AS5040-ASST
AS5040-ASST
    AMSOSRAM(艾迈斯半导体)
    SSOP16
    旋转编码器 磁性 1024 PWM
AS5040-ASST 数据手册
AS5040 10Bit 360º Programmable Magnetic Rotary Encoder General Description The AS5040 is a contactless magnetic rotary encoder for accurate angular measurement over a full turn of 360°. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device. To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet may be placed above or below the IC. The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.35° = 1024 positions per revolution. This digital data is available as a serial bit stream and as a PWM signal. Furthermore, a user-programmable incremental output is available, making the chip suitable for replacement of various optical encoders. An internal voltage regulator allows the AS5040 to operate at either 3.3 V or 5 V supplies. Ordering Information and Content Guide appear at end of datasheet. Figure 1: Typical Arrangement of AS5040 and Magnet ams Datasheet [v2-11] 2015-Nov-20 Page 1 Document Feedback AS5040 − General Description Key Benefits & Features The benefits and features of AS5040, 10Bit 360º Programmable Magnetic Rotary Encoder are listed below: Figure 2: Added Value of Using AS5040 Benefits Features • Highest reliability and durability • Contactless high resolution rotational position encoding over a full turn of 360 degrees • Simple programming • Simple user-programmable resolution, pole pairs and zero position • Multiple interfaces • • • • • • Ideal for motor applications • Rational speeds up to 30,000 rpm • Failure diagnostics • Failure detection mode for magnet placement monitoring and loss of power supply • Easy setup • Serial read-out of multiple interconnected devices using daisy chain mode • Great flexibility at a huge application area • Push button functionality detects movement of magnet in Z-axis • Fully automotive qualified • AEC-Q100, grade 1 • Small form factor • SSOP 16 (5.3mm x 6.2mm) • Robust environmental tolerance • Wide temperature range: -40°C to 125°C Serial communication interface (SSI) 10-bit pulse width modulated (PWM) output Quadrature A/B and Index output signal Step/Direction and Index output signal 3-Phase commutation for brushless DC motors Applications AS5040 is ideal for: • Industrial applications: • Contactless rotary position sensing • Robotics • Brushless DC motor commutation • Power tools • Automotive applications: • Steering wheel position sensing • Gas pedal position sensing • Transmission gearbox encoder • Headlight position control • Power seat position indicator Page 2 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − General Description • Office equipment: printers, scanners, copiers • Replacement of optical encoders • Front panel rotary switches • Replacement of potentiometers Block Diagram The functional blocks of this device are shown below: Figure 3: AS5040 Block Diagram VDDV3V MagINCn VDD5V MagDECn LDO 3.3V PWM Interface PWM_LSB Ang DSP Hall Array & Frontend Amplifier Cos Mag Absolute Interface (SSI) DO CSn CLK OTP Register A_LSB_U Programming Parameters Incremental Interface B_Dir_V Index_W Prog ams Datasheet [v2-11] 2015-Nov-20 Page 3 Document Feedback AS5040 − Pin Assignment Pin Assignment Figure 4: Pin Configuration SSOP16 1 16 VDD5V MagDECn 2 15 VDD3V3 A_LSB_U 3 14 NC B_Dir_V 4 13 NC NC 5 12 PWM_LSB Index_W 6 11 CSn VSS 7 10 CLK Prog 8 9 DO AS5040 MagINCn Pin Description Figure 6 shows the description of each pin of the standard SSOP16 package (Shrink Small Outline Package, 16 leads, body size: 5.3mm x 6.2mmm; see Figure 4). Pins 7, 15 and 16 are supply pins, pins 5, 13 and 14 are for internal use and must not be connected. Pins 1 and 2 are the magnetic field change indicators, MagINCn and MagDECn (magnetic field strength increase or decrease through variation of the distance between the magnet and the device). These outputs can be used to detect the valid magnetic field range. Furthermore those indicators can also be used for contact-less push-button functionality. Pins 3, 4 and 6 are the incremental pulse output pins. The functionality of these pins can be configured through programming the one-time programmable (OTP) register. Figure 5: Pin Assignment for the Different Incremental Output Modes Output Mode Pin 3 Pin 4 Pin 6 Pin 12 1.x: quadrature A B Index PWM 2.x:step/direction LSB Direction Index PWM 3.x: commutation U V W LSB Page 4 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Pin Assignment Mode 1.x: Quadrature A/B Output Represents the default quadrature A/B signal mode. Mode 2.x: Step / Direction Output Configures pin 3 to deliver up to 512 pulses (up to 1024 state changes) per revolution. It is equivalent to the LSB (least significant bit) of the absolute position value. Pin 4 provides the information of the rotational direction. Both modes (mode 1.x and mode 2.x) provide an index signal (1 pulse/revolution) with an adjustable width of one LSB or three LSB’s. Mode 3.x: Brushless DC Motor Commutation Mode In addition to the absolute encoder output over the SSI interface, this mode provides commutation signals for brushless DC motors with either one pole pair or two pole pair rotors. The commutation signals are usually provided by 3 discrete Hall switches, which are no longer required, as the AS5040 can fulfill two tasks in parallel: absolute encoder + BLDC motor commutation. In this mode, pin 12 provides the LSB output instead of the PWM (Pulse-Width-Modulation) signal. Pin 8 (Prog) is also used to program the different incremental interface modes, the incremental resolution and the zero position into the OTP. This pin is also used as digital input to shift serial data through the device in Daisy Chain configuration. Pin 11 Chip Select (CSn; active low) selects a device within a network of AS5040 encoders and initiates serial data transfer. A logic high at CSn puts the data output pin (DO) to tri-state and terminates serial data transfer. This pin is also used for Alignment Mode and Programming the AS5040. Pin 12 allows a single wire output of the 10-bit absolute position value. The value is encoded into a pulse width modulated signal with 1μs pulse width per step (1μs to 1024μs over a full turn). By using an external low pass filter, the digital PWM signal is converted into an analog voltage, allowing a direct replacement of potentiometers. Figure 6: Pin Description SSOP16 Pin Symbol Type 1 MagINCn DO_OD Magnet Field Magnitude INCrease; active low, indicates a distance reduction between the magnet and the device surface. 2 MagDECn DO_OD Magnet Field Magnitude DECrease; active low, indicates a distance increase between the device and the magnet. ams Datasheet [v2-11] 2015-Nov-20 Description Page 5 Document Feedback AS5040 − Pin Assignment Pin Symbol Type Description 3 A_LSB_U DO Mode1.x: Quadrature A channel Mode2.x: Least Significant Bit Mode3.x: U signal (phase1) 4 B_Dir_V DO Mode1.x: Quadrature B channel quarter period shift to channel A. Mode2.x: Direction of Rotation Mode3.x: V signal (phase2) 5 NC - 6 Index_W DO 7 VSS S 8 Prog DI_PD OTP Programming Input and Data Input for Daisy Chain mode. Internal pull-down resistor (~74kΩ). May be connected to VSS if programming is not used 9 DO DO_T Data Output of Synchronous Serial Interface 10 CLK DI, ST Clock Input of Synchronous Serial Interface; Schmitt-Trigger input 11 CSn DI_PU, ST 12 PWM_LSB DO 13 NC - Must be left unconnected 14 NC - Must be left unconnected 15 VDD3V3 S 3V-Regulator Output (see Figure 39) 16 VDD5V S Positive Supply Voltage 5 V Must be left unconnected Mode1.x and Mode2.x: Index signal indicates the absolute zero position Mode3.x: W signal (phase3) Negative Supply Voltage (GND) Chip Select, active low; Schmitt-Trigger input, internal pull-up resistor (~50kΩ) connect to VSS in incremental mode (see 0) Pulse Width Modulation of approx. 