MANUAL SETTING TYPE OPTICAL ENCODERS
REC/RES
■ FEATURES
RoHS compliant
Contactless, manual adjustment only
Compact, light weight
With click (REC20, REC20C, REC20D, RECW20D)
Panel seal type (RESW20D, RECW20D)
RoHS compliant
■ PART NUMBER DESIGNATION
RE C W 20 D - 50 - 201 - 1
Series name
Output connection
1:Cable wire
Click
Output phase
C:With click
S:Without click
2:“A” & “B”
Panel seal
Resolution (P/R)
W:Panel seal (With O ring)
Blank:Non Panel seal
25, 50
Model
Size
φ 20 mm
■ LIST OF PART NUMBERS
Resolution
50 (P/R)
100 (P/R)
50 (P/R)
100 (P/R)
ltem
Output wave form
Output terminal
Click
Panel seal
Saturated wave
Pin terminal
Without click
Pseudosquare wave
Without click
25 (P/R)
Non Panel seal
RES20-50-200
RES20-100-200
RES20-50-200-Z
RES20-100-200-Z
RES20B-25-201-1
RES20D-25-201-1
With click
REC20-25-201-1
REC20D-25-201-1
Without click
RES20D-50-201-1
With click
REC20C-50-201-1
REC20D-50-201-1
50 (P/R)
Square wave
Part number
Cable wire
RESW20D-25-201-1
Without click
25 (P/R)
RECW20D-25-201-1
With click
Panel seal
Without click
RESW20D-50-201-1
With click
RECW20D-50-201-1
50 (P/R)
※ Verify the above part numbers when placing orders.
The knob is available.
REC/RES
OPTICAL ENCODERS
■ STANDARD SPECIFICATIONS
● Electrical characteristics
Item
Part number
RES20
RES20-Z
REC20
RES20B
REC20C
RES20D
REC20D
RESW20D RECW20D
DC5 V ± 5 %
Input voltage
mA
maximum
Input current
40
50
70
50
Saturated wave Pseudosquare wave
Output wave form
Square wave
Output phases
A, B
50
Resolution
100
50
100
25
50
90° ± 45°
Phase difference of outputs A & B
Maximum frequency response Hz
“1 (High)”
Output signal
“0 (Low)”
25, 50
500
100
2 Vp-p 1 Vp-p
minimum minimum
+ 4.0 V
minimum
+ 1.0 V
maximum
500
200
+ 4.5 V minimum
+ 0.5 V maximum
LED
Light source
● Mechanical characteristics
Item
Part number
RES20-Z
REC20
RES20B
REC20C
RES20D
2.94
1.18 ± 0.78
4.90
2.94
mN·m
{30} maximum
{12 ± 8}
{gf·cm} {30} maximum {50} maximum
19.6
19.6
mN·m
{200} maximum
{200} maximum
{gf·cm}
Starting torque
Click torque
Click number
Shaft loading
(When mounting)
RES20
25
50
REC20D
RESW20D RECW20D
2.94 ± 1.96
{30 ± 20}
9.81 ± 4.9
{100 ± 50}
11.8 ± 4.9
{120 ± 50}
25, 50
25, 50
Radial
9.81 N {1 kgf} maximum
4.90 N {500 gf} maximum
Axial
4.9 N {500 gf} maximum
2.94 N {300 gf} maximum
Net weight
Approx. 20 g Approx. 20 g
Strength of tighten screw
Approx. 10 g
Approx. 25 g
0.98 N·m {10 kgf·cm} maximum
0.49 N·m {5 kgf·cm} maximum
● Environmental characteristics
Item
Part number
Operating temp. range
Storage temp. range
Protection grade
RES20
RES20-Z
REC20
RES20B
REC20C
RES20D
REC20D
0 ~ 50 °C
– 20 ~ 80 °C
IP40
Note) Manual setting only.
RESW20D RECW20D
REC/RES
OPTICAL ENCODERS
■ RELIABILITY TEST
The output shall satisfy the criteria below after the following tests.
Test item
Test conditions
2
Vibration
Power OFF
Amplitude : 1.52 mm or 98.1 m/s (10 G) whichever is smaller.
10 ~ 500 Hz excursion 15 min/cycle, 8 cycles each for X, Z, directions.
