731201
731201
    HENGSTLER(亨士乐)
    HENGSTLER - 731201 - Totalizing Counter, 8 Digit, 12 VDC to 24 VDC, tico 731 Series
731201 数据手册
Flexible Counter Series in DIN size 24 x 48 mm tico 731 high contrast 8-digit LCD display or brilliant 6-digit LED display different supply voltages available: – independent of mains supply with lithium battery or – maintenance-free and environmentally friendly with 12-24 VDC supply also high-voltage input 12-250 VAC/VDC up to 8 different functions for each standard model: 01 Pulse counter 02 Tachometer (1/min) 03 Time counter (display in hhhh:mm:ss) 04 Time counter (display in hhhhhh,hh) 06 Bidirectional position indicator 07 Counter with differential mode OVERVIEW Standard Models Type 1 Type 2 Type 3 Type 4 Type 5 8-digit LCD Lithium battery 7 years 8-digit LCD Lithium battery 7 years x 8-digit LCD 12 – 24 VDC NV-FRAM > 10 years x 8-digit LCD 12 – 24 VDC NV-Fram > 10 years x 6-digit LED 12 – 24 VDC NV-Fram > 10 years x < 0.7 and > 5 V, max. 30 V DC < 0.7 and > 5 V, max. 30 V DC < 0.7 and > 5 V, max. 30 V DC < 0.7 and > 5 V, max. 30 V DC Counting frequency programmable Control inputs max. 7.5 kHz or 30 Hz attenuated Reset and Keylock max. 7.5 kHz or 30 Hz attenuated Reset Keylock Mounting depth external input 32 mm programmable 32 mm external input 60 mm max. 7.5 kHz or 30 Hz attenuated Reset and application input programmable 60 mm max. 7.5 kHz or 30 Hz attenuated Reset and application input programmable 60 mm x x x x x x x x x x x x x x x x x x x x x x Hardware Display Supply voltage Nominal data retention Active edge negative or positive edge programmable Amplitude thresholds Software Impulse counter Tachometer 1/min Time counter h : 1/100 h Time counter h : min : s Numerical display for PLC Position indicator bi directional Counter with differential mode Maintenance counter (on request) Components x < 3 V and > 12 V max. 250 V DC/AC 20 Hz Reset and Keylock x x x x ENCODERS COUN TER S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Technical data tico 731 TYPE 1 TECHNICAL DATA Operating temperature Strorage temperature Electrical connection Mounting Front panel cutout Protection class (IEC 144) Dynamic strength Shock stability General rating Pulse shape Input resistance Min. pulse length Display Supply voltage Ub Nominal data retention Inputs: Amplitude thresholds Active edge Counting frequency Control inputs: Reset Reset lock Counting frequency RESET: reset input with contact (negative, 30 Hz) KEYLOCK: locking of the reset key short case -10 ... 50 °C -20 ... +60 °C screw terminals, cable length < 30 m with clamping frame 45 + 0.6 x 22 + 0.3 mm front side IP 54, terminals IP 20 10 m/s2 (10 ... 150 Hz) according to IEC 68-T2-6 100 m/s2 (18 ms) according to IEC 68-T2-27 according to EN 61010-1, EN 50178, protective system II any square wave (1:1 for max. frequency) < 50 kOhm (static) 17 ms (30 Hz), 70 µs (7.5 kHz) 8-digit LCD, 7 mm internal lithium battery lithium battery: 7 years voltage input up to 7.5 kHz: < 0.7 V and > 5 V, max 30 V DC negative or positive edge programmable programmable: 7.5 kHz or 30 Hz (attenuated for contacts) - manual reset via keyboard (can be locked) - external reset with static behaviour, active edge negative attenuated 30 Hz via Keylock input, bridged to 0 V max. 7.5 kHz DIMENSIONS CONNECTION DIAGRAM Terminal assignment: tico 731 Clamping frame Dimensions in mm ORDER NUMBER Connecting terminal Model tico 731 0 731 1 0 1 * S * Option: with plug-in screw terminals Software function 01 impulse counter 02 tachometer (1/min) 03 time counter (hhhh:mm:ss) 04 time counter (hhhhhh.hh) Components