0.633.031
0.633.031
    HENGSTLER(亨士乐)
0.633.031 数据手册
Time Counter mini "h", AC Version Type 633-AC ■ ■ ■ ■ TECHNICAL DATA Miniature dimensions Low power consumption Quiet operation Protection class IP 65 Display Digit height Supply voltage Vop Power consumption Operating temperature Storage temperature Humidity El. connection Mounting Mounting position Protection class (DIN 4050) Vibrostability Shock stability General design Noise level Reset 6-digit, 0 ... 99999.9 h 4 mm, visual acc. to order information, tolerance + 10 % 24 V 0.08 VA, 115 V 0.56 VA, 220 V 1 VA - 10 ... + 50 °C - 25 ... + 70 °C 75 %, without condensation depending on version screw terminal connection for cables up to 2.5 mm2 or 250 mm long connecting cable, AWG 28 or AMP 2.8 x 0.8 mm with clamping frame horizontal figure wheel shaft Version .8: front IP 66, connections IP 40 (touchproof) 30 m/s2 (10 - 500 Hz) acc. to IEC 068-2-6 800 m/s2 (6 ms) acc. to IEC 068-2-27 acc. to DIN VDE 0700; insulation group C (VDE 0110), protection class II approx. 40 dB (distance 25 cm) none CONNECTION DIAGRAM VAC M 224 Components 2000 ENCODERS COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Technical data Type 633-AC DIMENSIONS Screw terminals Dimensions in mm Connecting cable Dimensions in mm AMP connector Dimensions in mm ORDER INFORMATION Voltage Screw terminals Connecting cable Counter 24 V 50 Hz 115 V 50 Hz 115 V 60 Hz 220 V 50 Hz 0 633 811 0 633 813 0 633 814 0 633 815 0 633 821 0 633 823 0 633 824 0 633 825 Other voltages on request Accessories Components 2000 panel frame 24x36 mm (insert dimensions 22 x 36 mm) Ordering code 1 405 674 ENCODERS COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS 225 Time Counters mini "h", DC Version Type 633.0 Type 633.7 ■ ■ ■ ■ ■ ■ ■ TECHNICAL DATA Type 633-DC Type 633.8 High shock resistance Miniature dimensions Low power consumption Electrical connections in standard grid Suitable for PCB mounting Machine-solderable and washable versions available Protection class IP 65 Display Digit height Supply voltage Vop Power consumption Residual ripple Operating temperature Storage temperature El. connection Mounting Mounting position Protection class (DIN 4050) Vibrostability Shock stability General design Weight Time error Reset 7-digit, 0 ... 99 999.99 h 4 mm, visual acc. to order information, tolerance + 10 % approx. 30 mW 3500 m/s2 acc. to IEC 068-2-27 acc. to DIN VDE 0700; insulation group C (VDE 0110), protection class II approx. 10 g with disable per switching cycle 0.488 ms none CONNECTION DIAGRAM Typ Type0633.0 0633.0 + 1 3 Type0633.7/0633.8 0633.7/0633.8 Typ 5 2 - + 1 2 Disable-Eingang Disable input + VDC Activation: Components 2000 0V 6 7 - Disable-Eingang Disable input + VDC 0V The counter is connected to 0 V and + VDC. The counter is switched off by connecting Pin 2 with Pin 7 or Pin 3. ENCODERS COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS 221 Technical data Type 633-DC DIMENSIONS Type 633.0 Dimensions in mm Type 633.7 Dimensions in mm Typ 633.8 Dimensions in mm ORDER INFORMATION Counter Accessories 222 Voltage Ohm Current consumption Type 633.0 during pulse Ord. code Type 633.7 Ord. code Type 633.8 Ord. code 5 VDC 12 VDC 24 VDC 140 720 1140 35 mA 17 mA 9 mA 0 633 731 0 633 732 0 633 733 0 633 831 0 633 832 0 633 833 1 634 008 1 634 007 1 634 008 1 634 007 Flying lead 150 mm red Flying lead 150 mm black Components 2000 ENCODERS COUNTERS 0 633 031 0 633 032 0 633 033 CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Miniature Time Counter Type 633-DC for 35 mm DIN Rail Attachment ■ ■ ■ ■ ■ TECHNICAL DATA Miniature size Low power consumption Screw terminal connection Suitable for switch cabinet installation Snap-on attachment for 35 mm DIN rail Display Digit height Supply voltage Vop Current consumption Residual ripple Operating temperature Storage temperature Protection class (DIN 4050) Vibrostability Shock stability General design Weight Time error Reset CONNECTION DIAGRAM DIMENSIONS 7-digit, 0 ... 99999.99 h 4 mm, visual acc. to order information, tolerance + 10 % during pulse voltage 35 mA 5 VDC 17 mA 12 VDC 9 mA 24 VDC 3500 m/s2 acc. to IEC 068-2-27 acc. to DIN VDE 0700; insulation group C (VDE 0110), protection class II approx. 40 g with disable 0.488 ms per switching cycle none connection without disable 1 = + VDC 2 = 0V with disable 1 = + VDC 4 = 0V 2 = disable Dimensions in mm ORDER INFORMATION Components 2000 Time counter for supply voltage 5 VDC Time counter for supply voltage 12 VDC Time counter for supply voltage 24 VDC 0 633 531 0 633 532 0 633 533 ENCODERS COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS 223
0.633.031 价格&库存
很抱歉,暂时无法提供与“0.633.031”相匹配的价格&库存,您可以联系我们找货
