TSL25711FN
TSL25711FN
    AMSOSRAM(艾迈斯半导体)
    WDFN6
    光学传感器 环境 625nm I²C 6-WDFN
TSL25711FN 数据手册
Product Document Published by ams OSRAM Group TSL2571 Light-to-Digital Converter General Description The TSL2571 family of devices provides ambient light sensing (ALS) that approximates human eye response to light intensity under a variety of lighting conditions and through a variety of attenuation materials. While useful for general purpose light sensing, the device is particularly useful for display management with the purpose of extending battery life and providing optimum viewing in diverse lighting conditions. Display panel and keyboard backlighting can account for up to 30 to 40 percent of total platform power. The ALS features are ideal for use in notebook PCs, LCD monitors, flat-panel televisions, and cell phones. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of TSL2571, Light-to-Digital Converter are listed below: Figure 1: Added Value Of Using TSL2571 Benefits Features • Enables Operation in IR Light Environments • Patented Dual-Diode Architecture • Enables Dark Room to High Lux Sunlight Operation • 1M:1 Dynamic Range • Digital Interface is Less Susceptible to Noise • I2C Digital Interface • Enables Low Standby Power Consumption • 2.5μA Quiescent Current (Sleep Mode) • Reduces Board Space Requirements while Simplifying Designs • Available in 2mm x 2mm Dual Flat No-Lead (FN) Packages • Ambient Light Sensing (ALS) • Approximates Human Eye Response • Programmable Analog Gain • Programmable Integration Time • Programmable Interrupt Function with Upper and Lower Threshold • Resolution Up to 16 Bits • Very High Sensitivity — Operates Well Behind Darkened Glass • Up to 1,000,000:1 Dynamic Range ams Datasheet [v1-01] 2018-Mar-27 Page 1 Document Feedback TSL2571 − General Description • Programmable Wait Timer • Programmable from 2.72 ms to > 8 Seconds • Wait State — 65μA Typical Current • I²C Interface Compatible • Up to 400 kHz (I²C Fast Mode) • Dedicated Interrupt Pin • Small 2 mm x 2 mm ODFN Package • Sleep Mode — 2.5μA Typical Current Applications TSL2571, Light-to-Digital Converter is ideal for: • Display Management • Backlight Control • Portable Device Power Optimization • Cell Phones, PDA, GPS • Notebooks and Monitors • LCD TVs Functional Block Diagram The functional blocks of this device are shown below: Figure 2: TSL2571 Block Diagram Interrupt GND INT Wait Control V DD CH0 Data ALS Control CH0 CH1 ADC CH1 Data Lower Limit I 2 C Interface Upper Limit CH0 ADC SCL SDA CH1 Page 2 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Pin Assignments Pin Assignments Figure 3: Package FN Dual Flat No-Lead (Top View) VDD 1 6 SDA SCL 2 5 INT GND 3 4 NC Figure 4: Terminal Functions Terminal Type Description Name No VDD 1 SCL 2 GND 3 Power supply ground. All voltages are referenced to GND. NC 4 Do not connect. INT 5 O Interrupt — open drain (active low). SDA 6 I/O I²C serial data I/O terminal — serial data I/O for I²C . ams Datasheet [v1-01] 2018-Mar-27 Supply voltage. I I²C serial clock input terminal — clock signal for I²C serial data. Page 3 Document Feedback TSL2571 − Detailed Description Detailed Description The TSL2571 light-to-digital device includes on-chip photodiodes, integrating amplifiers, ADCs, accumulators, clocks, buffers, comparators, a state machine, and an I²C interface. The device combines one photodiode (CH0), which is responsive to both visible and infrared light, and one photodiode (CH1), which is responsive primarily to infrared light. Two integrating ADCs simultaneously convert the amplified photodiode currents into a digital value providing up to 16 bits of resolution. Upon completion of the conversion cycle, the conversion result is transferred to the data registers. This digital output can be read by a microprocessor through which the illuminance (ambient light level) in lux is derived using an empirical formula to approximate the human eye response. Communication to the device is accomplished through a fast (up to 400 kHz), two-wire I²C serial bus for easy connection to a microcontroller or embedded controller. The digital output of the device is inherently more immune to noise when compared to an analog interface. The device provides a separate pin for level-style interrupts. When interrupts are enabled and a pre-set value is exceeded, the interrupt pin is asserted and remains asserted until cleared by the controlling firmware. The interrupt feature simplifies and improves system efficiency by eliminating the need to