774102
774102
    HENGSTLER(亨士乐)
    HENGSTLER - 774102 - Multifunction Counter, 6 Digit, 30 VDC, tico 774 Series
774102 数据手册
tico 772/773/774 Multifunctional counter tico 772/773/774 Universally applicable as a tachometer, timer, shift counter, batch counter … Easy to operate Four different backlight colours Intensity of backlighting can now be adjusted Large, clearly readable 48 x 48 mm display Input frequency up to 60 kHz Easy installation via plug-in terminals Three presets TECHNICAL DATA GENERAL Display LCD reflective, Transflective positive: black figures on backlit background Transmissive negative: white, red or green figures on backlit ground, 2 lines, 6-digit counter readings & presets; leading zero suppression, decimal point (up to 4 decimal places) Digit height 1st line 9.3 mm; 2nd line 7.2 mm Supply voltage SELV: 12-30 VDC; reverse polarity protected SELV: 24 VAC, 50/60 Hz ± 10% 115 VAC; 230 VAC, 50/60 Hz ± 10% 100-240 VAC 50/60 Hz ± 10% with switch-mode power supply Current consumption 12-30 VDC
774102 价格&库存
很抱歉,暂时无法提供与“774102”相匹配的价格&库存,您可以联系我们找货