1kHz; LSB in Mode3.x Abbreviations for Pin Types in Figure 6: Page 6 Document Feedback DO_OD : Digital output open drain DO : Digital output DI_PD : Digital input pull-down DI_PU : Digital input pull-up S : Supply pin DI : Digital input DO_T : Digital output /tri-state ST : Schmitt-Trigger input ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 7: Absolute Maximum Ratings Symbol Parameter Min Max Units VDD5V DC supply voltage at pin VDD5V -0.3 7 V VDD3V3 DC supply voltage at pin VDD3V3 -0.3 5 V -0.3 VDD5V +0.3 Vin Input pin voltage Iscr Input current (latchup immunity) ESD Electrostatic discharge Tstrg Storage temperature TBody Body temperature (Lead free package) RHNC Relative humidity (non condensing) MSL Moisture sensitivity level ams Datasheet [v2-11] 2015-Nov-20 V -0.3 7.5 -100 100 5 3 Pins MagINCn, MagDECn, CLK, CSn Pin Prog mA Norm: JEDEC 78 kV Norm: MIL 883 E method 3015 125 ºC Min – 67°F, Max 257°F 260 ºC t=20 to 40s, Norm: IPC/JEDEC J-Std-020C Lead finish 100% Sn “matte tin” 85 % ±2 -55 Note Maximum floor life time of 168h Page 7 Document Feedback AS5040 − Electrical Characteristics Electrical Characteristics Operating Conditions Figure 8: Operating Conditions Symbol Parameter Min Tamb Ambient temperature -40 Isupp Supply current Typ Max Unit 125 °C 16 21 mA Note -40°F to 257°F VDD5V VDD3V3 External supply voltage at pin VDD5V Internal regulator output voltage at pin VDD3V3 4.5 3.0 5.0 3.3 5.5 3.6 V V 5V operation VDD5V VDD3V3 External supply voltage at pin VDD5V, VDD3V3 3.0 3.0 3.3 3.3 3.6 3.6 V V 3.3V operation (pins VDD5V and VDD3V3 connected) DC Characteristics for Digital Inputs and Outputs CMOS Schmitt-Trigger Inputs: CLK, CSn (CSn = Internal Pull-Up) Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 9: CMOS Schmitt-Trigger Inputs: CLK, CSn (CSn = Internal Pull-Up) Symbol Parameter VIH High level input voltage VIL Low level input voltage VIon-VIoff ILEAK IiL Schmitt trigger hysteresis Input leakage current Pull-up low level input current Page 8 Document Feedback Min Max 0.7 * VDD5V V 0.3 * VDD5V 1 -1 Unit Note Normal operation V V 1 CLK only μA -30 -100 CSn only, VDD5V: 5.0V ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Electrical Characteristics CMOS / Program Input: Prog Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 10: CMOS / Program Input: Prog Symbol Parameter VIH High level input voltage VPROG High level input voltage VIL Low level input voltage IiL Pull-down high level input current Min Max Unit 0.7 * VDD5V 5 V See Programming Conditions V 0.3 * VDD5V V 100 μA Note During programming VDD5V: 5.5V CMOS Output Open Drain: MagINCn, MagDECn Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 11: CMOS Output Open Drain: MagINCn, MagDECn Symbol VOL Parameter Low level output voltage Min Max Unit VSS+0.4 V IO Output current 4 2 mA IOZ Open drain leakage current 1 μA ams Datasheet [v2-11] 2015-Nov-20 Note VDD5V: 4.5V VDD5V: 3V Page 9 Document Feedback AS5040 − Electrical Characteristics CMOS Output: A, B, Index, PWM Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 12: CMOS Output: A, B, Index, PWM Symbol Parameter VOH High level output voltage VOL Low level output voltage IO Min Max VDD5V-0.5 Output current Unit Note V VSS+0.4 V 4 2 mA VDD5V: 4.5V VDD5V: 3V Tristate CMOS Output: DO Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 13: Tristate CMOS Output: DO Symbol Parameter VOH High level output voltage VOL Low level output voltage Min Max VDD5V-0.5 Unit V VSS+0.4 V IO Output current 4 2 mA IOZ Tri-state leakage current 1 μA Page 10 Document Feedback Note VDD5V: 4.5V VDD5V: 3V ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Electrical Characteristics Magnetic Input Specification Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Two-pole cylindrical diametrically magnetized source: Figure 14: Magnetic Input Specification Symbol Parameter Min Typ 6 dmag Diameter 4 tmag Thickness 2.5 Bpk Magnetic input field amplitude Boff Magnetic offset Unit mm mm 45 Field non-linearity fmag_abs fmag_inc Max Input frequency (rotational speed of magnet) 75 mT ± 10 mT Constant magnetic stray field 5 % Including offset gradient 10 Hz Absolute mode: 600 rpm @ readout of 1024 positions (see Figure 36) 500 Hz Incremental mode: no missing pulses at rotational speeds of up to 30,000 rpm (see Figure 36) Displacement radius mm Recommended magnet material and temperature drift ams Datasheet [v2-11] 2015-Nov-20 ±0.23 5 Max. X-Y offset between defined IC package center and magnet axis (see Figure 41) Max. X-Y offset between chip center and magnet axis. 0.485 Chip placement tolerance Recommended magnet: Ø 6mm x 2.5mm for cylindrical magnets Required vertical component of the magnetic field strength on the die’s surface, measured along a concentric circle with a radius of 1.1mm 0.25 Disp Note mm -0.12 Placement tolerance of chip within IC package (see Figure 43) NdFeB (Neodymium Iron Boron) %/K -0.035 SmCo (Samarium Cobalt) Page 11 Document Feedback AS5040 − Electrical Characteristics Electrical System Specifications Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 15: Electrical System Specifications Symbol Parameter RES Resolution LSB 7 bit 8 bit 9 bit 10 bit INLopt INLtemp Typ DNL Differential non-linearity Unit 10 bit 0.352 deg deg Adjustable resolution only available for incremental output modes; Least significant bit, minimum step deg Maximum error with respect to the best line fit. Verified at optimum magnet placement, Tamb =25 °C. deg Maximum error with respect to the best line fit. Verified at optimum magnet placement, Tamb = -40°C to 125°C ± 1.4 deg Best line fit = (Errmax – Errmin) / 2 Over displacement tolerance with 6mm diameter magnet, Tamb = -40°C to 125°C ± 0.176 deg 10bit, no missing codes 0.12 Deg RMS RMS equivalent to 1 sigma deg Incremental modes only ± 0.5 Integral non-linearity (optimum) Integral non-linearity Max 2.813 1.406 0.703 0.352 Integral non-linearity (optimum) INL TN Min ± 0.9 Transition noise 0.704 Note Hyst Hysteresis Von Power-on-reset threshold ON voltage; 300mV typ. hysteresis 1.37 2.2 2.9 V DC supply voltage 3.3V (VDD3V3) Voff Power-on-reset threshold OFF voltage; 300mV typ. hysteresis 1.08 1.9 2.6 V DC supply voltage 3.3V (VDD3V3) tPwrUp Power-up time 50 ms Until offset compensation finished tdelay System propagation delay absolute output 48 μs Includes delay of ADC and DSP System propagation delay incremental output 192 μs Calculation over two samples Page 12 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Electrical Characteristics Symbol fS Parameter Min Typ Max 9.90 10.42 10.94 Sampling rate for absolute output Note Internal sampling rate, Tamb = 25°C kHz 9.38 CLK Unit 10.42 Internal sampling rate, Tamb = -40°C to 125°C 11.46 Read-out frequency 1 MHz Max. clock frequency to read out serial data Figure 16: Integral and Differential Non-Linearity Example (Exaggerated Curve) 1023 D 10bit code 1023 Actual curve 2 TN 1 0 512 Ideal curve DNL+1LSB INL 0.35° 512 0 0q q 360 q D [degrees] Integral Non-Linearity (INL) is the maximum deviation between actual position and indicated position. Differential Non-Linearity (DNL) is the maximum deviation of the step length from one position to the next. Transition Noise (TN) is the repeatability of an indicated position. ams Datasheet [v2-11] 2015-Nov-20 Page 13 Document Feedback AS5040 − Electrical Characteristics Timing Characteristics Synchronous Serial Interface (SSI) Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 17: Synchronous Serial Interface (SSI) Symbol t DO active Parameter Min Data output activated (logic high) Typ Max Unit Note 100 ns Time between falling edge of CSn and data output activated tCLK FE First data shifted to output register 500 ns Time between falling edge of CSn and first falling edge of CLK T CLK / 2 Start of data output 500 ns Rising edge of CLK shifts out one bit at a time t DO valid Data output valid 357 413 ns Time between rising edge of CLK and data output valid 100 ns After the last bit DO changes back to “tristate” ns CSn = high; To initiate read-out of next angular position MHz Clock frequency to read out serial data t DO tristate Data output tristate t CSn Pulse width of CSn 500 fCLK Read-out frequency >0 Page 14 Document Feedback 1 ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Electrical Characteristics Pulse Width Modulation Output Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 18: Pulse Width Modulation Output Symbol f PWM Parameter Min Typ Max 0.927 0.976 1.024 PWM frequency Unit Note Signal period = 1025μs ±5% at Tamb = 25°C KHz 0.878 0.976 1.074 =1025μs ±10% at Tamb = -40°C to 125°C PW MIN Minimum pulse width 0.90 1 1.10 μs Position 0d; angle 0 degree PW MAX Maximum pulse width 922 1024 1126 μs Position 1023d; angle 359.65 degree Incremental Outputs Operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 19: Incremental Outputs Symbol t Incremental outputs valid t Dir valid Parameter Max Unit Incremental outputs valid after power-up 500 ns Time between first falling edge of CSn after power-up and valid incremental outputs Directional indication valid 500 ns Time between rising or falling edge of LSB output and valid directional indication ams Datasheet [v2-11] 2015-Nov-20 Min Typ Note Page 15 Document Feedback AS5040 − Electrical Characteristics Programming Conditions (operating conditions: Tamb = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted). Figure 20: Programming Conditions Symbol Parameter Min Typ Max Unit Note Time between rising edge at Prog pin and rising edge of CSn Programming enable time 2 μs t Data in Write data start 2 μs t Data in valid Write data valid 250 ns t Load PROG Load programming data 3 μs t PrgR Rise time of VPROG before CLKPROG 0 μs t PrgH Hold time of VPROG after CLKPROG 0 t Prog enable CLK PROG t PROG t PROG finished Write data – programming CLKPROG CLK pulse width Hold time of Vprog after programming 1.8 2 Write data at the rising edge of CLKPROG 5 μs 250 kHz 2.2 μs During programming; 16 clock cycles μs Programmed data is available after next power-on 