4, 5 or 6 XN06: 1 word) "Status" words 1 (state of XN06, connected - non-connected) Clock synchronise bit Date and time update bit XN07 ➞ XN06 Initialisation bit Initialization bit (update of number of slaves connected) Watch dog bit 1 per XN06 (0/1 if connected) Cycle time RTU at 1200 bauds: with 6 XN06: < 3.7 s at 1200 bauds: with 1 XN06: < 1 s at 57600 bauds: with 6 XN06: < 0.2 s ASCII at 1200 bauds: with 6 XN06: < 5.7 s at 1200 bauds: with 1 XN06: < 1.5 s at 57600 bauds: with 6 XN06: < 0.2 s *Also see Millenium 3 Smart and Essential General characteristics 24 113-UK_Millenium 3 Smart_Sandwich communication extensions_8350.fm Page 25 Jeudi, 5. décembre 2013 12:33 12 Dimensions (mm) XN07 88970125 67,5 200 20 90 35 39 108 35 27,5 100 15 20 42 35 11,7 53 57,5 52,5 27,5 10 88970126 25 44 15 Connections Example with three slaves and accessories (two-wire) XN07 88974250 88970125 1 88970126 88970126 88970125 2 3 4 XN06 88972250 XN06 88972250 XN06 88972250 1 RJ45/RJ45 "Cat 5E" - 100  FTP, 4 pairs (available in RJ45 wiring kit - part no.: 88970127) 2 XN06 Modbus slave 1 3 XN06 Modbus slave 2 4 XN06 Modbus slave 3 Concerning connection precautions, please refer to the installation sheet IS 0876 (M3 Application note - Modbus extension XN06 and XN07: Implementation of simplified networks) Applications Increase the number of inputs/outputs - More inputs/outputs while retaining the user-friendly program interface of the Millenium 3 - Easier wiring over long distances (up to 1000 m) - Flexible, modular solution Repartition of an application to several Millenium 3 - Each Millenium 3 manages a part of the application, the Master synchronizes the lot Double the processing capacity with data exchange - Local and/or remote data processing 25 114-115-UK_Millenium 3 Smart_Digital.fm Page 26 Jeudi, 5. décembre 2013 12:38 12 Millenium 3 Smart and Essential ➜ Digital sandwich extension* ■ Can be used to reach up to 50 inputs/outputs in conjunction with the XR14 termination extension XE10 ■ Relay outputs one of which is a changeover relay Part numbers Type XE10 Input 6 digital 6 digital 6 digital Output 4 relays 5 A (1 of which is a changeover relay) 4 relays 5 A (1 of which is a changeover relay) 4 relays 5 A (1 of which is a changeover relay) Supply Via the 24 V c controller 100 ➞ 240 V a 24 V a Code 88970321 88970323 88970324 Specific characteristics* Certifications CE, UL, CSA Dimensions (mm) 72 90 107,6 27,5 35 100 27,5 XE10 57,5 67,5 60 ➜ Digital extensions* ■ Power supply via the controller at the same voltage as the inputs ■ Number of inputs/outputs can be configured in accordance with your requirements XR06 XR10 XR14 Part numbers Type XR06 Input 4 digital 4 digital 4 digital 4 digital 6 digital 6 digital 6 digital 6 digital 8 digital 8 digital 8 digital 8 digital XR10 XR14 Output 2 relays 8 A 2 relays 8 A 2 relays 8 A 2 relays 8 A 4 relays 8 A 4 relays 8 A 4 relays 8 A 4 relays 8 A 6 relays (4 x 8 A relay and 2 x 5 A relay) 6 relays (4 x 8 A relay and 2 x 5 A relay) 6 relays (4 x 8 A relay and 2 x 5 A relay) 6 relays (4 x 8 A relay and 2 x 5 A relay) Supply Via the 24 V c controller Via the 100 ➞ 240 V a controller Via the 24 V a controller Via the 12 V c controller Via the 24 V c controller Via the 100 ➞ 240 V a controller Via the 24 V a controller Via the 12 V c controller Via the 24 V c controller Via the 100 ➞ 240 V a controller Via the 24 V a controller Via the 12 V c controller Dimensions (mm) XR06 XR10 - XR14 72 25 57,5 67,5 60 *Also see Millenium 3 Smart and Essential General characteristics 26 57,5 67,5 107,6 90 27,5 35 100 90 107,6 35 27,5 100 27,5 27,5 35,5 Code 88970211 88970213 88970214 88970215 88970221 88970223 88970224 88970225 88970231 88970233 88970234 88970235 116-UK_Millenium 3 Smart_ Application-specific analogue termination extension_6430.fm Page 27 Jeudi, 5. décembre 2013 12:40 12 Millenium 3 Smart ➜ "Application-specific" analog termination extension ■ 3 Pt100 temperature inputs in the same casing ■ "Application-specific" example: temperature regulation and measurement ■ Extension compatible with any Millenium 3 Smart expandable logic controller ■ Also see Pt100 probes XA03 Part numbers Type XA03 Input 3 Pt100 (-25 ➞ +125 °C) Supply Via the 24 V c controller Code 88970800 Specific characteristics* Inputs Certifications Conformity to standards Measurement range Resolution Value of LSB Input type Pt100 (IP, IQ, IR) CE, UL, CSA IEC/EN 61131-2 (Zone B), IEC/EN 61000-6-2, IEC/EN 61000-6-3, IEC/EN 61000-6-4 -25 ➞ + 125 °C 10 bit 0.15 °C Pt100 probe IEC/EN 60751 3-wire Module cycle time 2 mA  5Va 100 ➞ 240 V a (-15 % / +10 %) 0.24 mA @ 85 V a 0.75 mA @ 264 V a < 0.5 mA Configurable in increments of 10 ms 50 ms min. up to 255 ms State 0 ➞ 1 (50/60 Hz) 50 ms State 0 ➞ 1 (50/60 Hz) In accordance with cycle time (Tc) and input response time (Tr): 1/ ( (2 x Tc) + Tr) Contact or 3-wire PNP Resistive None None Yes On LCD screen for CD and XD 350 k  79 V a > 0.17 mA  20 V a ( 28 V a : XE10, XR06, XR10, XR14) < 0.5 mA Configurable in increments of 10 ms 50 ms min. up to 255 ms State 0 ➞ 1 (50/60 Hz) 50 ms State 0 ➞ 1 (50/60 Hz) In accordance with cycle time (Tc) and input response time (Tr): 1 / ( (2 x Tc) + Tr) Contact or 3-wire PNP Resistive None None Yes On LCD screen for CD and XD 123-UK_lpr_Millenium 3 Smart_3718.fm Page 41 Jeudi, 5. décembre 2013 2:18 14 Characteristics of relay outputs common to the entire range Max. breaking voltage Breaking current Electrical durability for 500 000 operating cycles Max. Output Common Current Minimum switching capacity Minimum load Maximum rate Mechanical life Voltage for withstanding shocks Response time Built-in protections Status indicator 5 ➞ 30 V c 24 ➞ 250 V a CB-CD-XD10-XB10-XR06-XR10: 8 A XD26-XB26: 8 x 8 A relay, 2 x 5 A relay XE10: 4 x 5 A relay XR14: 4 x 8 A relay, 2 x 5 A relay Utilization category DC-12: 24 V, 1.5 A Utilization category DC-13: 24 V (L/R = 10 ms), 0.6 A Utilization category AC-12: 230 V, 1.5 A Utilization category AC-15: 230 V, 0.9 A 12 A for O8, O9, OA 10 mA (at minimum voltage of 12 V) 12 V, 10 mA Off load: 10 Hz At operating current: 0.1 Hz 10.000.000 (operations) In accordance with IEC/EN 60947-1 and IEC/EN 60664-1: 4 kV Make 10 ms Release 5 ms Against short-circuits: None Against overvoltages and overloads: None On LCD screen for CD and XD Characteristics of product with DC power supplied 12 V c 24 V c Immunity from micro power cuts Max. absorbed power 12 V c -13 % / +20 % or 10.4 V c ➞ 14.4 V c (including ripple)  1 ms (repetition 20 times) CB12 with solid state outputs: 1.5 W CD12: 1.5 W CD20: 2.5 W XD26-XB26: 3 W XD26-XB26 with extension: 5 W XD26 with solid state outputs: 2.5 W Protection against polarity inversions Yes 24 V c -20 % / +25 % or 19.2 V c ➞ 30 V c (including ripple)  1 ms (repetition 20 times) CB12-CD12-CD20 with solid state outputs - XD10-XB10 with solid state outputs: 3 W XD10-XB10 with relay outputs: 4 W XD26-XB26 with solid state outputs: 5 W CB20-CD20 with relay outputs: 6 W XD26 with relay outputs: 6 W XD10-XB10 with extension: 8 W XD26-XB26 with extension: 10 W Yes 12 V c 24 V c 12 V c (-13 % / +20 %) 3.9 mA @ 10.44 V c 4.4 mA @ 12.0 V c 5.3 mA @ 14.4 V c 2.7 k  7Vc  2 mA  3Vc < 0.9 mA 1 ➞ 2 cycle times + 6 ms 24 V c (-20 % / +25 %) 2.6 mA @ 19.2 V c 3.2 mA @ 24 V c 4.0 mA @ 30.0 V c 7.4 k  15 V c  2.2 mA  5Vc < 0.75 mA 1 ➞ 2 cycle times + 6 ms - Inputs I1 & I2: FBD (up to 6 kHz) & Ladder (1 kHz) - Inputs I3 to IA & IH to IY: In accordance with cycle time (Tc) and input response time (Tr): 1/ ( (2 x Tc) + Tr) Contact or 3-wire PNP Type 1 Resistive None None Yes On LCD screen for CD and XD - Inputs I1 & I2: FBD (up to 6 kHz) & Ladder (1 kHz) - Inputs I3 to IA & IH to IY: In accordance with cycle time (Tc) and input response time (Tr): 1/ ( (2 x