95 16 165
95 16 165
    KNIPEX(凯尼派克)
    KNIPEX - 95 16 165 - Cable Cutter, 50mm² Capacity, Chrome Plated, Dual-Component Grips, 165mm Length
95 16 165 数据手册
95 16 165 Cable Shears ● ● ● ● ● ● ● ● Article No. 95 16 165 EAN 4003773039648 Tool chrome plated Handles insulated with multicomponent grips, VDEtested Style 1 Insulation standard IEC 60900 DIN EN 60900 Cutting capacity copper cable, multiple15 stranded (diameter) Ø mm For cutting copper and aluminium single conductors as well as multiple stranded cables Not suitable for steel wire and hard drawn copper conductors Precision ground, hardened blades Clean and smooth cut without crushing and deformation Easy cutting with one-hand operation Guard prevents operators’ fingers being pinched Adjustable bolted joint, self-retaining screw High-grade special tool steel, forged, oil-hardened Cut performed with a Diagonal Cutter: high effort required, inaccurate cut, considerable deforming and crushing of the cable Cut performed with a Cable Shear: easy, clean cut without any deformation of the cable Cutting capacity copper cable, multiple- 50 stranded mm² AWG 1/0 Length mm 165 Net weight g 262 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
95 16 165 价格&库存
很抱歉,暂时无法提供与“95 16 165”相匹配的价格&库存,您可以联系我们找货
