79 02 125 ESD
79 02 125 ESD
    KNIPEX(凯尼派克)
    侧面(对角) 切割器 椭圆形 成斜角 5.00"(127.0mm)
79 02 125 ESD 数据手册
79 02 125 ESD Precision Electronics Side Cutter ESD ● ● ● ● ● ● ● ● ● ● Electrically discharging handles - dissipative Precision pliers for ultra fine cutting work, e. g. in electronics and fine mechanics Very precisely ground and sharp cutting edges with very small bevels for exact cutting on delicate electronic components; also available without bevel for flush cutting Cutting edges additionally induction hardened, cutting edge hardness approx. 64 HRC Approx. 20% lighter than conventional electronics pliers Bolted joint with carefully manufactured joint surfaces for even, lowfriction movement throughout the entire opening range Smooth-running double spring for a gentle and even opening Ergonomically optimised multi-component handles Ball bearing chrome steel, forged, multi stage oil-hardened Round head The subtle difference KNIPEX precision electronics pliers are made of high-quality ball bearing steel and processed with the highest degree of care. Each opening movement is gentle and even without backlash. Each work step proceeds reliably and precisely. This makes work much easier for professionals. ESD pliers (electrostatic discharge) electrostatic energy is discharged through the handles in a gradual and controlled manner which protects components endangered by electrostatic discharge in accordance with applicable standards, e.g. IEC TR 61 340-5, DIN EN 61 340-5, SP Method 2472 Article No. 79 02 125 ESD EAN 4003773061519 Pliers burnished Head polished Handles with multi-component grips Style 0 Cutting capacities medium hard wire (diameter) Ø mm 1,3 Cutting capacities hard 0,7 wire (diameter) Ø mm Cutting capacities soft wire (diameter) Ø mm 0,2 - 1,7 B mm 10 D mm 6,5 A mm 11 Nominal size 125 mm Length mm 125 Net weight g 61 technical change and errors excepted KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 2
79 02 125 ESD
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作温度范围为-20℃至+70℃,隔离电压可达5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP6封装形式。
79 02 125 ESD 价格&库存
很抱歉,暂时无法提供与“79 02 125 ESD”相匹配的价格&库存,您可以联系我们找货
