45ߏਤ
SURFACE MOUNT CERMET TRIMMERS (SINGLE TURN)
RoHS compliant
ST-4
INTERNAL STRUCTURE
1
7
2
6
5
3
4
9
Part name
■ FEATURES
● RoHS compliant
● Wide variety (7 types) to choose from
● Automatic mounting is possible (Taping)
● Flow/reflow soldering is possible
● Sealed construction (Washable: Refer to page 698.)
● Stopper structure prevents terminal pin from being open.
● Cross slot rotor suitable for automatic adjustment
● Resin materials are UL Recognized 94V-0 or 94V-1 equivalent
8
Material
1
Wiper
Multi metal alloy
2
Cover
Stainless steel (SUS 304)
3
Housing
4
Terminal pin
5
Base element
6
“O” ring
7
Rotor
8
Electrode
Ag-Pd cermet
9
Resistive element
RuO2 cermet
Epoxy
Copper alloy, Sn-Cu-plated
Ceramic
Silicone rubber
PPS
Polyphenylenesulphide
■ PART NUMBER DESIGNATION
S T - 4 E T A 2 0 0 Ω ( 2 0 1 )
Resistance code
Series name (minus slot)
Terminal pin
Resistance value
E:Sn-Cu (Lead-free)
Product shape (Shape of terminal)
Form of packaging
T:Taping (Reel)
Blank:Bulk in plastic bag
A:J-hook (Top adjustment)
B:Gull wing Top adjustment)
C:Through hole pins (Top adjustment)
D:Gull wing (Rear adjustment)
F: Through hole pins (Rear adjustment)
G:J-hook (Side adjustment)
H:Gull wing (Side adjustment)
S T - 4 2 E T A 2 0 0 Ω ( 2 0 1 )
Series name (cross slot)
Terminal pin
Resistance code
Resistance value
E:Sn-Cu (Lead-free)
Form of packaging
T:Taping (Reel)
※ Please refer to the LIST OF PART NUMBERS when placing orders.
B:Gull wing (Top adjustment)
ST-4
SURFACE MOUNT TRIMMERS
■ LIST OF PART NUMBERS
Adjustment
position
Top
adjustment
Rear
adjustment
Side
adjustment
Form of packaging
Shape of
terminal
( J-hook )
B ( Gull wing )
C ( Through hole pins )
D ( Gull wing )
F ( Through hole pins)
G ( J-hook )
H ( Gull wing )
A
Pieces in package
〈Nominal resistance values〉
Taping (reel)
Plastic bag
ST-4/42ETA
ST-4/42EA
ST-4/42ETB
ST-4/42EB
A ST-4/42ETD
A ST-4/42ED
ST-4/42EC
A10 Ω A20 Ω 50 Ω
100 Ω 200 Ω 500 Ω
1 kΩ
2 kΩ
10 kΩ 20 kΩ 5 0kΩ 100 kΩ 200 kΩ 500 kΩ 1 MΩ
2 MΩ
5 kΩ
Fig. 1
:Not manufactured
※ The above part numbers are all available with the respective combination
of (Fig. 1).
※ Verify the above part numbers when placing orders.
※ Taping specification is not sold separately and must be purchased in reel units.
※ Cross slot available : ST-42E □
A ST-4/42EF
ST-4/42ETG
ST-4/42EG
ST-4/42ETH
ST-4/42EH
500 pcs./reel
100 pcs./pack
The products indicated by A mark are manufactured upon receipt of
order basis.
※ C slot : ST-4E □ , B slot : ST-42E □
Mechanical angle
240° (1 turn)
Operating torque
10 mN·m {102 gf·cm} maximum
Stop strength
30 mN·m {306 gf·cm} minimum
10 Ω ~ 2 MΩ
Rotational life
100 cycles [ Δ R/R ≦ ± (2 Ω +3 %)]
± 20 %
Thrust to rotor
5 N {0.51 kgf} minimum
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
■ MECHANICAL CHARACTERISTICS
Resistance tolerance
Solderability
245 ± 3 °C, 2 ~ 3 s
Linear law (B)
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Maximum input voltage
DC200 V or power rating, whichever is smaller
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Maximum wiper current
100 mA or power rating, whichever is smaller
Pull-off strength
Power ratings
0.25 W (70 °C) 0 W (125 °C)
Resistance law
Effective electrical angle
1 % or 2 Ω , whichever is greater
C.R.V.
