301511
301511
    HENGSTLER(亨士乐)
    HENGSTLER - 301511 - Stroke Counter, 5 Digit, 4.2 mm, Type 301 Series
301511 数据手册
surface-mounting flush-mounting Types 101/103 301/309 Totalizing Counters Revolutionor Stroke Counters without housing 4- or 5 digit display Without reset With or without case Miniature size CASE Counters in this series are available with surface-mounting case, with flush-mounting case or without any housing. TECHNICAL DATA Display Digit height Mounting Case Weight Counting mode Transmission ratio Max. speed Torque Reset DIMENSIONS Type 101/301 surface-mounting case 4 or 5-digit, depending on version 4.2 mm depending on version plastic (POM) black approx. 5 g, with case approx. 9 g Revolution counter: + (-) adding in the specified direction, subtracting in reverse direction. Stroke Counter: + is fixed, adding 1:1 or 1:10, depending on version Revolution counter: 1.000 rpm, at a transmission ratio of 1:10 max. 100 rpm. Stroke counter: max. 500 strokes/min., switching distance min. 46°, max. 49° Revolution counter: 0.05 Ncm, Stroke counter: 1.0 Ncm none Type 101/301 surface mounting case Type 101/301 without case 4 A 19.5 B 18.5 4 A 13.5 B 15.5 C 17.6 5 22.5 21.5 5 16.5 18.5 20.6 Dimensions in mm Components ENCODERS C O U N TE R S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Technical data Types 101/103 301/309 DIMENSIONS Typ 103/309 flush mounting case 4 digits 26 mm 5 digits 24 mm Dimensions in mm ORDER INFORMATION Revolution Counters Case Ratio 1:1 Surface flush 1:10 Surface flush Stroke Counter Case Surface flush without Number of digits 4 5 4 5 4 5 4 Number of digits 4 5 4 5 4 5 Actuation/sense of rotation Bz Bw Bz Bw 0 101 605 0 101 609 0 103 605 – 0 101 505 0 101 613 0 103 505 0 101 606* 0 101 610 0 103 606 – 0 101 506 0 101 614* 0 103 506 0 101 607 – 0 103 607 – 0 101 507 0 101 615* 0 103 507 0 101 608 – 0 103 608 – 0 101 508 0 101 616 0 103 508 Actuation/sense of rotation Bz Bw Bz Bw 0 301 505 0 301 509 0 309 505* 0 309 509 0 301 401* 0 301 405* 0 301 506 0 301 510 0 309 506* 0 309 510* 0 309 402 – 0 301 507 0 301 511 0 309 507* 0 309 511* – 0 301 407* 0 301 508 0 301 512 0 309 508* 0 309 512* – 0 301 408* Stroke lever 0 600 007 For further stroke levers see accessories * on request Inquire for other versions Components ENCODERS COUN TER S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS
301511 价格&库存
很抱歉,暂时无法提供与“301511”相匹配的价格&库存,您可以联系我们找货
