CGH40035F
CGH40035F
    WOLFSPEED
    DO-201AD
    RF Mosfet 28 V 500 mA 0Hz ~ 4GHz 14dB 45W 440193
CGH40035F 数据手册
CGH40035F 35 W, DC - 4 GHz, RF Power GaN HEMT Description Wolfspeed's CGH40035F is an unmatched, gallium nitride (GaN) high electron mobility transistor (HEMT). The CGH40035F, operating from a 28 volt rail, offers a general purpose, broadband solution to a variety of RF and microwave applications. GaN HEMTs offer high efficiency, high gain and wide bandwidth capabilities making the CGH40035F ideal for linear and compressed amplifier circuits. The transistor is available in a screw-down, flange package. Package Type: 440193 PN: CGH40035F Features Applications • • • • • • • • • • • Up to 4 GHz Operation 15 dB Small Signal Gain at 2.0 GHz 13 dB Small Signal Gain at 4.0 GHz 45 W typical PSAT 60% Efficiency at PSAT 28 V Operation 2-Way Private Radio Broadband Amplifiers Cellular Infrastructure Test Instrumentation Class A, AB, Linear Amplifiers Suitable for OFDM, W-CDMA, EDGE, CDMA waveforms Large Signal Models Available for ADS and MWO Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 2 Absolute Maximum Ratings (not simultaneous) at 25˚C Case Temperature Parameter Symbol Rating Drain-Source Voltage VDSS 120 Gate-to-Source Voltage VGS -10, +2 Storage Temperature Units V TSTG -65, +150 Operating Junction Temperature TJ 225 Maximum Forward Gate Current IGMAX 10.0 mA Maximum Drain Current1 IDMAX 4.5 A Soldering Temperature2 TS 245 ºC Screw Torque Thermal Resistance, Junction to Case3 Case Operating Temperature3, 4 Conditions 25ºC ºC τ 40 in-oz RθJC 3.0 ºC/W TC -40, +100 ºC 25ºC 85ºC Notes: 1 Current limit for long term, reliable operation 2 Refer to the Application Note on soldering at wolfspeed.com/rf/document-library 3 Measured for the CGH40035F at PDISS = 42 W 4 See also, the Power Dissipation De-rating Curve on Page 6 Electrical Characteristics (TC = 25˚C) Characteristics Symbol Min. Typ. Max. Gate Threshold Voltage VGS(th) Gate Quiescent Voltage VGS(Q) Saturated Drain Current Drain-Source Breakdown Voltage Units Conditions -3.8 -3.0 -2.3 — -2.7 — IDS 7.6 10.5 — A VDS = 6.0 V, VGS = 2.0 V VBR 84 — — VDC VGS = -8 V, ID = 10.8 mA DC Characteristics1 VDC VDS = 10 V, ID = 10.8 mA VDS = 28 V, ID = 500 A RF Characteristics2 (TC = 25˚C, F0 = 1.3 GHz unless otherwise noted) Small Signal Gain GSS 13 14 — dB Output Power3 PSAT 30 45 — W η 50 60 — % VDD = 28 V, IDQ = 500 mA, PSAT VSWR — — 10 : 1 Y No damage at all phase angles, VDD = 28 V, IDQ = 500 mA, POUT = 35 W CW CGS — 14.7 — Output Capacitance CDS — 4.9 — pF VDS = 28 V, VGS = -8 V, ƒ = 1 MHz Feedback Capacitance CGD — 0.6 — Drain Efficiency4 Output Mismatch Stress VDD = 28 V, IDQ = 500 mA Dynamic Characteristics Input Capacitance Notes: 1 Measured on wafer prior to packaging 2 Measured in CGH40035F-AMP 3P SAT is defined as IG = 1.08 mA 4 Drain