www.osram-os.com
Produktdatenblatt | Version 1.1
SFH 320 FA
SFH 320 FA
TOPLED ®
Silicon NPN Phototransistor in SMT TOPLED®-Package
Applications
——Electronic Equipment
——White Goods
Features:
——Package: black epoxy
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
——Spectral range of sensitivity: (typ) 750 ... 1120 nm
——High linearity
——P-LCC-2 package
——Available in groups
——Suitable for all soldering methods
Ordering Information
Type
Photocurrent
VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm²
IPCE
Ordering Code
SFH 320 FA-4-Z
40 ... 80 µA
Q65110A1836
SFH 320 FA-3-Z
25 ... 50 µA
Q65110A2470
SFH 320 FA-Z
16 ... 80 µA
Q65110A2472
SFH 320 FA-3/4-Z
25 ... 80 µA
Q65110A2475
Only one bin within one packing unit (variation less than 2:1)
1 Version 1.5 | 2018-10-02
SFH 320 FA
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Operating temperature
Top
min.
max.
-40 °C
100 °C
Storage temperature
Tstg
min.
max.
-40 °C
100 °C
Collector-emitter voltage
VCE
max.
35 V
Collector current
IC
max.
15 mA
Collector surge current
τ ≤ 10 µs
ICS
max.
75 mA
Total power dissipation
Ptot
max.
165 mW
ESD withstand voltage
VESD
max.
2 kV
2 Version 1.5 | 2018-10-02
Values
SFH 320 FA
Characteristics
TA = 25 °C
Parameter
Symbol
Wavelength of max sensitivity
λS max
typ.
980 nm
λ10%
typ.
750 ... 1120
nm
Chip dimensions
LxW
typ.
0.45 x 0.45
mm x mm
Radiant sensitive area
Ø = 220 µm
A
typ.
0.038 mm²
Half angle
φ
typ.
60 °
Dark current
VCE = 20 V; E = 0
ICE0
typ.
max.
Rise time
IC = 1 mA; VCC = 5 V; RL = 1 kΩ
tr
typ.
7 µs
Fall time
tf
typ.
7 µs
Collector-emitter saturation voltage 1)
IC = IPCE,min X 0.3; Ee = 0.1 mW/cm²
VCEsat
typ.
150 mV
Capacitance
VCE = 0 V; f = 1 MHz; E = 0
CCE
typ.
5 pF
Thermal resistance junction ambient real
RthJA
max.
Grouping
TA = 25 °C
Group
Photocurrent
min.
IPCE
16 µA
32 µA
3
25 µA
50 µA
4
40 µA
80 µA
3 Version 1.5 | 2018-10-02
1 nA
50 nA
450 K / W
Photocurrent
max.
IPCE
2
Only one bin within one packing unit (variation less than 2:1).
Values
SFH 320 FA
Relative Spectral Sensitivity
2), 3)
Srel = f (λ)
OHF00468
100
S rel %
80
60
40
400 500 600 700 800 900
Directional Characteristics
nm 1100
λ
2), 3)
Srel = f (φ)
40
50
30
60
ϕ
0.8
0.6
70
0.4
80
0.2
1.0
0.8
100
OHF01402
4 Version 1.5 | 2018-10-02
0.6
0.4
60
80
100
120
SFH 320 FA
Photocurrent
Photocurrent
2), 3)
IPCE = f (Ee) ; VCE = 5 V
2), 3)
IPCE = f (VCE), Ee = Parameter
OHF01924
10 3
µA
OHF01529
10 0
mA
Ι PCE
mW
1 2
cm
Ι PCE
10 2
10
4
3
2
1
0.5
mW
cm 2
0.25
mW
cm 2
0.1
mW
cm 2
10 -1
10 0
10 -1 -3
10
10
-2
mW/cm
2
10
Ee
Dark Current
2), 3)
ICE0 = f (VCE) ; E = 0 ;
OHF01527
10 1
nA
Ι CEO
10 0
10 -1
10 -2
10
15
10 -3
5 Version 1.5 | 2018-10-02
30 V 35
V CE
10 -2
10
15
30 V 35
V CE
SFH 320 FA
Collector-Emitter Capacitance
2), 3)
CCE = f (VCE); f = 1 MHz; E = 0 ;
OHF01528
5.0
C CE pF
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
10 -1
Dark Current
10 0
10 1 V 10 2
V CE
Photocurrent
2)
ICE0 = f (TA); E = 0
2)
IPCE,rel = f (TA); VCE = 5 V
OHF01530
10 3
nA
Ι PCE
Ι CEO
Ι PCE 25
10 2
OHF01524
1.6
1.4
1.2
1.0
10 1
0.8
0.6
0.4
10 0
0.2
50
10 -1
-25
6 Version 1.5 | 2018-10-02
75 ˚C 100
TA
50
75 C 100
TA
SFH 320 FA
Power Consumption
Ptot = f (TA); RthJA = 450 K / W
OHF00871
200
mW
P tot
160
120
80
40
60
80 ˚C 100
TA
7 Version 1.5 | 2018-10-02
SFH 320 FA
Dimensional Drawing
4)
2.1 (0.083)
3.0 (0.118)
2.6 (0.102)
2.3 (0.091)
1.7 (0.067)
0.1 (0.004) (typ.)