ENCODERS C O U N TE R S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Totalizing Counters LCD display Lithium battery COUNT: programmable count input for voltage signal or contact, frequency 7.5 kHz or 30 Hz Technical data tico 731 TYPE 2 LCD display DC supply voltage 12 – 24 V DC COUNT: programmable count input for voltage signal or contact, frequency 7.5 kHz or 30 Hz TECHNICAL DATA Operating temperature Strorage temperature Electrical connection Mmounting Front panel cutout Protection class (IEC 144) Dynamic strength Shock stability General rating Pulse shape Input resistance Min. pulse length Display Supply voltage Ub Current consumption DC Nominal data retention RESET: reset input with contact (negative, 30 Hz) short case -10 ... 50 °C -20 ... +60 °C screw terminals with clamping frame 45 + 0.6 x 22 + 0.3 mm front side IP 54, terminals IP 20 10 m/s2 (10 ... 150 Hz) according to IEC 68-T2-6 100 m/s2 (18 ms) according to IEC 68-T2-27 according to EN 61010-1, EN 50178, protective system II any square wave (1:1 for max. frequency) < 50 kOhm (static) 17 ms (30 Hz), 70 µs (7.5 kHz) 8-digit LCD, 7 mm 12 ... 24 V DC* 12 ... 24 V DC < 5 mA nonvolatile memory > 10 years * Not to be connected to a DC-Network. For further information see manual. Inputs: Amplitude thresholds voltage input up to 7.5 kHz: < 0.7 V and > 5 V, max. 30 V DC negative or positive edge programmable programmable: 7.5 kHz or 30 Hz (attenuated for contacts) Active edge Counting frequency Control inputs: Reset - manual reset via keyboard (can be locked) - external reset with static behaviour, active edge negative attenuated 30 Hz programmable via front key max. 7.5 kHz, transmission rate for numerical display: 100 Hz Reset lock Counting frequency DIMENSIONS CONNECTION DIAGRAM Terminal assignment: tico 731 Clamping frame Dimensions in mm ORDER NUMBER Connecting terminal Model tico 731 0 731 2 0 1 * S * Option: with plug-in screw terminals Software function 01 impulse counter 02 tachometer (1/min) 03 time counter (hhhh:mm:ss) 04 time counter (hhhhhh.hh) Components ENCODERS COUN TER S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Technical data tico 731 TYPE 3 TECHNICAL DATA Operating temperature Storage temperature Electrical connection Mounting Front panel cutout Protection class (IEC 144) Dynamic strength Shock stability General rating Pulse shape Input resistance Min. pulse length Display Supply voltage Ub Current consumption DC Inputs: Amplitude thresholds RESET: reset input for voltage pulses 12-250 V AC/DC (20 Hz) KEYLOCK: locking of the reset key long case -10 ... 50 °C -20 ... +60 °C screw terminals, cable length < 30 m with clamping frame 45 + 0.6 x 22 + 0.3 mm front side IP 54, terminals IP 20 10 m/s2 (10 ... 150 Hz) according to IEC 68-T2-6 100 m/s2 (18 ms) according to IEC 68-T2-27 according to EN 61010-1, EN 50178, protective system II any square wave (1:1 for max. frequency) < 50 kOhm (static) 25 ms (20 Hz) 8-digit LCD, 7 mm internal lithium battery lithium battery: 7 years high voltage input 20 Hz: < 3 V and > 12 V, max. 250 V DC/AC voltage input positive edge 20 Hz Active edge Counting frequency Control inputs: Reset - manual reset via keyboard (can be locked) - external reset with static behaviour, positive circuit by means of bridge on the keylock input Reset lock DIMENSIONS CONNECTION DIAGRAM Terminal assignment: tico 731 Clamping frame Connecting terminal Dimensions in mm ORDER NUMBER Model tico 731 0 731 3 0 1 Software function 01 impulse counter 03 time counter (hhhh:mm:ss) 04 time counter (hhhhhh.hh) Components ENCODERS C O U N TE R