71 72 610
71 72 610
    KNIPEX(凯尼派克)
    KNIPEX - 71 72 610 - Bolt Cutter, 9 mm, 610 mm
71 72 610 数据手册
Product information 71 72 610 Cuts hard components up to 48 HRC ● Cutting capacity up to 48 HRC hardness ● Robust cutting edges are additionally induction-hardened, cutting edge hardness approx. 62 HRC ● Forged-in stopper with comfortable shock- absorber ● Good access due to very flat construction of head and joint area ● Ergonomically angled handles to minimise effort ● Sturdy non-slip two-colour dual component handle sleeves ● Precise adjustment (12 positions) by eccentric bolt ● High cutting performance with minimum effort due to optimum coordination of the cutting edge angle and transmission ratio ● Bolted cutter head, replaceable ● Joint: special tool steel, forged ● Handles: steel tube, powder-coated ● Blade: chrome vanadium heavy-duty steel, forged, multi stage oilhardened Bolt Cutter General Article No. 71 72 610 EAN 4003773066767 Head grey atramentized Handles with multi-component grips weight 2,600 g Dimensions 610 x 130 x 34 mm Technische Attribute HRC 19 Ø 9 mm HRC 48 Ø 7 mm HRC 40 Ø 8 mm Cutting edge length mm 34 mm Head thickness 33 mm Classification eCl@ss 5.1.4 21040302 ETIM 5.0 EC002689 ETIM 6.0 EC002689 proficl@ss 6.0 AAC440c002 UNSPSC 13.1 27111512 technical change and errors excepted KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 1 2 KNIPEX Werk - C. Gustav Putsch KG - 42337 Wuppertal 09.03.2020 | page 2 2
71 72 610 价格&库存
很抱歉,暂时无法提供与“71 72 610”相匹配的价格&库存,您可以联系我们找货