Tc) + Tr) Contact or 3-wire PNP Type 1 Resistive None None Yes On LCD screen for CD and XD Supply Nominal voltage Operating limits Digital inputs (I1 to IA and IH to IY) Input voltage Input current Input impedance Logic 1 voltage threshold Making current at logic state 1 Logic 0 voltage threshold Release current at logic state 0 Response time Maximum counting frequency Sensor type Conforming to IEC/EN 61131-2 Input type Isolation between power supply and inputs Isolation between inputs Protection against polarity inversions Status indicator 41 123-UK_lpr_Millenium 3 Smart_3718.fm Page 42 Jeudi, 5. décembre 2013 2:18 14 12 V c 24 V c CB12-CD12-XD10-XB10 4 inputs IB ➞ IE 4 inputs IB ➞ IE CB20-CD20-XB26-XD26 6 inputs IB ➞ IG 6 inputs IB ➞ IG (0 ➞ 10 V) or (0 ➞ V power supply) 14 k 14.4 V c max. 14 mV Common mode 10 bit at max. input voltage Controller cycle time ±5% ± 6.2 % ±2% None 10 m maximum, with shielded cable (sensor not isolated) Yes 2.2 k / 0.5 W (recommended) 10 k max. (0 ➞ 10 V) ou (0 ➞ V power supply) 12 k 30 V c max. 29 mV Common mode 10 bit at max. input voltage Controller cycle time ±5% ± 6.2 % ±2% None 10 m maximum, with shielded cable (sensor not isolated) Yes 2.2 k / 0.5 W (recommended) 10 k max. 12 V c (-13 % / +20 %) 0.7 mA @ 10.44 V c 0.9 mA @ 12.0 V c 1.0 mA @ 14.4 V c 14 k  7Vc  0.5 mA  3Vc  0.2 mA 1 ➞ 2 cycle times In accordance with cycle time (Tc) and input response time (Tr): 1/ ( (2 x Tc) + Tr) Contact or 3-wire PNP Type 1 Resistive None None Yes On LCD screen for CD and XD 24 V c (-20 % / +25 %) 1.6 mA @ 19.2 V c 2.0 mA @ 24.0 V c 2.5 mA @ 30.0 V c 12 k  15 V c  1.2 mA  5Vc  0.5 mA 1 ➞ 2 cycle times In accordance with cycle time (Tc) and input response time (Tr): 1/ ( (2 x Tc) + Tr) Contact or 3-wire PNP Type 1 Resistive None None Yes On LCD screen for CD and XD Analog or digital inputs (IB to IG) Inputs used as analog inputs only in FBD Measurement range Input impedance Input voltage Value of LSB Input type Resolution Conversion time Accuracy at 25 °C Accuracy at 55 °C Repeat accuracy at 55 °C Isolation between analog channel and power supply Cable length Protection against polarity inversions Potentiometer control Inputs used as digital inputs Input voltage Input current Input impedance Logic 1 voltage threshold Making current at logic state 1 Logic 0 voltage threshold Release current at logic state 0 Response time Maximum counting frequency in FBD Sensor type Conforming to IEC/EN 61131-2 Input type Isolation between power supply and inputs Isolation between inputs Protection against polarity inversions Status indicator Characteristics of relay outputs common to the entire range Max. breaking voltage Max. Output Common Current Breaking current Electrical durability for 500 000 operating cycles Minimum switching capacity Minimum load Maximum rate Mechanical life Voltage for withstanding shocks Off-cycle response time Built-in protections Status indicator 42 5 ➞ 30 V c 24 ➞ 250 V a 12 A (10 A UL) for O8, O9, OA CB-CD-XD10-XB10-XR06-XR10: 8 A XD26-XB26: 8 x 8 A relay, 2 x 5 A relay XE10: 4 x 5 A relay XR14: 4 x 8 A relay, 2 x 5 A relay Utilization category DC-12: 24 V, 1.5 A Utilization category DC-13: 24 V (L/R = 10 ms), 0.6 A Utilization category AC-12: 230 V, 1.5 A Utilization category AC-15: 230 V, 0.9 A 10 mA (at minimum voltage of 12 V) 12 V, 10 mA Off load: 10 Hz At operating current: 0.1 Hz 10.000.000 (operations) In accordance with IEC/EN 60947-1 and IEC/EN 60664-1: 4 kV Make 10 ms Release 5 ms Against short-circuits: None Against overvoltages and overloads: None On LCD screen for CD and XD 123-UK_lpr_Millenium 3 Smart_3718.fm Page 43 Jeudi, 5. décembre 2013 2:18 14 Digital / PWM solid state outputs PWM solid state outputs* * Only available with "FBD" programming language Breaking voltage Nominal voltage Nominal current Max. breaking current Voltage drop Response time Frequency (Hz) Built-in