Shock
Power OFF
3 times each in directions (X, Z) at 490 m/s (50 G), 11 ms.
High temperature
exposure
Power OFF
80 °C 96 h
2
ON 50 °C 96 h
RESW20D Power
外形図
(To be measured after leaving samples for 1 h at normal temperature and
humidity after the test.)
Low temperature
exposure
Power OFF
− 20 °C 96 h
Power ON
0 °C 96 h
Humidity
Power OFF
(To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and
Thermal shock
Power OFF
To be done 10 cycles with the following condition
(To be measured after leaving samples for 1 h at normal temperature and humidity after the test.)
80 °C ± 2 °C 0.5 h、− 20 °C ± 2 °C 0.5 h
3&%ڞ௨ଐ
■ OUTLINE DIMENSIONS
5–2
(4.8)
0.5
6 –(4.8)
M 9 P = 0.75
M 9 P = 0.75
γϟϑτʢथࢷʣ
γϟϑτʢथࢷʣ
M 9 P = 0.75
Shaft (Plastic)Shaft (Plastic)
Without click / Without click, With panel seal
C
C
6.5
9
14
< Attachment >
1.5 5 (4.5) 1.5
14 5
(23)
(23)
10 ± 0.5
1.5
11
(4.5)
10 ± 0.5
< Option (Stopper) >
● RES20D / REC20D /
RESW20D / RECW20D
1. Nut
12
2
1. Nut
2
φ 12.9
φ 12.9 1
2. Washer 2. Washer
0.5
2.8
2
1
2.5
0.2
–R
5
R0.
7.25
P12
= 0.75
0.5
6.8
P = 0.75
M9
φ 9.4
4.7
M9
φ 9.4
※ Water resistant washer will be provided for panel seal type.
Position stopper (metal piece) is available.
φ 10.4
φ 13
φ 20
φ 10.3 –0.06
3
φ8
φ 6 –0.05
5.55
5.55
3
4.7
φ 10.3 –0.06
5.5
φ 6 –0.1
5.5
16
φ 6 –0.1
16
4.7
φ 10.3 –0.06
5
(With click / With click, With panel seal )
0.5 16
Accessories (1/1)
M 9 P = 0.75
0.
5
0.
● REC20D/RECW20D
5–2
Lead wire
AWG26
6 – ˘0.5
6 5 4 3 2 61 5ϐϯ/P
4 3 2 1 ϐϯ/P
Pin No.
Pin No.
80 min.
● RES20D/RESW20D
Unless otherwise specified, tolerance: ± 0.4 (Unit: mm)
0.5±0.1
φ 20
The stopper can be provided upon request.
12
.1
φ 9
2
1. Nut
2. Washer
REC/RES
20 外形図
OPTICAL ENCODERS
● RES20/RES20-Z
RES20B
外形図
(Without click )
B4P・SHF・1AA
Connector
6
11
q 20
3.5
0.8
q 10.3 –0.05
q 6 –0.02
M 9 P = 0.75
VBA O
1.2
15
6.5
23
(38)
1.5
15 max.
2.5
7
AWG26
M9 P = 0.75
6.5
0.5
1
q 9.
● REC20C
2. Washer
Accessories (1/1)
M 9 P = 0.75
12
P12
= 0.75
1. Nut
1. Nut
12
10 ± 0.5
q 13
2
2
1. Nut
2
12
φ 9.4
φ 9.4
φ 12.9
φ 12.9 1
1. Nut
q
2
0.5
1
0.5
0.5
0.3
q 1 1
2. Washer 2. Washer
2. Washer
6.8
2.8
2.5
3. Stopper
2. Washer
q
1
q 9.
7.5
1
q 9.
q 13
(4.5)
0.
q 1
3
0.5
1
2.8
2. Washer
0.
q 1
2.8
2.5
3. Stopper
0.5
7.5
1.(23)
Nut (1/1)
Accessories
10 ± 0.5
M 9 P = 0.75
0.5
5.55
3
5.55
3
φ 10.3 –0.06
1.5 52(4.5) 1.5
14 5
q
6.8
(23)
2.5
3. Stopper
q 6 –0.02
φ 10.3 –0.06
q 10.3 –0.05
12
14
0.5
1
6.8
16
P = 0.75
M9
2.8
3
< Accessories >
M9
AWG26
2
q 6 –0.02
25 max.