7.5 V Must be switched OFF after zapping 1 V Line must be discharged to this level 2 V PROG Programming voltage 7.3 V ProgOff Programming voltage OFF level 0 I PROG Programming current 130 mA During programming Analog read CLK 100 kHz Analog readback mode Programmed zener voltage (log.1) 100 mV VRef-VPROG during analog readback mode (see Analog Readback Mode) CLKAread Vprogrammed Vunprogrammed Unprogrammed zener voltage (log. 0) Page 16 Document Feedback 1 7.4 V ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Functional Description Functional Description The AS5040 is manufactured in a CMOS standard process and uses a spinning current Hall technology for sensing the magnetic field distribution across the surface of the chip. The integrated Hall elements are placed around the center of the device and deliver a voltage representation of the magnetic field at the surface of the IC. Through Sigma-Delta Analog / Digital Conversion and Digital Signal-Processing (DSP) algorithms, the AS5040 provides accurate high-resolution absolute angular position information. For this purpose a Coordinate Rotation Digital Computer (CORDIC) calculates the angle and the magnitude of the Hall array signals. The DSP is also used to provide digital information at the outputs MagINCn and MagDECn that indicate movements of the used magnet towards or away from the device’s surface. A small low cost diametrically magnetized (two-pole) standard magnet provides the angular position information (see Figure 40). The AS5040 senses the orientation of the magnetic field and calculates a 10-bit binary code. This code can be accessed via a Synchronous Serial Interface (SSI). In addition, an absolute angular representation is given by a Pulse Width Modulated signal at pin 12 (PWM). Besides the absolute angular position information the device simultaneously provides incremental output signals. The various incremental output modes can be selected by programming the OTP mode register bits (see Figure 36). As long as no programming voltage is applied to pin Prog, the new setting may be overwritten at any time and will be reset to default when power is turned OFF. To make the setting permanent, the OTP register must be programmed (see Figure 34). The default setting is a quadrature A/B mode including the Index signal with a pulse width of 1 LSB. The Index signal is logic high at the user programmable zero position. The AS5040 is tolerant to magnet misalignment and magnetic stray fields due to differential measurement technique and Hall sensor conditioning circuitry. ams Datasheet [v2-11] 2015-Nov-20 Page 17 Document Feedback AS5040 − 10-Bit Absolute Angular Position Output 10-Bit Absolute Angular Position Output Synchronous Serial Interface (SSI) Figure 21: Synchronous Serial Interface with Absolute Angular Position Data CSn t CLK FE T CLK / 2 t CSn 1 CLK DO D9 t DO active t DO valid 8 D8 D7 D6 D5 D4 D3 D2 1 16 D1 D0 Angular Position Data OCF COF LIN Mag INC Status Bits t CLK FE M ag Even D EC PAR D9 t DO Tristate If CSn changes to logic low, Data Out (DO) will change from high impedance (tri-state) to logic high and the read-out will be initiated. • After a minimum time tCLK FE, data is latched into the output shift register with the first falling edge of CLK. • Each subsequent rising CLK edge shifts out one bit of data. • The serial word contains 16 bits, the first 10 bits are the angular information D[9:0], the subsequent 6 bits contain system information, about the validity of data such as OCF, COF, LIN, Parity and Magnetic Field status (increase/decrease). • A subsequent measurement is initiated by a log. “high” pulse at CSn with a minimum duration of tCSn. Data Content D9:D0 absolute angular position data (MSB is clocked out first) OCF (Offset Compensation Finished), logic high indicates the finished Offset Compensation Algorithm. For fast startup, this bit may be polled by the external microcontroller. As soon as this bit is set, the AS5040 has completed the startup and the data is valid (see Figure 23) COF (CORDIC Overflow), logic high indicates an out of range error in the CORDIC part. When this bit is set, the data at D9:D0 is invalid. The absolute output maintains the last valid angular value. Page 18 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 This alarm may be resolved by bringing the magnet within the X-Y-Z tolerance limits. LIN (Linearity Alarm), logic high indicates that the input field generates a critical output linearity. When this bit is set, the data at D9:D0 may still be used, but can contain invalid data. This warning may be resolved by bringing the magnet within the X-Y-Z tolerance limits. MagINCn, (Magnitude Increase) becomes HIGH, when the magnet is pushed towards the IC, thus the magnetic field strength is increasing. MagDECn, (Magnitude Decrease) becomes HIGH, when the magnet is pulled away from the IC, thus the magnetic field strength is decreasing. Both signals HIGH indicate a magnetic field that is out of the allowed range (see Figure 22). Figure 22: Magnetic Magnitude Variation Indicator Mag INCn Mag DECn 0 0 No distance change; Magnetic input field OK (in range, 45mT to 75mT) 0 1 Distance increase: Pull-function. This state is dynamic, it is only active while the magnet is moving away from the chip in Z-axis 1 0 Distance decrease: Push- function. This state is dynamic, it is only active while the magnet is moving towards the chip in Z.-axis. 1 1 Magnetic Input Field invalid – out of range: 75mT (or missing magnet) Description Note(s) and/or Footnote(s): 1. Pins 1 and 2 (MagINCn, MagDECn) are open drain outputs and require external pull-up resistors. If the magnetic field is in range, both outputs are turned OFF. ams Datasheet [v2-11] 2015-Nov-20 Page 19 Document Feedback AS5040 − 10-Bit Absolute Angular Position Output The two pins may also be combined with a single pull-up resistor. In this case, the signal is high when the magnetic field is in range. It is low in all other cases (see Figure 22). Even Parity bit for transmission error detection of bits 1 to 15 (D9 to D0, OCF, COF, LIN, MagINCn, MagDECn). The absolute angular output is always set to a resolution of 10 bit. Placing the magnet above the chip, angular values increase in clockwise direction by default. Data D9:D0 is valid, when the status bits have the following configurations: Figure 23: Status Bit Outputs OCF 1 COF 0 LIN 0 Mag INCn Mag DECn 0 0 0 1 1 0 Parity Even checksum of bits 1:15 The absolute angular position is sampled at a rate of 10kHz (0.1ms). This allows reading of all 1024 positions per 360 degrees within 0.1 seconds = 9.76Hz (~10Hz) without skipping any position. Multiplying 10Hz by 60, results the corresponding maximum rotational speed of 600 rpm. Readout of every second angular position allows for rotational speeds of up to 1200rpm. Consequently, increasing the rotational speed reduces the number of absolute angular positions per revolution (see Figure 46). Regardless of the rotational speed or the number of positions to be read out, the absolute angular value is always given at the highest resolution of 10 bit. The incremental outputs are not affected by rotational speed restrictions due to the implemented interpolator. The incremental output signals may be used for high-speed applications with rotational speeds of up to 30,000 rpm without missing pulses. Page 20 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − 10-Bit Absolute Angular Position Output Daisy Chain Mode The Daisy Chain mode allows connection of several AS5040’s in series, while still keeping just one digital input for data transfer (see “Data IN” in Figure 24 below). This mode is accomplished by connecting the data output (DO; pin 9) to the data input (Prog; pin 8) of the subsequent device. An RC filter must be implemented between each PROG pin of device n and DO pin of device n+1, to prevent the encoders to enter the alignment mode, in case of ESD discharge, long cables, or not conform signal levels or shape. Using the values R=100R and C=1nF allow a max. CLK frequency of 1MHz on the whole chain. The serial data of all connected devices is read from the DO pin of the first device in the chain. The Prog pin of the last device in the chain should be connected to VSS. The length of the serial bit stream increases with every connected device, it is n * (16+1) bits: e.g. 34 bit for two devices, 51 bit for three devices, etc… The last data bit of the first device (Parity) is followed by a logic low bit and the first data bit of the second device (D9), etc… (see Figure 25). Programming Daisy Chained Devices In Daisy Chain mode, the Prog pin is connected directly to the DO pin of the subsequent device in the chain (see Figure 24). During programming (see Programming the AS5040), a programming voltage of 7.5V must be applied to pin Prog. This voltage level exceeds the limits for pin DO, so one of the following precautions