1N4744A
1N4744A
    TC(德昌)
    DO-41(DO-204AL)
    二极管配置:独立式 稳压值(标称值):15V 稳压值(范围):14.25V~15.75V 精度:±5% 功率:1W 反向电流(Ir):5uA@11.4V 阻抗(Zzt):14Ω 15V 1W
1N4744A 数据手册
® TAK CHEONG Li cens ed b y ON Semi condu cto r, A trade m ark of s emicon duc to r Compo ne n ts I ndustri es, LLC for Zene r T echnolo gy and P ro duct s. 1 Watt DO-41 Hermetically Sealed Glass Zener Voltage Regulators Maximum Ratings Rating Maximum Steady State Power Dissipation @TL≤50℃ , Lead Length = 3/8” D erate Above 50℃ Operating and Storage Temperature Range TJ, Tstg 6.67 -65 to +200 mW/℃ °C L 1N 47 xx A L 1N47xxA = Logo = Device Code Symbol PD Value 1 Units W Specification Features:         Zener Voltage Range = 3.3V to 100V ESD Rating of Class 3 (>6 KV) per Human Body Model DO-41 Package ( DO-204AL) D ouble Slug Type Construction Metallurgical Bonded Construction O xide Passivated Die R oHS Compliant Solder H ot Dip Tin (Sn) Lead Finish Cathode Anode Specification Features: Case Finish : D ouble slug type, hermetically sealed glass : All external surfaces are corrosion resistant and leads are readily solderable Polarity : C athode indicated by polarity band M ounting: Any Number: DB-070 Sep.2010 / F Page 1 1N4728A through 1N4764A Series ® TAK CHEONG ELECTRICAL CHARACTERISTICS (TA = 25℃ unless otherwise noted.) Z ener Voltage (Note 2 & 3.) Device (Note 1.) Device M arking M in 1N4728A 1N4729A 1N4730A 1N4731A 1N4732A 1N4733A 1N4734A 1N4735A 1N4736A 1N4737A 1N4738A 1N4739A 1N4740A 1N4741A 1N4742A 1N4743A 1N4744A 1N4745A 1N4746A 1N4747A 1N4748A 1N4749A 1N4750A 1N4751A 1N4752A 1N4753A 1N4754A 1N4755A 1N4756A 1N4758A 1N4759A 1N4761A 1N4763A 1N4764A 1N4728A 1N4729A 1N4730A 1N4731A 1N4732A 1N4733A 1N4734A 1N4735A 1N4736A 1N4737A 1N4738A 1N4739A 1N4740A 1N4741A 1N4742A 1N4743A 1N4744A 1N4745A 1N4746A 1N4747A 1N4748A 1N4749A 1N4750A 1N4751A 1N4752A 1N4753A 1N4754A 1N4755A 1N4756A 1N4758A 1N4759A 1N4761A 1N4763A 1N4764A 3.135 3.420 3.705 4.085 4.465 4.845 5.320 5.890 6.460 7.125 7.790 8.645 9.500 10.45 11.40 12.35 14.25 15.20 17.10 19.00 20.90 22.80 25.65 28.50 31.35 34.20 37.05 40.85 44.65 53.20 58.90 71.25 86.45 95.00 VZ (Volts) Nom 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 56 62 75 91 100 M ax 3.465 3.780 4.095 4.515 4.935 5.355 5.880 6.510 7.140 7.875 8.610 9.555 10.50 11.55 12.60 13.65 15.75 16.80 18.90 21.00 23.10 25.20 28.35 31.50 34.65 37.80 40.95 45.15 49.35 58.80 65.10 78.75 95.55 105.0 @IZT (mA) 76 69 64 58 53 49 45 41 37 34 31 28 25 23 21 19 17 15.5 14 12.5 11.5 10.5 9.5 8.5 7.5 7 6.5 6 5.5 4.5 4 3.3 2.8 2.5 Li cens ed b y ON Semi condu cto r, A trade m ark of s emicon duc to r Compo ne n ts I ndustri es, LLC for Zene r T echnolo gy and P ro duct s. Z ener Impedance (Note 4.) Z ZT @IZT (Ω ) 10 10 9 9 8 7 5 2 3.5 4 4.5 5 7 8 9 10 14 16 20 22 23 25 35 40 45 50 60 70 80 110 125 175 250 350 Z ZK @IZK (Ω ) 400 400 400 400 500 550 600 700 700 700 700 700 700 700 700 700 700 700 750 750 750 750 750 1000 1000 1000 1000 1500 1500 2000 2000 2000 3000 3000 (mA) 1 1 1 1 1 1 1 1 1 0.5 0.5 0.5 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 Leakage Current IR @ VR (uA M ax) 100 100 50 10 10 10 10 10 10 10 10 10 10 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 (Volts) 1 1 1 1 1 1 2 3 4 5 6 7 7.6 8.4 9.1 9.9 11.4 12.2 13.7 15.2 16.7 18.2 20.6 22.8 25.1 27.4 29.7 32.7 35.8 42.6 47.1 56.0 69.2 76.0 VF = 1.2V Max @IF = 200mA for 30V below types, VF = 2.0V Max @IF = 200mA for 30~56V types, and VF = 3.0V Max @IF = 200mA for 60V above types 1. TOLERANCE AND TYPE NUMBER DESIGNATION (V Z) The type numbers listed have a standard tolerance on the nominal zener voltage of ± 5%. 2. SPECIALS AVAILABLE INCLUDE N ominal zener voltages between the voltages shown and tighter voltage, for detailed information on price, availability and delivery, c ontact you nearest Tak Cheong representative. 3. ZENER VOLTAGE (V Z) MEASUREMENT The zener voltage (V Z) is tested under pulse condition. The measured V Z is guaranteed to be within specification with device junction in thermal equilibrium. 4. ZENER IMPEDANCE (Z Z) DERIVATION Number: DB-070 Sep.2010 / F Page 2 ® TAK CHEONG Li cens ed b y ON Semi condu cto r, A trade m ark of s emicon duc to r Compo ne n ts I ndustri es, LLC for Zene r T echnolo gy and P ro duct s. The zener impedance is derived from the 60 cycle AC voltage, which results when an AC current having an RMS value equal to 10% of the DC zener current (IZT or IZK) is superimposed on IZT or IZK. Package Outline Case Outline DO- 41 DIM Min M illimeters Max Min Inches Max A B C D 0.68 0.81 0.027 0.032 3.70 4.25 0.146 0.167 25.40 --- 1.000 --- 2.10 2.60 0.083 0.102 Number: DB-070 Sep.2010 / F Page 3 TAK CHEONG ® D ISC LA I MER NOTIC E NOTICE The information presented in this document is for reference only. Tak Cheong reserves the right to make changes without notice for the specification of the products displayed herein. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such improper use of sale. This publication supersedes & replaces all information reviously supplied. For additional information, please visit our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance. Number: DB-100 April 14, 2008 / A
1N4744A 价格&库存
很抱歉,暂时无法提供与“1N4744A”相匹配的价格&库存,您可以联系我们找货
