SFH 325 FA-3-Z
SFH 325 FA-3-Z
    AMSOSRAM(艾迈斯半导体)
    LCC-2
    光电晶体管 980nm 侧视图 2-LCC(J 形引线)
SFH 325 FA-3-Z 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 SFH 325 FA   SFH 325 FA SIDELED ® Silicon NPN Phototransistor in SMT SIDELED®-Package Applications ——Electronic Equipment ——Personal Computer ——Gesture Recognition Features: ——Package: black epoxy ——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) ——Spectral range of sensitivity: (typ) 750 ... 1120 nm ——High linearity ——P-LCC-2 package ——Available in groups Ordering Information  Type  Photocurrent  VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² IPCE Ordering Code SFH 325 FA-3-Z 25 ... 50 µA Q65110A2482 SFH 325 FA-4-Z 40 ... 80 µA Q65110A2485 SFH 325 FA-Z 16 ... 80 µA Q65110A2487 SFH 325 FA-3/4-Z 25 ... 80 µA Q65110A2490  Binning in half groups (see “grouping”-table), packing unit = only one half group 1 Version 1.4 | 2018-10-02 SFH 325 FA   Maximum Ratings TA = 25 °C Parameter Symbol Values Operating temperature Top min. max. -40 °C 100 °C Storage temperature Tstg min. max. -40 °C 100 °C Collector-emitter voltage VCE max. 35 V Collector current IC max. 15 mA Collector surge current τ ≤ 10 µs ICS max. 75 mA Total power dissipation Ptot max. 165 mW ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) VESD max. 2 kV Characteristics TA = 25 °C Parameter Symbol Wavelength of max sensitivity λS max typ. 980 nm Spectral range of sensitivity λ10% typ. 750 ... 1120 nm Chip dimensions LxW typ. 0.45 x 0.45 mm x mm A typ. 0.038 mm² φ typ. 60 ° Dark current VCE = 20 V; E = 0  ICE0 typ. max. Rise time IC = 1 mA; VCC = 5 V; RL = 1 kΩ tr typ. 7 µs Fall time IC = 1 mA; VCC = 5 V; RL = 1 kΩ tf typ. 7 µs Collector-emitter saturation voltage 1) IC = IPCE,min X 0.3; Ee = 0.1 mW/cm² VCEsat typ. 150 mV Capacitance VCE = 0 V; f = 1 MHz; E = 0  CCE typ. 5 pF Thermal resistance junction ambient real RthJA max. Radiant sensitive area  Half angle  2 Version 1.4 | 2018-10-02 Values 1 nA 50 nA 450 K / W SFH 325 FA   Grouping  TA = 25 °C Group Photocurrent VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² min. IPCE Photocurrent VCE = 5 V; λ = 950 nm; Ee = 0.1 mW/cm² max. IPCE 2A 16 µA 25 µA 2B 20 µA 32 µA 3A 25 µA 40 µA 3B 32 µA 50 µA 4A 40 µA 63 µA 4B 50 µA 80 µA Binning in half groups, packing unit = only one half group Relative Spectral Sensitivity 2), 3) Srel = f (λ) 100 OHF00468 S rel % 80  60 40 20  0 400 500 600 700 800 900 3 Version 1.4 | 2018-10-02 nm 1100 λ SFH 325 FA   Directional Characteristics 2), 3) Srel = f (φ) 40 30 20 10 ϕ 0 OHF01402 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 1.0 Photocurrent 0.8 0.6 0.4 40 60 80 OHF01924 Ι PCE 120 2), 3) OHF01529 10 0 mA mW 1 2 cm Ι PCE  2 100 IPCE = f (VCE), Ee = Parameter 10 3 µA 10 20 Photocurrent 2), 3) IPCE = f (Ee) ; VCE = 5 V 10 0 4 3 2 1 0.5 mW cm 2 0.25 mW cm 2 0.1 mW cm 2 10 -1 10 0 10 -1 -3 10 10 -2 10 0 mW/cm 2  Ee 4 Version 1.4 | 2018-10-02 10 -2 0 5 10 15 20 25 30 V 35 V CE SFH 325 FA   Dark Current 2), 3) ICE0 = f (VCE) ; E = 0 ; OHF01527 10 1 nA Ι CEO 10 0 10 -1 10 -2 10 -3 0 5 10 15 20 25 30 V 35 V CE Collector-Emitter Capacitance CCE = f (VCE); f = 1 MHz; E = 0 ; OHF01528 5.0 C CE pF  4.0 3.5 3.0 2.5 2.0 1.5 1.0 0.5 10 -1 10 0 10 1 V 10 2 V CE  0 10 -2 5 Version 1.4 | 2018-10-02 2), 