14 22 160
14 22 160
    KNIPEX(凯尼派克)
    工具 单层剥除器,可调 用于 13 ~ 15 AWG
14 22 160 数据手册
14 22 160 Diagonal Insulation Stripper ● ● ● ● ● ● ● Article No. 14 22 160 EAN 4003773034988 Head polished Handles with multi-component grips Pliers black atramentized Cutting capacities medium hard wire (diameter) Ø mm 1,5 Cutting capacities soft wire (diameter) Ø mm 2,5 Stripping capacities in square millimetres mm² 1,5 + 2,5 AWG 15 + 13 Length mm 160 Net weight g 206 With long cutter High cutting capacity due to high leverage joint Precision stripping holes for single conductors of 1.5 and 2.5 mm² Convenient cutting of NYM cables up to 5 x 2.5 mm² Long tips for ultra fine cutting work also in confined areas Induction hardened precision blades, cutting edge hardness approx. 60 HRC Vanadium electric steel, forged, multi stage oil-hardened technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
14 22 160 价格&库存
很抱歉,暂时无法提供与“14 22 160”相匹配的价格&库存,您可以联系我们找货