protections Min. load Maximum incandescent load Galvanic isolation PWM frequency PWM cyclic ratio PWM accuracy at 120 Hz Max. Breaking current PWM Max. cable length PWM PWM accuracy at 500 Hz Status indicator 12 V c 24 V c CB12: O4 XD26: O4 ➞ O7 CD12-XD10-XB10: O4 CD20-XD26-XB26: O4 ➞ O7 10.4 ➞ 30 V c 12-24 V c 0.5 A 0.625 A  2 V for I = 0.5 A (at state 1) Make  1 ms Release  1 ms 1 Maximum on inductive load Against overloads and short-circuits: Yes Against overvoltages (*): Yes Against inversions of power supply: Yes (*) In the absence of a voltfree contact between the logic controller output and the load 1 mA 0.2 A / 12 V c 0.1 A / 24 V c No 14.11 Hz 56.45 Hz 112.90 Hz 225.80 Hz 451.59 Hz 1806.37 Hz 0 ➞ 100 % (256 steps for CD, XD and 1024 steps for XA) < 5 % (20 % ➞ 80 %) load at 10 mA 50 mA 20 m < 10 % (20 % ➞ 80 %) load at 10 mA On LCD screen for CD and XD 19.2 ➞ 30 V c 24 V c 0.5 A 0.625 A  2 V for I = 0.5 A (at state 1) Make  1 ms Release  1 ms 1 Maximum on inductive load Against overloads and short-circuits: Yes Against overvoltages (*): Yes Against inversions of power supply: Yes (*) In the absence of a voltfree contact between the logic controller output and the load 1 mA 0.1 A / 24 V c No 14.11 Hz 56.45 Hz 112.90 Hz 225.80 Hz 451.59 Hz 1806.37 Hz 0 ➞ 100 % (256 steps for CD, XD and 1024 steps for XA) < 5 % (20 % ➞ 80 %) load at 10 mA 50 mA 20 m < 10 % (20 % ➞ 80 %) load at 10 mA On LCD screen for CD and XD Differences between Millenium 3 Smart and Millenium 3 Essential Millenium 3 Smart Display Supply versions Blue, backlit with white text 24 V c , 12 V c , 100 ➞ 240 V a , 24 V a Operating -20 ➞ +70 °C/-4 ➞ +158 °F Temperature (+40 °C/104 °F in non-ventilated enclosure), except CB, XB in c : -30 ➞ +70 °C/-22 ➞ +158 °F (+40 °C/104 °F in non-ventilated enclosure) in accordance with IEC/EN 60068-2-1 and IEC/EN 60068-2-2 Storage temperature -40 ➞ +80 °C (-40 ➞ +176 °F) in accordance with IEC/EN 60068-2-1 and IEC/EN 60068-2-2 More extensions - XN07 extension for inter-Millenium 3 communication (up to 7 Millenium) - XA03 extension (3 analog inputs for Pt100 temperature probes) More sensors Direct connection of NTC temperature probes and LDR luminosity sensors More functions Additional application specific functions: Autotuning PID, Astronomical clock, Transfer function y=f(x), 2 axis solar tracking, … Number of function 125 blocks in the library Millenium 3 Essential Green, backlit with black text 24 V c , 12 V c -20 ➞ +55 °C/-4 ➞ +131 °F (+40 °C/104 °F in non-ventilated enclosure) in accordance with IEC/EN 60068-2-1 and IEC/EN 60068-2-2 -40 ➞ +70 °C (-40 ➞ +158 °F) in accordance with IEC/EN 60068-2-1 and IEC/EN 60068-2-2 105 43 145-UK_Millenium 3 accessories_Millenium power supply_6830.fm Page 44 Jeudi, 5. décembre 2013 2:25 14 Millenium 3 accessories ➜ Modular power supplies See our NEW Power Suply Family HERE ■ Switch mode power supply regulated and protected ■ ■ ■ ■ against overloads and short-circuits, easy to integrate into switchboards and enclosures The potentiometer can be used to set the output voltage between 100 and 120 % (24 Vc versions) to compensate for any voltage drops on the line The LED continuously signals the presence of voltage at the output and, when flashing, triggering of the selfprotection Broad range of supply voltage Double insulation 7.5 W 30 W 60 W Part numbers Type PS Nominal output voltage 5 V c (4.75 V ➞ 6.25 V) 12 V c (11.4 V ➞ 15 V) 24 V c (22.8 V ➞ 28.8 V) 24 V c (22.8 V ➞ 28.8 V) 24 V c (22.8 V ➞ 28.8 V) 24 V c (22.8 V ➞ 28.8 V) Nominal power 20 W 25 W 7.5 W 15 W 30 W 60 W Nominal output current 4A 2.1 A 0.3 A 0.6 A 1.2 A 2.5 A Code 88950305 88950306 88950303 88950304 88950307 88950302 General characteristics Environmental characteristics Conformity to standards Certifications Emission Operating temperature Storage temperature (°C) Protection class Electrical characteristics Input voltage