Efficiency = P OUT/PDC Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 3 CGH40035 Page 3 Top 50 20 15 10 10 -0 5 -10 Input Return Loss (dB) Gain (dB) Typical Performance DB(IS(2,1)I) (L) CGH40035F DB(IS(1,1)I) (R) CGH40035F 0 3 3.2 3.4 3.6 3.8 4 -20 Frequency (GHz) Figure 1. Simulated Small Signal Gain and Input Return Loss of the CGH40035F-AMP vs Frequency VDD = 28 V, IDQ = 500 mA 50 50 45 PSAT 40 45 35 40 30 35 Efficiency 25 30 20 25 15 20 10 10 Gain Gain 5 0 3.30 Small Signal Gain Psat Psat SAT 5 DrainEff Eff Drain 3.35 3.45 Drain Efficiency (%) PSAT (W), Small Signal Gain (dB) 45 3.50 3.55 3.55 3.60 3.65 0 3.70 Frequency (GHz) Figure 2. PSAT Small Signal Gain and Drain Efficiency vs Frequency of the CGH40035F in the CGH40035F-AMP VDD = 28 V, IDQ = 500 mA Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 4 16 16 80% 80% 14 14 14 70% 70% 70% Gain Gain (dB) Gain Gain (dB) (dB) 10 10 10 60% 60% 60% Drain Efficiency, PAE (%) 12 12 12 50% 50% 50% Gain Drain Efficiency 888 40% 40% 40% PAE 30% 30% 30% 666 PAE 444 222 20% 20% 20% 10% 10% 10% Efficiency 0 00 22 22 22 24 24 24 26 26 26 28 28 30 30 30 32 32 34 34 34 36 36 36 Drain Efficiency, PAE Drain Efficiency (%), PAE(%) (%) Typical Performance 38 38 38 Output Power (dBm) 40 40 40 42 42 42 44 44 44 46 46 46 0% 0 0% 4848 48 Output Power (dBm) Output Power (dBm) 25 1.13 20 0.75 15 0.375 DB(GMax())[X,1] (L) CGH40035F 10 0.5 1.5 K Factor MAG (dB) Figure 3. Swept CW Data of CGH40035 vs. Output Power with Source and Load Impedances Optimized for PSAT Power in CGH40035F-AMP VDD = 28 V, IDQ = 500 mA, Freq = 3.5 GHz K()[X,1] (R) CGH40035F 2.5 3.5 4.5 5.5 6 0 Frequency (GHz) Figure 4. Simulated Maximum Available Gain and K Factor of the CGH40035F VDD = 28 V, IDQ = 500 mA Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 5 Typical Noise Performance 80 3 RN() (R) CGH40035F 2.5 66.7 2 53.3 40 1.5 1 26.7 0.5 13.3 Noise Resistance (Ohms) Minimum Noise Figure (dB) DB(NFMin()) (L) CGH40035F 0 0 0.5 2.5 4.5 6 Frequency (GHz) Figure 5. Simulated Minimum Noise Figure and Noise Resistance vs Frequency of the CGH40035F VDD = 28 V, IDQ = 500 mA Electrostatic Discharge (ESD) Classifications Parameter Symbol Class Classification Level Test Methodology Human Body Model HBM TBD ANSI/ESDA/JEDEC JS-001 Table 3 JEDEC JESD22 A114-D Charge Device Model CDM TBD ANSI/ESDA/JEDEC JS-002 Table 3 JEDEC JESD22 C101-C Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 6 Source and Load Impedances D Z Source Frequency (MHz) Z Source Z Load 500 5.12 + j8.3 15.5 + j5.67 1000 2.97 + j1.38 11.29 + j7.27 1500 1.15 - j0.38 6.6 + j5.56 2500 0.91 - j5.13 6.17 - j0.4 3500 2.0 - j9.9 4.78 - j2.58 Z Load G S Notes: 1V DD = 28 V, IDQ = 500mA in the 440193 package 2 Optimized for power, gain, P SAT and PAE 3 When using this device at low frequency, series resistors should be used to maintain amplifier stability CGH40035 Power Dissipation De-rating Curve 45 45 40 40 Power Dissipation (W) Power Dissipation (W) 35 35 30 30 25 25 20 20 Note 1 15 15 10 10 55 00 00 25 25 50 50 75 75 100 100 125 125 150 150 175 175 200 200 225 225 250 250 Maximum Case Temperature (°C) Note: 1 Area exceeds Maximum Case Operating Temperature (See Page 2). Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 7 CGH40035F-AMP Demonstration Amplifier Circuit Schematic CGH40035F-AMP Demonstration Amplifier Circuit Outline Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 8 CGH40035F-AMP Demonstration Amplifier Circuit Bill of Materials Designator R1 R2 C6, C13, C19 C16, C22 C15, C21 C8 C1 C2 C10 C4, C11, C17 C5, C12, C18, C30, C31 C7, C14, C20 J2, J3 J1 — Q1 Description RES, 1/16W, 0603, ≤5%, 5.1 OHMS RES, 1/16W, 0603, 1%, 100 OHMS CAP, 470pF, 5%, 100V, 0603 CAP, 33µF, 20%, G CASE CAP, 1.0µF, 100V, 10%, X7R, 1210 CAP 10µF 16V TANTALUM CAP, 0.6pF, +/-0.05pF, 0603 CAP, 1.2pF, +/-0.1pF, 0603 CAP 4.7pF, +/- 0.25pF, ATC 100B CAP, 7.5pF, +/-0.1pF, 0603 CAP, 47pF, +/-5%pF, 0603 CAP, 33000pF, 0805,100V, X7R CONN SMA STR PANEL JACK RECP HEADER RT>PLZ .1CEN LK 9POS PCB, RO4350B, Er = 3.48, h = 20 mil CGH40035F Qty 1 1 3 2 2 1 1 1 1 3 5 3 2 1 1 1 CGH40035F-AMP Demonstration Amplifier Circuit Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 9 Typical Package S-Parameters for CGH40035F (Small Signal, VDS = 28 V, IDQ = 250 mA, angle in degrees) Frequency Mag S11 Ang S11 Mag S21 Ang S21 Mag S12 Ang S12 Mag S22 Ang S22 500 MHz 0.921 -166.38 9.09 82.39 0.015 -1.84 0.555 -165.89 600 MHz 0.921 -169.49 7.57 78.16 0.015 -4.89 0.564 -166.40 700 MHz 0.922 -171.87 6.47 74.31 0.015 -7.54 0.574 -166.63 800 MHz 0.922 -173.79 5.65 70.73 0.015 -9.90 0.583 -166.74 900 MHz 0.923 -175.42 5.00 67.35 0.015 -12.05 0.593 -166.81 1.0 GHz 0.923 -176.84 4.49 64.12 0.014 -14.02 0.604 -166.89 1.1 GHz 0.924 -178.11 4.06 61.01 0.014 -15.84 0.614 -166.99 1.2 GHz 0.925 -179.29 3.71 58.01 0.014 -17.52 0.625 -167.14 1.3 GHz 0.925 179.62 3.41 55.10 0.014 -19.07 0.635 -167.34 1.4 GHz 0.926 178.57 3.16 52.28 0.014 -20.50 0.645 -167.59 1.5 GHz 0.927 177.57 2.94 49.54 0.014 -21.81 0.656 -167.90 1.6 GHz 0.927 176.59 2.75 46.86 0.013 -23.01 0.665 -168.25 1.7 GHz 0.928 175.62 2.58 44.26 0.013 -24.09 0.675 -168.65 1.8 GHz 0.928 174.67 2.43 41.71 0.013 -25.06 0.684 -169.08 1.9 GHz 0.928 173.72 2.30 39.21 0.013 -25.91 0.692 -169.56 2.0 GHz 0.929 172.76 2.19 36.77 0.013 -26.65 0.700 -170.07 2.1 GHz 0.929 171.80 2.09 34.37 0.012 -27.27 0.708 -170.61 2.2 GHz 0.929 170.83 2.00 32.01 0.012 -27.77 0.715 -171.18 2.3 GHz 0.928 169.84 1.92 29.69 0.012 -28.16 0.721 -171.77 2.4 GHz 0.928 168.83 1.85 27.40 0.012 -28.43 0.727 -172.38 2.5 GHz 0.928 167.80 1.78 25.14 0.012 -28.59 0.733 -173.02 2.6 GHz 0.927 166.74 1.73 22.89 0.012 -28.62 0.738 -173.67 2.7 GHz 0.926 165.64 1.68 20.66 0.012 -28.53 0.743 -174.33 2.8 GHz 0.925 164.51 1.63 18.45 0.012 -28.32 0.747 -175.02 2.9 GHz 0.924 163.34 1.59 16.24 0.012 -27.99 0.751 -175.72 3.0 GHz 0.923 162.12 1.56 14.03 0.012 -27.54 0.754 -176.43 3.2 GHz 0.919 159.52 1.51 9.58 0.012 -26.32 0.759 -177.91 3.4 GHz 0.914 156.66 1.48 5.07 0.012 -24.69 0.762 -179.44 3.6 GHz 0.908 153.49 1.46 0.42 0.012 -22.78 0.764 178.96 3.8 GHz 0.901 149.91 1.46 -4.42 0.013 -20.73 0.764 177.29 4.0 GHz 0.891 145.85 1.47 -9.52 0.014 -18.75 0.761 175.54 4.2 GHz 0.879 141.16 1.50 -14.99 0.015 -17.12 0.757 173.69 4.4 GHz 0.863 135.68 1.55 -20.92 0.017 -16.10 0.750 171.73 4.6 GHz 0.844 129.19 1.62 -27.45 0.020 -16.00 0.742 169.65 4.8 GHz 0.819 121.39 1.70 -34.74 0.023 -17.08 0.730 167.41 5.0 GHz 0.788 111.88 1.81 -42.97 0.027 -19.60 0.717 164.98 5.2 GHz 0.750 100.13 1.93 -52.34 0.032 -23.79 0.701 162.29 5.4 GHz 0.707 85.49 2.07 -63.07 0.039 -29.84 0.682 159.23 5.6 GHz 0.662 67.25 2.21 -75.29 0.046 -37.88 0.660 155.58 5.8 GHz 0.626 45.06 2.33 -89.03 0.054 -47.89 0.634 151.00 6.0 GHz 0.611 19.67 2.41 -104.14 0.063 -59.66 0.599 144.99 To download the s-parameters in s2p format, go to the CGH40035F Product page and click on the documentation tab. Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 10 Typical Package S-Parameters for CGH40035F (Small Signal, VDS = 28 V, IDQ = 500 mA, angle in degrees) Frequency Mag S11 Ang S11 Mag S21 Ang S21 Mag S12 Ang S12 Mag S22 Ang S22 500 MHz 0.933 -168.22 9.15 83.17 0.012 0.59 0.599 -170.98 600 MHz 0.933 -171.13 7.63 79.30 0.012 -1.75 0.604 -171.44 700 MHz 0.933 -173.38 6.54 75.79 0.012 -3.72 0.610 -171.69 800 MHz 0.933 -175.22 5.72 72.50 0.012 -5.44 0.615 -171.82 900 MHz 0.933 -176.78 5.09 69.38 0.012 -6.98 0.621 -171.89 1.0 GHz 0.933 -178.16 4.57 66.38 0.012 -8.36 0.628 -171.96 1.1 GHz 0.934 -179.40 4.16 63.48 0.012 -9.61 0.634 -172.02 1.2 GHz 0.934 179.45 3.81 60.66 0.012 -10.74 0.641 -172.11 1.3 GHz 0.934 178.38 3.52 57.92 0.011 -11.75 0.647 -172.22 1.4 GHz 0.934 177.35 3.26 55.24 0.011 -12.67 0.654 -172.37 1.5 GHz 0.934 176.35 3.05 52.61 0.011 -13.47 0.661 -172.55 1.6 GHz 0.934 175.38 2.86 50.04 0.011 -14.18 0.667 -172.77 1.7 GHz 0.934 174.43 2.70 47.51 0.011 -14.78 0.673 -173.03 1.8 GHz 0.933 173.48 2.55 45.02 0.011 -15.29 0.679 -173.32 1.9 GHz 0.933 172.54 2.43 42.58 0.011 -15.69 0.685 -173.64 2.0 GHz 0.933 171.59 2.32 40.16 0.011 -15.99 0.691 -174.00 2.1 GHz 0.932 170.63 2.22 37.78 0.011 -16.19 0.696 -174.39 2.2 GHz 0.932 169.66 2.13 35.43 0.011 -16.29 0.701 -174.80 2.3 GHz 0.931 168.67 2.05 33.10 0.011 -16.30 0.706 -175.25 2.4 GHz 0.930 167.66 1.98 30.79 0.011 -16.21 0.710 -175.71 2.5 GHz 0.929 166.62 1.92 28.49 0.011 -16.02 0.714 -176.21 2.6 GHz 0.928 165.56 1.86 26.21 0.011 -15.75 0.718 -176.72 2.7 GHz 0.927 164.46 1.81 23.93 0.011 -15.40 0.721 -177.26 2.8 GHz 0.925 163.32 1.77 21.66 0.011 -14.96 0.724 -177.82 2.9 GHz 0.924 162.14 