must be made during programming: • Open the connection DO -> Prog during programming or • Add a Schottky diode between DO and Prog (Anode = DO, Cathode = Prog) ams Datasheet [v2-11] 2015-Nov-20 Page 21 Document Feedback AS5040 − 10-Bit Absolute Angular Position Output Due to the parallel connection of CLK and CSn, all connected devices may be programmed simultaneously. Figure 24: Daisy Chain Hardware Configuration CSn CSn CLK CLK CLK CLK PROG DO DI CSn CSn 100R DO 100R PROG PROG GND GND GND MCU DO 1nF 1nF AS5040 AS5040 AS5040 Figure 25: Daisy Chain Mode Data Transfer CSn tCLK FE TCLK/2 1 CLK DO D9 tDO active tDO valid 8 D8 D7 D6 D5 D4 D3 D2 16 D1 D0 OCF Angular Position Data LIN Mag INC Status Bits 1st Device Page 22 Document Feedback COF Mag DEC Even PAR D 1 D9 2 D8 3 D7 Angular Position Data 2nd Device ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Incremental Outputs Incremental Outputs Three different incremental output modes are possible with quadrature A/B being the default mode. Figure 26 shows the two-channel quadrature as well as the step/direction incremental signal (LSB) and the direction bit in clockwise (CW) and counter-clockwise (CCW) direction. Quadrature A/B Output (Quad A/B Mode) The phase shift between channel A and B indicates the direction of the magnet movement. Channel A leads channel B at a clockwise rotation of the magnet (top view) by 90 electrical degrees. Channel B leads channel A at a counter-clockwise rotation. LSB Output (Step/Direction Mode) Output LSB reflects the LSB (least significant bit) of the programmed incremental resolution (OTP Register Bit Div0, Div1). Output Dir provides information about the rotational direction of the magnet, which may be placed above or below the device (1=clockwise; 0=counter clockwise; top view). Dir is updated with every LSB change. In both modes (quad A/B, step/direction) the resolution and the index output are user programmable. The index pulse indicates the zero position and is by default one angular step (1LSB) wide. However, it can be set to three LSBs by programming the Index-bit of the OTP register accordingly (see Figure 36). Figure 26: Incremental Output Modes Q uad A/B-M ode M echanical Zero Position Rotation Direction Change M echanical Zero Position A B Index=0 1LSB H yst = 2 LSB Index Step / Dir-Mode Index=1 3 LSB LSB Dir CSn t t ams Datasheet [v2-11] 2015-Nov-20 Counterclockwise ccw Clockwise cw D ir valid Increm ental outputs valid Page 23 Document Feedback AS5040 − Incremental Outputs Incremental Power-Up Lock Option After power-up, the incremental outputs can optionally be locked or unlocked, depending on the status of the CSn pin: CSn = low at power-up: CSn has an internal pull-up resistor and must be externally pulled low (R ext ≤ 5kΩ). If Csn is low at power-up, the incremental outputs (A, B, Index) will be high until the internal offset compensation is finished. This unique state (A=B=Index = high) may be used as an indicator for the external controller to shorten the waiting time at power-up. Instead of waiting for the specified maximum power up-time (0), the controller can start requesting data from the AS5040 as soon as the state (A=B=Index = high) is cleared. CSn = high or open at power-up: In this mode, the incremental outputs (A, B, Index) will remain at logic high state, until CSn goes low or a low pulse is applied at CSn. This mode allows intentional disabling of the incremental outputs until for example the system microcontroller is ready to receive data. Page 24 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Incremental Outputs Incremental Output Hysteresis To avoid flickering incremental outputs at a stationary magnet position, a hysteresis is introduced. In case of a rotational direction change, the incremental outputs have a hysteresis of 2 LSB. Regardless of the programmed incremental resolution, the hysteresis of 2 LSB always corresponds to the highest resolution of 10 bit. In absolute terms, the hysteresis is set to 0.704 degrees for all resolutions. For constant rotational directions, every magnet position change is indicated at the incremental outputs (see Figure 27). If for example the magnet turns clockwise from position “x+3“ to “x+4“, the incremental output would also indicate this position accordingly. A change of the magnet’s rotational direction back to position “x+3“ means, that the incremental output still remains unchanged for the duration of 2 LSB, until position “x+2“ is reached. Following this direction, the incremental outputs will again be updated with every change of the magnet position. Figure 27: Hysteresis Window for Incremental Outputs         0.35° !             !    Clockwise Direction Counterclockwise Direction ams Datasheet [v2-11] 2015-Nov-20 Page 25 Document Feedback AS5040 − Pulse Width Modulation (PWM) Output The AS5040 provides a pulse width modulated output (PWM), whose duty cycle is proportional to the measured angle. Pulse Width Modulation (PWM) Output t on × 1025 Position = ------------------------- – 1 t on + t off (EQ1) The PWM frequency is internally trimmed to an accuracy of ±5% (±10% over full temperature range). This tolerance can be canceled by measuring the complete duty cycle as shown above. Figure 28: PWM Output Signal Angle PW MIN 0 deg (Pos 0) 1μs 1025μs PW MAX 359.65 deg (Pos 1023) 1024μs 1/fPWM Figure 29: PWM Signal Parameters Parameter Symbol Typ Unit PWM frequency fPWM 0.9756 kHz MIN pulse width PWMIN 1 μs • Position 0d • Angle 0 deg MAX pulse width PWMAX 1024 μs • Position 1023d • Angle 359,65 deg Page 26 Document Feedback Note Signal period: 1025μs ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Analog Output An analog output can be generated by averaging the PWM signal, using an external active or passive low pass filter. The analog output voltage is proportional to the angle: 0º= 0V; 360º = VDD5V. Analog Output Using this method, the AS5040 can be used as direct replacement of potentiometers. Figure 30: Simple Passive 2nd Order RC Low Pass Filter R2 R1 analog out Pin12 PWM VDD2 C1 C2 0V2 0° Pin7 360° VSS (EQ2) R1, R2 ≥ 4K7 C1, C2 ≥ 1μF/6V R1 should be ≥ 4k7 to avoid loading of the PWM output. Larger values of Rx and Cx will provide better filtering and less ripple, but will also slow down the response time. ams Datasheet [v2-11] 2015-Nov-20 Page 27 Document Feedback AS5040 − Brushless DC Motor Commutation Mode Brushless DC motors require angular information for stator commutation. The AS5040 provides U-V-W commutation signals for one and two pole pair motors. In addition to the three-phase output signals, the step (LSB) output at pin 12 allows high accuracy speed measurement. Two resolutions (9 or 10 bit) can be selected by programming Div0 according to Figure 36. Mode 3.0 (3.1) is used for brush-less DC motors with one-pole pair rotors. The three phases (U, V, W) are 120 degrees apart, each phase is 180 degrees ON and 180 degrees OFF. Mode 3.2 (3.3) is used for motors with two pole pairs requiring a higher pulse count to ensure a proper current commutation. In this case the pulse width is 256 positions, equal to 90 degrees. The precise physical angle at which the U, V and W signals change state (“Angle” in Figure 31 and Figure 32) is calculated by multiplying each transition position by the angular value of 1 count: Angle [deg] = Position x (360 degree / 1024) Brushless DC Motor Commutation Mode (EQ3) Figure 31: U, V and V-Signals for BLDC Motor Commutation (Div1=0, Div0=0) Commutation - Mode 3.0 (One-pole-pair) Width: 512 Steps Width: 512 Steps U V W CW Direction Position: Angle: 0 171 341 512 683 853 0 0.0 60.12 119.88 180.0 240.12 299.88 360.0 Figure 32: U, V and W-Signals for 2-Pole BLDC Motor Commutation (Div1=1; Div0=0) Commutation - Mode 3.2 Width: 256 Steps (Two-pole-pairs) Width: 256 Steps U V W CW Direction Position: Angle: Page 28 Document Feedback 0 85 171 256 341 427 512 597 683 768 853 939 0 0.0 29.88 60.12 90.0 119.88 150.12 180.0 209.88 240.12 270.00 299.88 330.12 360.0 ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Programming the AS5040 Programming the AS5040 After power-on, programming the AS5040 is enabled with the rising edge of CSn with Prog = high and CLK = low. 16 bit configuration data must be serially shifted into the OTP register via the Prog-pin. The first “CCW” bit is followed by the zero position data (MSB first) and the incremental mode setting as shown in Table 6. Data must be valid at the rising edge of CLK (see Figure 33). After writing data into the OTP register it can be permanently programmed by rising the Prog pin to the programming voltage V PROG. 16 CLK pulses (t PROG) must be applied to program the fuses (Figure 34). To exit the programming mode, the chip must be reset by a power-on-reset. The programmed data is available after the next power-up. Note(s): During the programming process, the transitions in the programming current may cause high