Supply frequency range Output voltage Peak current on energisation Regulation of line and load Immunity from micro power cuts Thermal protection Technology Short-circuit protection Overload protection Primary protection Reset after overload Dielectric strength Status indication Mechanical characteristics Mounting Screw terminals connection capacity 44 IEC/EN 60950-1 IEC/EN 61000-6-2 IEC/EN 61000-6-3 IEC/EN 61204-3 IEC/EN 60364-4-41 – SELV: Safety Extra Low Voltage EN 55022 (CISPR22) CE, UL, CSA, TüV Harmonic: IEC/EN 61000-3-2 -25 ➞ +55 °C -40 ➞ +70 °C Class 2 (Double insulation) 100 ➞ 240 V a single-phase (-15 %/+10 %) 50/60 Hz (+4 % / -6 %) or 47➞ 53 Hz/57 ➞ 63 Hz Adjustable from 100 ➞ 120 % < 20 A (Except for 88950302: < 90 A during 1 ms) ±3% < 10 ms (100 V a ) < 150 ms (230 V a ) Yes Primary switch mode electronic power supplies Yes Yes Fuse gG 2 A or circuit breaker 2 A curve D for 88950303, 88950304, 88950305, 88950306, 88950307 Fuse gG 3 A or circuit breaker 3 A curve D for 88950302 Automatic Input/output 3000 VAC/50 Hz/1 mn LED at the output On section, 35 x 7. 5 mm and 35 x 15 mm or on panel (2 x Ø4 mm) Input connection 2 x 0.14 ➞ 2.5 mm 2 (AWG 26 ➞ AWG 14) Output connection 1 x 0.14 ➞ 2.5 mm 2 (AWG 26 ➞ AWG 14) 145-UK_Millenium 3 accessories_Millenium power supply_6830.fm Page 45 Jeudi, 5. décembre 2013 2:25 14 Dimensions (mm) 90 4 100 90 51,6 110 66,6 1 2 88950305 42 54 88950306 42 54 88950303 24 36 88950304 24 36 88950307 42 54 88950302 60 72 1 56,1 2 Curves Derating The ambient operating temperature of the Millenium power supplies is 55 °C. Above this, a derating is needed up to a maximum operating temperature of 70 °C. The chart below shows the power (compared to the nominal power) that can be permanently supplied by the power supply depending on the operating temperature P/Pn (%) 100 1 2 30 -25 -5 15 35 55 70 75 T°C 1 88950302 2 8895030x 45 144-UK_Millenium 3 accessories_DCDC converters_6450.fm Page 46 Jeudi, 5. décembre 2013 2:29 14 Millenium 3 accessories ➜ DC/DC converters ■ ■ ■ ■ Power supplies for extended input voltage range Provide your devices with a constant supply voltage Primary/secondary isolation Useful in case of battery use 10 W 6 ➞ 10 w Part numbers Type PS Input 9.2-18 V c 9.2-36 V c Output 12 V c Nominal power 10 W 6 ➞ 10 W 24 V c General characteristics 88950320 88950321 Certifications Output voltage Overvoltage Input limits CE 12 V c ± 5 % 20 V c max. 9.2 ➞ 18 V c (10 W available) Isolation primary / secondary Operating temperature Storage temperature (°C) Immunity from micro power cuts 1500 V c -30 ➞ +70 °C -40 ➞ +80 °C At 10 W: > 1 ms for 9.2 V < U < 12V > 5 ms for U  12 V At 6 W: > 5 ms for all voltage range CE 24 V c ± 5 % 40 V c max. 16 ➞ 36 V c (10 W available) 9.2 ➞ 16 V c (see graph) 1500 V c -30 ➞ +70 °C -40 ➞ +80 °C At 10 W: > 1 ms for 16 V < U < 18 V 5 ms for U  18 V At 6 W: > 1 ms for U < 12 V > 5 ms for 12 V  U < 18 V > 10 ms for U  18 V Dimensions (mm) 90 107,6 27,5 35 100 27,5 35,5 25 57,5 67,5 Curves Input limits W 10 6 9,2 16 36 V Product adaptations ■ Tropicalization ■ Integration in a resin board version 46 Code 88950320 88950321 125-127-UK_Millenium 3 accessories.fm Page 47 Jeudi, 5. décembre 2013 3:11 15 Millenium 3 accessories ➜ Programming tools and softwares ■ Millenium 3 software: multilingual software, intuitive operation ■ Memory card for loading the application and updating the on-board software (firmware) M3 Soft EEPROM memory cartridge Part numbers Type M3 Soft M3 ALARM PA Description Multilingual programming software containing specific library functions (CD-ROM) Alarm management software (CD-ROM) EEPROM memory cartridge Code 88970111 88970116 88970108 General characteristics M3 Soft is compatible with XP, Vista, Windows 7, Windows 8 from AC8 Minimum recommended configuration : 600 M Hz processor and 256 MB RAM PC M3 ALARM is used with the modem communication