64 02 115
64 02 115
    KNIPEX(凯尼派克)
    尖头(端部) 切割器 成角度,90° 4.50"(114.3mm)
64 02 115 数据手册
64 C A 64 Electronics End Cutting Nippers DIN ISO 9654 64 01 115 Style 0: End Cutter, with bevel 64 02 115 Style 0: End Cutter, with bevel 64 12 115 64 52 115 Style 1: End Cutter, with small bevel Style 5: Oblique End Cutter, short head, without bevel, for flush cutting, α = 27° 왘 precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics 왘 precision box joint 왘 low-friction double spring for gentle and even opening 왘 the polish or mirror polish (only finish 2) together with a fine film of oil offer the best possible rust protection - no circuit faults caused by peeling chrome from plated tools 왘 cutting edge hardness at least 56 HRC 왘 special tool steel, oil-hardened and tempered B D 64 12 115 C B D A 64 22 115 A C B 64 22 115 64 22 115 64 62 120 Style 2: End Cutter, mini-blade with small bevel Style 6: Oblique End Cutter, mini-blade with small bevel, α = 65° D 64 62 120 differently shaped jaws and miniblades for flush cutting in confined areas C 64 32/42/52 115 C 64 32 120 64 72 120 Style 3: Oblique End Cutter, short head, with small bevel, α = 15° Style 7: Oblique End Cutter, mini-blade with small bevel, head with recess, α = 35° ␣ ␣ B B D A D A 64 42 115 Style 4: Oblique End Cutter, short head, with small bevel, α = 27° Article-No. 9 EAN- 9 Style Length Code all pliers with mm 400377364 01 115 017745 0 64 02 115 035343 64 11 115 64 12 115 64 22 115 64 32 120 64 42 115 64 52 115 64 62 120 64 72 120 58 017769 040743 017806 017820 017844 040439 046998 017882 1 2 3 4 5 6 7 64 72 120 9 Head polished mirror polished polished mirror polished 64 72 120 9 Handles plastic coated with two-colour dual component handles plastic coated with two-colour dual component handles 64 62 120 9 Dimensions B A 9 Cutting capacities  D C mm 6.0 6.0 mm 11.0 11.0 mm 7.5 7.5 mm 16.0 16.0 ø mm 2.0 2.0 ø mm 1.0 1.0 ø mm g 0.6 80 0.6 90 6.0 6.0 20.0 10.0 10.3 10.0 18.5 19.5 11.0 11.0 10.0 11.0 10.0 10.0 9.5 12.0 7.0 7.0 6.0 7.0 7.0 7.0 6.0 7.0 16.0 16.0 3.0 17.0 12.0 12.0 5.0 5.0 1.4 2.0 0.8 1.5 1.5 1.3 0.6 1.5 0.8 0.8 1.0 1.0 - 0.5 0.5 0.5 - 80 90 70 90 70 70 70 90
64 02 115 价格&库存
很抱歉,暂时无法提供与“64 02 115”相匹配的价格&库存,您可以联系我们找货
