M-22E10-050 2K
M-22E10-050 2K
    NIDEC(尼得科)
    插件,D22xL19mm
    可调电阻/电位器 2KΩ ±5% 2W 插件,D22xL19mm ±50ppm/℃
M-22E10-050 2K 数据手册
WIREWOUND MULTITURN TYPE M series Basic construction Wirewound multiturn type RoHS compliant ■ FEATURES OLine-up includes products ranging from 3 to 10 turns OCost effective (M-22E10) in house comparison ODial can be attached (M-22 series only) ORoHS compliant ■ PART NUMBER DESIGNATION M - 1 3 0 3 1 0 0 Series name Nominal resistance value(Ω) M-1303, M-1305, M-22S10 M-22E10, M-22E10-050 100, 200, 500, 1 k, 2 k, 5 k, 10 k, 20 k, 50 k ■ LIST OF PART NUMBERS Item No. of turn Nominal resistance value (Ω) 3 turns Part number M-1303 Resistance value ※1 M-1305 Resistance value 100, 200, 500, 1 k, 2 k, 5 k, 10 k, 20 k 5 turns M-22S10 10 turns Resistance value 100, 200, 500, 1 k, 2 k, 5 k, 10 k, 20 k, 50 k M-22E10 Resistance value ※2 M-22E10-050 ※ Verify the above part numbers when placing orders. ※1:M-1303 200 Ω model is manufactured upon receipt of order basis. ※2:For M-22E10 series, plese refer to the drawing for its mount size. M series POTENTIOMETERS ■ STANDARD SPECIFICATIONS Item M-13 series Part number M-1303 Resistance torelance % Independent linearity % End resistance, maximum ±5 ± 0.5 ± 0.2 2 % or 4 Ω, whichever is greater 0.5 % or 1 Ω, whichever is greater 1080° Effective electrical angle 1080° Mechanical angle Power rating W Dielectric strength 1800° ±10° 1800° 0.75 3600° ±10° 2 1000 (at DC 500 V) 14.7 {150} mN·m {gf·cm} maximum Strength of tighten screw N·m {kgf·cm} maximum Stop strength 9.81 {100} 0.147 {1.5} 0.196 {2} Ω maximum Temp. coefficient of resistance 20 (at 4 min-1) ± 50 ppm/°C Operating temp. range M-22E10-000 M-22E10-050 0.784 {8} 0.588 {6} 0.98 {10} N·m {kgf·cm} maximum Peak noise − 40 ~ 85 °C Rotational life 15000 cycles Net weight +10° 0 1000 1 min MΩ minimum Rotational torque 3600° 1 Vrms Insulation resistance M-22 series M-22S10 M-22E10 M-1305 g 25000 cycles Approx. 7 Approx. 19 Protection grade Approx. 17 IP40 ■ 120,1$/5(6,67$1&(‡5(62/87,21‡5$7('92/7$*(‡5$7('&855(17 Nominal resistance value (Ω) Resolution(%) M-22S10 M-22E10 Rated voltage(V) M-22S10 M-22E10 Rated current(mA) M-22S10 M-22E10 100 200 500 1k 2k 5k 10k 20 k 50 k 100 k 0.041 0.036 0.029 0.025 0.020 0.014 0.018 0.014 0.011 A 0.009 14.1 20.0 31.6 44.7 63.2 100.0 141.1 200.1 141.8 100.0 63.2 44.7 31.6 20.0 14.1 10.1 6.3 A 4.47 100 200 500 1k 2k 5k 10 k 20 k Resolution(%) M-1303 0.190 A 0.154 0.115 0.072 0.056 0.069 0.053 0.038 M-1305 0.137 0.095 0.078 0.057 0.047 0.051 0.039 0.032 Rated voltage(V) M-1303 8.7 A 12.2 19.4 27.4 38.7 61.2 86.6 122.5 M-1305 10.0 14.1 22.4 31.6 44.7 70.7 100.0 141.4 200.0 A 200.0 Rated current(mA) M-1303 86.2 A 61.5 38.7 28.5 19.4 12.3 8.7 6.1 The products indicated by A mark are manufactured upon receipt of order basis. M-1305 100.0 70.9 44.6 31.6 22.4 14.1 10.0 7.1 ■ 5$7('32:(5'(5$7,1*&859( 100 Power rating ratio (%) Nominal resistance value (Ω) 316.2 A 450.0 – 40 + 40 Ambient temperature (℃) + 85 M series POTENTIOMETERS ■ OUTLINE DIMENSIONS (Unit: mm) OM-1303 (3 turns) OM-1305 (5 turns) Wiring diagram 2 φ 0.8 hole φ 13 φ8 0.3 9.7 0.3 0.3 3 1 1 0.7 3 2 0.6 4 3 8 (14.5) 2.8 0 φ 3 –0.05 10 3 2 M 6 (P = 0.75) 2 CW 2 0.5 1.2 10 6.5 16.1 OM-22S10 (10 turns) 40° ax . 3–3 6m 3 – φ 1.5 4.5 (10) 4 0.8 φ 10.3 –0.01 –0.04 0 φ 6 –0.02 φ 22 R1 M9 (P=0.75) 6.4 1.2 15 1.6 (23) 18.5 (41.5) 40° 3–3 6.1 (7.2) 5.7 R1 6m 3 – φ 1.5 ax . OM-22E10 (10 turns) 0.8 0 φ 10.3 –0.06 0 φ 6 –0.05 φ 22 A 1.2 6.5 15 1.5 (23) 21 Part number 19 (42) OMC1003, JC10, M-1303, M-1305 OFor mm size (M-22E10-050, in common M-22S10 in common) φ 6.4 9 2 φ 11 0.63 1.3 12 2 A M-22E10 3/8” 32 UNEF M-22E10-050 M 9 (P = 0.75) OFor inch size (M-22E10) 3/8 inch 32 UNEF M9, P=0.75 M6, P=0.75 Mark φ 9.4 φ 12.9 0.5 1 12.7 2.3 φ 10 φ 15 0.45 0.9
M-22E10-050 2K 价格&库存
很抱歉,暂时无法提供与“M-22E10-050 2K”相匹配的价格&库存,您可以联系我们找货
M-22E10-050 2K
  • 1+160.870341+20.87280
  • 10+133.6142710+17.33634
  • 30+122.1680530+15.85121
  • 50+117.1633150+15.20185
  • 100+110.68378100+14.36113
  • 250+102.64399250+13.31798
  • 500+101.88149500+13.21904
M-22E10-050 2K
  • 1+111.28320
  • 10+108.16200
库存:1
M-22E10-050 2K
  • 1+130.95400
  • 2+125.74709
  • 5+121.57114
库存:12
M-22E10-050 2K
  • 10+104.31437
  • 20+100.51957
  • 50+95.77502
  • 100+91.03985
库存:12