interface (M3MOD) and is compatible with Windows XP ➜ Connection accessories ■ Direct connection to all types of PC: serial, USB ■ Wireless "Bluetooth®" connection for applications that are complex in terms of access Bluetooth Interface® Serial programming cable USB programing cable Part numbers Type PA Description 3 m serial programming cable: PC ➞ Millenium 3 USB programing cable 3 m: PC ➞ Millenium 3 Millenium 3 interface ➞ Bluetooth® (class A 10 m) 1.80 m serial link cable: DB9 M/DB9 F 500 mm serial programming cable Millenium 3 ➞ DB9 M Code 88970102 88970109 88970104 88970123 88970510 ➜ Removable connectors ■ Millenium 3 can be removed for speedy replacement of the controller ■ Cable connection memory to exclude the risk of errors on reconnection ■ 2 types available: for Millenium 3 screw-type terminal and for Millenium 3 RBT Screw-type connectors Spring cage connectors Part numbers Type MA MA Description Removable kit for Millenium 3 CD12 or CB12 (screw-type terminal) Removable kit for Millenium 3 CD20 or CB20 (screw-type terminal) Removable kit for Millenium 3 XD26 or XB26 (screw-type terminal) Removable connector (spring cage) kit for NBR12, CD12 RBT Removable connector (spring cage) kit for XD26 RBT Code 88970310 88970311 88970312 88970313 88970317 General characteristics Screw terminals connection capacity Max. current Cable diameter 0.14 ➞ 2.5 mm2 AWG 22 - 12 12 A (10 A UL) Comments The references 88970310, 88970311, 88970312 are not usable on 100-230 Va versions of Millenium 3 for safety reasons 47 129-UK_Millenium 3 accessories_Millenium 3 Virtual Display_9850.fm Page 48 Jeudi, 5. décembre 2013 3:14 15 Millenium 3 accessories ➜ Millenium 3 Virtual Display ■ Enables an operator to visualize the Millenium 3 Display on a mobile device (smartphone, tablet, PC) Makes the development and configuration of Millenium 3 applications easy Allows remote monitoring of an equipment Makes the display of the Millenium 3 accessible even when the device is out of reach Available for Millenium 3 controllers with and without display The connection between the Millenium 3 and the device is made via a Bluetooth® interface or via a USB programing cable ■ The Millenium 3 Bluetooth® interface is filtered with its unique MAC address (for the Android version) ■ Available in a Standard and Lite Version. The Standard Version allows the use of all keys while the Lite Version allows the use of all keys with the exception of the ESC and OK keys ■ Android version downloadable on Google Play; Windows XP/7 downloadable on www.crouzet.com ■ ■ ■ ■ ■ Part numbers Type Android Windows XP/7 Description Millenium 3 Virtual Display Lite Millenium 3 Virtual Display Standard Millenium 3 Virtual Display Lite Millenium 3 Virtual Display Standard Code MVD-AND-L MVD-AND-S MVD-PCW-L MVD-PCW-S Accessories Type PA PA Description USB programing cable 3 m: PC ➞ Millenium 3 Millenium 3 interface ➞ Bluetooth® (class A 10 m) Comments Compatible with: - Android v2.2 and more (use the SPP Bluetooth® profile) - Windows XP or Windows 7 (32 or 64 bit) (Bluetooth® or USB connection) Principles Standard Version Lite Version 48 Code 88970109 88970104 130-131-UK_Millenium 3 accessories_Programmable touch panel MTP870_9930.fm Page 49 Jeudi, 5. décembre 2013 3:18 15 Millenium 3 accessories ➜ Programmable touch panels MTP6/50, MTP8/50 and MTP8/70 ■ ■ ■ ■ ■ ■ ■ ■ TFT-LCD compact resistive touch panels, 65536 colors, LED backlight Wide viewing angle: 70° horizontally and vertically Fan-less cooling system Text, data, graphic, animation display Processing of alarms and recipes 400 MHz core logic, 64 MB RAM Direct communication via the Millenium 3 programming port Programmable with user-friendly EB software (compatible with Windows 2000/XP/Vista/7) MTP8/70 MTP6/50 - MTP8/50 Main differentiating characteristics MTP6/50 MTP8/50 MTP8/70 Size of display 4.3" 4.3" 7" Graphical resolution 