poll a sensor for a light intensity value. An interrupt is generated when the value of an ALS conversion exceeds either an upper or lower threshold. In addition, a programmable interrupt persistence feature allows the user to determine how many consecutive exceeded thresholds are necessary to trigger an interrupt. Interrupt thresholds and persistence settings are configured independently. Page 4 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Over Operating Free-Air Temperature Range (unless otherwise noted) Symbol VDD(1) Parameter Min Max Units 3.8 V -0.5 3.8 V Supply voltage VO Digital output voltage range IO Digital Output current -1 +20 mA Storage temperature range -40 85 °C TSTRG ESDHBM ESD tolerance, human body model ±2000 V Note(s): 1. All voltages are with respect to GND. ams Datasheet [v1-01] 2018-Mar-27 Page 5 Document Feedback TSL2571 − Electrical Characteristics Electrical Characteristics Figure 6: Recommended Operating Conditions Symbol VDD TA Parameter Min Typ Max Units Supply voltage 2.6 3 3.6 V Operating free-air temperature -30 70 °C Figure 7: Operating Characteristics; VDD = 3V, TA = 25°C (unless otherwise noted) Symbol Parameter IDD VOL ILEAK VIH VIL Supply current Test Conditions Min Typ Max Active 175 250 Wait mode 65 Sleep mode — no I²C activity 2.5 μA 4 3 mA sink current 0 0.4 6 mA sink current 0 0.6 −5 5 INT SDA output low voltage V Leakage current, SDA, SCL, INT pins TSL25711, TSL25715 0.7 VDD TSL25713 1.25 μA V SCL SDA input high voltage TSL25711, TSL25715 0.3 VDD TSL25713 0.54 SCL SDA input low voltage Page 6 Document Feedback Unit V ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Electrical Characteristics Figure 8: ALS Characteristics; VDD = 3V, TA = 25°C, Gain = 16, AEN = 1 (unless otherwise noted)(1) (2) (3) Parameter Dark ADC count value ADC integration time step size Test Conditions Channel Ee = 0, AGAIN = 120× ATIME = 0xDB (100 ms) Min Typ Max Unit CH0 0 1 5 CH1 0 1 5 2.58 2.72 2.9 ms 1 256 steps counts ATIME = 0xFF ADC Number of integration steps ADC counts per step ATIME = 0xFF 0 1024 counts ADC count value ATIME = 0xC0 0 65535 counts λp = 625 nm, Ee = 171.6 CH0 μW/cm2 ADC count value ADC count value ratio: CH1/CH0 ATIME = 0xF6 (27 ms) (2) CH1 λp = 850 nm, Ee = 219.7 CH0 μW/cm2 ATIME = 0xF6 (27 ms) (3) CH1 Gain scaling, relative to 1× gain setting 5000 6000 790 counts λp = 625 ATIME 0xF6 (27 ms) (2) 4000 5000 6000 2800 10.8 15.8 20.8 % λp = 850 ATIME 0xF6 (27 ms) (3) 41 56 CH0 29.1 CH1 4.6 λp = 850 nm, ATIME = 0xF6 CH0 22.8 (27 ms) (3) CH1 12.7 λp = 625 nm, ATIME = 0xF6 Re Irradiance responsivity 4000 (27 ms) (2) 68 counts/ (μW/ cm2) 8× −10 10 16× −10 10 120× −10 10 % Note(s): 1. Optical measurements are made using small-angle incident radiation from light-emitting diode optical sources. Visible 625 nm LEDs and infrared 850 nm LEDs are used for final product testing for compatibility with high-volume production. 2. The 625 nm irradiance Ee is supplied by an AlInGaP light-emitting diode with the following typical characteristics: peak wavelength λp = 625 nm and spectral halfwidth Δλ½ = 20 nm. 3. The 850 nm irradiance Ee is supplied by a GaAs light-emitting diode with the following typical characteristics: peak wavelength λp = 850 nm and spectral halfwidth Δλ½ = 42 nm. ams Datasheet [v1-01] 2018-Mar-27 Page 7 Document Feedback TSL2571 − Electrical Characteristics Figure 9: Wait Characteristics; VDD = 3V, TA = 25°C, WEN = 1 (unless otherwise noted) Parameter Wait step size Test Conditions Channel WTIME = 0xFF Wait number of integration steps Min Typ Max Unit 2.58 2.72 2.9 ms 256 steps Max Unit 400 kHz 1 Figure 10: AC Electrical Characteristics; VDD = 3V, TA = 25°C, (unless otherwise noted) Parameter(1) Symbol Test Conditions Min Typ f(SCL) Clock frequency (I²C only) t(BUF) Bus free time between start and stop condition 1.3 μs t(HDSTA) Hold time after (repeated) start condition. After this period, the first clock is generated. 