3.520.003
3.520.003
    HENGSTLER(亨士乐)
    HENGSTLER - 3.520.003 - Coupling, Flexible, RI Series Rotary Encoders, 5/6 mm, 10000 rpm, 20 Ncm
3.520.003 数据手册
Accessories, Flexible Couplings Shaft encoders must be protected against excessive mechanical stresses, which occur whenever there are angular, axial, or radial misalignments between the machine and shaft encoder shafts. Our flexible couplings can compensate for this within limits. Plastic coupling Set screw Absolute max. speed Torque max. Moment of inertia Torsional spring constant Max. angular misalignment Max. shaft misalignment radial / axial Max. tightening torque of set screws Material Weight 10,000 RPM 20 Ncm 1.1 gcm2 25 Ncm/degree ± 2.5° ± 0.3 mm / ±0.2 mm 30 Ncm polyamide 6.6 glass-fibre reinforced 3.5 g approx. Dimensions in mm Hub diameter 5/5 mm 5/6 mm 6/6 mm Helical coupling Ordering code 3 520 034 Ordering code 3 520 033 Ordering code 1 761 026 Absolute max. speed Torque max. Moment of inertia Torsional spring constant Max. angular misalignment Max. shaft misalignment radial/axial Max. tightening torque of set screws Material Weight Suitable for encoder type RI 39 RI 32, RI 41, RI 42 6,000 RPM 80 Ncm 8.7 gcm2 14 Ncm/degree ± 4° ± 0.25 mm / ± 0.4 mm 80 Ncm AICuMgPb, chromed 16 g Dimensions in mm * applies for with * marked hub diameters Hub diameter 5/5 mm 5/6 mm 6/6 mm 6/6.35 mm 1)6/9.53 mm 1)6/10 mm 6.35/6.35 mm 1)6.35/9.52 mm 1)10/12 mm 1)10/10 mm 1) Ordering code 3 520 036 Ordering code 3 520 035 Ordering code 0 070 653 Ordering code 3 520 051 Ordering code 3 520 052 Ordering code 3 520 066 Ordering code 3 520 057 Ordering code 3 520 062 Ordering code 3 520 065 Ordering code 3 520 074 Suitable for encoder type RI 30, RI 32, RI 36, RI 41, RI 42, RI 58, RA 58 The dimensions marked with 1) apply for the dimensional drawings E N C O D E R S COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Shaft Encoders 2001 221 Flexible Couplings Absolute max. speed Torque max. Max. shaft misalignment Spring washer coupling 12,000 RPM 60 Ncm Radial Axial Angular ± 0.3 mm ± 0.4 mm ± 2.5° 50 Nm/rad Flanges Spring disc aluminium, surface-protected plastic, glassfibre-reinforced Torsional spring constant Material Dimensions in mm Hub diameter 5/6 mm 6/6 mm 6/10 mm 6/6.35 mm 6/9.53 mm 6.35/6.35 mm 7/7 mm 10/6.35 mm 10/10 mm Ordering code 3 520 080 Ordering code 3 520 081 Ordering code 3 520 082 Ordering code 3 520 083 Ordering code 3 520 084 Ordering code 3 520 085 Ordering code 3 520 086 Ordering code 3 520 087 Ordering code 3 520 088 Absolute max. speed Torque max. Moment of inertia Torsional spring constant Max. angular misalignment Max. shaft misalignment Flange-face coupling radial axial Max. tightening torque of set screws Hub diameter d and d1 Material coupling body, flange preloaded disc Weight Dimensions in mm 12,000 RPM 80 Ncm 19 gcm2 130 Ncm/degree ± 3.0° ± 0.3 mm ± 0.4 mm 80 Ncm 6 mm H 8 AICuMgPb, anodized aluminium CuSn6, stainless steel 14.5 g approx. Ordering code 0 070 663 Suitable for encoder type RI 36, RI 58, RA 58 Absolute max. speed Torque max. Moment of inertia Torsional spring constant Max. angular misalignment Max. shaft misalignment Bellows coupling radial axial Max. tightening torque of set screws Material flange bellows Weight 34 g Dimensions in mm Hub diameter 12/12 mm 10/10 mm 9.53/9.53 mm 6/6 mm 222 Shaft Encoders 2001 Ordering code 0 070 666 Ordering code 3 520 037 Ordering code 3 520 038 Ordering code 3 520 068 8,000 RPM 80 Ncm 22 gcm2 230 Ncm/degree ± 4.0° ± 0.3 mm ± 0.5 mm 150 Ncm CuZn39Pb3, nickel-plated CuZn20, nickel-plated Suitable for encoder type RI 58, RA 58 E N C O D E R S COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS
3.520.003 价格&库存
很抱歉,暂时无法提供与“3.520.003”相匹配的价格&库存,您可以联系我们找货