0.5 (0.020)
1.1 (0.043)
Collector marking
3.7 (0.146)
3.3 (0.130) 4˚±1
3.4 (0.134)
3.0 (0.118)
(2.4) (0.095)
2.1 (0.083)
0.9 (0.035)
0.7 (0.028)
0.18 (0.007)
0.12 (0.005)
0.6 (0.024)
0.4 (0.016)
GPLY6030
Approximate Weight:
35.0 mg
Package marking:
Collector
8 Version 1.5 | 2018-10-02
SFH 320 FA
Recommended Solder Pad
4)
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
150
tL
tS
100
50
25 ˚C
100
150
200
250
s 300
t
9 Version 1.5 | 2018-10-02
SFH 320 FA
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
60
Ramp-up rate to peak*)
TSmax to TP
2
3
100
120
2
3
Unit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
10
Ramp-down rate*
TP to 100 °C
°C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
4)
4 (0.157)
2 (0.079)
Cathode/Collector Marking
4 (0.157)
10 Version 1.5 | 2018-10-02
3.5 (0.138)
2.9 (0.114)
3.6 (0.142)
8 (0.315)
1.5 (0.059)
1.75 (0.069)
Taping
OHAY2271
s
K/s
s
SFH 320 FA
Tape and Reel
5)
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Reel dimensions [mm]
A
W
Nmin
W1
W2 max
Pieces per PU
180 mm
8 + 0.3 / - 0.1
60
8.4 + 2
14.4
2000
330 mm
8 + 0.3 / - 0.1
60
8.4 + 2
14.4
8000
11 Version 1.5 | 2018-10-02
SFH 320 FA
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
4)
Moisture-sensitive label or print
Barcode label
L
VE
LE
see
lab
e
If
nk,
bla cod
bar
hu
ve
y
el
H)
(R
dit
mi
e
ed ag
RH
/60
˚C
rar ck
rel
30
N s VE RS
inf pa
ainITI TO
of
to ak
90
d
ntNSUC
ns
(pe
or
TIO
d
cte
itio
an bje ing
U g coSEND
˚C
nd
5
˚C su ss
CO
Ais baRE
co
ce
y
40 be
TU MI
CThIS
˚C
ll pro
tor
SE
ati
_
urs
urs
Ho
de
urs
Ho
co
72
Ho urs
te
48
e
Ho
24 6
da
e
tim
e
th
tim
or
23
tim e
at t wi nt
l wi
or
fac
˚C
Flo
s
tim
at
or
ca
at
re.
Flo
tha ale el
d
or
nth
nti
Flo
du
uiv
if: rea
es
l 4 5
Flo
mo
lab
ce
ide
eq
low
g,
l
ve
vic
5a
is
or
be
24
de
tin en
pro
ve l
6
Le
de ,
e
te
co
g:
un wh
Le ve l
ke
r
se
da
ba ed low
ure
Le ve
mo %
ba
e
ba
al
d
ure
Le
ist
en ref e
e 10
for
tim
se
ist ure
ale op se
for >
Mo
se
3
ure
is
or .
se
is ha
Mo istist
nk
be
g
nk
-03
rd
Mo
in
n Flo
r-p
RH g,
bla
Mo
ba
TD
po If blathi
life s
kin Ca
(if
ar
t.
wi
J-S
10 ba tor
thi, va p.
elf
Ye ar ks
_
e icat me , C
1
tem ted
Ye ee urs
Sh ter
at
ed
low
uir
1
W Ho
un
Af
Ind no uir DE
1.
dy
d
e
4
ref
8
y
is
req
JE
2.
bo
e
Mo ore
tim
req
16
C/
e
es dit2b
a)
St
tim
or
is IP
mior
ed
vic
tim e
b)
g e
or
Hu
en
Flo
tim
or
De
2a kin nc
te
Flo
op
a)
or
3.
