HDGC1202WR-S-4P
HDGC1202WR-S-4P
    HDGC(华德共创)
    SMD,P=1.2mm,卧贴
    线对板针座 1x4P 卧贴 间距:1.2mm
HDGC1202WR-S-4P 数据手册
A B D C E F 修订 REV A0 标记 MARK 修改摘要 REVISION DESCRIPTION 日期 签名 DATE SIGNA TURE WANG NEW RELEEASE 2012-12-10 1 1 A Circuit 1 0.60 0.80 0.30 2 1.20 0.85 2 3 0.50 3.75 1.05 0.80 3 01 4 3D View Specification Voltage Rating : 50V AC/DC Current Rating : 2A AC/DC Withstanding Voltage : 500V AC /minute Insulation Resistance : ≥100MΩ min Temperature Range : -40℃ to + 105℃ Contact Resistance : ≤20mΩ After Environmental Testing: ≤40mΩ Suitable Wire/Cable:AWG #28 to #30,OD:0.8mm max 02 1.200 03 A±0.15 0.70 04 C±0.20 RECOMMENDED PCB LAYOUT GENERAL TOLERANCE ±0.05 2-3 Pin Without Sticking Point 5 10 1.40 0.20±0.05 08 6 06 1.20 05 B±0.25 4 5 12 4.30 6 Poles 02 0.10 09 0.20±0.05 07 7 Dimensions(mm) Poles A B C 03 1.20 4.20 2.64 Dimensions(mm) A B C 2.40 5.40 3.84 深 圳 市 华 德 共 创 科 技 有 限 公 司 7 Shenzhen Huade co-create Technology Co.,LTD TEL:0755-27129737 FAX:0755-29940187 -TOLERANCESUNLESS OTHERWISE SPECIFIED TITLE: 产品名称: MX1.2针座 XIE PART NO: 产品编号: HDGC1202WR-S-XP WANG DATE SCALE WANG 2012-12-10 1 1 公差参数表 8 A B C X.X ±0.30 X.X° ±3° X.XX ±0.30 X.XX° ±2° X.XXX ±0.10 X.XXX° ±1° D APPD: 核准: CHECK: 校对: DRAW: 绘图: E UNIT CODE NUMBER mm F A096 8 A B D C E F 修订 REV A0 标记 MARK 修改摘要 REVISION DESCRIPTION 日期 签名 DATE SIGNA TURE WANG NEW RELEEASE 2012-12-10 1 1 1.20 0.60 0.85 Circuit 1 0.33 A 0.80 2 02 1.200 3.75 3D View 0.23 01 3 0.50 0.80 1.05 2 03 3 A±0.15 C±0.20 04 0.70 4-5Pin Without Sticking Point RECOMMENDED PCB LAYOUT GENERAL TOLERANCE ±0.05 4 B±0.25 06 10 11 1.40 05 1.20 4 4.50 Specification Voltage Rating : 50V AC/DC Current Rating : 2A AC/DC Withstanding Voltage : 500V AC /minute Insulation Resistance : ≥100MΩ min Temperature Range : 40℃ to + 105℃ Contact Resistance : ≤20mΩ After Environmental Testing: ≤40mΩ Suitable Wire/Cable:AWG #28 to #30,OD:0.8mm max 0.10 09 5 0.20±0.05 07 0.20±0.05 08 0.624mm 6 6P With Sticking Point Scale 1:1 6 Dimensions(mm) Dimensions(mm) Poles Poles A B C A B C 04 3.60 6.60 5.04 08 8.40 11.40 9.84 05 4.80 7.80 6.24 09 9.60 12.60 11.04 06 6.00 9.00 7.44 10 10.80 13.80 12.24 07 7.20 10.20 8.64 7~10P With Sticking Point Scale 1:1 Furthermore be able to 11P,12P 7 5 深 圳 市 华 德 共 创 科 技 有 限 公 司 7 Shenzhen Huade co-create Technology Co.,LTD TEL:0755-27129737 FAX:0755-29940187 -TOLERANCESUNLESS OTHERWISE SPECIFIED TITLE: 产品名称: MX1.2针座 XIE PART NO: 产品编号: HDGC1202WR-S-XP WANG DATE SCALE WANG 2012-12-10 1 1 公差参数表 8 A B C X.X ±0.30 X.X° ±3° X.XX ±0.30 X.XX° ±2° X.XXX ±0.10 X.XXX° ±1° D APPD: 核准: CHECK: 校对: DRAW: 绘图: E UNIT CODE NUMBER mm F A096 8
HDGC1202WR-S-4P 价格&库存
很抱歉,暂时无法提供与“HDGC1202WR-S-4P”相匹配的价格&库存,您可以联系我们找货