voltage spikes generated by the inductance of the connection cable. To avoid these spikes and possible damage to the IC, the connection wires, especially the signals Prog and VSS must be kept as short as possible. The maximum wire length between the VPROG switching transistor and pin Prog (see Figure 35) should not exceed 50mm (2 inches). To suppress eventual voltage spikes, a 10nF ceramic capacitor should be connected close to pins Prog and VSS. This capacitor is only required for programming, it is not required for normal operation. The clock timing t clk must be selected at a proper rate to ensure that the signal Prog is stable at the rising edge of CLK (see Figure 33). Additionally, the programming supply voltage should be buffered with a 10μF capacitor mounted close to the switching transistor. This capacitor aids in providing peak currents during programming. The specified programming voltage at pin Prog is 7.3 – 7.5V (see section 0). To compensate for the voltage drop across the V PROG switching transistor, the applied programming voltage may be set slightly higher (7.5 - 8.0V, see Figure 35). OTP Register Contents: ams Datasheet [v2-11] 2015-Nov-20 CCW Counter Clockwise Bit • ccw=0 – angular value increases in clockwise direction • ccw=1 – angular value increases in counterclockwise direction Z [9:0] Programmable Zero / Index Position Indx Index Pulse Width Selection: 1LSB / 3LSB Div1, Div0 Divider Setting of Incremental Output Md1, Md0 Incremental Output Mode Selection Page 29 Document Feedback AS5040 − Programming the AS5040 OTP Default Setting The AS5040 can also be operated without programming. The default, un-programmed setting is shown in Figure 36 (Mode 0.0): CCW:0 = Clockwise operation Z9 to Z0: 00 = No programmed zero position Indx: 0 = Index bit width = 1LSB Div0,Div1: 00 = Incremental resolution = 10bit Md0, MD1: 00 = Incremental mode = quadrature Figure 33: Programming Access – Write Data (section of Figure 34) Figure 34: Complete Programming Sequence Write Data Programming Mode Power Off CSn Prog 7.5V VDD VProgOff 0V Data 1 16 CLKPROG tLoad PROG Page 30 Document Feedback tPrgH tPrgR tPROG tPROG finished ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Programming the AS5040 USB Figure 35: OTP Programming Connection of AS5040 (shown with AS5040 demoboard) ams Datasheet [v2-11] 2015-Nov-20 Page 31 Document Feedback AS5040 − Programming the AS5040 Incremental Mode Programming Three different incremental output modes are available. Mode: Md1=0 / Md0=1 sets the AS5040 in quadrature mode. Mode: Md1=1 / Md0=0 sets the AS5040 in step / direction mode (see Figure 5). In both modes, the incremental resolution may be reduced from 10 bit down to 9, 8 or 7 bit using the divider OTP bits Div1 and Div0. (see Figure 36 below). Mode: Md1=1 / Md0=1 sets the AS5040 in brushless DC motor commutation mode with an additional LSB incremental signal at pin 12 (PWM_LSB). To allow programming of all bits, the default factory setting is all bits = 0. This mode is equal to mode 1:0 (quadrature A/B, 1LSB index width, 256ppr). The absolute angular output value, by default, increases with clockwise rotation of the magnet (top view). Setting the CCW-bit (see Figure 33) allows reversing the indicated direction, e.g. when the magnet is placed underneath the IC: CCW = 0 – angular value increases clockwise; CCW = 1 – angular value increases counterclockwise. By default, the zero / index position pulse is one LSB wide. It can be increased to a three LSB wide pulse by setting the Index-bit of the OTP register. Further programming options (commutation modes) are available for brushless DC motor-control. Md1 = Md0 = 1 changes the incremental output pins 3, 4 and 6 to a 3-phase commutation signal. Div1 defines the number of pulses per revolution for either a two-pole (Div1=0) or four-pole (Div1=1) rotor. In addition, the LSB is available at pin 12 (the LSB signal replaces the PWM signal), which allows for high rotational speed measurement of up to 30,000 rpm. Page 32 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 A S 5 0 4 0 − Programming the AS5040 Figure 36: One Time Programmable (OTP) Register Options OTP-Mode-Register-Bit Pin # Mode Md1 Md0 Div1 Div0 Index Default (Mode0.0) 0 0 0(1) 0(1) 0(1) 1LSB quadAB-Mode1.0 0 1 0 0 0 1LSB quadAB-Mode1.1 0 1 0 0 1 3LSBs quadAB-Mode1.2 0 1 0 1 0 1LSB quadAB-Mode1.3 0 1 0 1 1 quadAB-Mode1.4 0 1 1 0 0 1LSB quadAB-Mode1.5 0 1 1 0 1 3LSBs quadAB-Mode1.6 0 1 1 1 0 1LSB quadAB-Mode1.7 0 1 1 1 1 3LSBs ams Datasheet [v2-11] 2015-Nov-20 3 A 4 B 6 3LSBs 12 PWM 10 bit Pulses per Revolution Incremental Resolution ppr bit 2x256 10 2x128 9 2x64 8 2x32 7 Page 33 Document Feedback A S 5 0 4 0 − Programming the AS5040 OTP-Mode-Register-Bit Pin # Mode Md1 Md0 Div1 Div0 Index 3 Step/Dir-Mode2.0 1 0 0 0 0 1LSB Step/Dir-Mode2.1 1 0 0 0 1 3LSBs Step/Dir -Mode2.2 1 0 0 1 0 1LSB Step/Dir -Mode2.3 1 0 0 1 1 3LSBs LSB 4 6 Dir Step/Dir -Mode2.4 1 0 1 0 0 1LSB Step/Dir -Mode2.5 1 0 1 0 1 3LSBs Step/Dir -Mode2.6 1 0 1 1 0 1LSB Step/Dir -Mode2.7 1 0 1 1 1 3LSBs CommutationMode3.0 1 1 0 0 0 1 1 0 1 0 CommutationMode3.2 1 1 1 0 0 CommutationMode3.3 1 1 1 0 ppr bit 512 10 256 9 128 8 64 7 PWM 10 bit V(120º) W(240º) LSB 3x1 9 10 U’ (0º, 180º) 1 Incremental Resolution 10 U(0º) CommutationMode3.1 12 Pulses per Revolution V’ (60º, 240º) W’ (120º, 300º) LSB 2x3 9 Note(s) and/or Footnote(s): 1. Div1, Div0 and Index cannot be programmed in Mode 0:0 Page 34 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Programming the AS5040 Zero Position Programming Zero position programming is an OTP option that simplifies assembly of a system, as the magnet does not need to be manually adjusted to the mechanical zero position. Once the assembly is completed, the mechanical and electrical zero positions can be matched by software. Any position within a full turn can be defined as the permanent new zero/index position. For zero position programming, the magnet is turned to the mechanical zero position (e.g. the “OFF”-position of a rotary switch) and the actual angular value is read. This value is written into the OTP register bits Z9:Z0 (see Figure 33) and programmed as described in Programming the AS5040. This new absolute zero position is also the new Index pulse position for incremental output modes. Note(s): The zero position value may also be modified before programming, e.g. to program an electrical zero position that is 180° (half turn) from the mechanical zero position, just add 512 to the value read at the mechanical zero position and program the new value into the OTP register. Repeated OTP Programming Although a single AS5040 OTP register bit can be programmed only once (from 0 to 1), it is possible to program other, unprogrammed bits in subsequent programming cycles. However, a bit that has already been programmed should not be programmed twice. Therefore it is recommended that bits that are already programmed are set to “0” during a programming cycle. Non-Permanent Programming It is also possible to re-configure the AS5040 in a non-permanent way by overwriting the OTP register. This procedure is essentially a “Write Data” sequence (see Figure 33) without a subsequent OTP programming cycle. The “Write Data” sequence may be applied at any time during normal operation. This configuration remains set while the power supply voltage is above the power-on reset level (see 0). See Application Note AN5000-20 for further information. Analog Readback Mode Non-volatile programming (OTP) uses on-chip zener diodes, which become permanently low resistive when subjected to a specified reverse current. The quality of the programming process depends on the amount of current that is applied during the programming process (up to 130mA). ams Datasheet [v2-11] 2015-Nov-20 Page 35 Document Feedback AS5040 − Programming the AS5040 This current must be provided by an external voltage source. If this voltage source cannot provide adequate power, the zener diodes may not be programmed properly. In order to verify the quality of the programmed bits, an analog level can be read for each zener diode, giving an indication whether this particular bit was properly programmed or not. To put the AS5040 in analog readback mode, a digital sequence must be applied to pins CSn, Prog and CLK as shown in Figure 37. The digital level for this pin depends on the supply configuration (3.3V or 5V; see 3.3V / 5V Operation). The second rising edge on CSn (OutpEN) changes pin Prog to a digital output and the log. high signal at pin Prog must be removed to avoid collision of outputs (grey area in Figure 37). The following falling slope of CSn changes pin Prog to an analog output, providing a reference voltage Vref, that must be saved as a reference for the calculation of the subsequent programmed and unprogrammed OTP bits. Following this step, each rising slope of CLK outputs one bit of data in the reverse order as