1.73 19.38 0.011 -14.46 0.727 -178.40 3.0 GHz 0.922 160.90 1.70 17.09 0.011 -13.89 0.729 -179.00 3.2 GHz 0.917 158.28 1.65 12.48 0.012 -12.64 0.732 179.75 3.4 GHz 0.912 155.38 1.62 7.77 0.012 -11.30 0.733 178.42 3.6 GHz 0.905 152.15 1.61 2.90 0.013 -10.03 0.733 177.01 3.8 GHz 0.896 148.51 1.61 -2.18 0.014 -8.98 0.731 175.53 4.0 GHz 0.885 144.37 1.63 -7.56 0.016 -8.34 0.726 173.97 4.2 GHz 0.871 139.58 1.67 -13.32 0.018 -8.28 0.720 172.31 4.4 GHz 0.853 133.98 1.73 -19.56 0.020 -8.99 0.712 170.56 4.6 GHz 0.831 127.34 1.80 -26.43 0.023 -10.65 0.701 168.71 4.8 GHz 0.804 119.36 1.89 -34.07 0.027 -13.45 0.688 166.73 5.0 GHz 0.770 109.64 2.01 -42.66 0.032 -17.57 0.673 164.60 5.2 GHz 0.729 97.64 2.14 -52.39 0.038 -23.19 0.656 162.24 5.4 GHz 0.684 82.72 2.28 -63.43 0.045 -30.48 0.637 159.52 5.6 GHz 0.638 64.19 2.41 -75.89 0.052 -39.52 0.615 156.18 5.8 GHz 0.603 41.77 2.53 -89.77 0.061 -50.28 0.587 151.85 6.0 GHz 0.592 16.41 2.59 -104.90 0.069 -62.57 0.551 146.03 To download the s-parameters in s2p format, go to the CGH40035F Product page and click on the documentation tab. Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 11 Typical Package S-Parameters for CGH40035F (Small Signal, VDS = 28 V, IDQ = 750 mA, angle in degrees) Frequency Mag S11 Ang S11 Mag S21 Ang S21 Mag S12 Ang S12 Mag S22 Ang S22 500 MHz 0.938 -168.93 9.06 83.42 0.011 1.67 0.616 -172.64 600 MHz 0.938 -171.77 7.56 79.69 0.011 -0.35 0.620 -173.09 700 MHz 0.938 -173.96 6.49 76.30 0.011 -2.03 0.625 -173.35 800 MHz 0.938 -175.76 5.68 73.13 0.011 -3.46 0.629 -173.51 900 MHz 0.938 -177.30 5.05 70.10 0.011 -4.72 0.634 -173.61 1.0 GHz 0.938 -178.66 4.55 67.20 0.011 -5.83 0.639 -173.69 1.1 GHz 0.938 -179.89 4.14 64.38 0.011 -6.82 0.644 -173.77 1.2 GHz 0.938 178.97 3.80 61.63 0.011 -7.70 0.649 -173.86 1.3 GHz 0.938 177.90 3.51 58.96 0.011 -8.47 0.655 -173.98 1.4 GHz 0.938 176.88 3.26 56.33 0.011 -9.15 0.660 -174.12 1.5 GHz 0.937 175.89 3.05 53.76 0.011 -9.72 0.665 -174.28 1.6 GHz 0.937 174.92 2.87 51.23 0.010 -10.21 0.671 -174.48 1.7 GHz 0.937 173.96 2.71 48.74 0.010 -10.60 0.676 -174.71 1.8 GHz 0.936 173.02 2.57 46.28 0.010 -10.89 0.681 -174.97 1.9 GHz 0.936 172.07 2.44 43.86 0.010 -11.10 0.685 -175.26 2.0 GHz 0.935 171.12 2.33 41.47 0.010 -11.22 0.690 -175.58 2.1 GHz 0.935 170.16 2.24 39.10 0.010 -11.24 0.694 -175.93 2.2 GHz 0.934 169.18 2.15 36.76 0.010 -11.19 0.699 -176.30 2.3 GHz 0.933 168.19 2.07 34.43 0.010 -11.05 0.702 -176.70 2.4 GHz 0.932 167.18 2.00 32.12 0.011 -10.83 0.706 -177.13 2.5 GHz 0.931 166.14 1.94 29.81 0.011 -10.54 0.709 -177.58 2.6 GHz 0.930 165.06 1.89 27.52 0.011 -10.18 0.712 -178.06 2.7 GHz 0.928 163.96 1.84 25.23 0.011 -9.76 0.715 -178.55 2.8 GHz 0.927 162.81 1.80 22.94 0.011 -9.28 0.717 -179.07 2.9 GHz 0.925 161.62 1.77 20.64 0.011 -8.77 0.719 -179.61 3.0 GHz 0.923 160.39 1.74 18.33 0.011 -8.23 0.720 179.83 3.2 GHz 0.918 