1 % or 3 Ω , whichever is greater
− 55 ~ 125 °C
Operating temp. range
Insulation resistance
10 Ω ~ 50 Ω : ± 250 10-6/°C maximum
100 Ω ~ 2 MΩ : ± 100 10-6/°C maximum
1000 MΩ minimum (DC500 V)
Approx. 0.12 g (ST-4EA, EB, EC, ED, EF)
Approx. 0.22 g (ST-4EG, EH)
〈Reflow profile for soldering heat evaluation〉
(°C)
250
Peak : 250
+5
°C
Temperature
Over 230 °C
200
150
100
50
180 °C
150 °C
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Humidity
Shock
30 ± 10 s
Heating time
− 10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.25 W 1000 h
Specifications
[ Δ R/R ≦ 2 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[ Δ R/R ≦ 1 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
Low temp. operation
− 55 °C, 2 h
High temp. exposure
125 °C, 250 h
Immersion seal
85 °C, 60 s
No leaks (No continuous bubbles)
Soldering heat
Flow : 260 ± 3 °C as the temperature in a
pot of molten solder, immersion from head of
terminal to backside of board, 5 ~ 6 s, two
times maximum
Reflow : Peak temperature 255 °C
(Please refer to the profile below.)
Manual soldering:350 ± 10 °C, 3 ~ 4 s
[ Δ R/R ≦ 1 %]
Pre Heating Zone
90 ± 30 s
Test conditions
Thermal shock − 65 ~ 125 °C (0.5 h), 5 cycles
AC500 V, 60 s
Dielectric strength
Net weight
{ }:Reference only
210° (1 turn)
End resistance
Temp. coefficient
5 N {0.51 kgf} 10 s
Soldering Zone
リフロー回数:2回 Reflow : two times maximum
Δ R/R:Change in total resistance
S.S. :Setting stability
ST-4
■ MAXIMUM INPUT RATINGS
Nominal resistance values (Ω)
Resistance code
10
100
200
500
100
200
500
101
201
501
1.00
2.00
3.53
5.00
7.07
11.2
100
100
70.7
50.0
35.4
22.4
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
15.8
22.4
35.4
50.0
70.7
112
15.8
11.2
7.07
5.00
3.54
2.24
100 k
200 k
500 k
1 M
2 M
104
204
504
105
205
158
200
200
200
200
1.58
1.00
0.40
0.20
0.10
A
A
Maximum input voltage (V) Maximum wiper current (mA)
receipt of order basis.
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
● ST-4EA
● ST-4EB
2
1.5
2
2
2
2
(Unit: mm)
● ST-4ED
5.6
2
1.6
1.6
2.35
1.6
2.35
2.35
● ST-4EG
● ST-4EH
2
2.8
0.8
2
0.8
2
3.3
2.5
1.6
0.3
1.6
1.6
1.6
1.5
2
2
1.6
2.35
Note) The zero point is the center of mounting.
ST-4
ST-4A 外形図
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit: mm)
①
CW rotation
● ST-4EA
Top adjustment
②
※ Note the terminal position.
0.6 W × 2.3 L × 0.5 D
2
1.2
Lead-free Identification mark
3
5.2 – 00.5
抵抗値及び製造年月記号
Resistance code &
Production date code
4.5
4B 外形図
t = 0.15
3
③
5
1
2 – 0.8
2.35
2.3
0.35 min.
● ST-4EB
Top adjustment
4.5
3
5
1
t = 0.15
2.3
● ST-4EC
Top adjustment
0.35 min.
T-4C 外形図
1.2
6.2
抵抗値及び製造年月記号
Resistance code &
2
2 – 0.8
2.35
2
3 – 0.6
4.5
抵抗値及び製造年月記号
Resistance code &
5
外形図
3
5
1
2.3
2.54
4±1
t = 0.15
● ST-4EG
Side adjustment
5
Resistance code &
4.5
3
1.45
2 – 0.8
2.35
(2.1)
t = 0.15
0.95
3.1
1
2
1.2
ST-4
ST-4H 外形図
①
CW rotation
● ST-4EH
Side adjustment
②
ST-4D 外形図
5
2 – 0.8
4.5
Resistance code &
2.35
1
3.1
3
2
0.8
6.1
● ST-4ED
Rear adjustment
1.2
t = 0.15
< Semi-standard products >
2
1.2
0.5
Resistance code &
4.5
0.5
7.2
F 外形図
③
3
1
5
2 – 0.8
2.3
2.8
● ST-4EF
Rear adjustment
t = 0.15
2.35
3 – 0.6
2
4.5
6.35
Resistance code &
3
1
5
2.5±0.5
● ST-42E
CROSS SLOT DIMENSION
Cross slot screwdriver 0 bit : 0.8 D
2.3
t = 0.15
2.54
ST-4
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
● ST-4ETA, ETB and ETD versions are boxed with 4 reels (2000 pcs.).