0.6 μs t(SUSTA) Repeated start condition setup time 0.6 μs t(SUSTO) Stop condition setup time 0.6 μs t(HDDAT) Data hold time 0 μs t(SUDAT) Data setup time 100 ns t(LOW) SCL clock low period 1.3 μs t(HIGH) SCL clock high period 0.6 μs tF Clock/data fall time 300 ns tR Clock/data rise time 300 ns Ci Input pin capacitance 10 pF 0 Note(s): 1. Specified by design and characterization; not production tested. Page 8 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Electrical Characteristics Figure 11: Timing Diagrams - Parameter Measurement Information t(LOW) t(R) t(F) VIH SCL VIL t(HDSTA) t(BUF) t(HIGH) t(HDDAT) t(SUSTA) t(SUSTO) t(SUDAT) VIH SDA VIL P Stop Condition S S Start Condition Start P Stop t(LOWSEXT) SCLACK SCLACK t(LOWMEXT) t(LOWMEXT) t(LOWMEXT) SCL SDA ams Datasheet [v1-01] 2018-Mar-27 Page 9 Document Feedback TSL2571 − Typical Characteristics Typical Characteristics Figure 12: Spectral Responsivity 1 Ch 0 Normalized Responsivity 0.8 0.6 0.4 Ch 1 0.2 0 300 400 500 600 700 800 900 1000 1100 λ − Wavelength − nm Figure 13: Normalized IDD vs.VDD and Temperature VDD and TEMPERATURE 110% 108% IDD Normalized @ 3 V, 25C 75C 106% 104% 50C 25C 102% 100% 0C 98% 96% 94% 92% 2.7 2.8 2.9 3 3.1 3.2 3.3 VDD — V Page 10 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Typical Characteristics Figure 14: Normalized Responsivity vs. Angular Displacement 1.0 Optical Axis Normalized Responsivity 0.8 0.6 0.4 0.2 0 −90 ams Datasheet [v1-01] 2018-Mar-27 -Q +Q −60 −30 0 30 60 Q − Angular Displacement − ° 90 Page 11 Document Feedback TSL2571 − Principles of Operation Principles of Operation System State Machine The device provides control of ALS and power management functionality through an internal state machine (see Figure 15). After a power-on-reset, the device is in the sleep mode. As soon as the PON bit is set, the device will move to the start state. It will then continue through the Wait and ALS states. If these states are enabled, the device will execute each function. If the PON bit is set to 0, the state machine will continue until all conversions are completed and then go into a low power sleep mode. Figure 15: Simplified State Diagram Sleep PON = 1 (r 0:b0) PON = 0 (r 0:b0) Start ALS Wait Note(s): In this document, the nomenclature uses the bit field name in italic followed by the register number and bit number to allow the user to easily identify the register and bit that controls the function. For example, the power on (PON) is in register 0, bit 0. This is represented as PON (r0:b0). Page 12 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Principles of Operation Photodiodes Conventional silicon detectors respond strongly to infrared light, which the human eye does not see. This can lead to significant error when the infrared content of the ambient light is high (such as with incandescent lighting) due to the difference between the silicon detector response and the brightness perceived by the human eye. This problem is overcome through the use of two photodiodes. The channel 0 photodiode, referred to as the CH0 channel, is sensitive to both visible and infrared light, while the channel 1 photodiode, referred to as CH1, is sensitive primarily to infrared light. Two integrating ADCs convert the photodiode currents to digital outputs. The ADC digital outputs from the two channels are used in a formula to obtain a value that approximates the human eye response in units of lux. ALS Operation The ALS engine contains ALS gain control (AGAIN) and two integrating analog-to-digital converters (ADC) for the Channel 0 and Channel 1 photodiodes. The ALS integration time (ATIME) impacts both the resolution and the sensitivity of the ALS reading. Integration of both channels occurs simultaneously and upon completion of the conversion cycle, the results are transferred to the data registers (C0DATA and C1DATA). This data is also referred to as channel count. The transfers are double-buffered to ensure data integrity. Figure 16: ALS Operation ATIME(r 1) 2.72 ms to 696 ms CH0 ALS CH0 Data C0DATAH(r 0x15), C0DATA(r 0x14) ALS Control CH0 CH1 ADC CH1 Data C1DATAH(r 0x17), C1DATA(r 0x16) CH1 AGAIN(r 0x0F, b1:0) 1, 8, 16, 120 Gain ams Datasheet [v1-01] 2018-Mar-27 Page 13 Document Feedback TSL2571 − Principles of Operation The registers for programming the integration and wait times are a 2’s compliment values. The actual time can be calculated as follows: ATIME = 256 - Integration Time / 2.72 ms Inversely, the time can be calculated from the register value as follows: Integration Time = 2.72 ms × (256 - ATIME) In order to reject 50/60-Hz ripple strongly present in fluorescent lighting, the integration time needs to be programmed in multiples of 10 / 8.3 ms or the half cycle time. Both frequencies can be rejected with a programmed value of 50 ms (ATIME = 0xED) or multiples of 50 ms (i.e. 100, 150, 200, 400, 600). The registers for programming the AGAIN hold a two-bit value representing a gain of 1×, 8×, 16×, or 120×. The gain, in terms of amount of gain, will be represented by the value AGAINx, i.e. AGAINx = 1, 8, 16, or 120. Lux Equation The lux