RES20D-50-201-1
RES20D-50-201-1
    NIDEC(尼得科)
    旋转编码器 手动控制 三件套
RES20D-50-201-1 数据手册
MANUAL SETTING TYPE OPTICAL ENCODERS REC/RES ■ FEATURES ● ● ● ● ● RoHS compliant Contactless, manual adjustment only Compact, light weight With click (REC20, REC20C, REC20D, RECW20D) Panel seal type (RESW20D, RECW20D) RoHS compliant ■ PART NUMBER DESIGNATION RE C W 20 D - 50 - 201 - 1 Series name Output connection 1:Cable wire Click Output phase C:With click S:Without click 2:“A” & “B” Panel seal Resolution (P/R) W:Panel seal (With O ring) Blank:Non Panel seal 25, 50 Model Size φ 20 mm ■ LIST OF PART NUMBERS Resolution 50 (P/R) 100 (P/R) 50 (P/R) 100 (P/R) ltem Output wave form Output terminal Click Panel seal Saturated wave Pin terminal Without click Pseudosquare wave Without click 25 (P/R) Non Panel seal RES20-50-200 RES20-100-200 RES20-50-200-Z RES20-100-200-Z RES20B-25-201-1 RES20D-25-201-1 With click REC20-25-201-1 REC20D-25-201-1 Without click RES20D-50-201-1 With click REC20C-50-201-1 REC20D-50-201-1 50 (P/R) Square wave Part number Cable wire RESW20D-25-201-1 Without click 25 (P/R) RECW20D-25-201-1 With click Panel seal Without click RESW20D-50-201-1 With click RECW20D-50-201-1 50 (P/R) ※ Verify the above part numbers when placing orders. The knob is available. REC/RES OPTICAL ENCODERS ■ STANDARD SPECIFICATIONS ● Electrical characteristics Item Part number RES20 RES20-Z REC20 RES20B REC20C RES20D REC20D RESW20D RECW20D DC5 V ± 5 % Input voltage mA maximum Input current 40 50 70 50 Saturated wave Pseudosquare wave Output wave form Square wave Output phases A, B 50 Resolution 100 50 100 25 50 90° ± 45° Phase difference of outputs A & B Maximum frequency response Hz “1 (High)” Output signal “0 (Low)” 25, 50 500 100 2 Vp-p 1 Vp-p minimum minimum + 4.0 V minimum + 1.0 V maximum 500 200 + 4.5 V minimum + 0.5 V maximum LED Light source ● Mechanical characteristics Item Part number RES20-Z REC20 RES20B REC20C RES20D 2.94 1.18 ± 0.78 4.90 2.94 mN·m ———— ———— {30} maximum {12 ± 8} {gf·cm} {30} maximum {50} maximum 19.6 19.6 mN·m ———— ———— ———— ———— {200} maximum {200} maximum {gf·cm} Starting torque Click torque Click number Shaft loading (When mounting) RES20 ———— ———— 25 50 ———— ———— REC20D RESW20D RECW20D ———— 2.94 ± 1.96 {30 ± 20} ———— 9.81 ± 4.9 {100 ± 50} ———— 11.8 ± 4.9 {120 ± 50} 25, 50 ———— 25, 50 Radial 9.81 N {1 kgf} maximum 4.90 N {500 gf} maximum Axial 4.9 N {500 gf} maximum 2.94 N {300 gf} maximum Net weight Approx. 20 g Approx. 20 g Strength of tighten screw Approx. 10 g Approx. 