866165
866165
    HENGSTLER(亨士乐)
    HENGSTLER - 866165 - Totalizing Counter, 6 Digit, 4 mm, 24 VDC, Type 866 Series
866165 数据手册
Totalizing Counters tico 007 Types 864-868 for Front Panel Mounting Totalizing Counters 6 or 8-digit display with manual/electrical reset or without reset Simple installation Various front panel sizes Front panel 56 x 40 mm Front panel 55 x 28 mm TECHNICAL DATA Display Digit height Supply voltage Vop Power consumption Operating temperature Storage temperature Protection class (EN 60529) Vibrostability Shock stability General design Maintenance-free operation Duty cycle at 25 °C Weight Count input Pulse length min. Counting frequency max. Pulse duty factor Reset Components 6 or 8-digit, depending on version 4 mm according to order information, tolerance +– 10 % 230 VAC + 6–10 % DC counter: counter 2.5 W/VA, reset magnet 12 W/VA AC counter: counter 2.75 W/VA, reset magnet 16 W/VA - 10 . . . + 50 °C - 20 . . . + 70 °C front IP 40; connections IP 00 50 m/s2 acc. to IEC 068-2-6 600 m/s2 (6 ms) acc, to IEC 068-2-27 EN 61010-1, EN 50178; contamination level 2 VDE 0110 counter 2 x 107, reset magnet 1.5 x 106 pulses counter 100 %, reset magnet: DC 20 %, max. 2 min., AC 10 %, max. 1 min. approx. 90 g adding DC counter: counter 20 ms, reset magnet 200 ms AC counter: counter 50 ms, reset magnet 200 ms DC counter 25 Hz, reset magnet 1 per s AC counter 10 Hz, reset magnet 1 per 2 s counter 1:1, reset magnet: DC 1:5, AC 1:10 depending on version - manual with button or key - electric (version with reset magnet) - without reset ENCODERS C O U N TE R S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Types 864-868 Technical data CONNECTION DIAGRAM DIMENSIONS (Front panel 56 x 40 mm) (Front panel 55 x 28 mm) Dimensions in mm ORDER INFORMATION Counters for screw attachment (Front panel 56 x 40 mm) Voltage 6 digits Button reset w/o reset 8 digits w/o reset 24 VDC 24 VAC 115 VAC 230 VAC 0 864 165 0 864 186 0 864 189 0 864 190 0 866 165 0 866 186* 0 866 189 0 866 190 0 868 165 0 868 186* 0 868 189 0 868 190 Standard accessory Key reset system Counters for spring attachment (Front panel 55 x 28 mm) Ordering code + SR e.g. 0 864 165 SR Voltage 6 digits Button reset w/o reset 8 digits w/o reset 24 VDC 24 VAC 115 VAC 230 VAC 0 864 465 0 864 486* 0 864 489 0 864 490 0 866 465 0 866 486* 0 866 489* 0 866 490* 0 868 465 0 868 486* 0 868 489* 0 868 490 Standard accessory Key-reset system Ordering code + SR e.g. 0 864 165 SR * on request Further voltages available on request. Components ENCODERS COUN TER S CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS
866165 价格&库存
很抱歉,暂时无法提供与“866165”相匹配的价格&库存,您可以联系我们找货