calculation is a function of CH0 channel count (C0DATA), CH1 channel count (C1DATA), ALS gain (AGAINx), and ALS integration time in milliseconds (ATIME_ms). If an aperture, glass/plastic, or a light pipe attenuates the light equally across the spectrum (300 nm to 1100 nm), then a scaling factor referred to as glass attenuation (GA) can be used to compensate for attenuation. For a device in open air with no aperture or glass/plastic above the device, GA = 1. If it is not spectrally flat, then a custom lux equation with new coefficients should be generated. (See ams application note). Counts per Lux (CPL) needs to be calculated only when ATIME or AGAIN is changed, otherwise it remains a constant. The first segment of the equation (Lux1) covers fluorescent and incandescent light. The second segment (Lux2) covers dimmed incandescent light. The final lux is the maximum of Lux1, Lux2, or 0. CPL = (ATIME_ms × AGAINx) / (GA × 53) Lux1 = (C0DATA - 2 × C1DATA) / CPL Lux2 = (0.6 × C0DATA - C1DATA) / CPL Lux = MAX(Lux1, Lux2, 0) Page 14 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Principles of Operation Interrupts The interrupt feature simplifies and improves system efficiency by eliminating the need to poll the sensor for light intensity values outside of a user-defined range. While the interrupt function is always enabled and it’s status is available in the status register (0x13), the output of the interrupt state can be enabled using the ALS interrupt enable (AIEN) field in the enable register (0x00). Two 16-bit interrupt threshold registers allow the user to set limits below and above a desired light level range. An interrupt can be generated when the ALS CH0 data (C0DATA) falls outside of the desired light level range, as determined by the values in the ALS interrupt low threshold registers (AILTx) and ALS interrupt high threshold registers (AIHTx). It is important to note that the low threshold value must be less than the high threshold value for proper operation. To further control when an interrupt occurs, the device provides a persistence filter. The persistence filter allows the user to specify the number of consecutive out-of-range ALS occurrences before an interrupt is generated. The persistence register (0x0C) allows the user to set the ALS persistence (APERS) value. See the persistence register for details on the persistence filter values. Once the persistence filter generates an interrupt, it will continue until a special function interrupt clear command is received (see Command Register). Figure 17: Programmable Interrupt AIHTH(r 07), AIHTL(r 06) Upper Limit CH0 ADC APERS(r 0x0C, b3:0) ALS Persistence CH0 Data Lower Limit CH0 AILTH(r 05), AILTL(r 04) ams Datasheet [v1-01] 2018-Mar-27 Page 15 Document Feedback State Diagram Figure 18 shows a more detailed flow for the state machine. The device starts in the sleep mode. The PON bit is written to enable the device. A 2.72-ms delay will occur before entering the start state. If the WEN bit is set, the state machine will then cycle through the wait state. If the WLONG bit is set, the wait cycles are extended by 12× over normal operation. When the wait counter terminates, the state machine will step to the ALS state. The AEN should always be set. In this case, a minimum of 1 integration time step should be programmed. The ALS state machine will continue until it reaches the terminal count at which point the data will be latched in the ALS register and the interrupt set, if enabled. Figure 18: Expanded State Diagram 1 to 256 steps Step: 2.72 ms Time: 2.72 ms − 696 ms 120 Hz Minimum − 8 ms 100 Hz Minimum − 10 ms Sleep PON = 1 PON = 0 Start ALS ALS Check AEN = 1 Wait Check ALS Delay 2.72 ms WEN = 1 Wait WLONG = 0 1 to 256 steps Step: 2.72 ms Time: 2.72 ms − 696 ms Minimum − 2.72 ms Page 16 Document Feedback WLONG = 1 1 to 256 steps Step: 32.64 ms Time: 32.64 ms − 8.35 s Minimum − 32.64 ms ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Principles of Operation I²C Protocol Interface and control are accomplished through an I²C serial compatible interface (standard or fast mode) to a set of registers that provide access to device control functions and output data. The devices support the 7-bit I²C addressing protocol. The I²C standard provides for three types of bus transaction: read, write, and a combined protocol (see Figure 34). During a write operation, the first byte written is a command byte followed by data. In a combined protocol, the first byte written is the command byte followed by reading