25 g 0.98 N·m {10 kgf·cm} maximum 0.49 N·m {5 kgf·cm} maximum ● Environmental characteristics Item Part number Operating temp. range Storage temp. range Protection grade RES20 RES20-Z REC20 RES20B REC20C RES20D REC20D 0 ~ 50 °C – 20 ~ 80 °C IP40 Note) Manual setting only. RESW20D RECW20D REC/RES OPTICAL ENCODERS ■ RELIABILITY TEST The output shall satisfy the criteria below after the following tests. Test item Test conditions 2 Vibration Power OFF Amplitude : 1.52 mm or 98.1 m/s (10 G) whichever is smaller. 10 ~ 500 Hz excursion 15 min/cycle, 8 cycles each for X, Z, directions. Shock Power OFF 3 times each in directions (X, Z) at 490 m/s (50 G), 11 ms. High temperature exposure Power OFF 80 °C 96 h 2 ON 50 °C 96 h RESW20D Power 外形図 (To be measured after leaving samples for 1 h at normal temperature and humidity after the test.) Low temperature exposure Power OFF − 20 °C 96 h Power ON 0 °C 96 h Humidity Power OFF (To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and humidity after the test.) Thermal shock Power OFF To be done 10 cycles with the following condition (To be measured after leaving samples for 1 h at normal temperature and humidity after the test.) 80 °C ± 2 °C 0.5 h、− 20 °C ± 2 °C 0.5 h 3&%౳‫ڞ‬௨෇ଐ඼ ■ OUTLINE DIMENSIONS 5–2 ˘ (4.8) 0.5 6 –(4.8) M 9 P = 0.75 M 9 P = 0.75 γϟϑτʢथࢷʣ γϟϑτʢथࢷʣ M 9 P = 0.75 Shaft (Plastic)Shaft (Plastic) ( Without click / Without click, With panel seal ) C C 6.5 9 20 16 14 < Attachment > 1.5 5 (4.5) 1.5 14 5 (23) (23) 10 ± 0.5 1.5 11 (4.5) 10 ± 0.5 < Option (Stopper) > ● RES20D / REC20D / RESW20D / RECW20D 1. Nut 12 2 1. Nut 2 φ 12.9 φ 12.9 1 2. Washer 2. Washer 0.5 2.8 2 1 2.5 0.2 –R 5 R0. 7.25 P12 = 0.75 0.5 6.8 P = 0.75 M9 φ 9.4 4.7 M9 φ 9.4 ※ Water resistant washer will be provided for panel seal type. Position stopper (metal piece) is available. φ 10.4 φ 13 φ 20 0 φ 10.3 –0.06 3 φ8 0 φ 6 –0.05 5.55 5.55 3 4.7 0 φ 10.3 –0.06 5.5 0 φ 6 –0.1 5.5 16 0 φ 6 –0.1 16 4.7 0 φ 10.3 –0.06 5 (With click / With click, With panel seal ) 0.5 16 Accessories (1/1) M 9 P = 0.75 0. 5 0. ● REC20D/RECW20D 5–2 Lead wire AWG26 6 – ˘0.5 6 5 4 3 2 61 5ϐϯ/P 4 3 2 1 ϐϯ/P Pin No. Pin No. 80 min. ● RES20D/RESW20D Unless otherwise specified, tolerance: ± 0.4 (Unit: mm) 0.5±0.1 φ 20 The stopper can be provided upon request. 12 .1 φ 9 2 1. Nut 2. Washer REC/RES 20 外形図 OPTICAL ENCODERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.4 (Unit: mm) ● RES20/RES20-Z RES20B 外形図 (Without click ) B4P・SHF・1AA Connector 6 11 q 20 3.5 0.8 0 0 q 10.3 –0.05 q 6 –0.02 M 9 P = 0.75 VBA O 1.2 15 6.5 23 (38) 1.5 15 max. 2.5 7 AWG26 M9 P = 0.75 6.5 0.5 1 q 9. ● REC20C 2. Washer Accessories (1/1) M 9 P = 0.75 12 P12 = 0.75 1. Nut 1. Nut 12 10 ± 0.5 q 13 2 2 1. Nut 2 12 φ 9.4 φ 9.4 φ 12.9 φ 12.9 1 1. Nut q 2 0.5 1 0.5 0.5 0.3 q 1 1 2. Washer 2. Washer 2. Washer 20 20 7.5 6.8 2.8 2.5 3. Stopper 2. Washer q 20 0.5 1 q 9. 