www.osram-os.com
SFH 30 9 FA
DATASHEET
SFH 309 FA
Datasheet
Published by ams-OSRAM AG
Tobelbader Strasse 30, 8141 Premstaetten, Austria
Phone +43 3136 500-0
ams-osram.com
© All
reserved
| Version
1.4 | 2022-08-11
1 rights
SFH 30 9 FA
DATASHEET
Radial T1
SFH 309 FA
Silicon NPN Phototransistor
Applications
- Access Control & Security
- Appliances & Tools
Features
- Package: black epoxy
- ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2)
- Spectral range of sensitivity: (typ) 730 ... 1120 nm
- High photosensitivity
- High linearity
- Available in groups
2 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Ordering Information
Type
Photocurrent 1)
VCE = 5 V; λ = 950 nm;
Ee = 0.5 mW/cm²
IPCE
Photocurrent 2)
Ordering Code
typ.
VCE = 5 V; λ = 950 nm; Ee = 0.5 mW/cm²
IPCE
SFH 309 FA-4
1120 ... 1800 µA
1,500 µA
Q62702P0178
SFH 309 FA-5
1800 ... 2800 µA
2,700 µA
Q62702P0180
SFH 309 FA
450 ... 4500 µA
2,700 µA
Q62702P0941
SFH 309 FA-3/4
710 ... 1800 µA
1,300 µA
Q62702P3590
SFH 309 FA-4/5
1120 ... 2800 µA
2,700 µA
Q62702P3591
SFH 309 FA-5/6
1800 ... 4500 µA
2,700 µA
Q62702P5199
Only one bin within one packing unit.
3 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Maximum Ratings
TA = 25 °C
Parameter
Symbol
Operating temperature
Top
min.
max.
-40 °C
100 °C
Storage temperature
Tstg
min.
max.
-40 °C
100 °C
Collector-emitter voltage
VCE
max.
35 V
Collector current
IC
max.
15 mA
Collector surge current
τ ≤ 10 µs
ICS
max.
75 mA
Total power dissipation
Ptot
max.
165 mW
ESD withstand voltage
VESD
max.
2 kV
4 | Version 1.4 | 2022-08-11
Values
SFH 30 9 FA
DATASHEET
Characteristics
TA = 25 °C
Parameter
Symbol
Wavelength of max sensitivity
λS max
typ.
900 nm
λ10%
typ.
730 ... 1120
nm
Dimensions of chip area
LxW
typ.
0.45 x 0.45
mm x mm
Radiant sensitive area
Ø = 220 µm
A
typ.
0.038 mm²
Distance chip front to case surface
H
max.
min.
2.8
2.4
Half angle
φ
typ.
12 °
Dark current
VCE = 20 V
ICE0
typ.
max.
Rise time
IC = 1 mA; λ = 950 nm; VCE = 5 V; RL = 1 kΩ
tr
typ.
7 µs
Fall time
tf
typ.
7 µs
Collector-emitter saturation voltage 3)
IC = IPCE,min X 0.3; λ = 950 nm; Ee = 0.5 mW/cm²
VCEsat
typ.
200 mV
Capacitance
VCE = 0 V; f = 1 MHz; E = 0
CCE
typ.
5 pF
5 | Version 1.4 | 2022-08-11
Values
1 nA
50 nA
SFH 30 9 FA
DATASHEET
Photocurrent Groups
TA = 25 °C
Group
Photocurrent 1)
min.
IPCE
Photocurrent 1)
max.