b) baere
Flo
da
e
l 1 2
Flo
If
al
ref
tim ve
l
4.
se
d
l 2a
ve
Le
3
g
an
ve l
Le
Ba
te
ure
Le ve
ure
ist
Le
Da
ure
ist
Mo
ist ure
Mo
Mo ist
Mo
MO
TO
OP
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
12 Version 1.5 | 2018-10-02
SFH 320 FA
Transportation Packing and Materials
4)
DE
R
18
-1
-1
+Q
P
OU
P:
44
01
C:
99
8
D/
(9
D)
210
021
34
O
H
12
(Q
)Q
TY
S S
em R
ic AM
o
nd O
uc p
to to
H
rs
NO
TC
BA
3G
5
14
2
(6
P)
NO
: 12
T
11
00
LO
(1
T)
NO
OD
M
Y
DE
-1
18
P
-1
Q
R
G
RO
UP
(G
44
01
D/
C:
(9
D)
AM
00
TY
:2
)Q
O
SR
34
NO
(X
PR
O
D
5
14 2
110 0
(Q
A
R
ic
NO
O
S
em
S
(1
T)
LO
T
NO
(6
P)
: 12
3G
BA
TC
H
H
12
o M
n O
d
u p
ct to
o
rs
M
Muster
u L
lt S
iT Y
O T6
P 76
L
E Bi
D Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
(X
PR
8
2199
2100
GR
L
el
at
(G
M
u L
lt S
iT Y
O T67
P
L 6
Muster
E
V
LE
see
lab
e
H)
nk,
cod
(R
bla
r
If
ty
ba
idi
RH
m
hu
0%
e
/6
ive d
˚C
re ag
lat
ra ck
re
30
_
inf pa
k
s
of
to
90
ea
ur s
d
ns
(p
or
d
Ho ururs s
de
cteg
itio
Ho
an bje
co
˚C
72
sin
nd
Ho ur
5
te
48
˚C su es
e
Ho
co
24 6
da
40 be oc
ry
tim e e
˚C
th
r
pr
ll
tim
cto
23
oo r
wi nt
tim e
l wi
fa
r
˚C
Fl oo
tim
s
at
at ale
e.
at
ica
Fl
th
oo r
th
ur
el
nt
Fl oo
on es uiv
if: read
ed
l 4 5
Fl
lab
m
ide
eq
low
oc
ve l
vic
is
ingen
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou%
se
da
ed
ba
flo ba
Le ve
tu re
m
ba
e
al
d
Le
r
en re
re
e
re 10
ois tu
tim
se
fo
tu re
ale op se
fo >
M ois
r
se
3
is
is ha
se
M
ois tu
nk
be
oo .
03
nk
rd
g
M ois
in
r-p
bla
in Fl RH g,
DM
ba
Ca
po If blath
kin
life is
(if
ar
ST
p.
wi
10 baator et
Jelf r th va
Ye ar ks s
m
_
m
ed
1
Ye ee ur
d, C
iredic t
Sh te w, te
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re ty is
qu JE
2.
bo
M
or
tim e e
16
re C/
es idi 2b
r
a)
St
tim
mor
is IP
e
ed
r
oo
vic
tim
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
re
3.
b)
Fl oo
da
ba
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
Le
re
Ba
te
Le ve
tu re
Le
Da ois tu
re
tu re
M
ois
M
ois tu
M ois
M
Nns IVEORS
ai IT
ntNS CT
TIO
DU
U g EcoSE
ON
A ba
IC
UR
M
CThisSTSE
OI
M TO
OP
M
Y
Barcode label
E Bi
D n1
Bi
Bi n2 : Pn3 : Q- 1: 1- 20
M
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
Packing
Sealing label
Dimensions of transportation box in mm
Width
Length
Height
200 ± 5 mm
195 ± 5 mm
30 ± 5 mm
352 ± 5 mm
352 ± 5 mm
33 ± 5 mm
13 Version 1.5 | 2018-10-02
OHA02044
SFH 320 FA
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related informations please visit www.osram-os.com/appnotes
14 Version 1.5 | 2018-10-02
SFH 320 FA
Disclaimer
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the OSRAM OS Webside.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to
invoice you for any costs incurred.
Product safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.
15 Version 1.5 | 2018-10-02
SFH 320 FA
Glossary
1)
IPCEmin: IPCEmin is the min. photocurrent of the specified group.
2)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
3)
Testing temperature: TA = 25°C
4)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
5)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
16 Version 1.5 | 2018-10-02
SFH 320 FA
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
17 Version 1.5 | 2018-10-02