7.5 1 q 9. q 13 (4.5) 0. q 1 3 0.5 1 2.8 2. Washer 0. q 1 2.8 2.5 3. Stopper 0.5 7.5 1.(23) Nut (1/1) Accessories 10 ± 0.5 M 9 P = 0.75 0.5 5.55 3 5.55 3 0 φ 10.3 –0.06 1.5 52(4.5) 1.5 14 5 q 6.8 (23) 2.5 3. Stopper 20 0 q 6 –0.02 0 0 φ 10.3 –0.06 q 10.3 –0.05 12 14 0.5 1 6.8 16 P = 0.75 M9 2.8 3 < Accessories > M9 AWG26 2 0 q 6 –0.02 25 max. 0 φ 6 –0.1 5.5 16 5 0. 0 φ 6 –0.1 M9 P = 0.75 AWG26 0.3 q 1 5–2 5–2 ˘ (4.8) 0.5 6 –(4.8) 6 – ˘0.5 M 9 P = 0.75 M 9 P = 0.75 γϟϑτʢथࢷʣ γϟϑτʢथࢷʣ 6 5 4 3 2 61 5ϐϯ/P 4 3 2 1 ϐϯ/P Shaft (Plastic)Shaft (Plastic) Pin No. Pin No. Accessories (1/1) 6.5 15 1.5 q M 9 P = 0.75 q (23) 23 max. 20 1 6.5 15 q 13 1.5 q 9. (23) 23 max. C 5 0. 16 10 10 M9 P = 0.75 5.5 25 max. 1. Nut C 4.7 2 0.5 1 (100) 7 12 20 0 q 10.3 –0.05 ( 7With click ) q 18 max. (100) q 13 1.5 7.5 (23) 6.8 15 q 2 W (1/1) 0.8 = D 1.2 Accessories M 9 P = 0.75 20 0 q 6 –0.02 23 max. ( Without click ) 0 q 10.3 –0.05 ● RES20B 0.5 16 (100) ● REC20 20C 外形図 ( With click ) 1 9 max. 2.5 3. Stopper REC/RES OPTICAL ENCODERS KNOB ● KNOB FOR SETTING ENCODERS Unless otherwise specified, tolerance: ± 0.4 (Unit: mm) 10 The knobs are sold separately as an optional item. 8.5 q 15 4.5 q 33 R10 q 6 +0.10 +0.05 q 11 9.5 2.5 2–M3 7.5 Knurl (All surronding area) ※ Use a hexagon wrench for 1.5 fastening. ■ OUTPUT ● RES20D/REC20D/RESW20D/RECW20D 矩形波 Square wave 矩形波 Square wave T T Click spot CW Output“A” Output“A” Output“B” Output“B” a b a c b d c Output “A” Output “A” CW Click spot Click spot a, b, c, d ≧ 1/10T d a, b, c, d ≧ 1/10T CW CW Output “B” Output “B” クリック位置 Click spot Click spot ● RES20 ● RES20 *** Z CW Saturated Wave T CCW Output “A” 2.5 V Output “B” 2.5 V Output“A” 1/2T a 1/4T1/8T 1/2T ● REC20/RES20B/REC20C Square Wave T CCW CW 1 Output“A” 1/4T1/8T 1 Output“B” 0 Click range c a, b, c, d ≧ 100 ms Output“B” 0 b (REC20,REC20C) d CW REC/RES OPTICAL ENCODERS ■ OUTPUT CIRCUIT ● RES20 ● RES20-Z Vcc 5 V Vcc 5 V Output “A” A Output “B” B 120 Ω 0 15 kΩ 15 kΩ 85 Ω min. GND ● REC20/RES20B/REC20C ● RES20D/REC20D/RESW20D/RECW20D Vcc 5 V (Red) Vcc 5 V (Red) 4.7 kΩ 1 kΩ 4֎෦ճ࿏ྫ Output “A” (White) “B” (Green) Output “A” (White) “B” (Green) IC 0 V (Black) 0 V (Black) ■ EXTERNAL SCHEMATICS ● RES20 V +5 V 10 kΩ ʵ Comp. ʴ A 5 kΩ G R ʵ Comp. ʴ B 85 Ω min. 10 kΩ 5 kΩ Output “A” R Output “B” 0V
RES20D-50-201-1 价格&库存
很抱歉,暂时无法提供与“RES20D-50-201-1”相匹配的价格&库存,您可以联系我们找货
RES20D-50-201-1
  • 1+152.77099
  • 2+146.67890
  • 5+141.78440
库存:9
RES20D-50-201-1
  • 1+231.158761+29.83803
RES20D-50-201-1
  • 1+104.00400
  • 10+99.37080
  • 40+91.36800
  • 80+84.38040