480 x 272 pixels 480 x 272 pixels 800 x 480 pixels Storage 128 MB flash memory 128 MB flash memory Programming USB Client port Ethernet port Communication RS232/RS485 serial port Sound output - RS232/RS485 serial port Ethernet port - 128 MB flash memory + SD card slot Ethernet port USB Client port 2 RS232/RS485 serial ports Ethernet port yes Part numbers Type RD Designation MTP6/50 user kit (fixing brackets, MTP-M3 cable) MTP8/50 user kit (fixing brackets, MTP-M3 cable) Size 4.3" Programming USB-MiniUSB cable Connection Direct connection M3-MTP Modbus RS232/RS485 serial port Code 88970492 4.3" Ethernet RJ45 crossover cable 88970494 RD MTP8/70 user kit (fixing brackets, MTP-M3 cable) 7" PA MTP6/50-MTP8/70 programming kit – USB-MiniUSB connection (EB/ helpfile CD, USB-MiniUSB cable) MTP8/50-MTP8/70 programming kit – Ethernet crossover connection (EB/ helpfile CD, RJ45 crossover cable) - USB-MiniUSB cable or Ethernet RJ45 crossover cable - Direct connection M3-MTP Modbus RS232/RS485 serial port, Ethernet TCP/IP port Direct connection M3-MTP 2 Modbus RS232/RS485 serial ports, USB port, Ethernet TCP/IP port - - - - 88970502 88970496 88970501 Accessories Type MA MA Designation Modbus cable for MTP6/50 & MTP8/50 Modbus cable for MTP8/70 Code 88970503 88970504 49 130-131-UK_Millenium 3 accessories_Programmable touch panel MTP870_9930.fm Page 50 Jeudi, 5. décembre 2013 3:18 15 General characteristics Environmental characteristics Certifications Conformity to standards Operating temperature Storage temperature (°C) Relative humidity Protection rating Vibration resistance Shock resistance Electrical characteristics Supply voltage Voltage limits Consumption Mechanical characteristics Dimensions (l x h x w) MTPx/50 MTP8/70 Panel cut-out Panel thickness Mounting Connection Weight Display characteristics Description MTPx/50 MTP8/70 MTPx/50 MTP8/70 MTP6/50, MTP 8/50 and MTP8/70 MTPx/50 MTP8/70 Display details Functions Communication Programming Real-time clock 50 MTP6/50, MTP 8/50 and MTP8/70 MTP8/50 and MTP8/70 MTP6/50 MTP8/50 MTP8/70 UL, cUL CEI 61000-4 0 ➞ +45 °C -20 ➞ +60 °C 10 ➞ 90 % (operation) IP65 - Dust and droplets Front panel seal watertight at standard 10 - 25 Hz, 2G 30 minutes in each of the X, Y, Z axes Free fall from 1 meter in each of the X, Y, Z axes 24 V c Internal insulation via transformer 19.2 ➞ 28.8 V c 7.2 W max. 128 x 102 x 38 mm Useful screen area: 95 x 54 mm 200 x 146 x 42.5 mm Useful screen area: 154 x 93 mm 119 x 93 mm 192 x 138 mm 1 ➞ 10 mm Built-in, fixing by 2 screw clamps (supplied) for 1 to 10 mm panel Removable 3-pin screw terminal block (supplied) a 300 g a 800 g TFT-LCD polychrome, 65536 colors LED backlight 400 MHz core logic, 64 MB RAM 128 MB flash memory (programs and recipes backup) Programmable with EB software Touch panel with user-definable layout Key life: 1 million operations minimum 4.3'' Resolution 480 x 272 pixels 7'' Resolution 800 x 480 pixels SD card memory slot and USB Host port Straight lines, free lines, squares, ovals, arcs, polygons, bitmaps, animations.gif, standard fonts Buttons, switches, levers, LEDs, messages, data, password-secured buttons, triggers Bar charts, linear gauges, clocks, alphanumeric keyboards, graphics, recipes, alarm lists Text scrolling, multiple windows, data transfer, multiple language Archive Direct connection M3-MTP (cable supplied) Modbus RS485 connection: 2/4 cables (accessory) Modbus TCP/IP connection (Ethernet port) PC-MTP6/50 connection via USB-MiniUSB cable (accessory) PC-MTP8/50 connection via Ethernet RJ45 cross-over cable (accessory) PC-MTP8/70 connection via USB-MiniUSB cable (accessory) or via Ethernet RJ45 cross-over cable (accessory) Uses Millenium 3 clock or built-in clock 130-131-UK_Millenium 3 accessories_Programmable touch panel MTP870_9930.fm Page 51 Jeudi, 5. décembre 2013 3:18 15 Dimensions (mm) Panel cut-out MTP6/50 and MTP8/50 MTP06 