a series of bytes. If a read command is issued, the register address from the previous command will be used for data access. Likewise, if the MSB of the command is not set, the device will write a series of bytes at the address stored in the last valid command with a register address. The command byte contains either control information or a 5-bit register address. The control commands can also be used to clear interrupts. The I²C bus protocol was developed by Philips (now NXP). For a complete description of the I²C protocol, please review the NXP I²C design specification at http://www.i2c-bus.org/references/. Figure 19: I²C Protocols 1 7 1 1 S Slave Address W A 8 Command Code 1 8 1 A Data Byte A 8 1 1 ... P I2C Write Protocol 1 S 7 Slave Address 1 R 1 8 A 1 Data A Data A 1 ... P I2C Read Protocol 1 7 1 1 8 1 1 7 1 1 S Slave Address W A Command Code A S Slave Address R A 8 Data A N P R S S W ... ams Datasheet [v1-01] 2018-Mar-27 1 8 1 A Data A 1 ... P Acknowledge (0) Not Acknowledged (1) Stop Condition Read (1) Start Condition Repeated Start Condition Write (0) Continuation of protocol Master-to-Slave Slave-to-Master Page 17 Document Feedback TSL2571 − Register Description Register Description Register Set The device is controlled and monitored by data registers and a command register accessed through the serial interface. These registers provide for a variety of control functions and can be read to determine results of the ADC conversions. The register set is summarized in Figure 20. Figure 20: Register Address Address Register Name R/W −− COMMAND W 0x00 ENABLE 0x01 Register Function Reset Value Specifies register address 0x00 R/W Enables states and interrupts 0x00 ATIME R/W ALS ADC time 0xFF 0x03 WTIME R/W Wait time 0xFF 0x04 AILTL R/W ALS interrupt low threshold low byte 0x00 0x05 AILTH R/W ALS interrupt low threshold high byte 0x00 0x06 AIHTL R/W ALS interrupt high threshold low byte 0x00 0x07 AIHTH R/W ALS interrupt high threshold high byte 0x00 0x0C PERS R/W Interrupt persistence filters 0x00 0x0D CONFIG R/W Configuration 0x00 0x0F CONTROL R/W Control register 0x00 0x12 ID R Device ID 0x13 STATUS R Device status 0x00 0x14 C0DATA R CH0 ADC low data register 0x00 0x15 C0DATAH R CH0 ADC high data register 0x00 0x16 C1DATA R CH1 ADC low data register 0x00 0x17 C1DATAH R CH1 ADC high data register 0x00 ID The mechanics of accessing a specific register depends on the specific protocol used. See the section on I²C protocols on the previous pages. In general, the COMMAND register is written first to specify the specific control/status register for following read/write operations. Page 18 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Register Description Command Register The command registers specifies the address of the target register for future write and read operations. Figure 21: Command Register 7 COMMAND 6 COMMAND Field Bits COMMAND 7 5 TYPE 4 3 2 1 0 −− ADD Description Select Command Register. Must write as 1 when addressing COMMAND register. Selects type of transaction to follow in subsequent data transfers. TYPE FIELD VALUE DESCRIPTION 00 Repeated byte protocol transaction 01 Auto-increment protocol transaction 10 Reserved — Do not use 11 Special function — See description below 6:5 Transaction type 00 will repeatedly read the same register with each data access. Transaction type 01 will provide an auto-increment function to read successive register bytes. Address register/special function field. Depending on the transaction type, see above, this field either specifies a special function command or selects the specific control-status-register for following write and read transactions. The field values listed below apply only to special function commands: ADD 4:0 FIELD VALUE DESCRIPTION 00000 Normal — no action 00110 ALS interrupt clear other Reserved — do not write ALS interrupt clear — clears any pending ALS interrupt. This special function is self clearing. ams Datasheet [v1-01] 2018-Mar-27 Page 19 Document Feedback TSL2571 − Register Description Enable Register (0x00) The ENABLE register is used to power the device ON/OFF, enable functions, and interrupts. Figure 22: Enable Register 7 6 5 Reserved ENABLE 4 3 2 1 0 AIEN WEN Reserved AEN PON Address 0x00 Field Bits Description Reserved 7:5 AIEN 4 ALS interrupt mask. When asserted, permits ALS interrupts to be generated. WEN 3 Wait enable. This bit activates the wait feature. Writing a 1 activates the wait timer. Writing a 0 disables the wait timer. Reserved 2 Reserved. Write as 0. AEN 