during programming (see Figure 37): Md0-MD1-Div0,Div1-Indx-Z0…Z9, ccw) During analog readback, the capacitor at pin Prog (see Figure 35) should be removed to allow a fast readout rate. If the capacitor is not removed the analog voltage will take longer to stabilize due to the additional capacitance. The measured analog voltage for each bit must be subtracted from the previously measured Vref, and the resulting value gives an indication on the quality of the programmed bit: a reading of 1V indicates a properly unprogrammed bit. A reading between 100mV and 1V indicates a faulty bit, which may result in an undefined digital value, when the OTP is read at power-up. Following the 16th clock (after reading bit “ccw”), the chip must be reset by disconnecting the power supply. Figure 37: OTP Register Analog Read P ro g E N O u tp E N P o w e r-o n R e se t; tu rn o ff s u p p ly A n a lo g R e a d b a c k D a ta a t P ro g CSn V re f In te rn a l te s t b it d ig ita l P ro g V p ro g ra m m e d M d 0 M d 1 D iv 0 D iv1 V u n p ro g ra m m e d Z 5 Z6 Z7 Z8 Z9 ccw P ro g c h a n g e s to O u tp u t 1 CLK t L o a d P ro g Page 36 Document Feedback 16 C L K A re a d ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Alignment Mode Alignment Mode The alignment mode simplifies centering the magnet over the chip to gain maximum accuracy and XY-alignment tolerance. This electrical centering method allows a wider XY-alignment tolerance (0.485mm radius) than mechanical centering(0.25mm radius) as it eliminates the placement tolerance of the die within the IC package (+/- 0.235mm). Alignment mode can be enabled with the falling edge of CSn while Prog = logic high (Figure 38). The Data bits D9-D0 of the SSI change to a 10-bit displacement amplitude output. A high value indicates large X or Y displacement, but also higher absolute magnetic field strength. The magnet is properly aligned, when the difference between highest and lowest value over one full turn is at a minimum. Under normal conditions, a properly aligned magnet will result in a reading of less than 32 over a full turn.The MagINCn and MagDECn indicators will be = 1 when the alignment mode reading is < 32. At the same time, both hardware pins MagINCn (#1) and MagDECn (#2) will be pulled to VSS. A properly aligned magnet will therefore produce a MagINCn = MagDECn = 1 signal throughout a full 360° turn of the magnet. Stronger magnets or short gaps between magnet and IC may show values larger than 32. These magnets are still properly aligned as long as the difference between highest and lowest value over one full turn is at a minimum. The alignment mode can be reset to normal operation mode by a power-on-reset (disconnect / re-connect power supply). Figure 38: Enabling the Alignment Mode Prog CSn AlignMode enable Read-out via SSI 2μs 2μs min. min. ams Datasheet [v2-11] 2015-Nov-20 Page 37 Document Feedback AS5040 − 3.3V / 5V Operation The AS5040 operates either at 3.3V ±10% or at 5V ±10%. This is made possible by an internal 3.3V Low-Dropout (LDO) voltage regulator. The internal supply voltage is always taken from the output of the LDO, meaning that the internal blocks are always operating at 3.3V. 3.3V / 5V Operation For 3.3V operation, the LDO must be bypassed by connecting VDD3V3 with VDD5V (see Figure 39). For 5V operation, the 5V supply is connected to pin VDD5V, while VDD3V3 (LDO output) must be buffered by a 2.2...10μF capacitor, which is supposed to be placed close to the supply pin (see Figure 39). The VDD3V3 output is intended for internal use only It must not be loaded with an external load. The output voltage of the digital interface I/O’s corresponds to the voltage at pin VDD5V, as the I/O buffers are supplied from this pin (see Figure 39). Figure 39: Connections for 5V / 3.3V Supply Voltages 5V Operation 3.3V Operation 2.2...10μF VDD3V3 VDD3V3 100n VDD5V 100n LDO VDD5V Internal VDD LDO Internal VDD DO DO 4.5 - 5.5V I N T E R F A C E PWM_LSB 3.0 - 3.6V CLK CSn A_LSB_U B_Dir_V Index_W Prog VSS I N T E R F A C E PWM_LSB CLK CSn A_LSB_U B_Dir_V Index_W Prog VSS A buffer capacitor of 100nF is recommended in both cases close to pin VDD5V. Note that pin VDD3V3 must always be buffered by a capacitor. It must not be left floating, as this may cause an instable internal 3.3V supply voltage which may lead to larger than normal jitter of the measured angle. Page 38 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Choosing the Proper Magnet Typically the magnet should be 6mm in diameter and ≥2.5mm in height. Magnetic materials such as rare earth AlNiCo, SmCo5 or NdFeB are recommended. Choosing the Proper Magnet The magnet’s field strength perpendicular to the die surface should be verified using a gauss-meter. The magnetic field Bv at a given distance, along a concentric circle with a radius of 1.1mm (R1), should be in the range of ±45mT to ±75mT. (see Figure 40). Figure 40: Typical Magnet and Magnetic Field Distribution typ. 6mm diameter N S Magnet axis R1 Vertical field component Magnet axis Bv (45…75mT) Vertical field component 0 N 360 S R1 concentric circle; radius 1.1mm ams Datasheet [v2-11] 2015-Nov-20 Page 39 Document Feedback AS5040 − Choosing the Proper Magnet Physical Placement of the Magnet The best linearity can be achieved by placing the center of the magnet exactly over the defined center of the IC package as shown in Figure 41: Figure 41: Defined IC Center and Magnet Displacement Radius 3.9 mm 3.9 mm 1 2.433 mm Defined center Rd 2.433 mm Page 40 Document Feedback Area of recommended maximum magnet misalignment ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Choosing the Proper Magnet Magnet Placement The magnet’s center axis should be aligned within a displacement radius R d of 0.25mm from the defined center of the IC with reference to the edge of pin #1 (see Figure 41). This radius includes the placement tolerance of the chip within the SSOP-16 package (± 0.235mm). The displacement radius R d is 0.485mm with reference to the center of the chip (see Alignment Mode) The vertical distance should be chosen such that the magnetic field on the die surface is within the specified limits (see Figure 40). The typical distance “z” between the magnet and the package surface is 0.5mm to 1.8mm with the recommended magnet (6mm x 2.5mm). Larger gaps are possible, as long as the required magnetic field strength stays within the defined limits. A magnetic field outside the specified range may still produce usable results, but the out-of-range condition will be indicated by MagINCn (pin 1) and MagDECn (pin 2), see Figure 22. Figure 42: Vertical Placement of the Magnet N Die surface S Package surface z 0.576mm ± 0.1mm 1.282mm ± 0.15mm ams Datasheet [v2-11] 2015-Nov-20 Page 41 Document Feedback AS5040 − Simulation Modelling Simulation Modelling Figure 43: Arrangement of Hall Sensor Array on Chip (principle) With reference to Figure 43, a diametrically magnetized permanent magnet is placed above or below the surface of the AS5040. The chip uses an array of Hall sensors to sample the vertical vector of a magnetic field distributed across the device package surface. The area of magnetic sensitivity is a circular locus of 1.1mm radius with respect to the center of the die. The Hall sensors in the area of magnetic sensitivity are grouped and configured such that orthogonally related components of the magnetic fields are sampled differentially. The differential signal Y1-Y2 will give a sine vector of the magnetic field. The differential signal X1-X2 will give an orthogonally related cosine vector of the magnetic field. The angular displacement (θ) of the magnetic source with reference to the Hall sensor array may then be modelled by: (EQ4) ( Y1 – Y2 ) θ = arc tan -------------------------- ± 0.5° ( X1 – X2 ) The ±0.5° angular error assumes a magnet optimally aligned over the center of the die and is a result of gain mismatch errors of the AS5040. Placement tolerances of the die within the package are ±0.235mm in X and Y direction, using a reference point of the edge of pin #1 (Figure 43). Page 42 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Simulation Modelling In order to neglect the influence of external disturbing magnetic fields, a robust differential sampling and ratiometric calculation algorithm has been implemented. The differential sampling of the sine and cosine vectors removes any common mode error due to DC components introduced by the magnetic source itself or external disturbing magnetic fields. A ratiometric division of the sine and cosine vectors removes the need for an accurate absolute magnitude of the magnetic field and thus accurate Z-axis alignment of the magnetic source. The recommended differential input range of the magnetic field strength (B (X1-X2) ,B(Y1-Y2) ) is ±75mT at the surface of the die. In addition to this range, an additional offset of ±5mT, caused by unwanted external stray fields