φ 6 –0.1
5.5
16
5
0.
φ 6 –0.1
M9 P = 0.75
AWG26
0.3
q 1
5–2
5–2
(4.8)
0.5
6 –(4.8)
6 – ˘0.5
M 9 P = 0.75
M 9 P = 0.75
γϟϑτʢथࢷʣ
γϟϑτʢथࢷʣ
6 5 4 3 2 61 5ϐϯ/P
4 3 2 1 ϐϯ/P
Pin No.
Pin No.
Accessories (1/1)
6.5
15
1.5 q
M 9 P = 0.75
q
(23)
23 max.
6.5
15
q 13
1.5
q 9.
(23)
23 max.
C
5
0.
16
10
10
M9 P = 0.75
5.5
25 max.
1. Nut
C
4.7
2
0.5
1
(100)
7
12
q 10.3 –0.05
( 7With click )
q
18 max.
(100)
q 13
1.5
7.5
(23)
6.8
15
q
2
W (1/1)
0.8 = D 1.2
Accessories
M 9 P = 0.75
q 6 –0.02
23 max.
( Without click )
q 10.3 –0.05
● RES20B
0.5 16
(100)
● REC20
20C 外形図
( With click )
1
9 max.
2.5
3. Stopper
REC/RES
OPTICAL ENCODERS
KNOB
● KNOB FOR SETTING ENCODERS
10
The knobs are sold separately as an optional item.
8.5
q 15
4.5
q 33
R10
q 6 +0.10
+0.05
q 11
9.5
2.5
2–M3
7.5
Knurl (All surronding area)
※ Use a hexagon wrench for
1.5 fastening.
■ OUTPUT
● RES20D/REC20D/RESW20D/RECW20D
矩形波 Square wave
矩形波 Square
wave
T
T
Click spot
CW
Output“A”
Output“A”
Output“B”
Output“B” a
b
a
c
b
d
c
Output “A”
Output “A”
CW
Click spot
Click spot
a, b, c, d ≧ 1/10T
d
a, b, c, d ≧ 1/10T
CW
CW
Output “B”
Output “B”
クリック位置
Click spot
Click spot
● RES20
● RES20 *** Z
CW
Saturated Wave
T
CCW
Output “A”
2.5 V
Output “B”
2.5 V
Output“A”
1/2T
a
1/4T1/8T
1/2T
● REC20/RES20B/REC20C
Square Wave
T
CCW
CW
1
Output“A”
1/4T1/8T
1
Output“B”
Click range
c
a, b, c, d ≧ 100 ms
Output“B”
b
(REC20,REC20C)
d
CW
REC/RES
OPTICAL ENCODERS
■ OUTPUT CIRCUIT
● RES20
● RES20-Z
Vcc 5 V
Vcc 5 V
Output “A”
A
Output “B”
B
120 Ω
15 kΩ
15 kΩ
85 Ω min.
GND
Vcc 5 V (Red)
Vcc 5 V (Red)
4.7 kΩ
1 kΩ
4֎෦ճ࿏ྫ
Output “A” (White)
“B” (Green)
Output “A” (White)
“B” (Green)
IC
0 V (Black)
0 V (Black)
■ EXTERNAL SCHEMATICS
● RES20
V
+5 V
10 kΩ
ʵ
Comp.
ʴ
A
5 kΩ
G
R
ʵ
Comp.
ʴ
B
85 Ω min.
10 kΩ
5 kΩ
Output “A”
R
Output “B”
0V
很抱歉,暂时无法提供与“REC20D-25-201-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+248.183321+32.25206
- 10+175.6004110+22.81972
- 25+150.0118325+19.49442
- 100+140.56954100+18.26737
- 500+138.46862500+17.99435
- 1000+137.082121000+17.81417
- 国内价格 香港价格
- 1+247.757751+32.19676
- 10+175.2999110+22.78067
- 25+149.7545125+19.46098
- 100+140.32830100+18.23602
- 500+138.23077500+17.96344
- 1000+136.846801000+17.78359
