73 05 160
73 05 160
    KNIPEX(凯尼派克)
    KNIPEX - 73 05 160 - Cutter, Compact, Diagonal, 160 mm, Edge, 4.8 mm
73 05 160 数据手册
73 05 160 KNIPEX X-Cut® Compact Diagonal Cutter high lever transmission ● ● ● ● ● ● ● ● ● ● ● Powerful, light and universal Cuts finest strands as well as multi-core cables and piano wires Box-joint design: highest stability with low weight High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio 40% less force required compared with standard diagonal cutters of the same length Large opening width for thicker cables Cuts precisely, even through fine copper wires Compact, low-weight construction Doubly supported joint axis for heaviest duty Universally usable, in the assembly, maintenance and production Chrome vanadium heavy-duty steel, forged, multi stage oil-hardened 40% less force required compared with standard diagonal cutters of the same length with double mounted hinged joint Article No. 73 05 160 EAN 4003773075134 Head Pliers chrome plated Handles with multi-component grips Cutting capacities medium hard wire (diameter) Ø mm 3,8 Cutting capacities hard 2,7 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 2,2 Cutting capacity copper cable, multiple12,0 stranded (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 4,8 Length mm 160 Length mm 160 Net weight g 175 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
73 05 160 价格&库存
很抱歉,暂时无法提供与“73 05 160”相匹配的价格&库存,您可以联系我们找货