S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Totalizing Counters LCD display Lithium battery COUNT: count input for voltage pulses 12-250 V AC/DC (20 Hz) Technical data tico 731 TYPE 4 LCD display 12-24 V DC supply voltage COUNT: programmable count input for voltage signal or contact, frequency 7.5 kHz or 30 Hz Operating temperature Strorage temperature Electrical connection Mounting Front panel cutout Protection class (IEC 144) Dynamic strength Shock stability General rating Pulse shape Input resistance Min. pulse length Display Supply voltage Ub Current consumption DC Nominal data retention TECHNICAL DATA INPUT 2: control input for temporary locking of count input (gate) or second count input with position indicator RESET: reset input OUT: transistor output for preset signal long case -10 ... 50 °C -20 ... +60 °C screw terminals, cable length < 30 m with clamping frame 45 + 0.6 x 22 + 0.3 mm front side IP 54, terminals IP 20 10 m/s2 (10 ... 150 Hz) according to IEC 68-T2-6 100 m/s2 (18 ms) according to IEC 68-T2-27 according to EN 61010-1, EN 50178, protective system II any square wave (1:1 for max. frequency) < 50 kOhm (static) 17 ms (30 Hz), 70 µs (7.5 kHz) 8-digit LCD, 7 mm 12 … 24 V DC* 12 … 24 V DC < 50 mA nonvolatile memory > 10 years * Not to be connected to a DC-Network. For further information see manual. Count input: Amplitude thresholds voltage input up to 7.5 kHz: < 0.7 V and > 5 V, max. 30 V DC negative or positive edge programmable programmable: 7.5 kHz or 30 Hz (attenuated for contacts) with position indicator 2 kHz: active edge positive Active edge Counting frequency Control inputs: Reset – manual reset via keyboard (can be locked) – external reset with static behaviour, 30 Hz attenuated same edge as with count input gate or second count channel; same edge as with count input programmable via front key PNP output voltage supply minus 2 V; max. 10 mA max. 7.5 kHz, transmission rate for numerical display: 1 kHz Input 2: Reset lock Transistor output signal Voltage/switching current Counting frequency This is a class A device. This device may cause radio interferences in residentialenviroments. In this case, the user may be asked to take care of reasonable action. DIMENSIONS CONNECTION DIAGRAM tico 731 Input 2 Tr. out 12-24 VDC 0V Terminal assignment: Count Reset INFORMATION Clamping frame Dimensions in mm Connecting terminal Model tico 731 ORDER NUMBER 0 731 Components 4 ENCODERS COUN TER S 0 1 Software function 01 impulse counter 02 tachometer (1/min) 03 time counter (hhhh:mm:ss) 04 time counter (hhhhhh.hh) 06 bidirectional position indicator CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Technical data LED display 12-24 V DC supply voltage COUNT: programmable count input for voltage signal or contact, frequency 7.5 kHz or 30 Hz TECHNICAL DATA Operating temperature Strorage temperature Electrical connection Mounting Front panel cutout Protection class (IEC 144) Dynamic strength Shock stability General rating Pulse shape Input resistance Min. pulse length Display Supply voltage Ub Current consumption DC Nominal data retention Count input: Amplitude thresholds INPUT 2: control input for temporary locking of count input (gate) or second count input with position indicator RESET: reset input OUT: transistor output for preset signal long case -10 ... 50 °C -20 ... +60 °C screw terminals with clamping frame 45 + 0.6 x 22 + 0.3 mm front side IP 54, terminals IP 20 10 m/s2 (10 ... 