is allowed. The chip will continue to operate, but with degraded output linearity, if the signal field strength is outside the recommended range. Too strong magnetic fields will introduce errors due to saturation effects in the internal preamplifiers. Too weak magnetic fields will introduce errors due to noise becoming more dominant. ams Datasheet [v2-11] 2015-Nov-20 Page 43 Document Feedback AS5040 − Failure Diagnostics Failure Diagnostics The AS5040 also offers several diagnostic and failure detection features: Magnetic Field Strength Diagnosis By software: the MagINCn and MagDECn status bits will both be high when the magnetic field is out of range. By hardware: Pins #1 (MagINCn) and #2 (MagDECn) are open-drain outputs and will both be turned ON (= low with external pull-up resistor) when the magnetic field is out of range. If only one of the outputs is low, the magnet is either moving towards the chip (MagINCn) or away from the chip (MagDECn). Power Supply Failure Detection By software: If the power supply to the AS5040 is interrupted, the digital data read by the SSI will be all “0”s. Data is only valid, when bit OCF is high, hence a data stream with all “0”s is invalid. To ensure adequate low levels in the failure case, a pull-down resistor (~10kΩ) should be added between pin DO and VSS at the receiving side. By hardware: The MagINCn and MagDECn pins are open drain outputs and require external pull-up resistors. In normal operation, these pins are high ohmic and the outputs are high (see Figure 22). In a failure case, either when the magnetic field is out of range or the power supply is missing, these outputs will become low. To ensure adequate low levels in case of a broken power supply to the AS5040, the pull-up resistors (>10kΩ) from each pin must be connected to the positive supply at pin 16 (VDD5V). By hardware: PWM output: The PWM output is a constant stream of pulses with 1kHz repetition frequency. In case of power loss, these pulses are missing. By hardware: Incremental outputs: In normal operation, pins A(#3), B(#4) and Index (#6) will never be high at the same time, as Index is only high when A=B=low. However, after a power-on-reset, if VDD is powered up or restarts after a power supply interruption, all three outputs will remain in high state until pin CSn is pulled low. If CSn is already tied to VSS during power-up, the incremental outputs will all be high until the internal offset compensation is finished (within t PwrUp). Page 44 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Angular Output Tolerances Angular Output Tolerances Accuracy Accuracy is defined as the error between measured angle and actual angle. It is influenced by several factors: • The non-linearity of the analog-digital converters, • Internal gain and mismatch errors, • Non-linearity due to misalignment of the magnet As a sum of all these errors, the accuracy with centered magnet = (Err max – Err min)/2 is specified as better than ±0.5 degrees @ 25°C (see Figure 45). Misalignment of the magnet further reduces the accuracy. Figure 44 shows an example of a 3D-graph displaying nonlinearity over XY-misalignment. The center of the square XY-area corresponds to a centered magnet (see dot in the center of the graph). The X- and Y- axis extends to a misalignment of ±1mm in both directions. The total misalignment area of the graph covers a square of 2x2 mm (79x79mil) with a step size of 100μm. For each misalignment step, the measurement as shown in Figure 45 is repeated and the accuracy (Errmax – Err min )/2 (e.g. 0.25° in Figure 45) is entered as the Z-axis in the 3D-graph. Figure 44: Example of Linearity Error Over XY Misalignment ams Datasheet [v2-11] 2015-Nov-20 Page 45 Document Feedback AS5040 − Angular Output Tolerances The maximum non-linearity error on this example is better than ±1 degree (inner circle) over a misalignment radius of ~0.7mm. For volume production, the placement tolerance of the IC within the package (±0.235mm) must also be taken into account. The total nonlinearity error over process tolerances, temperature and a misalignment circle radius of 0.25mm is specified better than ±1.4 degrees. The magnet used for this measurement was a cylindrical NdFeB (Bomatec® BMN-35H) magnet with 6mm diameter and 2.5mm in height. Figure 45: Example of Linearity Error Over 360º Linearity error with centered magnet [degrees] 0.5 0.4 0.3 0.2 transition noise 0.1 Err max 0 -0.1 1 -0.2 55 109 163 217 271 325 379 433 487 541 595 649 703 757 811 865 919 973 Err min -0.3 -0.4 -0.5 Transition Noise Transition noise is defined as the jitter in the transition between two steps. Due to the nature of the measurement principle (Hall sensors + Preamplifier + ADC), there is always a certain degree of noise involved. This transition noise voltage results in an angular transition noise at the outputs. It is specified as 0.12 degrees rms (1 sigma) 1 This is the repeatability of an indicated angle at a given mechanical position. 1. Statistically, 1 sigma represents 68.27% of readings, 3 sigma represents 99.73% of readings. Page 46 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Angular Output Tolerances The transition noise has different implications on the type of output that is used: • Absolute Output; SSI Interface: The transition noise of the absolute output can be reduced by the user by applying an averaging of readings. • PWM Interface: If the PWM interface is used as an analog output by adding a low pass filter, the transition noise can be reduced by lowering the cutoff frequency of the filter. If the PWM interface is used as a digital interface with a counter at the receiving side, the transition noise may again be reduced by averaging of readings. • Incremental Mode: In incremental mode, the transition noise influences the period, width and phase shift of the output signals A, B and Index. However, the algorithm used to generate the incremental outputs guarantees no missing or additional pulses even at high speeds (up to 30.000 rpm and higher). High Speed Operation Sampling Rate The AS5040 samples the angular value at a rate of 10.42k samples per second. Consequently, the incremental, as well as the absolute outputs are updated each 96μs. At a stationary position of the magnet, this sampling rate creates no additional error. Absolute Mode with Serial Communication With the given sampling rate of 10.4 kHz, the number of samples (n) per turn for a magnet rotating at high speed can be calculated by: (EQ5) 60 n = --------------------------rpm ⋅ 96μs In practice, there is no upper speed limit. The only restriction is that there will be fewer samples per revolution as the speed increases. Regardless of the rotational speed, the absolute angular value is always sampled at the highest resolution of 10 bit. Likewise, for a given number of samples per revolution (n), the maximum speed can be calculated by: (EQ6) 60 rpm = -------------------n ⋅ 96μs In absolute mode with serial communication, 610 rpm is the maximum speed, where 1024 readings per revolution can be obtained. In incremental mode, the maximum error caused by the sampling rate of the ADCs is 0/+96μs. It has a peak of 1LSB = 0.35° at 610 rpm. At higher speeds this error is reduced again due to interpolation and the output delay remains at 192μs as the DSP requires two sampling periods (2x96μs) to synthesize and redistribute any missing pulses. ams Datasheet [v2-11] 2015-Nov-20 Page 47 Document Feedback AS5040 − Angular Output Tolerances Absolute Mode with PWM The principle is the same as with the serial communication. The PWM output is refreshed with a rate of 1.025ms, the number of samples (n) per turn for a magnet rotating at high speed can be calculated by: (EQ7) 60 n = ------------------------------------rpm × 1.025ms In absolute mode with PWM output, 57 rpm is the maximum speed, where 1024 readings per revolution can be obtained. Incremental Mode Incremental encoders are usually required to produce no missing pulses up to several thousand rpm’s. Therefore, the AS5040 has a built-in interpolator, which ensures that there are no missing pulses at the incremental outputs for rotational speeds of up to 30,000 rpm, even at the highest resolution of 10 bits (512 pulses per revolution). Figure 46: Speed Performance Absolute Output Mode Incremental Output Mode 610rpm = 1024 samples / turn 1220rpm = 512 samples / turn 2441rpm = 256 samples / turn No missing pulses @ 10 bit resolution (512ppr): max. speed = 30,000 rpm etc… Propagation Delays The propagation delay is the delay between the time that the sample is taken until it is converted and available as angular data. This delay is 48μs for the absolute interface and 192μs for the incremental interface. Using the SSI interface for absolute data transmission, an additional delay must be considered, caused by the asynchronous sampling (t = 0...1/fs) and the time it takes the external control