48 41 J31
48 41 J31
    KNIPEX(凯尼派克)
    KNIPEX - 48 41 J31 - Plier, Circlip, 100 mm Jaw Opening Max, 210 mm, Grey Atramentised
48 41 J31 数据手册
Product information 48 41 J31 ● Heavy duty in continuous operation: up to 10 times longer service life compared to turned tips ● With inserted tips for reliable work ● ● ● ● ● Precision Circlip Pliers For internal circlips in bore holes DIN 5256 D ● ● ● ● ● Bolted joint: precise, zero backlash operation of pliers Non-slip plastic coating on the handles With overexpansion guard (adjustable using end stop) Adjustment using hexagonal screw Ideal for series production as excessive expansion of rings is effectively prevented 90° angled tips With overstretching limiter for standardized assembly in accordance with DIN 472 The adjustable stop screw prevents the rings from overstretching Inserted tips: spring steel wire, drawn Pliers body: chrome vanadium electric steel, forged, oil-hardened General Article No. 48 41 J31 EAN 4003773079590 Pliers grey atramentized Handles with non-slip plastic coating weight 265 g Dimensions 210 x 45 x 13 mm Standard DIN 5256 D Technische Attribute Style 4 Size of bore Ø 40 – 100 mm Tips (diameter) Ø 2.3 mm Classification eCl@ss 5.1.4 21040301 ETIM 5.0 EC002228 ETIM 6.0 EC002228 proficl@ss 6.0 AAC470c002 UNSPSC 13.1 27112140 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 1
48 41 J31
- 物料型号:4841J31 - 器件简介:KNIPEX精密内圈钳,德国制造,适用于DIN 5256 D标准内圈。 - 引脚分配:文档中未明确提及引脚分配信息。 - 参数特性: - 适用孔径:040-100 mm - 钳口直径:2.3 mm - 重量:265g - 尺寸:210x45x13 mm - 标准:DIN 5256D - 功能详解:重型设计,适用于连续操作,具有长寿命;配有插入式尖端,可进行可靠工作;螺栓连接,确保钳子操作精确无回弹;手柄有防滑塑料涂层;具有过扩张保护(可通过端止调节);调整使用六角螺丝;90°角尖端;具有过拉伸限制器,符合DIN 472标准;可调节的止动螺丝防止环过度拉伸;插入式尖端:弹簧钢丝,拉伸;钳身:铬钒电力钢,锻造,油淬火。 - 应用信息:适用于系列生产,有效防止环过度扩张。 - 封装信息:灰色涂层,带有防滑塑料手柄。
48 41 J31 价格&库存
很抱歉,暂时无法提供与“48 41 J31”相匹配的价格&库存,您可以联系我们找货