128 CPU PWR 93 102 COM 118 38,25 92 119 R eset D IP S W COM + -- MTP08 Panel cut-out MTP8/70 200 5 6 138 146 7 8 9 10 11 190 42,5 192 4 4 4 4 1 136 2 3 1 DIP SW & Reset button 2 Fuse 3 Power connector 4 VESA 75 mm screw holes 5 Audio 6 SD card slot 7 Com1 RS485, Com3 RS485, Com3 RS232 8 Com1 RS232, Com2 RS232 9 Ethernet port (RJ-45) 10 USB Host port 11 USB client port (programmation) 51 135-UK_Millenium 3 accessories_Remote LCD displayskeypads_7150.fm Page 52 Jeudi, 5. décembre 2013 3:26 15 Millenium 3 accessories ➜ Remote LCD displays/keypads ■ Direct link with Millenium 3 via cable ■ Highlight the data and parameters information of your automation application ■ Backlit LCD screen with 4 lines of 18 characters and keypad with 6 keys or 10 keys and 4 LEDs ■ Direct communication with the Millenium 3 via the programming port ■ Plug and play: no additional software (the function Remote LCD screen/keypad keys and LEDs are controlled by the M3 Soft SLIn/ SLOut function blocks) ■ Check bit for controlling communication ■ Universal screen compatible with any Millenium 3 logic controller (standard, budget, expandable, bare board, resin board) Remote LCD screen/keypad + 4 function keys + 4 LEDs Part numbers Type RD1 RD2 Designation Remote LCD screen/keypad Kit with remote LCD screen/keypad + 3 m cable Remote LCD screen/keypad + 4 function keys + 4 LEDs Kit with remote LCD screen/keypad + 4 function keys + 4 LEDs + 3 m cable Code 88970410 88970412 88970411 88970413 Accessories Type MA PA PA Designation IP65 protective membrane (in accordance with DIN 40050 and EN60529) 3 m serial programming cable: PC ➞ Millenium 3 1.80 m serial link cable: DB9 M / DB9 F Code 88970414 88970102 88970123 General characteristics Environmental characteristics Certifications Dimensions (l x h x w) Panel cut-out Protection rating Electrical characteristics Supply voltage Voltage limits Consumption Protection against polarity inversions Mechanical characteristics Mounting Display protection Keyboard material Housing material Connection Connection Cable length Display characteristics Cycle time CE 96.6 x 72.8 x 63 mm 92 x 68 mm IP54 on front panel IP20 on rear panel 24 V c (the power supply has to be common with the Millenium 3 power supply) - 20 %/+ 25 % or 19.2 ➞ 30 V c (including ripple) 1.5 W (88970410) 2 W (88970411) yes Flush-mounted, fixed with 2 clips (supplied) Polyester Polyester Self-extinguishing UL94V1 Removable 2-pin terminal Serial via 9-pin male SUB D connector 3 m maximum 20 ms + 2 Millenium 3 Controller cycles (88970410 and 88970412) 50 ms + 10 Millenium 3 Controller cycles (88970411 and 88970413) Comments If using a remote display/keypad with a Millenium 3 resin board version, order the DB9/DB9 serial programming cable separately (Part no. 88970123) 52 135-UK_Millenium 3 accessories_Remote LCD displayskeypads_7150.fm Page 53 Jeudi, 5. décembre 2013 3:26 15 Dimensions (mm) Backside 1 96,6 A - B 72,8 + + - 24VDC ESC OK 9 8 55 120 1 Seal 30 68 68 +0,7 +0 30 92 +0 92,2 +0.8 53 136-UK_Millenium 3 accessories_Remote LED display - Input 0-10 V_6510.fm Page 54 Jeudi, 5. décembre 2013 3:29 15 Millenium 3 accessories ➜ Remote LED display - Input 0-10 V Highlight the data of your automation application Display (36 x 72 mm) with 4 x 14 mm red digits Configurable display range 0-10 V input IP65 degree of protection on front panel ■ ■ ■ ■ ■ Part numbers Type RD Description Display with 4 x 14 mm red digits Supply 24 V c General characteristics Environmental characteristics Certifications Conformity to standards Protection rating CE IEC/EN 61000-6-4, IEC/EN 61010-1 In accordance with IEC/EN 60529: IP65 on front panel IP20 on rear -10 ➞ +55 °C 36 x 72 x 61 mm 71 x 29 mm Operating temperature Dimensions (l x h x w) Panel cut-out Electrical characteristics Supply 24 V c Tolerance ± 10 % Consumption , =,
88970052 价格&库存
很抱歉,暂时无法提供与“88970052”相匹配的价格&库存,您可以联系我们找货
