49 31 A3
Precision Circlip Pliers for external circlips on shafts
with overstretching limiter
With inserted tips for reliable work
Heavy duty in continuous operation: up to 10 times longer service life
compared to turned tips
Large contact faces on the tips: no distortion of circlips, easy fitting
Bolted joint: precise, zero backlash operation of pliers
Internal opening spring, protected and captive
Non-slip plastic coating on the handles
Pliers body: chrome vanadium electric steel, forged, oil-hardened
Inserted tips: spring steel wire, drawn
Style:DIN 5254 A; straight tips
Style:with overstretching limiter for standardized assembly in
accordance with DIN 471
Style:the adjustable stop screw prevents the rings from
overstretching
With overexpansion guard (adjustable using end stop)
Adjustment using hexagonal screw
Ideal for series production as excessive expansion of rings is
effectively prevented
High precision quality
Easy and reliable assembly: form-fitting inserted and pressed-in tips made of high-density spring steel offer a high level of protection against
excessive stress and strain, e.g. when removing stuck rings. The large supporting surfaces and the position of the tips make it more difficult for the
rings to bounce off.
Precision and durability
High-density spring steel with a score-free surface is used for the tips. This increases the tips' resistance to dynamic and static strain. The tips are
30 % more stable than conventional pliers when subjected to one-off overloading while still allowing good accessibility during assembly. Subjected
to dynamic strain, the tips' resistance capacity is up to 10 times greater! The tips on the precision circlip pliers are non-detachable!
KNIPEX circlip pliers with overexpansion guard
For the standardized fitting of circlips in the industrial serial production. Particularly manufacturers of sensitive, safety-relevant components (e.g.
brakes or gears) highly appreciate the compliance of DIN 471 and 472. The mounting of circlip rings in this case requires pliers with overexpansion
guard or a cone. KNIPEX Circlip Pliers with overexpansion guard meet the requirements and furthermore offer a superior durability.
Article No.
49 31 A3
EAN
4003773073918
Pliers
grey atramentized
Handles
with non-slip plastic
coating
Style
3
Size of shaft Ø mm
40 - 100
Tips (diameter) Ø mm
2,3
Length mm
225
Net weight g
270
Style 3 / Style 4: with
adjustable opening
restriction
Spring inside the joint:
the spring is protected
inside the precisely
bolted joint. It does not
hinder work and cannot
get dirty or lost.
Tight fit through
compression
technical change and errors excepted
KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany
info@knipex.de | www.knipex.de
1
很抱歉,暂时无法提供与“49 31 A3”相匹配的价格&库存,您可以联系我们找货
