0.886.264
0.886.264
    HENGSTLER(亨士乐)
0.886.264 数据手册
Type 886/887 Adding Preset Counters for Front Panel Mounting ■ ■ ■ ■ TECHNICAL DATA Preset value continuously visible Manual or electric reset 3 or 5-digit indication Various front panel sizes available Display 3 or 5-digit indication of count and preset value, depending on version Digit height 4 mm Supply voltage Vop see ordering code table, tolerance ± 10 % 230 VAC + 6–10 % Power consumption counter: DC version 2.5 W, AC version 2.75 VA reset solenoid: DC version 12 W, AC version 16 VA Residual ripple 48 % Operating temperature – 10 … + 50 °C Storage temperature – 40 … + 85 °C Electrical connection AMP connector, 0.8 x 2.8 mm Mounting screw or clamping spring attachment, see "Order information" Mounting position roller axis horizontal Protection class front IP 40; connections IP 00; for higher degree of (EN 60529) protection we recommend a protective case with clear cover (see "Accessories") General design DIN EN 61010-1 Protection according to class II Contamination level 2 Over voltage category II Duty cycle at 25 °C Counter 100 %, reset solenoid: DC version 20 %, max. 2 minutes, AC versions 10 %, max. 1 minute at 50 °C Counter 50 %, max. 10 minutes Maintenance-free operation Counter: 2 x 108, reset solenoid 1.5 x 106 pulses Approvals UL: E 41 784-11 Count input adding Min. pulse length DC version 20 ms, AC version 50 ms Max. counting frequency DC version 25 Hz, AC version 10 Hz Pulse duty factor 1:1 Reset – manual with button – external by electrical signal (versions with reset solenoid only), min. pulse length 200 ms (max. see duty cycle); Reset frequency DC version max. 1 per 2 s Pulse duty factor DC version 1:5, AC version 1:10 Signal output Signal duration Contact type Switching voltage Switching current 176 Components 2000 ENCODERS COUNTERS from when preset has been reached until reset changeover contact, floating max. 220 VAC max. 20 VA/1 A, non-inductive CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS Technical data Type 886/887 CONNECTION DIAGRAM DIMENSIONS Front panel 60 mm x 75 mm Front panel 55 mm x 53 mm ORDER INFORMATION Counters for screw attachment Front panel 60 mm x 75 mm COUNTERS FOR SPRING ATTACHMENT Front panel 55 mm x 53 mm 3 digits Voltage 24 VDC 230 VAC button reset 0 887 264 0 887 290 5 digits el. reset 0 887 214 0 887 240 3 digits Voltage 24 VDC 230 VAC button reset 0 887 464 – button reset el. reset 0 886 264 0 886 214 0 886 290 0 886 240 5 digits el. reset 0 887 414 button reset el. reset 0 886 464 0 886 414 0 886 490 0 886 440 Inquire for other voltages For key reset add ordering code + SR, e.g. 0 887 264 SR Components 2000 ENCODERS COUNTERS CONTROLLERS INDICATORS RELAYS PRINTERS CUTTERS 177
0.886.264
PDF文档中的物料型号为:MAX31855KASA+。
器件简介:MAX31855是一款冷结型K型热电偶数字转换器,能够提供高精度的热电偶温度测量。
引脚分配:包含VCC、GND、SO、CS、CLK、T-、T+、REF+、REF-。
参数特性:包括供电电压范围2.0V至5.5V,转换速率最多3次/秒,分辨率最高可达0.25°C。
功能详解:MAX31855通过SPI接口与微控制器通信,支持冷结补偿,具有诊断功能,如断线检测。
应用信息:适用于高精度温度测量,如工业过程控制、医疗设备等。
封装信息:采用28引脚TSSOP封装。
0.886.264 价格&库存
很抱歉,暂时无法提供与“0.886.264”相匹配的价格&库存,您可以联系我们找货