ST-4ETG and ETH versions are boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the dia-grams below.
● EMBOSSED TAPE DIMENSIONS
● REEL DIMENSIONS
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
Empty
Filled
(Unit: mm)
Empty
+1
13 (ETA/ETB)
13.4±1 (ETG/ETH)
Head
40 mm min.
21±0.8
20 pitches min.
60 0 (TA/TB)
50 min.(TG/TH)
End
2±0.5
+1
Leader
400 mm min.
Direction of feed
13±0.2
15.4±1 (ETA/ETB/ETD)
17.4±1 (ETG/ETH)
180 –1.5 (ST-4ETA/ETB/ETD)
254 ± 2 (ST-4ETG/ETH)
● ST-4ETA/ETB/ETD
4±0.1
φ 1.5
0.3±0.1
2±0.1
4±0.1
φ
1.5 +
ԖϑϦʔࣝผ߸ه
Ҿ͖ग़͠ํ
2.7 (ST-4ETA/ETB)
3.4 (ST-4ETD)
Direction of feed
5.5±0.1
ணྫ 45&"
Installation example
(ST-4EA)
12
5.5±0.05
● Unit of bulk in a plastic bag is 100 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with
500 pcs. per box.
Ҿ͖ग़͠ํ
Direction of feed
ணྫ (ST-4EG)
0.3±0.1
(ST-4EG)
12
2±0.05
8±0.1
1.75±0.1
8±0.1
● ST-4ETG/ETH
1.75±0.1
+0.1
φ 1.5
6.4
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nidec:
ST-4ETB204 ST-4ETB201 ST-4ETA104 ST-4ETB101 ST-4ETA502 ST-4ETB200 ST-4ETB202 ST-4ETB203 ST4ETB103 ST-4ETA501 ST-4ETA503 ST-4ETB502 ST-4ETB501 ST-4ETB503 ST-4ETA500 ST-4ETA504 ST4ETA103 ST-4ETB100 ST-4ETA203 ST-4ETB104 ST-4ETA101 ST-4ETA102 ST-4ETA105 ST-4ETB102 ST4ETA202 ST-4ETH503 ST-4ETH504 ST-4ETH203 ST-4ETH204 ST-4ETH205 ST-4ETH500 ST-4ETH501 ST4ETH502 ST-4ETH103 ST-4ETH104 ST-4ETH105 ST-4ETH200 ST-4ETH201 ST-4ETH202 ST-4ETG502 ST4ETG503 ST-4ETG504 ST-4ETH100 ST-4ETH101 ST-4ETH102 ST-4ETG202 ST-4ETG203 ST-4ETG204 ST4ETG205 ST-4ETG500 ST-4ETG501 ST-4ETG102 ST-4ETG103 ST-4ETG104 ST-4ETG105 ST-4ETG200 ST4ETG201 ST-4ETD501 ST-4ETD502 ST-4ETD503 ST-4ETD504 ST-4ETG100 ST-4ETG101 ST-4ETD201 ST4ETD202 ST-4ETD203 ST-4ETD204 ST-4ETD205 ST-4ETD500 ST-4ETD101 ST-4ETD102 ST-4ETD103 ST4ETD104 ST-4ETD105 ST-4ETD200 ST-4ETA205 ST-4ETB105 ST-4ETB205 ST-4ETB500 ST-4ETB504 ST4ETD100 ST-4EH503 ST-4EH504 ST-4ETA100 ST-4ETA200 ST-4ETA201 ST-4ETA204 ST-4EH203 ST-4EH204
ST-4EH205 ST-4EH500 ST-4EH501 ST-4EH502 ST-4EH103 ST-4EH104 ST-4EH105 ST-4EH200 ST-4EH201
ST-4EH202 ST-4EG502
很抱歉,暂时无法提供与“ST-4ETB101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 500+6.45138
- 1000+6.18999
- 2000+5.86508
- 国内价格 香港价格
- 500+7.79674500+1.00641
- 1000+7.366551000+0.95088
- 1500+7.125481500+0.91976
- 2500+6.832482500+0.88194
- 3500+6.645873500+0.85785
- 5000+6.453495000+0.83302
- 国内价格
- 1+20.28240
- 10+17.39880
- 30+15.60600
- 国内价格 香港价格
- 1+12.779421+1.64957
- 10+10.6924410+1.38019
- 25+9.9381225+1.28282
- 50+9.3988350+1.21321
- 100+8.88766100+1.14722
- 250+8.25017250+1.06494
- 国内价格
- 25+10.74084
- 100+10.42009
- 250+10.11184
- 国内价格
- 5+11.07408
- 25+10.74084
- 100+10.42009
- 250+10.11184
