94 10 185
94 10 185
    KNIPEX(凯尼派克)
    KNIPEX - 94 10 185 - Cutter, Plastic Pipe, 6-35mm Pipe Diameter, 185mm Length
94 10 185 数据手册
94 10 185 Pipe Cutter for plastic conduit pipes (electrical installation work) ● ● ● ● ● ● ● Article No. 94 10 185 EAN 4003773047025 Body die-cast aluminium body, red lacquered Capacity (diameter) Ø mm 6,0 - 35,0 Cutting edge length mm mm 35 Cutting capacities (diameter) Ø mm 6,0 - 35,0 Length mm 185 Net weight g 583 For clean cutting of plastic pipes (e.g. plastic conduit pipes) with 6.0 35.0 mm dia. Not suitable for cutting cables Blade is replaceable and can be retracted from any position Low force requirement due to special blade geometry and optimum transmission Minimum operator fatigue due to ergonomic handle design and incremental ratchet blade feed Housing: die-cast aluminium, red lacquered Blade: special tool steel, oil-hardened technical change and errors excepted Spare Parts Article No. EAN 94 19 185 4003773047032 Spare blade for 94 10 185 for plastic conduit pipes 94 19 185 02 4003773053804 Torsion spring for 94 10 185 KNIPEX-Werk C. Gustav Putsch KG | Oberkamper Straße 13 | 42349 Wuppertal | Germany info@knipex.de | www.knipex.de 1
94 10 185 价格&库存
很抱歉,暂时无法提供与“94 10 185”相匹配的价格&库存,您可以联系我们找货