1 ALS Enable. Writing a 1 activates the ALS. Writing a 0 disables the ALS. PON (1) 0 Power ON. This bit activates the internal oscillator to permit the timers and ADC channels to operate. Writing a 1 activates the oscillator. Writing a 0 disables the oscillator. Reserved. Write as 0. Note(s): 1. A minimum interval of 2.72 ms must pass after PON is asserted before ALS can be initiated. This required time is enforced by the hardware in cases where the firmware does not provide it. Page 20 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Register Description ALS Timing Register (0x01) The ALS timing register controls the internal integration time of the ALS ADCs in 2.72-ms increments. Figure 23: ALS Timing Register Field ATIME Bits Description VALUE INTEG_CYCLES TIME MAX COUNT 0xFF 1 2.72 ms 1024 0xF6 10 27.2 ms 10240 0xDB 37 101 ms 37888 0xC0 64 174 ms 65535 0x00 256 696 ms 65535 7:0 Wait Time Register (0x03) Wait time is set 2.72 ms increments unless the WLONG bit is asserted in which case the wait times are 12× longer. WTIME is programmed as a 2’s complement number. Figure 24: Wait Time Register Field WTIME Bits 7:0 Description REGISTER VALUE WAIT TIME TIME (WLONG = 0) TIME (WLONG = 1) 0xFF 1 2.72 ms 0.032 s 0xB6 74 201 ms 2.4 s 0x00 256 696 ms 8.3 s Note(s): 1. The Wait Time Register should be configured before AEN is asserted. ams Datasheet [v1-01] 2018-Mar-27 Page 21 Document Feedback TSL2571 − Register Description ALS Interrupt Threshold Registers (0x04 - 0x07) The ALS interrupt threshold registers provides the values to be used as the high and low trigger points for the comparison function for interrupt generation. If C0DATA crosses below the low threshold specified, or above the higher threshold, an interrupt is asserted on the interrupt pin. Figure 25: ALS Interrupt Threshold Registers Register Address Bits AILTL 0x04 7:0 ALS low threshold lower byte AILTH 0x05 7:0 ALS low threshold upper byte AIHTL 0x06 7:0 ALS high threshold lower byte AIHTH 0x07 7:0 ALS high threshold upper byte Page 22 Document Feedback Description ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Register Description Persistence Register (0x0C) The persistence register controls the filtering interrupt capabilities of the device. Configurable filtering is provided to allow interrupts to be generated after each ADC integration cycle or if the ADC integration has produced a result that is outside of the values specified by threshold register for some specified amount of time. ALS interrupts are generated using C0DATA. Figure 26: Persistence Register 7 6 PERS 5 4 3 Reserved Field Bits Reserved 7:4 2 1 0 Address 0x0C APERS Description Reserved Interrupt persistence. Controls rate of interrupt to the host processor. APERS ams Datasheet [v1-01] 2018-Mar-27 FIELD VALUE MEANING INTERRUPT PERSISTENCE FUNCTION 0000 Every Every ALS cycle generates an interrupt 0001 1 1 value outside of threshold range 0010 2 2 consecutive values out of range 0011 3 3 consecutive values out of range 0100 5 5 consecutive values out of range 0101 10 10 consecutive values out of range 0110 15 15 consecutive values out of range 0111 20 20 consecutive values out of range 1000 25 25 consecutive values out of range 1001 30 30 consecutive values out of range 1010 35 35 consecutive values out of range 1011 40 40 consecutive values out of range 1100 45 45 consecutive values out of range 1101 50 50 consecutive values out of range 1110 55 55 consecutive values out of range 1111 60 60 consecutive values out of range 3:0 Page 23 Document Feedback TSL2571 − Register Description Configuration Register (0x0D) The configuration register sets the wait long time. Figure 27: Configuration Register 7 6 5 CONFIG 4 3 2 Reserved 1 0 WLONG Reserved Address 0x0D Field Bits Description Reserved 7:2 WLONG 1 Wait Long. When asserted, the wait cycles are increased by a factor 12× from that programmed in the WTIME register. Reserved 0 Reserved. Write as 0. Reserved. Write as 0. Control Register (0x0F) The Control register provides eight bits of miscellaneous control to the analog block. These bits typically control functions such as gain settings and/or diode selection. Figure 28: Control Register 7 6 5 CONTROL 4 3 2 1 Reserved Field Bits Reserved 7:2 0 AGAIN Address 0x0F Description Reserved. Write bits as 0 ALS Gain Control. AGAIN Page 24 Document Feedback FIELD VALUE ALS GAIN VALUE 00 1× gain 01 8× gain 10 16× gain 11 120× gain 1:0 ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Register Description ID Register (0x12) The ID Register provides the value for the part number. The ID register is a read-only register. Figure 29: ID Register 7 6 5 4 3 ID 2 1 0 Address 0x12 ID Field Bits ID 7:0 Description 0x04 = TSL25711 and TSL25715 Part number identification 0x0D = TSL25713 Status Register (0x13) The Status Register provides the internal status of the device. This register is read only. Figure 30: Status Register 7 STATUS 6 5 Reserved Field Bit Reserved 7:5 AINT 4 Reserved 3:1 AVALID 0 ams Datasheet [v1-01] 2018-Mar-27 4 AINT 3 2 Reserved 1 0 AVALID Address 0x13 Description Reserved. Write as 0. ALS Interrupt. Indicates that the device is asserting an ALS interrupt. Reserved. ALS Valid. Indicates that the ALS CH0 / CH1 channels have completed an integration cycle. Page 25 Document Feedback TSL2571 − Register Description ADC Channel Data Registers (0x14 - 0x17) ALS data is stored as two 16-bit values. To ensure the data is read correctly, a two-byte read I²C transaction should be used with auto increment protocol bits set in the command register. With this operation, when the lower byte register is read, the upper eight bits are stored in a shadow register, which is read by a subsequent read to the upper byte. The upper register will read the correct value even if additional ADC integration cycles end between the reading of the lower and upper registers. Figure 31: ADC Channel Data Registers Register Address Bits C0DATA 0x14 7:0 ALS CH0 data low byte C0DATAH 0x15 7:0 ALS CH0 data high byte C1DATA 0x16 7:0 ALS CH1 data low byte C1DATAH 0x17 7:0 ALS CH1 data high byte Page 26 Document Feedback Description ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Application Information Hardware Application Information Hardware Typical Hardware Application A typical hardware application circuit is shown in Figure 32. A 1-μF low-ESR decoupling capacitor should be placed as close as possible to the VDD pin. Figure 32: Typical Application Hardware Circuit VDD VBUS VDD RP 1 mF TSL2571 RP RPI INT SCL GND SDA V BUS in Figure 32 refers to the I²C bus voltage, which is either V DD or 1.8 V. Be sure to apply the specified I²C bus voltage shown in the Available Options table for the specific device being used. The I²C signals and the Interrupt are open-drain outputs and require pull-up resistors. The pull-up resistor (R P) value is a function of the I²C bus speed, the I²C bus voltage, and the capacitive load. The ams EVM running at 400 kbps, uses 1.5-kΩ resistors. A 10-kΩ pull-up resistor (RPI) can be used for the interrupt line. ams Datasheet [v1-01] 2018-Mar-27 Page 27 Document Feedback TSL2571 − Application Information Hardware PCB Pad Layout Suggested PCB pad layout guidelines for the Dual Flat No-Lead (FN) surface mount package are shown in Figure 33. Note(s): Pads can be extended further if hand soldering is needed. Figure 33: Suggested FN Package PCB Layout 2500 1000 1000 400 650 1700 650 400 Note(s): 1. All linear dimensions are in micrometers. 2. This drawing is subject to change without notice. Page 28 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Mechanical Data Mechanical Data Figure 34: Package FN — Dual Flat No-Lead Packaging Configuration PACKAGE FN Dual Flat No-Lead TOP VIEW 466  10 PIN OUT TOP VIEW PIN 1 466  10 2000  100 2000  100 VDD 1 6 SDA SCL 2 5 INT GND 3 4 NC Photodiode Array Area END VIEW SIDE VIEW 295 Nominal 650  50 203  8 650 300  50 BOTTOM VIEW CL of Photodiode Array Area (Note ) CL of Solder Contacts 20 Nominal 140 Nominal CL of Solder Contacts CL of Photodiode Array Area (Note ) PIN 1 750  150 RoHS Pb Green Lead Free Note(s): 1. All linear dimensions are in micrometers. Dimension tolerance is ±20μm unless otherwise noted. 2. The die is centered within the package within a tolerance of ± 3 mils. 3. Package top surface is molded with an electrically nonconductive clear plastic compound having an index of refraction of 1.55. 4. Contact finish is copper alloy A194 with pre-plated NiPdAu lead finish. 5. This package contains no lead (Pb). 6. This drawing is subject to change without notice. ams Datasheet [v1-01] 2018-Mar-27 Page 29 Document Feedback TSL2571 − Mechanical Data Figure 35: Package FN Carrier Tape TOP VIEW 2.00  0.05 1.75 4.00 8.00  1.50 4.00 B + 0.30 − 0.10 3.50  0.05  1.00  0.25 A B A DETAIL B DETAIL A 5 Max 5 Max 2.18  0.05 0.254  0.02 Ao 0.83  0.05 Ko 2.18  0.05 Bo Note(s): 1. All linear dimensions are in millimeters. Dimension tolerance is ±0.10 mm unless otherwise noted. 2. The dimensions on this drawing are for illustrative purposes only. Dimensions of an actual carrier may vary slightly. 