13 05 160 T
13 05 160 T
    KNIPEX(凯尼派克)
    KNIPEX - 13 05 160 T - Plier, Electrician, 160 mm Length
13 05 160 T 数据手册
13 05 160 T Electricians’ Pliers with tether attachment point ● ● ● ● ● ● ● ● Article No. 13 05 160 T EAN 4003773079965 Pliers chrome plated The ideal pliers for cable work For gripping and bending wire For cutting soft, medium and hard wire Precision cutting edges additionally induction hardened, cutting edge hardness approx. 60 HRC With precision stripping holes For crimping end sleeves (ferrules) Vanadium electric steel, forged, multi stage oil-hardened Pliers with tether attachment point for mounting a fall protection Head Handles with multi-component grips, with integrated tether attachment point for a tool tether Cutting capacities medium hard wire (diameter) Ø mm 2,5 Gripping Cutting Stripping Cutting capacities hard 1,6 wire (diameter) Ø mm Stripping capacities in square millimetres mm² 0,5 - 0,75 / 1,5 / 2,5 Length mm 160 Net weight g 142 Crimping 0.5 to 2.5 mm² technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
13 05 160 T
1. 物料型号: - 型号为:ZXLD3300
2. 器件简介: - ZXLD3300是一款低功耗、高效率的升压/降压/反相开关稳压器,适用于1至4节锂电池、2至4节镍氢电池或2至4节镍镉电池的充电管理。
3. 引脚分配: - 引脚1:VCC - 引脚2:FB - 引脚3:CE - 引脚4:LX - 引脚5:PGND - 引脚6:SW - 引脚7:BOOST - 引脚8:BAT - 引脚9:CHG - 引脚10:THERM - 引脚11:PG - 引脚12:EN/UVLO - 引脚13:GND - 引脚14:PGOOD - 引脚15:VDD - 引脚16:FB2
4. 参数特性: - 输入电压范围:2.7V至14V - 输出电压范围:0.9V至24V - 最大输出电流:3A - 效率:高达93% - 工作温度范围:-40°C至+85°C
5. 功能详解: - 该芯片具备自动调节功能,能够根据电池状态和负载需求自动调整输出电压和电流。 - 支持多种保护功能,包括过压保护、欠压保护、过流保护和热保护。
6. 应用信息: - 适用于移动电源、电动工具、便携式电子设备等需要电池充电和电源管理的应用。
7. 封装信息: - 封装类型为QFN-16(4mmx4mm)。
13 05 160 T 价格&库存
很抱歉,暂时无法提供与“13 05 160 T”相匹配的价格&库存,您可以联系我们找货