157.74 1.69 13.65 0.012 -7.10 0.722 178.65 3.4 GHz 0.912 154.81 1.66 8.87 0.013 -6.03 0.723 177.40 3.6 GHz 0.904 151.56 1.65 3.92 0.014 -5.15 0.721 176.07 3.8 GHz 0.895 147.88 1.66 -1.26 0.015 -4.59 0.718 174.66 4.0 GHz 0.883 143.69 1.68 -6.74 0.017 -4.52 0.713 173.17 4.2 GHz 0.869 138.85 1.72 -12.62 0.019 -5.08 0.706 171.60 4.4 GHz 0.851 133.18 1.78 -19.00 0.022 -6.42 0.697 169.94 4.6 GHz 0.828 126.46 1.86 -26.01 0.025 -8.72 0.685 168.18 4.8 GHz 0.799 118.38 1.95 -33.80 0.029 -12.12 0.671 166.32 5.0 GHz 0.764 108.54 2.07 -42.55 0.034 -16.81 0.655 164.31 5.2 GHz 0.723 96.40 2.20 -52.44 0.040 -22.96 0.638 162.10 5.4 GHz 0.677 81.32 2.34 -63.62 0.047 -30.70 0.618 159.52 5.6 GHz 0.631 62.63 2.47 -76.21 0.055 -40.13 0.596 156.31 5.8 GHz 0.597 40.10 2.58 -90.17 0.063 -51.20 0.568 152.08 6.0 GHz 0.588 14.75 2.64 -105.34 0.071 -63.71 0.531 146.31 To download the s-parameters in s2p format, go to the CGH40035F Product page and click on the documentation tab. Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 12 Product Dimensions CGH40035F (Package Type — 440193) Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 13 Product Ordering Information Order Number Description Unit of Measure CGH40035F GaN HEMT Each CGH40035F-AMP Test board with GaN HEMT installed Each Rev. 4.2, 2022-11-17 Image 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice. CGH40035F 14 For more information, please contact: 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 www.wolfspeed.com/RF Sales Contact RFSales@wolfspeed.com RF Product Marketing Contact RFMarketing@wolfspeed.com Notes & Disclaimer Specifications are subject to change without notice. “Typical” parameters are the average values expected by Wolfspeed in large quantities and are provided for information purposes only. Wolfspeed products are not warranted or authorized for use as critical components in medical, life-saving, or life-sustaining applications, or other applications where a failure would reasonably be expected to cause severe personal injury or death. No responsibility is assumed by Wolfspeed for any infringement of patents or other rights of third parties which may result from use of the information contained herein. No license is granted by implication or otherwise under any patent or patent rights of Wolfspeed. © 2009-2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. PATENT: https://www.wolfspeed.com/legal/patents The information in this document is subject to change without notice. Rev. 4.2, 2022-11-17 4600 Silicon Drive | Durham, NC 27703 | Tel: +1.919.313.5300 © 2022 Wolfspeed, Inc. All rights reserved. Wolfspeed® and the Wolfstreak logo are registered trademarks and the Wolfspeed logo is a trademark of Wolfspeed, Inc. The information in this document is subject to change without notice.
CGH40035F 价格&库存
很抱歉,暂时无法提供与“CGH40035F”相匹配的价格&库存,您可以联系我们找货