unit to read and process the data. Page 48 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Angular Output Tolerances Angular Error Caused by Propagation Delay A rotating magnet will therefore cause an angular error caused by the output delay. This error increases linearly with speed: (EQ8) e sampling = rpm × 6 × prop⋅delay Where: e sampling = angular error [º] rpm = rotating speed [rpm] prop delay = propagation delay [seconds] Note(s): Since the propagation delay is known, it can be automatically compensated by the control unit processing the data from the AS5040, thus reducing the angular error caused by speed. Internal Timing Tolerance The AS5040 does not require an external ceramic resonator or quartz. All internal clock timings for the AS5040 are generated by an on-chip RC oscillator. This oscillator is factory trimmed to ±5% accuracy at room temperature (±10% over full temperature range). This tolerance influences the ADC sampling rate and the pulse width of the PWM output: • Absolute Output; SSI Interface: A new angular value is updated every 100μs (typ) • Incremental outputs: the incremental outputs are updated every 100μs (typ.) • PWM output: A new angular value is updated every 100μs (typ.). The PWM pulse timings Ton and T off also have the same tolerance as the internal oscillator. If only the PWM pulse width T on is used to measure the angle, the resulting value also has this timing tolerance. However, this tolerance can be canceled by measuring both T on and Toff and calculating the angle from the duty cycle (see Incremental Outputs): (EQ9) ams Datasheet [v2-11] 2015-Nov-20 t on ⋅ 1025 Position = -------------------------- – 1 ( t on + t off ) Page 49 Document Feedback AS5040 − Angular Output Tolerances Temperature Magnetic Temperature Coefficient One of the major benefits of the AS5040 compared to linear Hall sensors is that it is much less sensitive to temperature. While linear Hall sensors require a compensation of the magnet’s temperature coefficients, the AS5040 automatically compensates for the varying magnetic field strength over temperature. The magnet’s temperature drift does not need to be considered, as the AS5040 operates with magnetic field strengths from ±45mT to ±75mT. Example: A NdFeB magnet has a field strength of 75mT @ -40ºC and a temperature coefficient of -0.12% per Kelvin. The temperature change is from -40º to +125º = 165K. The magnetic field change is: 165 x -0.12% = -19.8%, which corresponds to 75mT at -40ºC and 60mT at 125ºC. The AS5040 can compensate for this temperature related field strength change automatically, no user adjustment is required. Accuracy Over Temperature The influence of temperature in the absolute accuracy is very low. While the accuracy is ≤ ±0.5º at room temperature, it may increase to ≤ ±0.9º due to increasing noise at high temperatures. Timing Tolerance Over Temperature The internal RC oscillator is factory trimmed to ±5%. Over temperature, this tolerance may increase to ±10%. Generally, the timing tolerance has no influence in the accuracy or resolution of the system, as it is used mainly for internal clock generation. The only concern to the user is the width of the PWM output pulse, which relates directly to the timing tolerance of the internal oscillator. This influence, however, can be canceled by measuring the complete PWM duty cycle (see Internal Timing Tolerance). Page 50 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Mechanical Data Mechanical Data The internal Hall elements are located in the center of the package on a circle with a radius of 1 mm. Figure 47: Hall Element Positions Note(s) and/or Footnote(s): 1. All dimensions in mm. 2. Die thickness 381μm nom. 3. Adhesive thickness 30 ± 15μm. 4. Leadframe downset 200 ± 38μm. 5. Leadframe thickness 152±8 μm. ams Datasheet [v2-11] 2015-Nov-20 Page 51 Document Feedback AS5040 − Package Drawings & Mark ings Package Drawings & Markings Figure 48: 16-Lead Shrink Small Outline Package SSOP-16 Symbol Min Typ Max A A1 A2 b c D E E1 e L L1 L2 R Θ N 1.73 0.05 1.68 0.25 0.09 6.07 7.65 5.2 1.86 0.13 1.73 0.315 6.20 7.8 5.3 0.65 0.75 1.25 REF 0.25 BSC 4º 16 1.99 0.21 1.78 0.38 0.20 6.33 7.9 5.38 0.63 0.09 0º 0.95 RoHS Green 8º Note(s) and/or Footnote(s): 1. Dimensioning and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles in degrees. 3. N is the total number of terminals. Page 52 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Package Drawings & Markings Figure 49: Package Marking Figure 50: Packaging Code YY Last two digits of the manufacturing year WW M Manufacturing week Plant identifier ZZ @ Free choice/ traceability code Sublot identifier JEDEC Package Outline Standard: MO - 150 AC Thermal Resistance R th(j-a) : typ. 151 K/W in still air, soldered on PCB IC's marked with a white dot or the letters "ES" denote Engineering Samples ams Datasheet [v2-11] 2015-Nov-20 Page 53 Document Feedback AS5040 − Recommended PCB Footprint Recommended PCB Footprint Figure 51: Recommended PCB Footprint Figure 52: Recommended Footprint Data Recommended Footprint Data Page 54 Document Feedback mm inch A 9.02 0.355 B 6.16 0.242 C 0.46 0.018 D 0.65 0.025 E 5.01 0.197 ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Ordering & Contact Information Ordering & Contact Information Figure 53: Ordering Information Ordering Code Package Marking Delivery Form Delivery Quantity AS5040-ASSU SSOP-16 AS5040 Tubes (1) 7700 pcs AS5040-ASST SSOP-16 AS5040 Tape & Reel 2000 pcs/reel Note(s) and/or Footnote(s): 1. 1 tube = 77 devices Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams Tobelbaderstrasse 30 8141 Unterpremstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v2-11] 2015-Nov-20 Page 55 Document Feedback AS5040 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 56 Document Feedback ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v2-11] 2015-Nov-20 Page 57 Document Feedback AS5040 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 58 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Revision Information Revision Information Changes from 2.10 to current revision 2-11 (2015-Nov-20) Page Content of austriamicrosystems datasheet was converted to latest ams design Added benefits to the Key Features 2 Added Mechanical Data section 51 Updated Package Drawings & Markings section 52 Updated Figure 53 55 Note(s) and/or Footnote(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision ams Datasheet [v2-11] 2015-Nov-20 Page 59 Document Feedback AS5040 − Content Guide Content Guide Page 60 Document Feedback 1 2 2 3 General Description Key Benefits & Features Applications Block Diagram 4 4 5 5 5 Pin Assignment Pin Description Mode 1.x: Quadrature A/B Output Mode 2.x: Step / Direction Output Mode 3.x: Brushless DC Motor Commutation Mode 7 Absolute Maximum Ratings 8 8 8 8 9 9 10 10 11 12 14 14 15 15 16 Electrical Characteristics Operating Conditions DC Characteristics for Digital Inputs and Outputs CMOS Schmitt-Trigger Inputs: CLK, CSn (CSn = Internal Pull-Up) CMOS / Program Input: Prog CMOS Output Open Drain: MagINCn, MagDECn CMOS Output: A, B, Index, PWM Tristate CMOS Output: DO Magnetic Input Specification Electrical System Specifications Timing Characteristics Synchronous Serial Interface (SSI) Pulse Width Modulation Output Incremental Outputs Programming Conditions 17 Functional Description 18 18 18 21 21 10-Bit Absolute Angular Position Output Synchronous Serial Interface (SSI) Data Content Daisy Chain Mode Programming Daisy Chained Devices 23 23 23 24 25 Incremental Outputs Quadrature A/B Output (Quad A/B Mode) LSB Output (Step/Direction Mode) Incremental Power-Up Lock Option Incremental Output Hysteresis 26 27 28 Pulse Width Modulation (PWM) Output Analog Output Brushless DC Motor Commutation Mode ams Datasheet [v2-11] 2015-Nov-20 AS5040 − Content Guide ams Datasheet [v2-11] 2015-Nov-20 29 30 32 35 35 35 35 Programming the AS5040 OTP Default Setting Incremental Mode Programming Zero Position Programming Repeated OTP Programming Non-Permanent Programming Analog Readback Mode 37 38 Alignment Mode 3.3V / 5V Operation 39 40 41 Choosing the Proper Magnet Physical Placement of the Magnet Magnet Placement 42 Simulation Modelling 44 44 44 Failure Diagnostics Magnetic Field Strength Diagnosis Power Supply Failure Detection 45 45 46 47 47 47 48 48 48 49 49 50 50 50 50 Angular Output Tolerances Accuracy Transition Noise High Speed Operation Sampling Rate. Absolute Mode with Serial Communication Absolute Mode with PWM Incremental Mode Propagation Delays Angular Error Caused by Propagation Delay Internal Timing Tolerance Temperature Magnetic Temperature Coefficient Accuracy Over Temperature Timing Tolerance Over Temperature 51 52 54 55 56 57 58 59 Mechanical Data Package Drawings & Markings Recommended PCB Footprint Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Page 61 Document Feedback
AS5040-ASST 价格&库存
很抱歉,暂时无法提供与“AS5040-ASST”相匹配的价格&库存,您可以联系我们找货
