86 05 150
86 05 150
    KNIPEX(凯尼派克)
    KNIPEX - 86 05 150 - 150mm Mini Pliers Wrench with Two-colour Dual Component Handles
86 05 150 数据手册
86 05 150 Mini Pliers Wrench pliers and a wrench in a single tool ● ● ● ● ● ● ● ● ● ● ● ● ● ● Replaces the need for sets of metric and imperial spanners Smooth jaws for damage free installation of plated fittings - working directly on chrome! Adjustable tightening tool Also excellent for gripping, holding, pressing and bending workpieces Push the button for adjustment on the workpiece Zero backlash jaw pressure prevents damage to edges of sensitive components Parallel jaws give a more solid grip; its design allows flexible adjustment of all widths up to the specified maximum size Reliable catching of the hinge bolt: no unintentional shifting The ratchet type principle allows quick and easy tightening and release of all bolted connections Lever transmission greater than 10 : 1 for strong gripping power Chrome vanadium electric steel, forged, oil-hardened The mini pliers wrench for precision mechanics Ideal multi-purpose wrench in pocket size Indispensable companion in emergency tool kit The smooth jaws grip all parallel surfaces in the capacity range with a high degree of pressure if necessary and open up almost unlimited application possibilities for the pliers wrench: e.g. for tightening locknuts, exerting pressure to activate the adhesive power of contact adhesives, edge breaking in tile work, snapping cable ties, utilisation as a small vice. Article No. 86 05 150 EAN 4003773069928 Pliers chrome plated Handles with multi-component grips B2 mm 7,0 B3 mm 10,5 B1 mm 4,7 Adjustment positions 14 Capacities for nuts Inch 1 Pliers wrench: zero backlash contact pressure, no damage to edges Conventional open end wrench: edge pressure causes surface damage Capacities for nuts mm 27 Length mm 150 Net weight g 193 technical change and errors excepted Spare Parts Article No. EAN 86 09 150 4003773073123 Range of spare parts adjustment for 86 150 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
86 05 150 价格&库存
很抱歉,暂时无法提供与“86 05 150”相匹配的价格&库存,您可以联系我们找货
