64 12 115
64 12 115
    KNIPEX(凯尼派克)
    尖头(端部) 切割器 成角度,90° 4.50"(114.3mm)
64 12 115 数据手册
64 12 115 Electronics End Cutting Nipper ● ● ● ● ● ● ● Article No. 64 12 115 EAN 4003773040743 Head mirror polished Handles with multi-component grips Style 1 Cutting capacities medium hard wire (diameter) Ø mm 0,8 Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Sturdy, zero backlash box joint Low-friction double spring for gentle and even opening The polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Cutting edges additionally induction hardened, cutting edge hardness at least 56 HRC High-grade special tool steel, forged, multi stage oil-hardened End Cutter, with small bevel Cutting capacities hard wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 1,4 B mm 6,0 D mm 7,0 C mm 16,0 A mm 11,0 Length mm 115 Net weight g 91 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
64 12 115 价格&库存
很抱歉,暂时无法提供与“64 12 115”相匹配的价格&库存,您可以联系我们找货