3) SFH 325 FA   Dark Current Photocurrent 2) ICE0 = f (TA); E = 0  2) IPCE,rel = f (TA); VCE = 5 V OHF01530 10 3 nA Ι PCE Ι CEO Ι PCE 25 10 2 OHF01524 1.6 1.4 1.2 1.0 10 1 0.8 0.6 0.4 10 0 0.2 10 -1 -25 0 25 50 75 ˚C 100 TA Power Consumption Ptot = f (TA) OHF00871 200 mW P tot  160 120 80 40 0 20 40 60  0 6 Version 1.4 | 2018-10-02 80 ˚C 100 TA 0 -25 0 25 50 75 C 100 TA SFH 325 FA   Dimensional Drawing 4) 1.1 (0.043) (1.4 (0.055)) (R1) 4.2 (0.165) 3.8 (0.150) Approximate Weight: 76.0 mg Package marking: Collector   7 Version 1.4 | 2018-10-02 Emitter 3.8 (0.150) 3.4 (0.134) (2.9 (0.114)) Collector marking 2.54 (0.100) spacing (2.85 (0.112)) 0.9 (0.035) (0.3 (0.012)) Collector 0.7 (0.028) 4.2 (0.165) 3.8 (0.150) 2.4 (0.094) 2.8 (0.110) (2.4 (0.094)) GPLY6068 SFH 325 FA   Recommended Solder Pad 4) Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C  200 150 tL tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300  t 8 Version 1.4 | 2018-10-02 SFH 325 FA   Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax 60 Ramp-up rate to peak*) TSmax to TP Maximum 2 3 100 120 2 3 Unit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 250 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 4 10 Ramp-down rate* TP to 100 °C °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range Taping 4) 4 (0.157)  4.25 (0.167) 9 Version 1.4 | 2018-10-02 8 (0.315) 12 (0.472) 1.75 (0.069) Cathode/Collector Marking 5.5 (0.217)  2 (0.079) 3.95 (0.156) 1.5 (0.059) OHAY2273 s K/s s SFH 325 FA   Tape and Reel 5) W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Reel dimensions [mm] A W Nmin W1 W2 max Pieces per PU 330 mm 12 + 0.3 / - 0.1 60 12.4 + 2 18.4 2000   10 Version 1.4 | 2018-10-02 SFH 325 FA   Barcode-Product-Label (BPL) Dry Packing Process and Materials 4) Moisture-sensitive label or print Barcode label L VE LE see lab e If nk, bla cod bar hu ve y el . H) (R dit mi e ed ag % . RH /60 ˚C rar ck rel 30 N s VE RS inf pa % ainITI TO of to ak 90 d ntNSUC < ns (pe or TIO d , cte itio an bje ing U g coSEND ˚C nd 5 ˚C su ss CO Ais baRE co ± ce y 40 be TU MI CThIS ˚C < ll pro tor SE ati _ < ). urs urs Ho de urs Ho co 72 Ho urs te 48 e Ho 24 6 da e tim e th tim or ). 23 tim e at t wi nt l wi or fac ˚C Flo s tim at or ca at re. Flo tha ale el d or nth nti Flo du uiv if: rea es l 4 5 Flo mo lab ce ide eq low g, l ve vic 5a is or be 24 de tin en pro ve l 6 Le de , e te co g: , un wh Le ve l ke r se da ba ed low ure Le ve mo % ba e ba al d ure Le ist en ref e e 10 for tim se ist ure ale op se for > , Mo se 3 ure is or . , se is ha Mo istist nk be g nk -03 rd Mo in n Flo r-p RH g, bla Mo ba TD po If blathi life s % kin Ca (if ar t. wi J-S 10 ba tor thi, va p. elf Ye ar ks _ < e icat me , C 1 tem ted Ye ee urs Sh ter at ed low uir > 1 W Ho un Af Ind no uir DE 1. dy d e 4 ref 8 y is req JE 2. bo e Mo ore tim req 16 : C/ e es dit2b a) St tim or is IP mior ed vic tim e b) g e or Hu en Flo tim or De 2a kin nc te Flo op a) or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a ve Le 3 g an ve l Le Ba te ure Le ve ure ist Le Da ure ist Mo ist ure Mo Mo ist Mo MO TO OP  M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 11 Version 1.4 | 2018-10-02 SFH 325 FA   Transportation Packing and Materials 4) DE R 18 -1 -1 +Q P OU P: 44 01 C: 99 8 D/ 20 