00 21 41
00 21 41
    KNIPEX(凯尼派克)
    KNIPEX - 00 21 41 - Tool Kit, Electrical, Big Twin Move Series, 65 Piece - Tool Kit, Electrical, Big...
00 21 41 数据手册
00 21 41 Tool Case "BIG Twin Move" Electric 65-part ● ● ● ● ● ● ● ● ● Article No. 00 21 41 EAN 4003773082118 Net weight g 12675 Equipped with 65 brand name quality tools, some VDE-tested according to DIN EN 60900 Hard-wearing ABS hard-shell construction with aluminium frame and circular buffer protection Pull-out handle embedded in the base and two integrated smooth inline skater runners Can be opened on one or both sides; bottom tray and cover can be opened independently Stands stable in any opening position due to lid-holders and hinge mechanisms on both sides, that register in a position of 45° and 90° 3-digit lock and two flip-locks for fixation of the cover Removable document compartment and removable tool panel with 13 tool pouches Base tray, height 60 mm, can be subdivided by flexible inserts; tool panel as cover plate with 13 tool pouches Dimensions, external (W x H x D): 510 x 270 x 410 mm, dimensions, interior (W x H x D): 480/445 x (105 + 105) x 370/330 mm technical change and errors excepted Content 00 21 41 (21) Article No. Quantity Nominal size 00 11 01 Knipex KNIPEX TwinKey®, for all standard cabinets and shut-off systems 08 26 145 Knipex Needle-Nose Combination Pliers 1 12 42 195 Knipex KNIPEX MultiStrip 10, Automatic Insulation Stripper 1 13 86 200 Knipex Pliers for Electrical Installation 1 16 95 01 SB Knipex KNIPEX ErgoStrip , Universal Stripping Tool 1 26 26 200 Knipex Snipe Nose Side Cutting Pliers, (Stork Beak Pliers) 1 200 mm 70 06 160 Knipex Diagonal Cutter 1 160 mm 74 06 200 Knipex High Leverage Diagonal Cutter 1 200 mm 86 03 180 Knipex Pliers Wrench, pliers and a wrench in a single tool 1 180 mm 87 01 180 Knipex KNIPEX Cobra , Hightech Water 1 Pump Pliers 180 mm 97 53 04 Knipex Self-Adjusting Crimping Pliers for End Sleeves (ferrules), with lateral access 1 98 52 Knipex Cable Knife 1 185 mm Knipex Screwdriver (Slim) for crossrecessed screws, Pozidriv® 1 PZ1 Knipex Screwdriver (Slim) for slotted screws 1 3,5 x 100 mm 05003484001 Wera 16-part set of VDE interchangeable blades, slim 1 004018 Wera 8100 SA 8 Zyklop set of metal ratchets, 28 parts 1 1/4" 003760 Wera Joker open-end wrench 1 10 x 13 mm 3003010119 Picard Locksmith’s hammer 1 300 g 361 252 1 Rennsteig Electrician’s Chisel 1 250 x 10 mm 16135 Stabila Model 70 Electric spirit level 1 430 mm 18115 Stabila Pocket Electric mini spirit level 1 68 mm 98 25 01 SL 98 20 35 SL ® 1 ® KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 Spare Parts Article No. EAN 00 21 41 LE 4003773071549 Tool Case "BIG Twin-Move" with integrated rollers and telescopic handle 00 21 99 V04 4003773080732 Replacement telescopic handle for "BIG Twin-Move" KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
00 21 41 价格&库存
很抱歉,暂时无法提供与“00 21 41”相匹配的价格&库存,您可以联系我们找货
