64 52 115
64 52 115
    KNIPEX(凯尼派克)
    尖头(倾斜) 切割器 成角度,27° 4.50"(114.3mm)
64 52 115 数据手册
64 52 115 Electronics End Cutting Nipper ● ● ● ● ● ● Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Sturdy, zero backlash box joint Low-friction double spring for gentle and even opening The polish or mirror polish (only finish 2) together with a fine film of oil offer effective rust protection - no circuit faults caused by peeling chrome from plated tools Cutting edges additionally induction hardened, cutting edge hardness at least 56 HRC High-grade special tool steel, forged, multi stage oil-hardened Style:Oblique End Cutter, short head, without bevel, for flush cutting, a = 27° ❍ Article No. 64 52 115 EAN 4003773040439 Head mirror polished Handles with multi-component grips Style 5 Cutting capacities soft wire (diameter) Ø mm 1,3 B mm 10,0 D mm 7,0 C mm 12,0 A mm 10,5 Dimensions angle ° 27 Length mm 115 Net weight g 69 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
64 52 115 价格&库存
很抱歉,暂时无法提供与“64 52 115”相匹配的价格&库存,您可以联系我们找货
