73 72 180
73 72 180
    KNIPEX(凯尼派克)
    KNIPEX - 73 72 180 - Cable Cutter, Diagonal, Twinforce High Performance, 180mm Length
73 72 180 数据手册
73 72 180 KNIPEX TwinForce® High Performance Diagonal Cutters ● ● ● ● ● ● ● ● The superior High-Leverage Diagonal Cutter with patented double joint Ideal transmission of force due to double-hinged design Reliably cuts all types of wire, including steel tape For rough or very fine cutting Low cutting impact: gentle on hands. The tension on muscles and tendons is relieved For comfortable cutting, repetitive cutting or extremely hard cutting jobs High degree of stability and zero-backlash due to precisely milled forged-in axles Chrome vanadium heavy-duty steel, forged, oil-hardened Extremely easy cutting with little strain: cuts again 50 % easier than the tried and tested KNIPEX high leverage diagonal cutters New for diagonal cutters: The option to reapply the tool. The KNIPEX TwinForce® cuts even 4 mm thick wire without great effort when reapplied two or three times. Conventional high leverage diagonal cutters either cannot cut these diameters or only with very great effort. Article No. 73 72 180 EAN 4003773074779 Pliers black atramentized Head polished Handles with multi-component grips Cutting capacities medium hard wire (diameter) Ø mm 4,6 Cutting capacities hard 3,2 wire (diameter) Ø mm Cutting capacities piano wire (diameter) Ø mm 3,0 Cutting capacities soft wire (diameter) Ø mm 5,5 Length mm 180 Net weight g 280 The high performance diagonal cutters with opening spring for easier reapplication and for heavy use The opening spring can be easily activated and deactivated by a press of the thumb Insert the wires as close to the hinge as possible. In case of cutters with very high transmission, the width of the gap between the First make a notch in the wire using the KNIPEX TwinForce® until the required hand force increases considerably. Now open technical change and errors excepted Continue cutting in the same location along the wire. Now cutting is much more easier because the wire remains in place closer KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 cutting edges close to the fulcrum may be less than the thickness of the wire. Wires may slip forward when the cutting starts. the pliers and slide the to the fulcrum. wire backwards towards the joint. Hold the cutting edge in the notches you have made in step 1. You can repeat this process if necessary. KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
73 72 180 价格&库存
很抱歉,暂时无法提供与“73 72 180”相匹配的价格&库存,您可以联系我们找货