IPCE
2
450 µA
710 µA
3
710 µA
1120 µA
4
1120 µA
1800 µA
5
1800 µA
2800 µA
6
2800 µA
4500 µA
6 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Relative Spectral Sensitivity
4),
5)
Srel = f (λ)
Directional Characteristics
Srel = f (φ)
7 | Version 1.4 | 2022-08-11
4),
5)
SFH 30 9 FA
DATASHEET
Photocurrent
4),
Photocurrent
5)
IPCE = f (Ee) ; VCE = 5 V
Dark Current
4),
5)
OHF01527
10 1
nA
Ι CEO
10 0
10 -1
10 -2
5
10
15
IPCE = f (VCE); Ee = Parameter
ICE0 = f (VCE) ; E = 0
10 -3
4),
8 | Version 1.4 | 2022-08-11
30 V 35
V CE
SFH 30 9 FA
DATASHEET
Collector-Emitter Capacitance
4),
5)
CCE = f (VCE); f = 1 MHz; E = 0
OHF01528
5.0
C CE pF
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
10 -1
Dark Current
10 0
10 1 V 10 2
V CE
Photocurrent
4)
ICE0 = f (TA); VCE = 20 V; Ee = 0 mW/cm²
IPCE,rel = f (TA); VCE = 5 V; λ = 950 nm; Ee = 0.5 mW/cm²
OHF01530
10 3
nA
Ι PCE
Ι CEO
Ι PCE 25
10 2
4)
OHF01524
1.6
1.4
1.2
1.0
10 1
0.8
0.6
0.4
10 0
0.2
50
10 -1
-25
9 | Version 1.4 | 2022-08-11
75 ˚C 100
TA
50
75 C 100
TA
SFH 30 9 FA
DATASHEET
Dimensional Drawing
6)
Collector (Transistor)
Cathode (Diode)
ø3.1 (0.122)
ø2.9 (0.114)
0.7 (0.028)
0.4 (0.016)
0.8 (0.031)
0.4 (0.016)
2.54 (0.100)
spacing
Area not flat
5.2 (0.205)
4.5 (0.177)
4.1 (0.161)
3.9 (0.154)
4.0 (0.157)
3.6 (0.142)
3.5 (0.138)
1.8 (0.071)
1.2 (0.047)
29 (1.142)
27 (1.063)
0.6 (0.024)
0.4 (0.016)
Chip position
6.3 (0.248)
5.9 (0.232)
GEOY6653
Further Information:
Approximate Weight:
178.0 mg
Package marking:
Collector
10 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Recommended Solder Pad
Pad 1: emitter
11 | Version 1.4 | 2022-08-11
6)
SFH 30 9 FA
DATASHEET
TTW Soldering
IEC-61760-1 TTW
OHA04645
300
10 s max., max. contact time 5 s per wave
˚C
T 250
235 ˚C - 260 ˚C
First wave
Second wave
Continuous line: typical process
Dotted line: process limits
∆T < 150 K
200
Cooling
Preheating
ca. 3.5 K/s typical
150
ca. 2 K/s
130 ˚C
120 ˚C
100 ˚C
100
ca. 5 K/s
Typical
50
60
80
100
120
140
160
180
200
220 s 240
t
Notes
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
Packing information is available on the internet (online product catalog).
For further application related information please visit www.osram-os.com/appnotes
12 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on our website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
Our components are not developed, constructed or tested for the application as safety relevant component
or for the application in medical devices.
Our products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using our components in product safety devices/
applications or medical devices/applications, buyer and/or customer has to inform our local sales partner
immediately and we and buyer and /or customer will analyze and coordinate the customer-specific request
between us and buyer and/or customer.
13 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Glossary
1)
Photocurrent: The photocurrent values are measured (by irradiating the devices with a homogenous
light source and applying a voltage to the device) with a tolerance of ±11 %.
2)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
3)
IPCEmin: IPCEmin is the min. photocurrent of the specified group.
4)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
5)
Testing temperature: TA = 25°C (unless otherwise specified)
6)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
14 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
Revision History
Version
Date
Change
1.4
2022-08-11
Applications
New Layout
15 | Version 1.4 | 2022-08-11
SFH 30 9 FA
DATASHEET
ams-osram.com
© All rights reserved
16 | Version 1.4 | 2022-08-11
很抱歉,暂时无法提供与“SFH 309 FA-4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+2.92317
- 500+2.85964
- 1000+2.79820
- 国内价格
- 500+2.85964
- 1000+2.79820
