7027-D-350
7027-D-350
    LEDDYNAMICS
    Module
    7027-D-350
7027-D-350 数据手册
TM 7027 BuckToot TM Low-Voltage LED Power Module by LEDdynamics TM PRELIMINARY Product Overview The 7027 “BuckToot” LED Power Module is a true constantcurrent regulated driver for LEDs. Unlike standard power supplies, which deliver a fixed voltage to the output, the BuckToot LED driver is designed to reliably vary the output voltage as required to deliver a stable constant current to the LED(s). The BuckToot exhibits very high efficiency and does not require external current limiting resistors or additional heat sinking. The extremely small form-factor of the 7027 BuckToot makes it the ideal choice for many MR-11 and MR-16 integration applications since it can easily be incorporated into the housing assembly. Fully potted and sealed from harsh environments, * the BuckToot measures only 10mm diameter x 19mm long and is supplied with 150mm 24AWG colored leads. Custom sizes can be created to meet customer requirements. Contact LuxDrive for more information. 7027 BuckToot LED Driver Module powering (6) Luxeon I LEDs in series (VIN>24V) Features DC input power up to 28V surge protected True constant current output * Extremely small form-factor Figure 1. Wiring Connections (10mm diameter x 19mm length) Output open and short circuit protection Typical Applications Solar & Landscape Lighting Architectural Lighting Track Lighting Automotive & Marine Lighting 7027 BuckToot LED Driver Portable Lighting & Flashlights Point of Purchase Lighting Desk & Reading Lamps Signal & Marker Lighting Cabinet & Display Case Lighting Pb Sign & Channel Letters Much More... Figure 2. BuckToot shown powering (6) Luxeon I LEDs in series (VIN = 24VDC) 2002/95/EC * - Units can be customized for OEM applications - Contact LuxDrive for more information © 2008 LuxDrive, A Division of LEDdynamics, Inc. 44 Hull Street - Randolph, Vermont 05060-0444 PH: 802.728.4533 FAX: 802.728.3800 RoHS Compliant Page 1 of 2 May, 2008 - Rev 1.0 www.LuxDrive.com TM 7027 BuckToot TM Low-Voltage LED Power Module by LEDdynamics TM PRELIMINARY Part Number Identification Table Part Number Input Output Current 7027-D-350 5-28 Volts DC 350mA *Other currents available by special order. Absolute Maximum Ratings Input Voltage . . . . . . . . . . . . . . . . . . . . . . . . 28V DC Typical Characteristics Output current tolerance (within specified temp. range) . . ±10% Efficiency . . . . . . . . . . . . . . . . . . . . . . . . Up to 94% Input Voltage Minimum . . . . . . . . . . . . . . . . . . . 5VDC Input Margin (Vin - Vout) . . . . . . . . . . . . . . . . . . 2VDC Ripple Current . . . . . . . . . . . . . . . . . . . . . . . . . 15% Specifications Output current, 7027-D-xxx . . . . . . . . . . . . . . 350mA Figure 3. Efficiency vs. Vin Allowable case operating temperature . . . . -40-+85°C Storage temperature . . . . . . . . . . . . . . . -40-+125°C Physical Dimensions Pb Shown approximately actual size RoHS Compliant 2002/95/EC © 2008 LuxDrive, A Division of LEDdynamics, Inc. 44 Hull Street - Randolph, Vermont 05060-0444 PH: 802.728.4533 FAX: 802.728.3800 Page 2 of 2 May, 2008 - Rev 1.0 www.LuxDrive.com
7027-D-350 价格&库存
很抱歉,暂时无法提供与“7027-D-350”相匹配的价格&库存,您可以联系我们找货