150 Hz) according to IEC 68-T2-6 100 m/s2 (18 ms) according to IEC 68-T2-27 according to EN 61010-1, EN 50178, protective system II any square wave (1:1 for max. frequency) < 50 kOhm (static) 17 ms (30 Hz), 70 µs (7,5 kHz) 6-digit LCD, 7 mm 12 … 24 V DC* 12 … 24 V DC < 50 mA nonvolatile memory > 10 years voltage input up to 7.5 kHz: < 0.7 V and > 5 V, max. 30 V DC negative or positive edge programmable programmable: 7.5 kHz or 30 Hz (attenuated for contacts) with position indicator 2 kHz Active edge Counting frequency * Not to be connected to a DC-Network. For further information see manual. Control inputs: Reset – manual reset via keyboard (can be locked) – external reset with static behaviour, same edge as count input Input 2: gate or second count channel Reset lock programmable via front key Transistor output signal PNP output Voltage/switching current supply minus 2 V; max. 10 mA Counting frequency max. 7.5 kHz, transmission rate for numerical display: 1 kHz DIMENSIONS CONNECTION DIAGRAM Input 2 Tr. out tico 731 Count Reset 12-24 VDC 0V Terminal assignment: Clamping frame Dimensions in mm ORDER NUMBER Components Connecting terminal Model tico 731 0 731 5 0 1 0 731 5 0 7 Software function 01 impulse counter 02 tachometer (1/min) 03 time counter (hhhh:mm:ss) 04 time counter (hhhhhh.hh) 06 bidirectional position indicator 07 counter with differential mode (1 kHz) ENCODERS C O U N TE R S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Totalizing Counters TYPE 5 tico 731 tico 731 Special functions SPECIAL FUNCTIONS To best match your application, you can order special functions such as prescaler value, decimal point and preset value, which are permanently set by us before delivery. With the variable prescaler value you can adapt to already existing transfer ratios of your application. Small resolutions can be shown with the decimal point, e. g. for the position indicator or the tachometer. A special feature is the possibility of displaying an information text in the display, e. g. for the surveillance of maintenance cycles. In this case the desired information is shown in the display after reaching the fixed preset value. You can display any text that can be created with the 7-segment alphabet, e. g. STOP, HELP, FILTER etc. ORDER NUMBERS SPECIAL VERSIONS ORDER NUMBERS SPECIAL VERSIONS Special functions for Impulse Tacho- Time Numerical Position Differential counter meter counter display indicator counter Prescaler value 0.000015 to 65535,99998 Decimal point 0 to 3 positions behind the comma Preset value 0 to 99 999 999 Information text (on reaching the preset value) LCD = 8 characters LED = 6 characters x x x x x x x x x x x x Choose version and basic function: Model tico 731 0 731 * 7 S * Option: with plug-in screw terminals only for standard model 1, 2 Function: 1 Impulse counter 2 Tachometer (1/min)1) 3 Time counter (hhhh:mm:ss) 4 Time counter (hhhhhh.hh) 6 Position indicator (2-channel)2) 7 Counter with differential mode3) Standard version: 1 Standard model 1 2 Standard model 2 3 Standard model 3 4 Standard model 4 5 Standard model 5 1) not available for standard type 3 2) not available for standard types 1, 2, 3 3) only available for standard type 5 Please state the desired special version on your order: P: (Value); Prescaler value: 0.000015 to 65535,999984) D: (Value); V: (Value); Decimal point: 0 to 3 positions after the dot4) Preset value: 0 to 99 999 9995) T: (Text); The information text displayed on reaching the preset value can be built up as required from the 7-segment alphabet 4) not available for time counters 5) not available for tachometers and position indicator Components ENCODERS COUN TER S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS
731201 价格&库存
很抱歉,暂时无法提供与“731201”相匹配的价格&库存,您可以联系我们找货
