70 02 160
70 02 160
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 6.25"(158.8mm)
70 02 160 数据手册
70 02 160 Diagonal Cutter ● ● ● ● ● ● ● ● Article No. 70 02 160 EAN 4003773034032 Head polished Handles with multi-component grips Style 0 Pliers black atramentized Cutting capacities medium hard wire (diameter) Ø mm 3,0 The indispensable diagonal cutter for all-round use High-quality material and precise workmanship for long service life Precision cutting edges for soft and hard wire Clean cutting of thin copper wires, also at the cutting-edge tips Cutting edges additionally induction hardened, cutting edge hardness approx. 62 HRC Narrow head style for use in confined areas Vanadium electric steel, forged, multi stage oil-hardened With elongated cutting edge Cutting capacities hard 2,0 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 4,0 Nominal size 160 mm Length mm 160 Net weight g 206 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
70 02 160 价格&库存
很抱歉,暂时无法提供与“70 02 160”相匹配的价格&库存,您可以联系我们找货