3. Symbols on drawing Ao, Bo, and Ko are defined in ANSI EIA Standard 481-B 2001. 4. Each reel is 178 millimeters in diameter and contains 3500 parts. 5. ams packaging tape and reel conform to the requirements of EIA Standard 481-B. 6. In accordance with EIA standard, device pin 1 is located next to the sprocket holes in the tape. 7. This drawing is subject to change without notice. Page 30 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Manufacturing Information The FN package has been tested and has demonstrated an ability to be reflow soldered to a PCB substrate. Manufacturing Information The solder reflow profile describes the expected maximum heat exposure of components during the solder reflow process of product on a PCB. Temperature is measured on top of component. The components should be limited to a maximum of three passes through this solder reflow profile. Figure 36: Soldier Reflow Profile Parameter Reference Device Average temperature gradient in preheating 2.5°C/s tsoak 2 to 3 minutes Time above 217°C (T1) t1 Max 60 s Time above 230°C (T2) t2 Max 50 s Time above Tpeak −10°C (T3) t3 Max 10 s Peak temperature in reflow Tpeak 260°C Soak time Temperature gradient in cooling Max −5°C/s Figure 37: Solder Reflow Profile Graph Tpeak Not to scale — for reference o T3 T2 Temperature (C) T1 Time (s) t3 t2 tsoak t1 Note(s): 1. Not to scale - for reference only. ams Datasheet [v1-01] 2018-Mar-27 Page 31 Document Feedback TSL2571 − Manufacturing Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is dry-baked prior to being packed for shipping. Devices are packed in a sealed aluminized envelope called a moisture barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. The FN package has been assigned a moisture sensitivity level of MSL 3 and the devices should be stored under the following conditions: • Temperature Range: 5°C to 50°C • Relative Humidity: 60% maximum • Total Time: 12 months from the date code on the aluminized envelope—if unopened • Opened Time: 168 hours or fewer Rebaking will be required if the devices have been stored unopened for more than 12 months or if the aluminized envelope has been open for more than 168 hours. If rebaking is required, it should be done at 50°C for 12 hours. Page 32 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Ordering & Contact Information Ordering & Contact Information Figure 38: Ordering Information Ordering Code Device Address Package Leads Interface Description TSL25711FN TSL25711 0x39 FN−6 I²C Vbus = VDD Interface TSL25713FN TSL25713 0x39 FN−6 I²C Vbus = 1.8 V Interface TSL25715FN TSL25715 0x29 FN−6 I²C Vbus = VDD Interface Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v1-01] 2018-Mar-27 Page 33 Document Feedback TSL2571 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 34 Document Feedback ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v1-01] 2018-Mar-27 Page 35 Document Feedback TSL2571 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 36 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v1-01] 2018-Mar-27 TSL2571 − Revision Information Revision Information Changes from 1-00 (2016-May-26) to current revision 1-01 (2018-Mar-27) Page Updated Figure 7 6 Updated Figure 29 25 Updated Figure 38 33 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. ams Datasheet [v1-01] 2018-Mar-27 Page 37 Document Feedback TSL2571 − Content Guide Content Guide Page 38 Document Feedback 1 1 2 2 General Description Key Benefits & Features Applications Functional Block Diagram 3 4 5 6 10 Pin Assignments Detailed Description Absolute Maximum Ratings Electrical Characteristics Typical Characteristics 12 12 13 13 14 15 16 17 Principles of Operation System State Machine Photodiodes ALS Operation Lux Equation Interrupts State Diagram I²C Protocol 18 18 19 20 21 21 22 23 24 24 25 25 26 Register Description Register Set Command Register Enable Register (0x00) ALS Timing Register (0x01) Wait Time Register (0x03) ALS Interrupt Threshold Registers (0x04 - 0x07) Persistence Register (0x0C) Configuration Register (0x0D) Control Register (0x0F) ID Register (0x12) Status Register (0x13) ADC Channel Data Registers (0x14 - 0x17) 27 27 28 Application Information Hardware Typical Hardware Application PCB Pad Layout 29 Mechanical Data 31 32 Manufacturing Information Moisture Sensitivity 33 34 35 36 37 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ams Datasheet [v1-01] 2018-Mar-27
TSL25711FN 价格&库存
很抱歉,暂时无法提供与“TSL25711FN”相匹配的价格&库存,您可以联系我们找货