00 (9 D) 210 021 : 34 O H 12 (Q )Q TY : S S em R ic AM o nd O uc p to to H rs NO TC BA 3G 5 14 2 (6 P) NO : 12 T 11 00 LO (1 T) NO : OD M Y DE -1 18 P -1 + Q R G RO UP : (G ) 44 01 D/ C: (9 D) 0 AM 00 TY :2 )Q O SR 34 NO : (X ) PR O D 5 14 2 110 0 (Q A R ic NO : O S em S (1 T) LO T NO (6 P) : 12 3G BA TC H H 12 o M n O d u p ct to o rs M Muster u L lt S iT Y O T6 P 76 L E Bi D Bi n1 Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: (X ) PR < 8 2199 2100 GR L el at (G ) M u L lt S iT Y O T67 P L 6 Muster E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or d Ho ururs s , de cteg itio Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho co ± 24 6 da 40 be oc ry tim e e ˚C th r pr ll tim cto ). 23 oo r wi nt tim e l wi fa r ˚C Fl oo tim s at at ale e. at ica Fl th oo r th ur el nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low oc ve l vic is ingen de be 24 de or l 5a6 pr Le ve nt wh e te co , w, g: ve l Le ke r re ou% se da ed ba flo ba Le ve tu re m ba e al d Le r en re re e re 10 ois tu tim se fo tu re ale op se fo > , M ois r se 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba Ca po If blath % kin life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e ou 4 8 re ed re ty is qu JE 2. bo M or tim e e 16 re C/ : es idi 2b r a) St tim mor is IP e ed r oo vic tim b) g e r Hu Fl oo en tim De 2a kin nc te Fl oo r a) op re 3. b) Fl oo da ba e fe l 1 Fl If al re tim ve l 2 4. se d l 2a3 Le ve g an ve l Le re Ba te Le ve tu re Le Da ois tu re tu re M ois M ois tu M ois M Nns IVEORS ai IT ntNS CT TIO DU U g EcoSE ON A ba IC UR M CThisSTSE OI M TO OP M Y Barcode label E Bi D n1 Bi Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label Packing Sealing label Dimensions of transportation box in mm Width Length Height 349 ± 5 mm 349 ± 5 mm 33 ± 5 mm   12 Version 1.4 | 2018-10-02 OHA02044 SFH 325 FA   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related informations please visit www.osram-os.com/appnotes   13 Version 1.4 | 2018-10-02 SFH 325 FA   Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the OSRAM OS Webside. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. In case Buyer – or Customer supplied by Buyer– considers using OSRAM OS components in product safety devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.   14 Version 1.4 | 2018-10-02 SFH 325 FA   Glossary 1) IPCEmin: IPCEmin is the min. photocurrent of the specified group. 2) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 3) Testing temperature: TA = 25°C 4) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 5) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   15 Version 1.4 | 2018-10-02 SFH 325 FA     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 16 Version 1.4 | 2018-10-02
SFH 325 FA-3-Z 价格&库存
很抱歉,暂时无法提供与“SFH 325 FA-3-Z”相匹配的价格&库存,您可以联系我们找货
SFH 325 FA-3-Z
    • 1+3.53160
    • 10+3.45600
    • 30+3.40200
    库存:7
    SFH 325 FA-3-Z
    • 1+7.995261+0.95597
    • 10+4.8303410+0.57755
    • 100+3.23554100+0.38687
    • 500+2.61009500+0.31208
    • 1000+2.418131000+0.28913
    库存:8586
    SFH 325 FA-3-Z
    • 2000+2.260882000+0.27033
    • 4000+2.131964000+0.25492
    • 6000+2.067616000+0.24722
    • 10000+1.9965010000+0.23872
    • 14000+1.9550414000+0.23376
    • 20000+1.9152320000+0.22900
    库存:8586
